HBL6023
HBL6023
    HUBBELL(哈伯尔公司)
HBL6023 数据手册
Twist-Lock® Devices Twist-Lock® Devices Accessories for 15 Ampere 2 and 3 Wire Plugs, Connector Bodies and Flanged Devices IP55* SUITABILITY Seal-Tite®, Weatherproof, Triple Seal Boots for 15A Insulgrip® Devices Description Black elastomer boot for plugs when used in a cord set and connector bodies when used with a flange inlet. Same as above except yellow elastomer. Catalog Numbers HBL6023 Black elastomer boot for connector bodies when used in cord sets. Same as above except yellow elastomer. HBL6024 HBL60CM24 HBL6023 HBL60CM23 Note: * When installed and used properly with plug and connector body combinations. HBL6024 Closure Cover Description For use with 3 wire 15A Twist-Lock flush or flanged receptacles. Catalog Numbers HBL7529 PLUGOUT® Lockout Devices Description Lockout device for 15A and 20A straight blade plugs. Lockout device for attachable 20 and 30A plugs, straight body or angle types, with or without weatherproof covers. Catalog Numbers HLDMP HLD HBL7529 Note: See section U for more information on PLUGOUT Lockout Devices. 3.14" (79.8) 4.22" (107.2) HLDMP 4.27" (108.5) 7.27" (184.7) Accessories HLD Dimensions in Inches (mm) www.hubbell-wiring.com B-49
HBL6023 价格&库存
很抱歉,暂时无法提供与“HBL6023”相匹配的价格&库存,您可以联系我们找货
