HBL6031
HBL6031
    HUBBELL(哈伯尔公司)
HBL6031 数据手册
Twist-Lock® Devices Accessories for 20 and 30 Ampere, 3 Wire Plugs and Connector Bodies IP55* Insulgrip® SUITABILITY Weatherproof, Seal-Tite®, Triple Seal Boots Description Catalog Number Black elastomer boot for plugs when used in a cord set and connector bodies when used in flanged inlets. HBL6031 Same as above except yellow. HBL60CM31 Black elastomer boot for connector bodies when used in a cord set. HBL6032 Same as above except yellow. HBL60CM32 HBL6031 Angle Adapter Description Catalog Number Nylon, angle adapter for Insulgrip plugs and connector bodies, cord grip range .325"-.930" (8.3-24). HBL3WAA HBL6032 PLUGOUT® Lockout Devices Description Catalog Number Lockout device for attachable 20 and 30A locking plugs, straight body or angle types, with or without weatherproof covers. HLD Lockout device for 20 and 30A 3 wire angle plugs and watertight Safety-Shroud® Twist-Lock® plugs. HLD2 Note: See section Z for additional information on PLUGOUT Lockout devices. *When installed and used properly with plug and connector body combinations. HBL3WAA Insulgrip® Plug and Connector Body Latching Kit The Hubbell latching kit provides both improved safety and security through a double locking feature that makes unintentional disconnection virtually impossible – even under high vibration situations. The plug and connector body lock once when first connected, then again when you push the special position locking slide into place. Insulgrip® Latching Kit Description Catalog Number For all 3 wire 20A and 30A Twist-Lock Insulgrip plugs and connectors. SK2 Valise® SK2 IP55* SUITABILITY Weatherproof, Seal-Tite®, Triple Seal Boots Description Catalog Number Yellow Seal-Tite® elastomer triple seal cover for use with Valise plugs when used in cord set and Valise connector bodies when used with flanged inlet. HBL60CM31V Yellow Seal-Tite® elastomer triple seal cover for use with Valise connector bodies. HBL60CM32V HBL60CM31V Note: *When installed and used properly with plug and connector body combinations. HBL60CM32V www.hubbell-wiring.com ® Wiring Device-Kellems B-51
HBL6031 价格&库存
很抱歉,暂时无法提供与“HBL6031”相匹配的价格&库存,您可以联系我们找货
HBL6031
    • 1+294.42001
    • 5+290.17116
    • 10+285.29748
    库存:157
