Wire Management Products
Cord and Cable Reels
Industrial Power Cord Reels
Features
Durable, Corrosion Resistant Cast Aluminum Construction
UL Type 1
Multi-Position Guide Arm can be mounted in two different positions
Positive Latch mechanism automatically maintains desired cord
length
Ratchet Lock can be disengaged in field for constant tension
applications
Ordering Information
Description
White Industrial Reel with
Yellow Portable Outlet Box
and (1) 20A Duplex
Receptacle, UL Type 1, 45
Ft, #12/3 SJO, 20 A, 250
VAC
UPC
783585669205
Catalog Number
HBLI45123R20
Listings
cULus Listed
Specifications
Spool
Guide Frame
Cord
Internal Terminals
Ball Stopper
Fitting
Aluminum
Thermoplastic
Copper
Copper Alloy
Thermoplastic
Aluminum
Complementary Products
Pivot Base
Mounting Bracket
Ball Stop
Performance
Electrical
Amperage
Max. Working Voltage
Number of Wires
Environmental
Moisture Resistance
20 A
250V AC
3-Wire
Dry, Indoor, Non-Hazardous Locations - UL
Type 1
Online Resources
Customer Sales Drawing
eCatalog
Installation Instructions
Dimensions in Inches (mm)
Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484
Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice.
HBLI340PB
HBLIMB
HBLI12BS
很抱歉,暂时无法提供与“HBLI45123R20”相匹配的价格&库存,您可以联系我们找货
