Switch-Rated IEC Pin and Sleeve
60A 3 Phase 480V, 3 Pole, 4 Wire
Watertight Connector Body
Features
Mates with existing installed base of IEC 60309-2 pin and sleeve devices
Approved as a disconnecting means for motor circuits and branch circuits
UL Type 4X, 12 and IP69k environmental ratings
Impact and corrosion-resistant PBT that is color coded by voltage.
Unswitched ground and power indicating LED lights
Ordering Information
Description
Watertight IEC Pin and Sleeve
Connector Body
UPC
783585478593
Catalog Number
HBLS460C7W
Listings
UL Listed, File E146033
CSA Certified File LR280C
UL Classified to IEC 60309-1 IEC 60309-2
Specifications
Housing
Cord Clamps
Glands
Covers
Gaskets
PBT
PBT
Solid Neoprene
PBT
Santoprene
Performance
Electrical
Current Interrupting
Dielectric Voltage
Max. Working Voltage
Mechanical
Impact Resistance
Product Identification
Terminal Identification
Environmental
Flammability
Ingress Protection
Moisture Resistance
Operating Temperatures
Certified for current interrupting at full rated
current
Withstand 3000V AC
600V RMS
Per CSA C22.2 No. 182.1 / UL1682
Identification and ratings are a permanent part of
the device housing
Terminals identified in accordance with North
American and IEC conventions
V-0
TYPE 3R,3RX,4X AND IP68,IP69K
IEC 60309-1
Maximum Continuous 75°C; Minimum - 40°C
w/o impact
Dimensions in Inches (mm)
Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484
Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice.
很抱歉,暂时无法提供与“HBLS460C7W”相匹配的价格&库存,您可以联系我们找货
