073031203
073031203
    HUBBELL(哈伯尔公司)
073031203 数据手册
Dustight Strain Relief Grips Aluminum Fittings, Galvanized Steel Mesh, for Insulated Cables Non-Insulated Wide Range Strain Relief Cable Diameter Range Inches (cm.) .24”-.32” (.61-.81) .32”-.43” (.81-1.09) .43”-.54” (1.09-1.37) .54”-.73” (1.37-1.85) .73”-.97” (1.85-2.46) .97”-1.25” (2.46-3.17) .73”-.97” (1.85-2.46) Thread Size N.P.T. (Inches) 1/2” 1/2” 1/2” 3/4” 1” 11/4” PG29 Mesh Length @ Nom. Dia. Inches (cm) 31/4” (8.25) 33/4” (9.52) 43/4” (12.06) 61/2” (16.51) 7” (17.78) 9” 7” (22.86) (17.78) Catalog Numbers 073031200 073031201 073031202 073031203 073031204 Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-68 through T-74. Wire Management Products Strain Relief 073031205 073PG291204 Insulated Wide Range Strain Relief with Insulating Bushing Cable Diameter Range In. (cm.) .24”-.32” (.61-.81) .32”-.43” (.81-1.09) .43”-.54” (1.09-1.37) .54”-.73” (1.37-1.85) .73”-.97” (1.85-2.46) .97”-1.25” (2.46-3.17) 1.25”-1.50” (3.17-3.81) 1.50”-1.70” (3.81-4.32) 1.70”-2.00” (4.32-5.08) 2.00”-2.45” (5.08-6.22) Mesh Thread Length @ Size Nom. Dia. Dim. Inches Inches(cm) A In.(cm) 1/2” N.P.S. 31/4” (8.25) 1” (2.54) 1/2” N.P.S. 33/4” (9.52) 1” (2.54) 1/2” N.P.S. 43/4” (12.06) 1” (2.54) 3/4” N.P.S. 61/2” (16.51) 1” (2.54) 1” N.P.S. 7” (17.78) 13 /16” (3.02) 11/4” N.P.S. 9” (22.86) 13 /16” (3.02) 11/2” N.P.T. 113 /4” (29.84) 13 /16” (3.02) 2” N.P.T. 131/4” (33.65) 13 /8” (3.49) 21/2” N.P.T. 131/2” (34.29) 11/2” (3.81) 21/2” N.P.T. 133/4” (34.92) 11/2” (3.81) Min. Space Between Grips Catalog B In.(cm) Numbers 11/4” (3.17) 073031206 11/4” (3.17) 073031207 11/4” (3.17) 073031208 11/2” (3.81) 073031209 13/4” (4.44) 073031210 21/4” (5.71) 073031211 21/2” (6.35) 073031212 31/4” (8.25) 073031213 35 /8” (9.21) 073031214 35 /8” (9.21) 073031215 Non-Insulated A Insulated Strain Relief Grips Dimensions in Inches (mm) www.hubbell-wiring.com T-67
073031203 价格&库存
很抱歉,暂时无法提供与“073031203”相匹配的价格&库存,您可以联系我们找货
