AFR20TRBK
AFR20TRBK
    HUBBELL(哈伯尔公司)
    HUBBELL WIRING DEVICES - AFR20TRBK - CONN, MAINS SOCKET, 20A, 120V, BLACK
AFR20TRBK 数据手册
Hubbell Arc Fault Receptacles For Commercial and Residential Applications ® Wiring Device-Kellems Meets the Latest National Electric Code Requirements for Arc Fault Circuit Interruption Helps to Protect Against Electrical Fires Originating from Arcing Faults! TR Where is AFCI Protection Required by the NEC?  Bedroom  Living Room  Library  Sunroom  Family Room  Closet  Laundry Areas  Rec Room  Dining Room  Parlor  Kitchen  Den Why is it Needed? Yearly Electrical Incidents What are Typical Causes of Arc Faults? • • • • • Damaged Wiring • Pinched Cord • Broken Plugs • Overheating • Loose Connections • Aged/Worn Conductors > 47,000 Fires > 400 Deaths > 1,600 Injuries > $1.4B in Damages Housing Hotel University Dorm www.hubbell-wiring.com Healthcare Facility Residential Hubbell Arc Fault Receptacles ® Wiring Device-Kellems For Commercial and Residential Applications ORDERING INFORMATION Description Color 15 Amp 20 Amp Outlet Branch Circuit Arc Fault Receptacle with Tamper-Resistant Outlets 20A 125V Feed Through and LED Indicator Black Brown Gray Ivory Light Almond White Ivory White AFR15TRBK AFR15TR AFR15TRGY AFR15TRI AFR15TRLA AFR15TRW — — AFR20TRBK AFR20TR AFR20TRGY AFR20TRI AFR20TRLA AFR20TRW AFR20BFI AFR20BFW Outlet Branch Circuit AFCI Blank Face - LED Indicator NATIONAL ELECTRIC CODE 2011 NEC 210.12(A) “Where required all 15A or 20A 120V branch circuits in dwelling units that supply outlets to family rooms, dining rooms, living rooms, parlors, libraries, dens, bedrooms, sunrooms, recreation rooms, closets, hallways or similar areas must be protected by a listed AFCI device of the combination type.” There are (2) exceptions noted below: (1) AFCI can be branch circuit type located at the first outlet if circuit conductors installed in RMC, IMC, EMT or Type MC or steel armored Type AC cable and AFCI device is contained in a metal outlet or box. (2) Where a listed metal or nonmetallic conduit or tubing is encased in not less than 2 inches of concrete for the portion of the branch circuit between the branch-circuit overcurrent device and the first outlet, an outlet branch-circuit AFCI at the first outlet is permitted to provide protection for the remaining portion of the branch circuit. (B) Branch circuit extensions or modifications – dwelling units. Where branch-circuit wiring is modified, replaced, or extended in any of the areas specified in 210.12(A), the branch circuit must be protected by a listed combination AFCI located at the origin of the branch circuit; or a a listed outlet branch circuit AFCI located at the first receptacle outlet of the existing branch circuit” 2014 NEC 406.4(D) “Requirements for replacement receptacles where a receptacle outlet is supplied by a branch circuit that requires arc-fault circuit interrupter protection [210.12(A)], a replacement receptacle at this outlet must be one of the following: (1) A listed outlet branch circuit type arc-fault circuit interrupter receptacle; (2) A receptacle protected by a listed outlet branch circuit code arc-fault circuit interrupter code receptacle; (3) A receptacle protected by a listed combination type arc-fault circuit interrupter type circuit breaker.” SPECIFICATIONS Ratings Amperage Feed-thru Voltage Horsepower Flammability Operating Temperature Certifications Construction UL 1699A E366570 Termination UL 498 Receptacle Terminal UL Fed Spec WC-596 Grounding CSA Standard C22.2 No. 42 Indicators CSA Tech Letter No. M-02A Configuration NEMA WD-6 NEMA  Tamper Resistant TR NEC 406.11; 210.52 – All 15 & 20A 125V, Receptacles shall be listed Tamper-Resistant for dwelling installations. 15 Amp/20 Amp 20 Amp Protection 120V AC (+10% to15%) (102V to 132V) (1) @ Rated Voltage Rated V2 per UL 94 (-35°C to 66°C) or (-30°F to 150°F) Back and Side #14-10 AWG Self-Grounding Clip Power & Rev Wire 2 Pole, 3 Wire 5-15R, 5-20R The Hubbell “AFR” series meets all requirements for an outlet branch-circuit type AFCI; protects branch circuit wiring and extensions to branches such including appliances and cord sets. DIMENSIONS 1.31" (33.3) 15 Amp 1.29" (32.8) 1.29" (32.8) 4.21" (106.9) 3.81" (96.8) 3.28" (83.3) 1.31" (33.3) 20 Amp 1.29" (32.8) 2.60" (66.0) 3.28" (83.3) 1.07" (27.2) 1.68" (42.7) 4.21" (106.9) 3.81" (96.8) 1.35" (34.3) 2.60" (66.0) 1.07" (27.2) 1.43" (36.3) 1.07" (27.2) 1.68" (42.7) 1.35" (34.3) ® Wiring Device-Kellems www.hubbell-wiring.com Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 • Phone (800) 288-6000 • FAX (800) 255-1031 Printed in U.S.A. Specifications subject to change without notice. WLFSB003 3/14
AFR20TRBK 价格&库存
很抱歉,暂时无法提供与“AFR20TRBK”相匹配的价格&库存,您可以联系我们找货
