CS8269
CS8269
    HUBBELL(哈伯尔公司)
CS8269 数据手册
Industrial Weatherproof Covers Features - Specifications Rugged die-cast aluminum construction with gray epoxy finish provides excellent corrosion resistance Self-closing lift lid cover with heavy-duty stainless steel spring assures maximum weatherproof protection UL Listed, wet, damp and dry locations with cover closed All weatherproof covers are furnished complete with nickel-plated brass mounting screws, (except catalog numbers 23007 and 7770 furnished with stainless steel mounting screws). F.S. and F.D. box mounting INDUSTRIAL, CAST ALUMINUM OUTDOOR PLATES, VERTICAL, F.S. MOUNTING CATALOG NUMBER 4510B APPLICATION 4510B 4510D 7418B 7420B 7427B 7429B 7770 23007 20405 Duplex receptacle opening GFI/Fashion NEMA 1.3" (33.0) x 2.6" (66.0) opening 1.40" (35.6) dia. opening, 15 and 20 amp single receptacle 1.62" (41.1) dia. opening, 20 and 30 amp locking receptacle 2.15" (54.6) dia. opening, 30 and 50 amp, 3-wire power receptacles 2.31" (58.7) dia. opening for “MBWP” inlets 50 amp standard locking receptacles 20 amp power interrupting, locking receptacles 30 amp power interrupting, locking receptacles HORIZONTAL F.S. AND DEVICE MOUNTING 4510D 5210B 5211B Duplex receptacle, device mounted Duplex receptacle, F.S. mounting INDUSTRIAL, POLYCARBONATE OUTDOOR PLATE, VERTICAL, F.S. MOUNTING 7774CR 50 amp “CS” or standard locking receptacles RECOMMENDED WEATHER PROTECTIVE COVERS 7420B 556 5261 5251 5661 5361 5351 5461 4710 4760 7582 7310 8210 7418B 8310 7250 5284 5258 5684 5384 5484 5261IG 5361IG 7535 70615FR 70520FR 70620FR 70720FR 70820FR 70920FR 70530FR 70630FR 70730FR 70830FR 70930FR 71020FR 71120FR 71220FR 71030FR 71130FR PRODUCT DIMENSIONS – ( 7420B 71230FR 71330FR 71420FR 71520FR 71620FR 71430FR 71530FR 71630FR 71730FR 71820FR 71920FR 72020FR 71830FR 71930FR 72030FR 72120FR 72220FR 72320FR 72130FR 72230FR 72330FR 3330 3430 3520 7410 40045FR FSL1FR FSL2FR FSL3FR FSL4FR 7427B 9530FR 9630FR 9303 9306 9550FR 9650FR 7770/7774CR 3771 7379 3769 6369CR 6370CR 7774CR CS6369 CS6370 CS8169 CS8269 CS8369 CS8469 CS6369N CS6370N CS8169N CS8269N CS8369N CS8469N ) Indicates mm dimensions .86 (21.8) 2.81 (71.4) 23007 1.88 (47.8) 4.67 (118.6) 3.25 (82.6) 7770 I 18 FRONT Catalog Numbers 23007 and 7770 have lacquer finish. “CS” 50 amp locking receptacles require this cover. Outline drawing is shown on page I-19. SIDE BACK See page I-19 for additional information on Weather Protective Inlet & Outlet Covers. Specifications are subject to change without notice.
CS8269 价格&库存
很抱歉,暂时无法提供与“CS8269”相匹配的价格&库存,您可以联系我们找货
