CS8275
CS8275
    HUBBELL(哈伯尔公司)
CS8275 数据手册
50 Amp Twist-Lock® Devices 50 Amp Twist-Lock® Devices 50A Twist-Lock® Devices Hubbell’s 50 Amp Twist-Lock® Devices feature a heavy-duty design and super-tough nylon housing built for heavy-duty applications and impact resistance, even in the harshest environments. Their rigid construction restricts contact distortion, minimizing the possibility of mating dissimilar devices. The cord grip’s offset gripping jaws securely hold the conductors and the cord jacket for excellent strain relief. » Support secure, reliable, superior terminations with Hubbell’s box terminals » Ensure durability with solid, stainless steel shrouds on plugs » Achieve high heat resistance on receptacles and inlets with thermoset interior components Ideal for: Construction Temporary Power Welding Data Centers Ordering Information 50A Twist-Lock® Devices Description Plugs Cord Diameter Rating Catalog Number .830"-1.250" (21.08-31.75) 50A 50A 50A 50A 50A 50A 125V AC 250V AC 480V AC 125/250V AC 3Ø 250V AC 3Ø 480V AC CS6361C CS8265C CS8465C CS6365C CS8365C CS8165C Nylon housing, thermoplastic polyester interior .830"-1.250" (21.08-31.75) 50A 50A 50A 50A 50A 50A 125V AC 250V AC 480V AC 125/250V AC 3Ø 250V AC 3Ø 480V AC CS6360C CS8264C CS8464C CS6364C CS8364C CS8164C Insulgrip® connector with conduit adapter; capable of accepting metallic or non-metallic conduit fittings ½” NPT size ¾” NPT size 1” NPT size 50A 3Ø 250V AC CS8364CA05 CS8364CA34 CS8364CA10 — 50A 50A 50A 50A 50A 50A 125V AC 250V AC 480V AC 125/250V AC 3Ø 250V AC 3Ø 480V AC CS6377 CS8275 CS8475† CS6375 CS8375 CS8175 — 50A 50A 50A 50A 50A 50A 125V AC 250V AC 480V AC 125/250V AC 3Ø 250V AC 3Ø 480V AC CS6370 CS8269 CS8469† CS6369 CS8369 CS8169 Nylon housing, thermoplastic polyester interior Connector body Flanged inlet Receptacle Zinc plated steel casing, thermoset interior Black phenolic Not CSA certified. † hubbell.com/wiringdevice-kellems/en Plug Connector Flanged Inlet Receptacle Plug HBL® Series 50A Twist-Lock® Devices Description Cord Diameter Rating Plugs Nylon housing, thermoplastic polyester interior .830"-1.250" (21.08-31.75) 50A 250V DC 50A 600V AC HBL3763C HBL3765C HBL7765C Connector body Nylon housing, thermoplastic polyester interior .830"-1.250" (21.08-31.75) 50A 250V DC 50A 600V AC HBL3762C HBL3764C HBL7764C Zinc plated steel casing, thermoset interior — 50A 250V DC 50A 600V AC HBL3777 HBL3775 HBL7958 Zinc plated steel casing, thermoset interior with lift cover — 50A 250V DC 50A 600V AC HBL3767 HBL3768 HBL7968 Black phenolic — 50A 250V DC 50A 600V AC HBL3771 HBL3769 HBL7379 Flanged inlet Receptacle Connector Flanged Inlet with Lift Cover Female configuration shown. Accessories Receptacle Accessories for FS/FD Box Mounting Description Weatherproof receptacle lift cover plates Receptacle plates Catalog Number Gray Yellow Corrosion resistant thermoplastic HBL7774WO HBL77CM74WO HBL7770 Cast aluminum Cast aluminum; for use with HBL® Series 50A Twist-Lock devices with lift cover no lift cover Stainless steel single gang wallplate HBL7382* HBL7383 SS750 *Not UL Listed “WDL Closed” | IP20 suitability  Receptacle ½” Raised Cover Description Catalog Number Galvanized steel; fits 4” square or 2-gang box HBL50SC  IP20 suitability Conduit Adapters Description NPT Thread Size Thermoplastic housing for use with CS style 50A Twist-Lock® devices ½” ¾” 1” Catalog Number CS50CA05 CS50CA34 CS50CA10 Weatherproof Boots Description Seal-Tite® triple seal black elastomeric cover † Catalog Number for plugs when used with cord sets and for connector bodies when used with flanged inlets HBL7716C† for connector bodies when used with cord sets HBL7717C† Not UL Listed Inlet Closure Plug Description Catalog Number Black closure plug HBL4892† † Not UL Listed Replacement Parts Description Catalog Number Cord clamp kit HBLCSCK 50 Amp Twist-Lock® Devices Related Products Spider ® Temporary Power Distribution Boxes Rating 50A 120/240V AC (Maximum) 50A 120/240V AC (Maximum) Type Qty Straight Blade Twist-Lock® Twist-Lock® (Inlet) Twist-Lock® (Outlet) Twist-Lock® Twist-Lock® Twist-Lock® (Inlet) Twist-Lock® (Outlet) 6 1 1 1 6 1 1 1 Receptacle Rating 20A, 125V 30A, 250V 50A, 125/250V 50A, 125/250V 20A, 125V 30A, 250V 50A, 125/250V 50A, 125/250V Catalog Number TPDS TPDL Temporary Power Cables Rating Cable Type 50A 125/250V 6/3, 8/1 Length (ft) 50 100 Catalog Number TPC50 TPC100 Temporary Power Receptacle Description Rating Catalog Number Pre-wired wall mount receptacle with 3R enclosure and 2' wire leads 50A 125/250V SR50 Hubbell Product Literature Circuit-Lock® Motor Disconnects Wiring Device-Kellems IEC Pin and Sleeve Devices Watertight Wiring Devices hubbell.com/wiringdevice-kellems/en Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 • Phone (800) 288-6000 • FAX (800) 255-1031 Printed in U.S.A. Specifications subject to change without notice. ® is a registered trademark of Hubbell Incorporated. WLBL004 5/20
CS8275 价格&库存
很抱歉,暂时无法提供与“CS8275”相匹配的价格&库存,您可以联系我们找货
