HBL13R92
HBL13R92
    HUBBELL(哈伯尔公司)
    HUBBELL WIRING DEVICES - HBL13R92 - SW DISCONNECTOR, 2P, 30A, 600VAC, SMD
HBL13R92 数据手册
Switched Disconnects and Enclosures ® Circuit-Lock 2-Pole NEMA 3R Enclosures with Switch, 30A Features All aluminum cover and base Metal Type 3R enclosure Ideal for use on outdoor equipment Surface mount control Ordering Information Description HBL7832D in HBL13R90 metal Type 3R enclosure, Ideal for use in outdoor environments UPC Number 783585680989 Catalog Number HBL13R92 Listings UL 508 CSA-C22.2 No.14 Specifications Enclosure Material Aluminum Performance Electrical Dielectric Voltage Electrical Life Max. Working Voltage Short Circuit Current Ratings (SCCR): (Motor Disconnect) Mechanical Mechanical Life Terminal Accommodations Wire Type Environmental Flammability Operating Temperature 2,200V AC minimum for 1 minute Min. 6,000 Cycles at rated switch load 600V AC RMS 60A max. when protected by J fuses 10,000 minimum cycles #10 AWG Max. Solid and stranded copper wire only Online Resources UL94HB/VO Max. Continous: 75°C; Min. Continuous: -40°C without impact Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. Customer Use Drawing eCatalog Installation Instructions
HBL13R92 价格&库存
很抱歉,暂时无法提供与“HBL13R92”相匹配的价格&库存,您可以联系我们找货
