Twist-Lock® Devices
20 Ampere, 125, 250 Volts and 277 Volts AC
2 Pole, 3 Wire Grounding
W
X
G
W
G
G
Y
20A 125V
NEMA L5-20R
UL/CSA
1 HP
Connector Bodies
Watertight Safety-Shroud®
20A 250V
NEMA L6-20R
UL/CSA
2 HP
IP66 SUITABILITY
Description
Cord Dia.
Catalog Number
Black Valox® housing,
white Valox® clamps.
.360"-.930"
(9-24)
HBL2313SW
Insulgrip®
20A 277V AC
NEMA L7-20R
UL/CSA
2 HP
UL Type 4x, 12
HBL2323SW
IP20
HBL2333SW
2.56"
(65.0)
4.38"
(111.1)
SUITABILITY
Description
Cord Dia.
Catalog Number
Black and white nylon.
.360"-.930"
(9-24)
HBL2313
HBL2323
Corrosion resistant,
yellow nylon.
.360"-.930"
(9-24)
HBL23CM13
HBL23CM23
All black nylon.
.360"-.930"
(9-24)
HBL2313BK
HBL2323BK
Cord clamps with removable
inserts. All black nylon.
.360"-.930"
(9-24)
HBL2313EBK
HBL2323EBK
HBL2323SW
HBL2333
3.86"
(98.0)
2.26"
(57.4)
1.97"
(50.0)
HBL2313
Note: See page B-51 for accessories.
2.60"
(66.0)
Valise®
IP20
SUITABILITY
Description
Cord Dia.
Catalog Number
Yellow nylon.
.325"-.720"
(8.26-18.3)
HBL2313VY
HBL2323VY
Black nylon.
.325"-.720"
(8.26-18.3)
HBL2313VBK
HBL2323VBK
1.78"
(45.2)
HBL2333VBK
HBL2313VY
2.69"
(68.3)
Receptacles
Description
Gray
Valox®
IP66 SUITABILITY
UL Type 4x, 12
3.75"
(95.3)
Catalog Number
housing and flange, back wired.
HBL2310SW
HBL2320SW
HBL2330SW
Note: See page B-54 for accessories.
Safety-Shroud® Twist-Lock®
IP20
3.75"
(95.3)
SUITABILITY
Description
Catalog Number
Gray Valox® angle housing, one gang, back wired.
HBL2310AR
HBL2320AR
HBL2330AR
Gray Valox® surface mounting, one gang, back wired. HBL2310SR
HBL2320SR
HBL2330SR
Gray Valox® semi-flush, two gang, back wired.
HBL2320SR2
HBL2330SR2
HBL2310SR2
HBL2320SW
3.14"
(79.8)
4.57"
(116.1)
Single Flush Receptacles
IP20
SUITABILITY
Description
Catalog Number
Black nylon face, back and side wired.
HBL2310
HBL2320
Blue nylon face, back and side wired.
HBL2310M7
HBL2320M4
Isolated ground, orange nylon face,
IG2310
IG2320
Corrosion resistant, yellow nylon face,
HBL23CM10
Ring terminal connection.
HBL2310RT
HBL2330
2.88"
(73.2)
HBL2320AR
1.58"
(40.1)
HBL2320RT
Note: See page B-50 for accessories.
Insulgrip®
1.50"
(38.1)
4.56"
(115.8)
Flanged Receptacles
Description
Catalog Number
Nylon casing, back wired.
HBL2316
HBL2326
HBL2336
HBL2320SR
Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company.
www.hubbell-wiring.com
2.84"
(72.1)
Dimensions in Inches (mm)
Wiring Device-Kellems
B-19
很抱歉,暂时无法提供与“HBL2320AR”相匹配的价格&库存,您可以联系我们找货
