HBL2421
HBL2421
    HUBBELL(哈伯尔公司)
HBL2421 数据手册
Twist-Lock® Devices Twist-Lock® Devices 20 Ampere, 125/250 Volts 3Ø 250 and 3Ø 480 Volts AC 3 Pole, 4 Wire Grounding Insulgrip® Plugs and Flanged Inlets X W Plugs 2.94" (74.7) 4.50" (114.3) X G Y X G Y Z Z 20A 125/250V AC NEMA L14-20P UL/CSA 2 (1) HP 20A 3Ø 250V AC NEMA L15-20P UL/CSA 3 HP 20A 3Ø 480V AC NEMA L16-20P UL/CSA 5 HP Watertight Safety-Shroud® IP66 Description Black Valox® housing, white Valox® clamps. Catalog Numbers HBL2411SW HBL2421SW Cord Dia. .35"-1.15" (9-29) G Y SUITABILITY HBL2431SW HBL2421SW 2.33" (59.2) 2.21" (56.1) 4.12" (104.6) HBL2421S Safety-Shroud IP20 Description Cord Dia. Black and white nylon body, .35"-1.15" white Valox® shroud. (9-29) Can be used with the Insulgrip Connector Bodies. Accessories on page B-40. Catalog Numbers HBL2411S HBL2421S Insulgrip IP20 Description Black and white nylon. 2.75" (69.9) 2.33" (59.2) 2.21" (56.1) Corrosion resistant, yellow nylon. All black nylon. Cord Dia. .35"-1.15" (9-29) .35"-1.15" (9-29) .35"-1.15" (9-29) SUITABILITY HBL2431S SUITABILITY Catalog Numbers HBL2411 HBL2421 HBL2431 HBL24CM11 HBL24CM21 HBL24CM31 HBL2411BK – – HBL2425SW HBL2435SW 20 Ampere, 125/250 Volts 3Ø 250 and 3Ø 480 Volts AC Accessories on page B-53. HBL2411 Flanged Inlets 2.44" (62.0) 3.75" (95.3) 1.81" (46.0) 3.75" (95.3) HBL2425SW Watertight Safety-Shroud IP66 Description Gray Valox® housing and flange. Accessories on page B-54. Catalog Numbers SUITABILITY HBL2415SW Insulgrip IP20 Description Nylon casing, back wired. Catalog Numbers HBL2415 HBL2425 SUITABILITY HBL2435 Accessories on page B-52. 3.06" (77.7) 120° 1.34" R. (34.0) Notes: For technical information on Twist-Lock® and Watertight Safety-Shroud Devices see pages B-69 and B-70. .19" (4.8) 120° DIA. 2.27" (57.7) 2.23" (56.6) HBLMITL - For use with Watertight Safety-Shroud receptacles, see page B-39. HBL2415 Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. B-20 www.hubbell-wiring.com Dimensions in Inches (mm)
HBL2421 价格&库存
很抱歉,暂时无法提供与“HBL2421”相匹配的价格&库存,您可以联系我们找货
HBL2421
    • 1+634.23392
    • 5+620.76883
    • 10+611.76086
    库存:91
