HBL4779C
HBL4779C
    HUBBELL(哈伯尔公司)
HBL4779C 数据手册
15 Ampere, 125, 250 Volts and 277 Volts AC 2 Pole, 3 Wire Grounding Insulgrip® Connector Bodies and Receptacles G W X G IP20 SUITABILITY Connector Bodies Description Insulgrip connector body, black and white nylon. Multiple drive screws. All black nylon. Cord Dia. .230"-.720" (5.8-18.3) .230"-.720" (5.8-18.3) Insulgrip connector body, 8 position .325"-.655" angle, black and white nylon. (8.3-16.6) Multiple drive screws. Insulgrip connector body, corrosion .230"-.720" resistant, yellow and white nylon. (5.8-18.3) Multiple drive screws. Elastogrip connector body, .300"-.655" yellow elastomer, dust tight. (7.6-16.6) Elastogrip® connector body, .300"-.655" yellow elastomer, water/dust tight. (7.6-16.6) Valise® connector body, .220"-.660" yellow nylon. (5.6-16.8) Valise® connector body, .220"-.660" black nylon. (5.6-16.8) W G Y 15A 125V NEMA L5-15R UL/CSA 15A 250V NEMA L6-15R UL/CSA Catalog Numbers HBL4729C™ HBL4579C HBL4729CBK HBL4729CA – – 2.78" (70.6) 15A 277V AC NEMA L7-15R UL/CSA 1.41" (35.8) 1.53" (38.9) HBL4779C – HBL4729C – 1.75" (44.5) Twist-Lock® Devices Twist-Lock® Devices 4.00" (101.6) HBL47CM29C HBL45CM79C HBL47CM79C HBL2547 – – HBL25W47** – – HBL25W47 2.59" (65.8) HBL4729VY HBL4579VY HBL4779VY HBL4729VBK HBL4579VBK HBL4779VBK 1.50" (38.1) Accessories on page B-49. HBL4729VY Receptacles, Back and Side Wired Catalog Numbers HBL4700* HBL4550* HBL4700I* – HBL4700RT* HBL4550RT* IG4700A* IG4550A* HBL47CM00* – HBL4710 HBL4560 – – 1.70" (43.2) HBL4750* – – – – HBL4760 HBL4760C HBL4710RT IG4710 HBL4711 HBL4560RT IG4560 – HBL4761 HBL4713 HBL4563 HBL4763 3.28" (83.3) 2.735" (69.5) – HBL4700 1.27" (32.3) Accessories on pages B-48 and B-49. Description Insulgrip flanged receptacle, nylon casing, back wired. Stainless steel casing, brown phenolic. Corrosion resistant, stainless steel casing, yellow melamine. Catalog Numbers HBL4715C HBL4585C HBL4785C HBL4715 HBL47CM15 HBL4785 – HBL4585 – Accessories on pages B-48 and B-49. Notes: HP ratings are AC only. RTP is an abbreviation for reinforced thermoplastic polyester. See section J for full line of isolated ground devices. *Supplied with break-off tabs for split circuit wiring. **Watertight connector body IP55 suitability when closure plug inserted or when installed and used properly with watertight plug. Dimensions in Inches (mm) 3.28" (83.3) 2.38" 1.38" (60.5) (35.1) Flanged Receptacles www.hubbell-wiring.com HBL4710 2.56" (65.0) 2.19" (55.6) 2.31" (58.7) 1.94" (49.3) .16" (4.1) DIA. 1.75" (44.5) .16" (4.1) DIA. 1.72" (43.7) 1.36" (34.5) 1.50" (38.1) 1.69" (42.9) HBL4715 HBL4715C B-11 15 Ampere, 125, 250 Volts and 277 Volts AC Description Duplex, flush, brown RTP face. Duplex, flush, ivory RTP face. Duplex, ring terminal connection. Duplex, isolated ground, flush, orange RTP face. Duplex, corrosion resistant, yellow RTP face. Single, flush, black nylon face. Same as HBL4760 without mounting screws, ears. Terminal screws backed out. Single, ring terminal connection. Single, isolated ground, flush, orange nylon face. Single, black nylon face mounted on a 4" (101.6) round box cover. Single, panel mount, black nylon face, side wired only, 1.75" or 1.937" (44.5 or 49.2) mounting centers.
HBL4779C 价格&库存
很抱歉,暂时无法提供与“HBL4779C”相匹配的价格&库存,您可以联系我们找货
