HBL5240
HBL5240
    HUBBELL(哈伯尔公司)
HBL5240 数据手册
Straight Blade Devices Straight Blade Devices 15 and 20 Ampere, 125 Volts 2 Pole, 3 Wire Grounding Insulgrip® Flanged Inlets and Receptacles G 2.56" (65.0) 2.19" (55.6) Flanged Inlets .16" (4.1) Dia. 1.72" (43.7) 1.72" (43.7) HBL5278C 2.25" (57.2) .39"(9.9) Dia. 2.88" (73.2) 1.88" (47.8) 2.66" (67.6) G W .19" (4.8) Dia. 4 Holes W 15A 125V NEMA 5-15P UL CSA 20A 125V NEMA 5-20P UL CSA Description Catalog Numbers Nylon casing, back wired. HBL5278C Weatherproof, gray, with lift cover and multiple drive screws. HBL61CM64 Weatherproof, black, with lift cover and boot, multiple drive screws. HBL61CM64BK – Stainless steel flange, phenolic body, miniature style, for molded on connectors only, multiple drive screws. HBL5240* – HBL5378C Notes: *Specially designed to accept “molded-on" connector bodies. Catalog number HBL5240 will not accept re-wireable size connector bodies listed in this catalog or molded connectors having a “rejection obstruction" as required by Underwriters Laboratories Inc. standard #817 cord sets and power supply cords" effective 7/1/81. See page A-45 for accessories. 1.56" (39.6) HBL61CM64 G G W W 2.56" (65.0) 15A 125V NEMA 5-15R UL CSA 0.5 HP 2.19" (55.6) Flanged Receptacles .16" (4.1) Dia. 1.72" (43.7) 1.72" (43.7) HBL5279C 1.47" (37.3) 2.06" (52.3) Description Catalog Numbers Nylon casing, back wired. HBL5279C Stainless steel flange, phenolic body, covered terminals, multiple drive screws. HBL5279 – Stainless steel flange, brown phenolic (mounting screws packed separately). HBL5256 – Weatherproof, gray nylon, with lift cover and boot, multiple drive screws. .20" Dia. (5.1) 15 and 20 Ampere, 125 Volts 20A 125V NEMA 5-20R UL CSA 1 HP – HBL5379C HBL61CM65* Notes: *Not CSA Certified. See page A-45 for accessories. 1.09" (27.7) HBL5256 2.25" (57.2) .39"(9.9) Dia. 2.88" (73.2) 1.88" (47.8) .19" (4.8) Dia. 4 Holes 2.66" (67.6) 1.56" (39.6) HBL61CM65 A-28 www.hubbell-wiring.com Dimensions in Inches (mm)
HBL5240 价格&库存
很抱歉,暂时无法提供与“HBL5240”相匹配的价格&库存,您可以联系我们找货
