HBL5261
HBL5261
    HUBBELL(哈伯尔公司)
HBL5261 数据手册
Straight Blade Devices 15A, 125V, 2 Pole, 3 Wire Grounding HBL® Extra Heavy Duty Specification Grade Single Receptacle Features One-piece brass integral ground strap Unique bypass contact design Ordering Information Description Device Color UPC Catalog Number Back and side wired Brown 783585013855 HBL5261 Listings UL Listed to UL498 File No. E2186 Certified to CSA 22.2, No. 42 File 285 Fed. Spec. W-C-596 NEMA® WD-6 Compliant Specifications Face Base Power Contacts Ground Contact Mounting Strap Auto Self-grounding Clip Mounting Screws Nylon PBT .037 in. (.9) Brass Brass .050" (1.3) Brass Stainless steel Zinc plated steel Performance Electrical Current Interrupting Dielectric Voltage Certified for current interrupting at full rated current Withstands 2,000V minimum Mechanical Product Identification Ratings are a permanent part of the device Terminal Accommodation #14-#10 AWG copper stranded or solid conductor only Terminal Identification Terminals identified in accordance with UL 498 and CSA Environmental Flammability Operating Temperatures Top: UL 94V-2, Base: UL 94V-0 Maximum continuous 75°C; minimum -40°C (w/o impact) Online Resources Customer Use Drawing eCatalog Installation Instructions Accessories Wallplate or Weatherproof Cover Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. 1.40" Opening
HBL5261 价格&库存
很抱歉,暂时无法提供与“HBL5261”相匹配的价格&库存,您可以联系我们找货
