HBL7314C
HBL7314C
    HUBBELL(哈伯尔公司)
HBL7314C 数据手册
Non-NEMA Twist-Lock® Devices 20 Ampere, 250, 125/250 Volts and 3ØY 120/208 Volts AC Insulgrip® Plugs, Flanged Inlets, Connector Bodies and Receptacles 3P 3W 2P 3W Y For Replacement Use Only IP20 X 20A 250V Non-NEMA Not UL Listed Connector Bodies 3.86"(98.0) W GR CU SUITABILITY 20A 125/250V Non-NEMA Not UL Listed Description Cord Dia. Catalog Number Black and white nylon. .360"-.930" (9-24) HBL7314GCB Corrosion resistant, yellow nylon. .360"-.930" (9-24) – 2.26" (57.4) 1.97" (50.0) HBL7314C HBL7314C HBL73CM14C 1.39" (35.2) 1.11" (28.2) Note: See page B-51 for accessories. Single Flush Receptacles 2.20" (57.2) Description Catalog Number Black nylon face, back wired. HBL7310BG 1.38" (34.9) 2.38" (60.5) 3.61" (91.6) HBL7310B Note: See page B-50 for accessories. #6-32 TAP 1.28" (32.5) HBL7310B Flanged Receptacles Description Catalog Number – Nylon casing, back wired. 1.25" R. (31.8) HBL3326C .19" (4.8) DIA. 2.09" (53.1) Note: See page B-50 for accessories. 120° 2.04" (51.8) 2.88" (73.2) 3P 4W For Replacement Use Only IP20 SUITABILITY 4P 4W GR Z W X Z 120° X HBL3326C Y Y 20A 3Ø 250V AC Non-NEMA Not UL Listed Connector Bodies 20A 3Ø Y 120/208V AC Non-NEMA Not UL Listed Description Cord Dia. Catalog Number Black and white nylon. .350"-1.150" (9-29) HBL7413GCB HBL7413C 3.86"(98.0) 2.33" (59.2) 2.21" (56.1) Note: See page B-53 for accessories. HBL7413GCB Single Flush Receptacles Description Catalog Number Black thermoset, back wired. HBL7410BG HBL7417B Note: See page B-52 for accessories. 2.50" (63.5) Flanged Receptacles Description – 1.57" (39.8) #6-32 TAP Catalog Number Nylon casing, back wired. 1.05" (26.7) HBL7410B – Mounted on a 4" (101.6) round metal cover. 1.71" (43.4) HBL7409C 2.38" (60.5) 3.61" (91.6) 1.28" (32.5) HBL7410BG Note: See page B-52 for accessories. The devices shown on this page are not listed by Underwriters Laboratories Inc. and are for replacement use only in existing installations. 1.34" R. (34.0) .19" (4.8) DIA. 2.27" (57.7) 120° 2.23" (56.6) 3.06" (77.7) 120° CAUTION: To avoid electrical shock, review premises carefully and do not use if slot or blade configuration (design) is already in a circuit having a rating differing from the rating of this device. www.hubbell-wiring.com ® Wiring Device-Kellems HBL7409C Dimensions in Inches (mm) B-43
HBL7314C 价格&库存
很抱歉,暂时无法提供与“HBL7314C”相匹配的价格&库存,您可以联系我们找货
