HBL7487
HBL7487
    HUBBELL(哈伯尔公司)
HBL7487 数据手册
15 Ampere, 125, 125/250 Volts Midget Twist-Lock Connector Bodies and Flanged Receptacles X IP20 1.77" (45.0) W SUITABILITY Y Connector Bodies Description Valise® connector body, black nylon, polarized. Valise® connector body, black nylon, insulation displacement terminals. Black nylon cover, phenolic body, screw terminals. Angle connector body, black nylon cover, phenolic body, screw terminals. Valise® type, black nylon, with insulation displacement terminals, multiple drive screws. Black nylon body, phenolic base, multiple drive screws, cord grip. Same as above, except for angle cord grip. Accessories on page B-6. 15A 125V NEMA ML-2R 15A 125V NEMA ML-1R 15A 125/250V NEMA ML-3R Cord Dia. Catalog Numbers .220"-.385" (5.6-9.8) HBL7464V – – .300"-.430" (7.6-10.9) – HBL7593V – .281"-.421" (7.1-10.7) .335"-.421" (8.5-10.7) – HBL7593 – – HBL7571 – .300"-.430" (7.6-10.9) – – HBL7484V .281"-.421" (7.1-10.7) – – HBL7484 .335"-.421" (8.5-10.7) – – HBL7433 1.06" (26.9) .97" (24.6) Twist-Lock® Devices Twist-Lock® Devices HBL7464V 1.98" (50.4) 1.19" (30.2) HBL7593V 2.42" (61.5) 1.13" (28.7) 1.17" (29.7) HBL7593 1.69" (42.9) 1.28" (32.5) Flanged Receptacles Description Stainless steel flange, exposed terminals. Exposed terminals, black nylon flange. Exposed terminals, stainless steel flange. Covered terminals, stainless steel flange, accepts cord .500" (12.7) in dia. Exposed terminals, black nylon flange. Exposed terminals, stainless steel flange. Covered terminals, stainless steel flange, accepts cord .500" (12.7) in diameter. Catalog Numbers HBL7468 – – HBL7596N – HBL7596 – HBL7598 – – – – – – 1.17" (29.7) – – – – HBL7571 1.97" (50.0) 1.19" (30.2) HBL7487N HBL7487 HBL7489 HBL7484V 2.02" (51.3) Notes: Male ML-2R devices have solid center ground pins. Male ML-3R devices have hollow center neutral sleeves. 1.17" (29.7) 1.13" (28.7) HBL7484 2.06" (52.3) 1.75" (44.5) 2.06" (52.3) 1.75" (44.5) .16" (4.1) DIA. .97" (24.6) .16" (4.1) DIA. 2.06" (52.3) 1.75" (44.5) 1.25" (31.8) 1.00" (25.4) .15" (3.8) DIA. 1.17" (29.7) 1.17" (29.7) 1.14" (29.0) HBL7596 HBL7598 HBL7596N Dimensions in Inches (mm) www.hubbell-wiring.com 1.63" (41.4) 1.38" (35.1) .16" (4.1) DIA. .78" (19.8) 1.03" (26.2) HBL7468 B-5 15 Ampere, 125, 125/250 Volts Accessories on page B-6.
HBL7487 价格&库存
很抱歉,暂时无法提供与“HBL7487”相匹配的价格&库存,您可以联系我们找货
