HBLTRED5B
HBLTRED5B
    HUBBELL(哈伯尔公司)
HBLTRED5B 数据手册
® HUBBELL Safety Product Guide think SAFETY... think HUBBELLSAFE Hubbell Safety Product Guide Table of Contents Hubbell Safe . ........................................................................ 3 Watertight Wiring Devices............................................ 4-5 Watertight Safety-Shroud® Twist-Lock®; Watertight Devices; IEC Pin & Sleeve; UL/CSA Enclosure Type 4X Box Watertight Wiring Devices Ground Fault Circuit Interrupters.............................. 6-7 Receptacles; Portables; Sensing Modules; Circuit Testers Temporary Power............................................................. 8-9 SPIDER® II Temporary Power Boxes; Portable Outlet Boxes; LINKOSITY® Motor Control Motor Control................................................................. 10-11 Circuit-Lock® Unfused and Fused Disconnect Switches; Manual Motor Controllers; MotorQuick® Wire Management........................................................ 12-13 Kellems® Strain Relief; Kellems® Support Grips; PolyTuff® Non-Metallic Liquidtight Conduit and Tubing Arc Flash Safety................................................................. 14 ARC Flash Protection Panel-Safe™; Mechanical Interlocks Lockout, Tagout. ................................................................ 15 PLUGOUT®; SWITCHOUT®; Locking Switches Cable Protection................................................................ 16 Industrial and Commercial Cord Reels Hose and Cable Protection Systems........................ 17 Lockout Tagout TrukTrak®, TredTrak® and AccessTrak® Specialty Devices......................................................... 18-19 HBL5262 Series Receptacles; Tamper-Resistant and Water Resistant Duplex Receptacles; Corrosion Resistant Devices; Weatherproof Covers Cable Protection 2 www.hubbell-wiring.com Safety First with Hubbell The safety of people and equipment matter most Too costly to ignore Hubbell believes that every employee in every business has the right to a safe working environment. Not only is safety the key to allowing people to be confident and secure in their jobs, it is also critical to enhancing productivity, reducing downtime and avoiding significant accident expenses—all of which leads to sustainability and a lower Total Cost of Ownership (TCO). Ensuring safety everywhere Potential safety hazards exist in almost every workplace environment—from open office areas and factory floors, to construction sites and retail spaces. That’s why all employers are required to comply with strict safety codes and regulations. Many businesses pride themselves on the number of accident-free days, which is achieved through established formal safety programs that include training, ongoing safety evaluations and documentation. Hubbell Wiring Systems is committed to helping our customers maintain a safe workplace environment. Since introducing the first safety receptacle that set the industry standard, Hubbell has always been focused on safety. That’s why Hubbell products are designed and developed to first provide maximum safety against injury and the potential dangers of electricity. • Hubbell Twist-Lock® plugs and receptacles ensure mating only with the correct voltage and amperage. • Hubbell’s full line of watertight devices provides protection against electrical shock in wet environments. • All Hubbell ground fault receptacles and temporary power distribution systems provide a high level of personnel protection. • Hubbell Circuit-Lock® disconnects and MotorQuick® motor controllers enable safe control and disconnection of power in the industrial environment • Lockout-tagout features and devices offer a means to protect employees by avoiding unintentional energizing of equipment during diagnostics or repair. • Hubbell wire management and hose and cable protection systems safeguard cables and cords, ultimately protecting people by preventing damaged circuits and minimizing trip hazards. An essential core value As an industry leader, Hubbell is extremely involved with regulatory associations and has an extensive knowledge of codes and regulations that businesses must comply with to ensure safety and reduce risk. From the latest version of the National Electric Code® (NEC) to NEMA requirements and OSHA regulations, Hubbell products comply with the latest codes to help our customers ensure proper safety in the workplace. As part of our ongoing commitment to safety, Hubbell holds numerous ShopTalk™ Seminars across the nation to provide up-to-date information on safety requirements, potential safety risks and products and solutions. Hubbell understands the importance of making safety a core value in every business and the cost of non-compliance. Keeping people and equipment safe with Hubbell products reduces risk and liability. Think safety. Think Hubbell. NEC® is a registered trademark of the National Fire Protection Association (NFPA). www.hubbell-wiring.com 3 Connections for Wet and Damp Locations Watertight Devices When it comes to safety, most everyone knows that water and electricity can create a dangerous environment. From harsh factory and construction sites to laboratories and outdoor applications, ensuring a watertight seal for electrical devices is critical to ensuring maximum safety of personnel in any wet environment. Hubbell Watertight Twist-Lock® devices have become the industry standard for maintaining a watertight seal when in use and when disconnected as well as preventing unintentional disconnects. Watertight Safety-Shroud® Twist-Lock® • Maintains UL/CSA Enclosure Type 4X watertight seal when in use and when disconnected • Constructed from engineered high impact thermoplastic for heavy-duty industrial applications • Shroud meets or exceeds California OSHA 2510.7(6) electrical safety requirement for "skirted plugs" Title 8 Division 1 Chapter 4 Watertight Devices • Double insulated elastomeric cover and NEMA IEC Enclosure Enclosure Classification Type No. Designation Basic Description 3R IP14 Rainproof and Sleet (Ice) Resistant- Outdoor 4 IP56 Watertight and DusttightIndoor and Outdoor 4X IP56 Watertight, Dusttight and Corrosion-Resistant Indoor and Outdoor 6 IP67 Watertight, Dusttight and Sleet (Ice) ResistantIndoor and Outdoor 12 IP52 Industrial Use, Dusttight and Driptight- Indoor thermoplastic body for extra safety and water resistance • Exclusive triple by-pass sealing system • Corrosion-resistant nickel plated blades and stainless steel captive assembly screws • NEMA 4, 4X, 6, 6P, IP65, IP66, IP67 Ordering Information Watertight Locking Devices NEMA Rating Color Coded by Voltage 15A 125V 15A 277V AC 20A 125V 20A 250V 20A 277V AC 20A 3Ø 250V 30A 3Ø 250V AC 30A 3Ø 480V AC 4 W G Poles/ Wires Plug Watertight Safety-Shroud® Connector Receptacle Plug Watertight Connector Receptacle L5-15 2P/3W — — — 24W47H 25W47H 65W47H L7-15 2P/3W — — — 24W34H 25W34H 65W34H 15A 125V NEMA L5-15P UL/CSA 0.5 HP W G 15A 277V AC NEMA L7-15P UL/CSA 2 HP W G L5-20 2P/3W HBL2311SW HBL2313SW HBL2310SW 26W47H 27W47H 67W47H 20A 125V NEMA L5-20P UL/CSA 1 HP X G Y L6-20 2P/3W HBL2321SW HBL2323SW HBL2320SW 26W48H 27W48H 67W48H 20A 250V NEMA L6-20P UL/CSA 2 HP L7-20 2P/3W HBL2331SW HBL2333SW HBL2330SW 26W49H 27W49H 67W49H 30A 277V AC NEMA L7-30P UL/CSA 3 HP X Y G L15-20 3P/4W HBL2421SW HBL2423SW HBL2420SW 26W75H 27W75H 67W75H Z 20A 3Ø 250V AC NEMA L15-20P UL/CSA 3 HP X Y G L15-30 3P/4W HBL2721SW HBL2723SW HBL2720SW 28W75H 29W75H 69W75H Z 30A 3Ø 250V AC NEMA L15-30P UL/CSA 3 HP X Y G L16-30 3P/4W HBL2731SW HBL2733SW HBL2730SW 28W76H 29W76H 69W76H Z 30A 3Ø 480V AC NEMA L16-30P UL/CSA 10 HP For complete listing of Hubbell Products see our full line catalog. www.hubbell-wiring.com Maximum Protection for Electrical Connections Watertight Devices For food processing and waste water applications, Hubbell Watertight IEC Pin & Sleeve devices ensure watertight performance while protecting users with a super tough, non-conductive housing and shrouded contact pins. The opening on the plug shroud accommodates lockout/tagout locks for maximum safety while the UL Enclosure Type 4X Box offers a variety of watertight connections and provides maximum safety for use with Straight Blade and Twist-Lock® devices. IEC Pin & Sleeve • Superior construction and engineered materials for maximum durability • Sequential contact engagement ensures the ground mates first and breaks last • Thermoset polyester interiors provide unsurpassed ability to withstand high amounts of heat which may result from overload or arching UL Enclosure Type 4X Box • One step self-latching, spring loaded gasketed cover for maintaining maximum reliability and protection when not in use • Corrosion, impact and chemical resistant Valox® enclosure • Available in common NEMA configurations, pre-wired for installation simplicity NEC® 110.11 (Electrical Installations) Unless identified for use in the operating environment, no conductors or equipment shall be located in damp or wet locations. Ordering Information IEC Watertight Pin & Sleeve Rating Color Coded by Voltage 20A 3Ø 480V 30A 3Ø 250V 30A 3Ø 480V 30A 3Ø 600V 30A 3ØY 277/480V 60A 250V 60A 3ØY 120/208V 60A 3Ø 480V 60A 3Ø 600V 100A 250V 100A 3ØY 120/208V 100A 3Ø 480V 100A 3Ø 600V Conduit Feed UL Type 4X Rated Poles/ Wires Plug, Connector and Receptacle 3P 4W HBL420x7W 3P 4W HBL430x9W 3P 4W HBL430x7W 3P 4W HBL430x5W Straight Blade Rating Catalog Numbers 20A 125V MCWF2010* Watertight Safety-Shroud® Twist-Lock® Rating Catalog Numbers 20A 125V MCWF2020 20A 250V MCWF2030 20A 277V MCWF2040 20A 125/250V MCWF2070 4P 5W HBL530x7W 3P 4W HBL460x9W 20A 3Ø 250V MCWF2080 HBL560x9W 20A 3Ø 480V MCWF2090 30A 125V MCWF2050 4P 5W 3P 4W HBL460x7W 30A 250V MCWF2060 3P 4W HBL460x5W 30A 125/250V MCWF2100 3P 4W HBL4100x9W 30A 3Ø 250V MCWF2110 30A 3Ø 480V MCWF2120 30A 3Ø 600V MCWF2130 4P 5W NEC® 300.6(D) (Indoor Wet Locations) For indoor wet locations where walls are frequently washed or where there are surfaces of absorbent materials, such as wood, the wiring system where exposed, including boxes, fittings, raceway and cable shall be mounted so that there is at least 1/4 inch (6mm) airspace between it and the wall or supporting surface. HBL5100x9W 3P 4W HBL4100x7W 3P 4W HBL4100x5W * Type 4X Rating with cover closed Valox® is a registered trademark of SABIC Innovative Plastics acquired from GE. x= device: P (Plug), C (Connector), and R (Receptacle) www.hubbell-wiring.com For complete listing of Hubbell Products see our full line catalog. 5 Personnel Protection and Safety Ground Fault Circuit Interrupters (GFCIs) Required by code, receptacles in any wet area must all be protected with ground fault circuit interrupters (GFCIs) that stop the flow of electric current to protect people in the presence of a ground fault. Hubbell offers AUTOGUARD™ and standard heavy duty GFCI receptacles. AUTOGUARD™ is a self-test version that continually tests electronic circuitry automatically. The AUTOGUARD™ unit features a green LED to indicate “power-on” and a red LED that is both a “trip indicator” when solid, and an “end of life indicator” when flashing. The GFCI sensing modules work in conjunction with hydraulic magnetic circuit breakers to interrupt power in the event of a ground fault condition. Extra Heavy Duty GFCI Receptacles • Patented tamper-resistant design limits improper access to energized contacts • Heavy duty brass bridge to withstand abuse • Self-Test units continually tests and monitors for protection automatically • No power at device face if reverse wired, eliminating false assumption of protection • 10 kA Short Circuit Current Rating Sensing Modules For non-residential installations all 125V 15 and 20 AMP receptacles installed in locations specified in NEC® Article 210.8(B)(1)FR-(8) shall have ground fault circuit interrupter protection for personnel. These areas include: • Monitors electrical circuit with no direct load present (1) Bathrooms (2) Kitchens (3) Roof Tops (4) Outdoors (5) Sinks (within 6’ of edge) (6) Indoor Wet Locations (7) Locker Rooms / Shower Facilities (8) Garages / Service Bays • Enclosure Type 4X rating at the module • Hydraulic breakers available from 1 to 50 AMP meets • 120 and 240 volt modules available in automatic or manual “safe start” reset versions • UL 1053 Compliant Ordering Information GFCI Sensing Module 50A Maximum Extra Heavy Duty GFCI Receptacles NEMA Rating Color Tamper-Resistant/Weather Resistant AUTOGUARD™ Self Test Circuit Guard® 15A Brown GFR5262SG GFR5262TR 125V Other GFR5262SGxx GFR5262xxTR 15A 125V NEMA 5-15R 20A Brown GFR5362SG GFR5362TR 125V Other GFR5362SGxx GFR5362xxTR 20A 125V NEMA 5-20R x=color: BK (Black), GY (Gray), I (Ivory), R (Red) and W (White) Description Catalog Number 120V AC Sensing Module 240V AC Sensing Module GFSM120x GFSM240x x= A (Automatic) or M (Manual) Set GFCI Sensing Module Circuit Breakers Catalog Number Configurator. Example: GFSMCB120401P GFSMCB Ground Fault Sensing Module Circuit Breaker Circuit Guard ® Hard Wired 30A GFCI UL Type 4X Rated NEC® is a registered trademark of the National Fire Protection Association (NFPA). Description Voltage Alarm Catalog Number Hard wired; manual and automatic set GFCIs. 120V AC 120V AC 240V AC 240V AC 120/240V AC 3Ø 250V AC 3Ø 120/208V AC None Audible None Audible Audible None None GFHW13x05 GFHW13x15 GFHW23x05 GFHW23x15 GFHW33x15 GFHW53x GFHW43x x= 1 (Automatic) or 0 (Manual) Set 6 For complete listing of Hubbell Products see our full line catalog. 120 40 120 Volt 1 thru 240 Volt 50 Amp 120/240 Volt Circuit Guard ® Plug-In GFCI Portable 15A, 120V AC 1P 1P 2P 3P GFP315A Description Catalog Number Three outlet plug-in GFP315A GFI Tester 120V AC Description Catalog Number Ground fault tester GFT2G GFT2G www.hubbell-wiring.com Minimize Electrical Shock Hazards Ground Fault Circuit Interrupters (GFCIs) GFCIs are also critical for protecting people when using portable line cords and outlets in a variety of indoor and outdoor applications. Hubbell Circuit Guard GFCI line cords are available with an Automatic Set feature for providing safety in applications where equipment is intended for continuous use but where temporary power failure is undesirable such as pumps, pressure washers or portable lighting. Manual Set GFCIs are also available for applications where operator injury might occur if equipment were to restart after a power failure such as drills, saws, lathes and grinders. "Portable GFCI" provides open-neutral protection for temporary power applications. Portable GFCI Line Cords • Provides a watertight housing for maximum safety in harsh environments • Available with either automatic and manual set feature to fit the application • Bright indicator light provides fault confirmation from a distance Portable GFCI Outlets • Ideal for providing safety in applications requiring multiple outlets • Features gasketed cover to protect outlets not in use • Ensures safety by interrupting power when leakage to ground is 4 to 6 milliamperes Ordering Information Circuit Guard ® Wired On Straight Blade Portable GFCI Plugs 15A 125V AC Circuit Guard ® Portable GFCI Line Cords Description Length 15A 120V AC 18 in. 6 ft. 15 ft. 25 ft. 20A 120V AC 3 ft. Industrial Grade GFCI Cord Line w/ Stripped Leads GFP4C15x GFP6C15x — GFP25C15x GFP3C20M — — GFPOEMx — — x= A (Automatic) or M (Manual) Set Circuit Guard Portable GFCI Line Cords ® Rating 15A 120V AC Length 2 ft. 15 ft. 25 ft. 35 ft. Single Triple Tap Cat. No. Manual set; plug; black GFP5266C Manual set; plug; yellow GFP5266CY Manual Set; plug with GFP1C 1 ft. Line cord Commercial Grade Description Cat. No. Field Wireable; black GFP515x w/ Flying Leads GFP2Cx GFP2TTx — — — GFP15Lx GFP25Cx GFP25TTx — — — GFP35Lx Circuit Guard ® In-Line GFCI 2 ft. cord length Single Description x= A (Automatic) or M (Manual) Set x= A (Automatic) or M (Manual) Set Description NEC® 590.6(A) All 125-volt, single-phase, 15-, 20-, and 30-ampere receptacle outlets that are not a part of the permanent wiring of the building or structure and that are in use by personnel shall have groundfault circuit-interrupter protection for personnel. For the purposes of this section, cord sets or devices incorporating listed ground-fault circuitinterrupter protection for personnel identified for portable use shall be permitted. Triple Tap Locking Multiple Outlet Portable GFCI Description www.hubbell-wiring.com Cat. No. GFCI Module UL Type 3R Rated 15A 120V AC GFPIL15125x GFPIL15125TRIx — Rating 20A 120V AC — — GFPIL20125LKx 20A, 120V AC; 20A 250V AC — — GFPIL20250LKx 60 Hz x= A (Automatic) or M (Manual) Set Rating 4-Outlet; 2-Duplex; 15A 120V AC GFP15M Manual Set 20A 120V AC GFP20M Description Cat. No. Manual set Auto set GFM20 GFM20A For complete listing of Hubbell Products see our full line catalog. NEC® is a registered trademark of the National Fire Protection Association (NFPA). 7 Delivery of Safe Convenient Temporary Power Temporary Power Construction sites and outdoor events need to ensure maximum safety when providing temporary electrical power for equipment and lighting, especially since these applications involve frequent plug-ins and disconnects. Hubbell temporary power distribution systems come in a variety of device types for protecting people against electrical shock in a wide range of applications and job sites. SPIDER® II Temporary Power Boxes • Incorporates the most advanced ground fault module technology for safety • Accommodates watertight straight blade and Safety-Shroud® Twist-Lock® receptacles • Heavy Duty UL Type 3R metallic enclosure Portable Outlet Boxes NEC® 110.12(A) (Unused Openings) Unused openings, other than those intended for the operation of equipment, those intended for mounting purposes, or those permitted as part of the design for listed equipment, shall be closed to afford protection substantially equivalent to the wall of the equipment. • Provides a safe rugged portable enclosure that can be used in many applications and complies with NEC® 110.12 regarding unused cable openings in metallic boxes NEC 110.12 Mechanical Execution of Work. Electrical equipment shall be installed in a neat and workmanlike manner. ® • Provides Type 3R protection with weatherproof cover plates • Maximize strain relief protection with the addition of a Kellems® mesh grip Ordering Information Temporary Power Boxes Max Rating Type Receptacle Rating Receptacle Type Protection Overload/GFI Straight Blade Twist-Lock® Spider® II 30A, 120/240V AC Spider® II 50A, 120/240V AC Spider® II 60A, 3Ø 120/208V 50A 125/240V AC (7) Receptacles (1) Twist-Lock® (inlet & outlet) (7) Receptacles (1) Twist-Lock® (inlet & outlet) (6) Receptacles (1) Pin and Sleeve (inlet & outlet) (6) Receptacles (1) (1) Twist-Lock® (1) Twist-Lock® (inlet & outlet) 20A, 125V 30A, 120/240V 20A, 125V 50A, 125/250V 20A, 125V 60A, 3ØY, 120/208V 20A, 125V 30A, 250V 50A 125/250V Yes/Yes No/No Yes/Yes No/No Yes/Yes No/No Yes/Yes Yes/No No/No SDSB1A SDTL1A SBSB1A SBTL1A SCSB0 SCTL0 TPDS TPDL Portable Outlet Boxes and Plates NEC® is a registered trademark of the National Fire Protection Association (NFPA). Description Catalog Numbers Box with cord strain relief, with one blank cover plate Box with cord strain relief, with two duplex (indoor) cover plates Blank, non-metallic FS cover plate with foam gasket, gray Duplex, non-metallic FS cover plate, gray Single receptacle (1.39"), non-metallic FS cover plate, gray Single receptacle (1.56"), non-metallic FS cover plate, gray Rectangular opening, non-metallic FS cover plate, gray HBLPOB1 HBLPOB1D* HBLP14FS HBLP8FS* HBLP7FS HBLP720FS HBLP26FS * Add Y for Yellow 8 For complete listing of Hubbell Products see our full line catalog. www.hubbell-wiring.com Plug and Play Power System Modular Power Factories and industrial environments often need flexible power distribution systems for all types of equipment. Hubbell LINKOSITY® modular power distribution system is ideal for ensuring safety when providing flexible power in these applications. Hubbell LINKOSITY® provides the necessary system components to create code compliant safe installations. LINKOSITY® • Reconfigurable factory defined assemblies that can be easily installed as a cost effective alternative to conventional wiring methods • Cables are UL Type TC-ER with the crush and impact resistance of metal clad cable for maximum safety in industrial environments • Enables fast installation and high technical performance for 20A and 30A circuits up to 600V • Power assemblies available in straight blade and Twist-Lock® receptacles NEC® Article 670 on Industrial Machinery refers to NFPA 79-2007, Electrical Standard for Industrial Machinery where sections 14.1.2.2 and 14.1.5.1 specifically indicate that molded connections factory-applied to cable and cords are to be permitted. NEC® 336.10(7) Permits type TC-ER cable in transitions between cable trays and the utilization equipment or devices when secured at intervals not more than 6 ft without continuous support. Ordering Information Power Components 20A, 30A up to 600V Cables and Receptacles Device Type Ratings PH PM PN PF PG PQ PR PS RF RM 20 20A up to 600V Double Ended Cable - Male/Female Straight Male Single Ended Straight Male Single Ended 90° Female Single Ended Straight Female Single Ended 90° Double Ended Cable with Female 90° Double Ended Cable with Male 90° Double Ended Cable with (2) 90° Connectors Female Receptacle; ½" N.P.T. rear thread Male Receptacle (Inlet); ½” N.P.T. rear thread Wires Conductor Colors** Length (ft.) 02 - 05 PA Green/Yellow; Black (all others) 23 20A up to 600V 03 PB Specialty construction 04 Green/Yellow (Includes isolated ground 05 White on 6 wire and 10AWG 06 Black (all others) super neutral conductor **other color on 5 and 6 wire devices) 30 30A up to 600V 04 codes available upon request 001 005 010 015 020 025 030 035 040 045 050 1' 5' 10' 15' 20' 25' 30' 35' 40' 45' 50' Example Catalog Number: PH2306PB05 LINKOSITY® Tees Description Catalog Numbers M/F/F Tee, 20A, 2P M/F/F Tee, 20A, 3P M/F/F Tee, 20A, 4P M/F/F Tee, 20A, 5P M/F/F Tee, 20A SNIG, 4P M/F/F Tee, 20A SNIG, 6P M/F/F Tee, 20A SNIG, A Phase Tap M/F/F Tee, 20A SNIG, B Phase Tap M/F/F Tee, 20A SNIG, C Phase Tap M/F/F Tee, 30A, 4P TX2002002002T00 TX2003002003T00 TX2004002004T00 TX2005002005T00 TX2304002304T00 TX2306002306T00 TX2306002304A00 TX2306002304B00 TX2306002304C00 TX3004003004T00 www.hubbell-wiring.com Closure Caps Description For use with Female Receptacle Male Inlet 20A and 30A CCMBC Receptacle Closure Cap CCFBC For complete listing of Hubbell Products see our full line catalog. NEC® is a registered trademark of the National Fire Protection Association (NFPA). 9 Line of Sight Disconnect Means Motor Control Hubbell motor control devices can safely disconnect power at any point in a circuit without powering down other equipment and sacrificing productivity. The NEC® requires motor controllers on equipment like HVAC units, compactors and back-up generators to have a disconnect within line of sight and allows a controller and disconnect to be the same device. By combining both functions in one device, Hubbell CIRCUIT-LOCK® eliminates the confusion of which switch is a motor controller or disconnect, providing owners and operators with a renewed level of comfort and safety. Circuit-Lock® Unfused Disconnect Switches • Meets line of sight disconnect requirements to ensure maximum safety • High visibility handle is lockable to meet OSHA lockout/tagout requirements 29CFR 1910.147 • Switch cannot be turned ON unless the Type 4X enclosure cover is closed • NEC 430.109(A)(6) recognizes that a manual motor controller and disconnect can be the same unit Circuit-Lock® Fused Disconnect Switches NEC® 430.75(A) Disconnection. Motor control circuits shall be arranged so that they will be disconnected from all sources of supply when the disconnecting means is in the open position. The disconnecting means shall be permitted to consist of two or more separate devices, one of which disconnects the motor and the controller from the source(s) of power supply for the motor, and the other(s), the motor control circuit(s) from its power supply. Where separate devices are used, they shall be located immediately adjacent to each other. • Certified for current interrupting at full rated current and voltage • High visibility red handle can be locked in OFF position • Type 4X enclosure with neoprene watertight gasket • Accepts class "J" fuses • Meets NEC 300.6(D) mounting requirements Ordering Information IP66 SUITABILITY Circuit-Lock® 30 and 60 Ampere Fused Disconnect Switches Circuit-Lock® Unfused Disconnect Switches Description Catalog No. 30A disconnect switch 30A disconnect switch with one HBLAC1 auxiliary contact 60A disconnect switch 60A disconnect switch with one HBLAC1 auxiliary contact 100A disconnect switch 100A disconnect switch with one HBLAC1 auxiliary contact HBLDS3 HBLDS3AC 10 FDS30* FDS60* Note: *Class "J" fuses not included. HBLDS10 HBLDS10AC Auxiliary Contacts Catalog No. Watertight Closure Plug Kits Auxiliary contacts, “break after main break” HBLAC1 1 set of n/o & n/c contacts Auxiliary contacts, “break before main HBLAC2 break”1 set of n/o contacts NEC® is a registered trademark of the National Fire Protection Association (NFPA). Catalog No. 30A fused disconnect switch 60A fused disconnect switch HBLDS6 HBLDS6AC Auxiliary Contacts for 30, 60 and 100A Switches Description Description Description Catalog No. Normally open;A600 pilot duty Normally closed;A600 pilot duty ACFSNO ACFSNC Description Catalog No. For 30A fused disconnect switch MICPK30 For 60A fused disconnect switch MICPK60 Ground Block Description Catalog No. For 30A switches. For 60A and 100A switches. HBL30RGB HBL60100RGB For complete listing of Hubbell Products see our full line catalog. www.hubbell-wiring.com Installation Safety Motor Control Hubbell motor control devices are also available for use with Hubbell LINKOSITY® modular plug-and-play power distribution system. MotorQuick® offers the functionality of a motor disconnect switch with the safety of factory pre-wired connections. LINKOSITY® connections make motor change outs fast and simple. Heavy duty manual motor controllers are also available for controlling and disconnecting power to equipment. MotorQuick® • Combines Circuit-Lock® motor disconnect with plug- and-play LINKOSITY® system for faster installation and replacement of motors • Lockable handle meets OSHA lockout/tagout regulations • Easily retrofits to existing hard wired installations with LINKOSITY® components Manual Motor Controllers • Available in double-pole and three-pole 30A and 60A 600V AC controllers • Suitable as a motor disconnect • Type 1 and Type 3R enclosures available • Optional finger guards (HBLFG30) fit 30A, 40A and 50A controllers Ordering Information Manual Motor Controller Type 1 30A 3 Pole 600V AC Description Catalog No. HBL1389D with (1) pre-wired LINKOSITY® female receptacle (load side) HBL1389D with 5 ft. pre-wired LINKOSITY® female cable (load side) HBL1389D with (1) pre-wired LINKOSITY® male receptacle (line side) and (1) pre-wired LINKOSITY® female receptacle (load side) HBL1389MQR HBL1389MQ5 HBL1389MQR2 Description Double Pole 30A 600V AC motor controller In Type 1 enclosure; non-metallic cover In metal Type 1 enclosure In NEMA 3R non-metallic enclosure In metal Type 3R enclosure In NEMA 3R flip lid enclosure 60A 600V AC motor controller HBL7832D HBL1392D NEC® 430.102 Location. (A) Controller. An individual disconnecting means shall be provided for each controller and shall disconnect the controller. The disconnecting means shall be located in sight from the controller location. (2) Controller Disconnect. The controller disconnecting means required in accordance with 430.102(A) shall be permitted to serve as the disconnecting means for the motor if it is in sight from the motor location and the driven machinery location. HBL1372D HBL13R22D HBL13R92D HBL13R12D HBL7862D Manual Motor Controller Description Type 4X 30A 3 Pole 600V AC Description Catalog No. HBLDS3 with (1) pre-wired LINKOSITY® HBLDS3MQR female receptacle (load side) HBLDS3MQ5 HBLDS3 with 5 ft. pre-wired LINKOSITY® female cable (load side) HBLDS3 with (1) pre-wired LINKOSITY® HBLDS3MQR2 male receptacle (line side) and (1) pre-wired LINKOSITY® female receptacle (load side) www.hubbell-wiring.com Three Pole 30A 600V AC motor controller HBL7810D In Type 1 enclosure; HBL1389D non-metallic cover In metal Type 1 enclosure HBL1379D In NEMA 3R non-metallic HBL13R23D enclosure In metal Type 3R enclosure HBL13R89D In NEMA 3R flip lid enclosure HBL13R13D 60A 600V AC motor controller HBL7863D In Type 3R enclosure HBL16R93D For complete listing of Hubbell Products see our full line catalog. NEC® is a registered trademark of the National Fire Protection Association (NFPA). 11 Wire Secureness and Strain Relief Wire Management Hubbell wire mesh grips are designed to prevent strain from being transmitted to joints and terminals on electrical cords, cables and conduit. This provides greater security than using a fitting alone, making electrical systems safer by preventing cable pull-out and controlling cable arc-of-bend.The positive action mesh grips distributes loads equally over the cable jacket. Strain Relief Grips • Multi-weave grip products provide arc-of-bend control minimizing cable damage and extending cable life • Ideal for providing maximum safety where conduit is subject to vibration, motion or strain • Stainless steel mesh is corrosion resistant and optional liquidtight fittings provide a watertight seal Support Grips • Ideal for ensuring safety by supporting electrical NEC® 400.10 (Pull at Joints and Terminals) Flexible cords and cables shall be connected to devices and to fittings so that tension is not transmitted to joints or terminals. OSHA Regulation 29 CFR 1926.405(g)(2)(iv) Strain relief. Flexible cords shall be connected to devices and fittings so that strain relief is provided which will prevent pull from being directly transmitted to joints or terminal screws. 1926.405(g)(2)(v) Cords passing through holes. Flexible cords and cables shall be protected by bushings or fittings where passing through holes in covers, outlet boxes, or similar enclosures. NEC® is a registered trademark of the National Fire Protection Association (NFPA). cable service drops or hoses • Positive action mesh grip design provides equal loading throughout the entire grip length • Available in heavy duty, standard and light duty for a variety of applications Ordering Information Kellems® Deluxe Cord Grips Description Grip Diameter Range Catalog No. Straight male thread; ³⁄₈ in. N.P.T. thread size Straight male thread; ¹⁄₂ in. N.P.T. thread size .250"-.312" (.63-.79) .312"-.375" (.79-.95) .375"-.437" (.95-1.11) .187"-.250" (.47-.63) .250"-.375" (.63-.95) .375"-.500" (.95-1.27) .500"-.625" (1.27-1.59) 07401001 07401002 07401003 07401004 07401006 07401008 07401010 90º male thread; ³⁄₈ in. N.P.T. thread size 90º male thread; ¹⁄₂ in. N.P.T. thread size .250"-.312" (.63-.79) .312"-.375" (.79-.95) .375"-.437" (.95-1.11) .187"-.250" (.47-.63) .250"-.375" (.63-.95) .375"-.500" (.95-1.27) .500"-.625" (1.27-1.59) 07401071 07401072 07401073 07401074 07401076 07401078 07401080* 45º male thread; ¹⁄₂ in. N.P.T. thread size 45º male thread; ³⁄₄ in. N.P.T. thread size .250"-.312" (.63-.79) .375"-.500" (.95-.1.27) .500"-.625" (1.27-1.59) .500"-.625" (1.27-1.59) .625"-.750" (1.59-1.90) .750"-.875" (1.90-2.22) 074011236 074011021 074011237 074011049 074011051* 074011239* * Cable jacket may have to be stripped to pass through connector body. 12 Single Eye, Closed Mesh** For permanent support when cable end is available to be installed through grip. Cable Diameter Range Inches (cm) Approx. Breaking Strength Lbs. (N) Catalog No. .50"-.62" (1.27-1.57) .63"-.74" (1.60-1.88) .75"-.99" (1.90-2.51) 1.00"-1.24" (2.54-3.15) 1.25"-1.49" (3.17-3.78) 1.50"-1.74" (3.81-4.42) 530 (2,357) 790 (3,514) 1,020 (4,537) 1,610 (7,161) 1,610 (7,161) 1,610 (7,161) 02201013 02201014 02201015 02201017 02201018 02201019 **Change catalog number from 022 to 024 for stainless steel. Consult factory for availability. Single Eye, Split Mesh, Rod Closing** For support when cable end is not available. Cable Diameter Range Inches (cm) Approx. Breaking Strength Lbs. (N) Catalog No. .50"-.62" (1.27-1.57) .63"-.74" (1.60-1.88) .75"-.99" (1.90-2.51) 1.00"-1.24" (2.54-3.15) 1.25"-1.49" (3.17-3.78) 1.50"-1.74" (3.81-4.42) 790 (3,514) 790 (3,514) 1,020 (4,537) 1,610 (7,161) 1,610 (7,161) 1,610 (7,161) 02203013 02203014 02203015 02203017 02203018 02203019 **Change catalog number from 022 to 024 for stainless steel. Consult factory for availability. For complete listing of Hubbell Products see our full line catalog. www.hubbell-wiring.com Protect Wires from Moisture and Damage Wire Management Protecting electrical circuitry on the factory floor improves safety for both people and equipment by preventing mechanical damage and moisture from impacting the integrity of the wiring. Hubbell PolyTuff® non-metallic liquidtight conduit and fittings are commonly used between disconnect switches and equipment in industrial applications to protect wiring and improve safety. Metallic liquidtight fittings are also available for certain applications. PolyTuff® Non-Metallic Liquidtight Conduit and Tubing • Non-metallic construction ends metal fatigue and separation problems • Cuts cleanly with a knife or PVC cutter with no jagged metal edges • Handles twists, turns, bends, swtichbacks and straightaways with ease • Available with rigid PVC core PolyTuff® I or flexible corrugated wall PolyTuff® II PolyTuff® Liquidtight Fittings • SwivelLok® nylon two-piece swivel body enables fitting to twist from 0° to 90° • Neoprene O-ring ensures liquidtight seal at hub or enclosure • Non-integral ferrule provides conduit seal and superior pullout protection Ordering Information PolyTuff I ® Conduit and PolyTuff II ® Tubing Trade Size (metric designator) Feet (m) PolyTuff I Conduit PolyTuff II Tubing ¼ (10) ³⁄₈ (12) ½ (16) ¾ (21) 1 (27) 1¼ (35) 1½ (41) 2 (53) — G1038 G1050 G1075 G1100 G1125 G1150 G1200 B2025 B2038 B2050 B2075 B2100 B2125 B2150 B2200 100 (30.5) 100 (30.5) 100 (30.5) 100 (30.5) 100 (30.5) 100 (30.5) 50 (15.2) 50 (15.2) SwivelLok® Multi-Position with Male Non-Metallic Liquidtight Fittings Trade Size (metric designator) Black Gray ³⁄₈ (9) ½ (13) ¾ (19) 1 (25) PS0389NBK PS0509NBK PS0759NBK PS1009NBK PS0389NGY PS0509NGY PS0759NGY PS1009NGY ½ (13) ¾ (19) www.hubbell-wiring.com ¼ (6) ³⁄₈ (9) ½ (13) ¾ (19) 1 (25) 1¼ (32) 1½ (38) 2 (51) F2025 P038NBKA P050NBKA P075NBKA P100NBKA P125NBK P150NBK P200NBK Trade Size (metric designator) Black Fitting and Conduit Kit Catalog No. (2) PS0509NGY, 6' G1050 (2) PS0759NGY, 6' G1075 Trade Size (metric designator) Black Gray – P038NGYA P050NGYA P075NGYA P100NGYA P125NGY P150NGY P200NGY (1) Where flexibility is required for installation, operation, or maintenance. (2) Where protection of the contained conductors is required from vapors, liquids or solids. (3) For outdoor locations where listed and marked as suitable for the purpose. (4) For direct burial where listed and marked for the purpose. (5) Type LFNC-B shall be permitted to be installed in lengths longer than 1.8 m (6 ft) where secured in accordance with 356.30. (6) For encasement in concrete where listed for direct burial and installed in compliance with 356.42. Fixed 90°Fittings for Non-Metallic Conduit SwivelLok® Flexible Conduit Kit Trade Size (metric designator) Straight with Male Non-Metallic Fittings for Non-Metallic Conduit NEC® 356.10 Uses Permitted. LFNC shall be permitted to be used in exposed or concealed locations for the following purposes: PS05GYKIT PS07GYKIT ¼ (6) ³⁄₈ (9) ½ (13) ¾ (19) 1 (25) 1¼ (32) F20259 P0389NBK P0509NBK P0759NBK P1009NBK P1259NBK Gray – P0389NGY P0509NGY P0759NGY P1009NGY P1259NGY For complete listing of Hubbell Products see our full line catalog. NEC® is a registered trademark of the National Fire Protection Association (NFPA). 13 Comply with OSHA Safe Work Practices Arc Flash Safety An arc flash is a short circuit that travels through air from one live circuit to another. Problems including gaps in insulation, dust or corrosion on the surface of a conductor, or even use of substandard components can cause a serious safety hazards and equipment failures. Arc flash incidents can be extremely costly to a business and can result in serious or even fatal burns, as well as damage to eyesight. Hubbell PANELSAFE™ and mechanical interlocks provide arc flash safety by ensuring isolation from live electrical components. Panel Safe • Available in Type 4, 12 and 4X versions with protective clear cover • Provides overcurrent protection for both power and data access ports • Ensures safety with finger-safe contacts and Hubbell GFCI functionality Mechanical Interlock • Eliminates the possibility of making and breaking the NFPA 70E: • Electrical equipment enclosures can ONLY be accessed by qualified personnel with extensive protective clothing and equipment, including fire-resistant suits and hoods with non-conductive wands. NFPA 79: Electrical Standard for Industrial Machinery • ALL utility receptacles must be GFCI protected • ALL external utility receptacles must be covered • ALL covers must maintain enclosure rating circuit under load providing safe connections to portable equipment • Non-metallic enclosure can be connected to metallic conduit and not interfere with the ground continuity • Highly visible red handle can be locked out to comply with OSHA lockout/tagout regulations • UL/CSA certified as a manual motor controller and also as suitable as a disconnect Ordering Information PANEL-SAFE™ Access Ports Description Power Only 20A 125V GFCI with In-Cabinet Receptacle Data Only Cat. 5e Ethernet Access only DB9 Interface Connector only DH + Combo (DB9/8M Din) and Cat. 5e Ethernet Power and Data 20A 125V GFCI with In-Cabinet Receptacle and Cat. 5e Ethernet Access 20A 125V GFCI with In-Cabinet Receptacle, Cat. 5e Ethernet Access and 3A Circuit Breaker 20A 125V GFCI Power and Cat. 5e Ethernet, DH + Combo (DB9/8M Din) 15A 125V Power and Cat. 5e Ethernet Access 15A 125V Power, Cat. 5e Ethernet Access and 3A Circuit Breaker 15A 125V Power and (2) Cat. 5e Ethernet Access 14 IEC Watertight Pin & Sleeve Rating Color Coded by Voltage 20A 3Ø 480V 30A 3Ø 250V 30A 3Ø 480V 30A 3Ø 600V 30A 3ØY 277/480V 60A 3Ø 250V 60A 3ØY 120/208V 60A 3Ø 480V 60A 3Ø 600V 100A 250V 100A 3ØY 120/208V 100A 3Ø 480V 100A 3Ø 600V NEMA NEMA TYPE 4, 12 TYPE 4X PR20 — P5E PDB9 PDH5E P4X5E — — PR205E PR4X205E PR205EB PR4X205EB P20DH5E — P155E P4X155E P155EB P4X155EB P155E2 — Poles/ Wires Mechanical Interlock 3P 4W HBL420MI7W 3P 4W HBL430MI9W 3P 4W HBL430MI7W 3P 4W HBL430MI5W 4P 5W HBL530MI7W 3P 4W HBL460MI9W 4P 5W HBL560MI9W 3P 4W HBL460MI7W 3P 4W HBL460MI5W 3P 4W HBL4100MI9W 4P 5W HBL5100MI9W 3P 4W HBL4100MI7W 3P 4W HBL4100MI5W For mating plug, replace MI with P. Ex. HBL420MI7W (mechanical interlock) to HBL420P7W (mating plug) For complete listing of Hubbell Products see our full line catalog. www.hubbell-wiring.com Safe Maintenance and Repairs Lockout, Tagout for Electrical Safety Lockout/tagout refers to specific procedures to safeguard people from the unexpected energization or startup of machinery and equipment, or the release of hazardous energy during service or maintenance activities. Hubbell offers many products that meet OSHA lockout/tagout regulations including integrated lockout features in pin and sleeve plugs and switched enclosures as well as a variety of dedicated lockout devices. PLUGOUT® and SWITCHOUT® Lockout Devices • Provides an approved method of complying with OSHA lockout/tagout regulation • Available in 15A, 20A, 30A and 60A plugout devices enclose the equipment plug and secure with a key padlock Locking Switches • Prevents unauthorized control of lighting or ventilation control • Keys supplied with each locking switch • One piece integral grounding terminal provides a low resistance ground path Ordering Information PLUGOUT® Lockout Devices Description Typical Devices Accommodated Catalog No Small yellow lockout device Medium yellow lockout device 15 and 20A straight blade HLDMP plugs;15A Twist-Lock® plugs HLD 15 and 20A, 125V straight blade plugs; 20 and 30A Twist-Lock® plugs 20, 30 and 60A metallic and HLD2 non-metallic Pin and Sleeve; Hubbellock®; 50A Twist-Lock® plugs Large yellow lockout device SWITCHOUT® Yellow Switchout Toggle switch device Keyed PLUGOUT Yellow keyed 15 and 20A, 125V straight Plugout; keyed blade; plugs with holes in differently blades Yellow keyed 15 and 20A, 125V straight Plugout; keyed blade; plugs with holes in alike blades * Two devices per package HSLDPK2* www.hubbell-wiring.com This section requires employers to establish a program and utilize procedures for affixing appropriate lockout devices or tagout devices to energy isolating devices, and to otherwise disable machines or equipment to prevent unexpected energization, start up or release of stored energy in order to prevent injury to employees. AC Barrel Key Locking Switches 20 Amp 120-277 Volt Description Catalog Numbers Single pole Double pole Three-Way Four-Way Barrel key replacement HBL1221RKL HBL1222RKL HBL1223RKL HBL1224RKL HBL1209RKL Locking Switches 15 Amp 120-277 Volt Description Catalog Numbers HKLD Single pole Double pole Three-Way Four-Way HBL1201L HBL1202L HBL1203L HBL1204L HKLDPK2* 20 Amp 120-277 Volt ® NFPA 70E-2004 LO/TO Procedures 29CFR1910.147(a)(3)(i) Description Catalog Numbers Single pole Double pole Three-Way Four-Way Replacement key HBL1221L HBL1222L HBL1223L HBL1224L HBL1209 For complete listing of Hubbell Products see our full line catalog. NEC® is a registered trademark of the National Fire Protection Association (NFPA). 15 Eliminate Tripping Hazards Cable Management Cable reels can help eliminate unmanaged cords and cables that would otherwise cause trip hazards or an increased potential of electric shock. Hubbell offers a wide range of cord reels that provide cable protection, including watertight, industrial, commercial and static discharge reels with grounding jaw clamps for a low resistant ground termination for maximum safety. Industrial Cord Reels • Provide safe convenient power and lighting for demanding industrial applications and environments • All steel construction can be ceiling. wall or bench mounted • Keeps cord organized and off the floor, saves time and money and improves safety while extending cord life Commercial Cord Reels • Lighter weight for the less demanding requirements UL355 4.3, 4.4 Cord Reels, that employ GroundFault Circuit Interrupter outlet(s) and are connected to the power supply by means of flexible cord with an attachment plug and/or that employ slip rings, shall be provided with open neutral protection as part of the GFCI. AFL version allows cord reel installation to conform to NEC® Article 511 concerning installation of electrical devices in commercial garages, repair facilities and storage locations by positioning the switch above the defined area where hazardous fumes may collect. of commercial and light industrial environments • Eliminates unmanaged cords which can cause trip hazards or an increased potential of electric shock • AFL version provides automatic lamp shut-off to switch power above the floor height requirement • Holds cord at desired length and provides smooth cord retraction Ordering Information Industrial Power Cord Reels Cord End NEMA Style HBL5269C 15A connector HBL5369C 20A connector Portable duplex outlet box; 15A gray duplex Portable duplex outlet box; 20A gray duplex Portable duplex outlet box; 15A gray GFCI duplex Portable duplex outlet box; 20A gray GFCI duplex HBL2313 20A connector Pivot Base 330° Rotation 5-15R 5-20R 5-15R 5-20R 5-15R 5-20R 5-20R – Cable Volts Feet (m) AC Cable Type 45 (13.7) 45 (13.7) 45 (13.7) 45 (13.7) 45 (13.7) 45 (13.7) 45 (13.7) – 125 125 125 125 125 125 125 – Weight Lbs. (kg) Catalog Number 12/3 SJEO 12/3 SJEO 12/3 SJEO 12/3 SJEO 12/3 SJEO 12/3 SJEO 12/3 SJEO – 23 (10.4) 29 (13.2) 29 (13.2) 29 (13.2) 29 (13.2) 28 (12.7) 23 (10.4) 5 (2.3) HBL45123C HBL45123C20 HBL45123R HBL45123R20 HBL45123GF15 HBL45123GF20 HBL45123TL20 HBL340PB Commercial Cord Reels Cord End NEC® is a registered trademark of the National Fire Protection Association (NFPA). 16 Triple tap outlet; 15A Wire leads; 10A HBL5969VBLK connector; 10A Metallic incandescent hand lamp with receptacle; 13A Fluorescent hand lamp and inline receptacle; 10A Fluorescent hand lamp; automatic shut off switch; 0.3A Watts (Max) Cable Feet (m) Volts AC Cable Type Weight Lbs. (kg) Catalog Number 1200 1250 1250 1625 40 (12.2) 25 (7.6) 25 (7.6) 25 (7.6) 125 125 125 125 12/3 SJTW 16/3 SJT 16/3 SJT 14/3 SJT 9 (4.1) 8.5 (3.9) 8.5 (3.9) 9.5 (4.3) HBLC40123TT HBLC25163 HBLC25163C HBLC25143IN 1200 40 (12.2) 120 16/3 SJT 9 (4.1) HBLC40163FL 13 40 (12.2) 120 18/2 SJTOW 8.2 (3.7) For complete listing of Hubbell Products see our full line catalog. HBLC40182AFL www.hubbell-wiring.com Prevent Damage to Cables Hose and Cable Protection Systems Exposed cables, cords and hoses can be a trip hazard for pedestrians, as well as a potential shock hazard. Hubbell offers a variety of hose and cable protection systems that provide a safe ramping system for both pedestrians and vehicles to pass over cables and hoses. TrukTrak® and TredTrak® • Safeguards cables and cords from vehicle and pedestrian traffic • TrukTrak® is ideal for industrial environments where trucks and forklifts are present • TredTrak® supports pedestrian and light vehicle traffic in public, institutional and commercial applications • Complies with NEC Article 525 for insulating cables at carnivals, amusement parks, convention centers and similar public areas AccessTrak® • Modular cable protection for compliance with ADA accessibility guidelines • Expandable five channel system that limits exposure of cables and hoses • Protects cable and hose diameters up to 1.31 inches NEC® 110(F)(2) Outdoor. Outdoor electrical equipment shall be installed in suitable enclosures and shall be protected from accidental contact by unauthorized personnel, or by vehicular traffic. OSHA 1926.416(e)(1) Requires that worn or frayed electrical cords or cables shall not be used. Precautions to mitigate wear include protection from damage and pinch points Ordering Information TrukTrak® and TredTrak® Systems Description TrukTrak® TredTrak® 5 Channel, blue and yellow 5 Channel end caps (pair only), yellow 5 Channel female end caps (2 females), yellow 5 Channel 45° right turn, blue and yellow 5 Channel 45° left turn, blue and yellow 5 Channel “X” fitting, blue and yellow 5 Channel “Y” fitting, blue and yellow 3 Channel, blue and yellow 3 Channel end caps (pair only), yellow 2 Channel, blue and yellow HBLTT5B HBLTT5ECB — HBLTT545RB HBLTT545LB — — HBLTT3B HBLTT3ECB HBLTT2B HBLTRED5B HBLTRED5ECB HBLTRED5ECFB — — HBLTRED5XB HBLTRED5YB — — — AccessTrak® System Description Catalog Number 5 Channel AccessTrak kit*, blue and gray 5 Channel AccessTrak trough, blue and gray AccessTrak trough end rails (set), gray AccessTrak ramps (set), blue AccessTrak ramp end rails (set), gray HBLAT5KITA HBLAT5A HBLAT5ERA HBLAT5RAMPA HBLAT5RAMPERA *Consists of (1) HBLAT5A; (1 set) HBLAT5ERA; (1 set) HBLAT5RAMPA; (2 sets) HBLRAMPERA. www.hubbell-wiring.com Expanded by Length Expanded by Width For complete listing of Hubbell Products see our full line catalog. NEC® is a registered trademark of the National Fire Protection Association (NFPA). 17 Enhanced Safety for Convenience Outlets Specialty Devices Hubbell knows that safety of people should be first in every environment. Hubbell offers a wide variety of receptacles all designed and developed to provide maximum safety from the factory floor to the doctor’s office to the outdoor amusement park. Hubbell’s HBL® Extra Heavy Duty Industrial Series receptacles reduce heat buildup and provide low resistance of fault currents while Hubbell Tamper-Resistant and Weather-Resistant receptacles provide an additional level of safety now required for use in dwelling units and wet and damp locations. HBL® Extra Heavy Duty Industrial Series Receptacles • Reinforced thermoplastic polyester base for heat resistance and contact stability • Exclusive nickel-plated bypass contact design ensures uninterrupted power • Four-point grounding system provides redundant grounding for low resistance • Meets NEC® 406.9 requirements WR Tamper-Resistant and Water Resistant Receptacles • Spring-loaded shutter restricts access to live contacts NEC® 406.9(B)(1) – REVISED [Formerly 406.8(B)(1)] by single-pronged items for maximum safety • Only proper plug insertion opens the shutters, 2011 NEC® wording: 406.9 Receptacles in Damp or Wet Locations. All 15- and 20-ampere, 125and 250-volt nonlocking-type receptacles shall be listed weather-resistant type. 406.12 Tamper-Resistant Receptacles in Dwelling Units. In all areas specified in 210.52, all nonlocking type 125-volt, 15and 20-ampere receptacles shall be listed tamper-resistant receptacles. 406.13 – NEC Tamper-Resistant Receptacles in Guest Rooms and Guest Suites. All nonlocking-type, 125-volt, 15- and 20-ampere receptacles located in guest rooms and guest suites shall be listed tamper-resistant receptacles. 406.14 – NEC Tamper-Resistant Receptacles in Child Care Facilities. In all child care facilities, all nonlocking-type, 125-volt, 15- and 20-ampere receptacles shall be listed tamper-resistant receptacles. allowing electrical contact • Tamper resistant meets NEC® 406.12, 406.13 and 406.14 requirements TR • Weather resistant meets NEC® 406.9 requirements WR Ordering Information HBL® Extra Heavy Duty Industrial Series NEMA 15A 125V NEMA 5-15R 20A 125V NEMA 5-20R Rating Color 15A 125V Brown Black Ivory Other 20A 125V Brown Black Ivory Other Receptacle Circuit Tester Duplex Weather Resistant Single Description HBL5262 HBL5262BK HBL5262I HBL5262x HBL5362 HBL5362BK HBL5362I HBL5362x HBL5262WR HBL5262BKWR HBL5262IWR HBL5262xWR HBL5362WR HBL5362BKWR HBL5362IWR HBL5362xWR HBL5261 HBL5261BK HBL5261I — HBL5361 HBL5361BK HBL5361I HBL5361xx Neon lights HBL5200 visually indicate and verify various fault conditions in electrical circuits Catalog No. x=color: GY (Gray), R (Red) and W (White). xx=color: GRY (Gray), and W (White). TR Commercial Specification Grade Receptacles NEMA 15A 125V NEMA 5-15R NEC® is a registered trademark of the National Fire Protection Association (NFPA). 20A 125V NEMA 5-20R Rating Color 15A 125V Brown Black Ivory Other 20A 125V Brown Black Ivory Other WR TR WR Standard Duplex Tamper-Resistant Weather Resistant Tamper-Resistant Weather Resistant BR15 BR15BLK BR15I BR15x BR20 BR20BLK BR20I BR20x BR15WRTR BR15BLKWRTR BR15IWRTR BR15xWRTR BR20WRTR BR20BLKWRTR BR20IWRTR BR20xWRTR BR15TR BR15BLKTR BR15ITR BR15xTR BR20TR BR20BLKTR BR20ITR BR20xTR BR15WR BR15BLKWR BR15IWR BR15xWR BR20WR BR20BLKWR BR20IWR BR20xWR x=color: AL (Almond), GY (Gray), LA (Light Almond) and W (White). xx=color: GRY (Gray), and W (White). 18 For complete listing of Hubbell Products see our full line catalog. www.hubbell-wiring.com Protect Devices from Corrosion and Abuse Specialty Devices Some environments can be particularly corrosive for electrical connections, calling for an extra level of safety and protection. Hubbell offers a wide range of plugs, connectors and receptacles that are specifically designed to withstand corrosive environments like chemical plants and wastewater treatment facilities. Corrosion Resistant Plugs, Connectors and Receptacles • Reinforced thermoplastic elastomer housing to resist ultraviolet rays, oil and chemicals • Powerful nylon cord grips on plugs prevents strain on terminals and prevents cord pull-outs • Plated contacts provide for reliable electrical connections and long life Weatherproof Covers • UL listed for wet locations in both thermoplastic and cast aluminum with cover closed • Suffix "WO" are listed for wet location with cover open and plug installed • Available in single and dual receptacles with individual weatherproof covers for each receptacle Ordering Information Corrosion Resistant Straight Blade NEMA 15A 125V NEMA 5-15R 20A 125V NEMA 5-20R Twist-Lock® Rating Device Catalog Number 15A Duplex Receptacle 125V Duplex Lift Cover Single Receptacle Plug Connector 20A Duplex Receptacle 125V Duplex Lift Cover Single Receptacle Plug Connector HBL52CM62 HBL52CM21 HBL52CM61 HBL52CM66C HBL52CM69C HBL53CM62 HBL52CM21 HBL53CM61 HBL53CM66C HBL53CM69C Duplex Covers Thermoplastic for Vertical Mounting Description NEMA W G 15A 125V NEMA L5-15P UL/CSA 0.5 HP W G 20A 125V NEMA L5-20P UL/CSA 1 HP Rating Device Catalog Number 15A Duplex Receptacle 125V Duplex Lift Cover Plug Connector Lift Cover 20A Single Receptacle 125V Plug Connector Lift Cover HBL47CM00 HBL52CM21 HBL47CM20C HBL47CM29C HBL74CM25WOA HBL23CM10 HBL23CM11 HBL23CM13 HBL74CM25WOA Receptacle Covers Vertical FS/FD Mounting Gray Yellow Face Diameter For FS/FD box mounting HBL5221 HBL52CM21 For device mounting HBL5222 HBL52CM22 Duplex Covers Cast Aluminum for Horizontal Mounting Description 406.9 Receptacles in Wet Locations. (B) Wet Locations. 15- and 20-ampere, 125- and 250-volt receptacles installed in a wet location shall have an enclosure that is weatherproof whether or not the attachment plug cap is inserted. All 15- and 20-ampere, 125- and 250-volt nonlocking receptacles shall be listed weather-resistant type. Exception 15- and 20-ampere, 125- through 250volt receptacles installed in a wet location and subject to routine high-pressure spray washing shall be permitted to have an enclosure that is weatherproof when the attachment plus is removed. Catalog Number For FS/FD box mounting HBL5206WO For device mounting HBL5205WO www.hubbell-wiring.com Cast Aluminum inches (mm) Color Thermoplastic 1.36"-1.39" (34.5-35.3) 1.55" - 1.58" (39.4-35.3) 1.68" - 1.72" (42.7-43.7) Gray Yellow Gray Yellow Gray Yellow HBL7423WO HBL7420 HBL74CM23WO — HBL7425WOA HBL7420* HBL74CM25WOA — HBL7424WO HBL3393 HBL74CM24WO — NEC® is a registered trademark of the National Fire Protection Association (NFPA). Wet Locations: Thermoplastic w/ cover "open" Cast Aluminum w/ cover "closed" For complete listing of Hubbell Products see our full line catalog. 19 ® HUBBELL Safety Application Guide Hubbell Supports Sustainable Building All around the globe, there is a powerful shift towards “sustainable” thinking. Now increased interest in energy efficiency and waste reduction has put sustainable building design at the very forefront of the industrial, commercial and residential construction industries. As a leader in the industry, Hubbell Wiring Systems recognizes its role and responsibility in safeguarding the environment. Through its GreenWise™ Sustainability Initiative, Hubbell designs and develops innovative products that optimize sustainable building design by saving energy, supporting space efficiency and reducing waste. Hubbell Wiring Systems is committed to maintaining environmental stewardship in our own manufacturing and corporate facilities through restricting the use of hazardous materials, implementing comprehensive recycling programs and improving energy efficiency. Website Support The Hubbell Wiring Systems website features a landing page dedicated to the GreenWise™ Initiative. Here you can find quick links to Hubbell's sustainable building products, resources and councils, financial incentives per state and support literature. Literature Support Hubbell offers an extensive literature library for product support. Downloadable PDFs are available online. Hubbell Watertight Wiring Devices Insulgrip® Wiring Devices Application Guide Hubbell Wiring DeviceKellems Catalog WIRING DEVICE SAFETY EVALUATION Lockout Tagout Solution Problem Problem: A machine is being repaired or set-up. How can employees be protected from unintentional energizing of equipment? Solution: Plugout devices in a full range of sizes, enclose the equipment plug and secure with a keyed padlock. NEC Information: Article 430.102 – Explains lock-out tag-out procedure. Straight Blade Receptacle 15-20 Ampere Solution Problem Solution Problem: A toggle switch controls equipment being serviced. Unintentional actuation of the switch during service presents a hazard to maintenance personnel. Solution: Switchout devices on any standard toggle switch to mechanically lock it in the off position. NEC Information: Article 430.102 – Explains lock-out tag-out procedure. Mechanical Interlock Switch Problem Solution Problem Problem: Lighting or ventilation may require only authorized access to switch. Solution: Barrel key locking switch prevents unauthorized on or off activation. TrukTrak® Problem Problem: Electrical, pneumatic and hydraulic cables are being damaged when driven over and create a trip hazard. Solution: Protect your cables and hoses with TrukTrak®, TredTrak® and AccessTrak® non-metallic cable protectors designed to safeguard electrical cables and cords from vehicle and pedestrian traffic. NEC Information: Article 527.4(H) – Protection from accidental damage indicates that cords shall be protected from sharp corners and projections. Solution Problem: Potential for dangerous arcing when equipment is unintentionally connected / disconnected under load. Solution: Circuit-Lock® Switched Mechanical Interlock Enclosure virtually eliminates the possibility of making or breaking the circuit under load or making a casual or “lazy” connection. NEC Information: Article 430.103 – The disconnecting means shall open all ungrounded conductors and be designed so that no pole can be operated independently. Solution SAFETY EVALUATION A step-by-step checklist to help identify potential problems, from the wiring device experts...Hubbell. Problem: Switch controls equipment that is exposed to frequent washdowns and cleaning chemicals. Solution: Circuit-Lock Switched Enclosure with a UL Type 4X (Washdown, Corrosion Resistant ) rating and a lockable handle to meet OSHA Lockout / Tagout regulations. NEC Information: Article 430.91 – Refers to enclosure type ratings, and Article 430.102 (B) – refers to Lock-out, Tag-out requirements. Problem: A standard GFCI receptacle installed in a 4" square box for temporary power. Solution: Portable GFCI products with open neutral protection as required. OSHA Information: Meets OSHA 29 CRF 1926.404(b)(1)(ii) and 29 CRF 1926.405(a)(2)(ii)(G) requirements for portable power/lighting in confined space. Article 305-5 (A). Continued on back Problem Problem: Using a box that is not listed for pendant application. Open knockouts and inadequate strain relief could potentially harm equipment or personnel. Solution: Portable outlet boxes provide a safe rugged portable enclosure which can be used in many different applications. NEC Information: Article 110.12 - Refers to unused cable openings in metallic boxes. Printed In U.S.A. Specifications subject to change without notice. ® Registered trademark of Hubbell Incorporated. Hubbell Incorporated (Delaware) • 185 Plains Road • Milford, CT 06460-2420 • (203) 882-4800 • H5149 FAX (800) 255-1031 We recommend that you begin your safety inspection by reviewing the condition of existing installed wiring devices. Strong consideration should be given to upgrading to the most current wiring device technology and the latest NEC requirements. It is extremely important that users adhere to the manufacturer’s installation instructions when installing and using wiring devices. Proper product selection for the given application is important. Wiring devices are designed to perform specific tasks within the limit of their design, electrical rating and intended installation environment. Hubbell offers a complete line of wiring device products serving a wide range of applications. A safety checklist by product type (switches, wire management, plugs/connectors, receptacles, high-amperage products, ground fault protection and lock-out/tag-out) outlines some of the “inspection checkpoints” plant electricians should be aware of when checking various types of wiring devices. Most inspection points can be done visually without disassembling the devices. Solution Visual inspections not only indicate potential failures of products; for an experienced maintenance technician they are an early warning system signaling the possibility of product failure or of a potential hazard to personnel. Portable Outlet Box Solution Problem Workplace safety has a significant impact on your business. Employee safety and productivity, machine down time, and production throughput are all impacted by the condition of the work environment. Hubbell Wiring Device Kellems encourages and promotes a safe and well maintained work place, through the proper selection, use and installation of wiring devices. This brochure details applications, NEC references and product solutions to assist you in achieving those goals. Safety Evaluation Checklist Disconnect Switch Problem GFCI HUBBELL WIRING DEVICE SAFETY IN THE WORKPLACE Solution Problem Problem: Devices are burning out from coming in contact with water and debris. Solution: Safety-Shrouded Twist-Lock® products that are UL Type 4X rated for use in harsh environments. NEC Information: Article 110.11 - Refers to deteriorating agents, and Table 430.91 for environmental type ratings. Problem: Misapplied receptacles installed in demanding applications. Solution: Industrial receptacles are made with impact resistant nylon faces to minimize damage from impact and abrupt pull-out. Stainless steel plates also provide excellent strength and protection. NEC Information: Article 110.3 & 110.12(C) – Indicates requirements for the structural integrity of product. Hubbell Slide Charts PROBLEMS & SOLUTIONS PROBLEMS & SOLUTIONS Plug/Connector Problem Hubbell Safety Evaluation Solution Common Examples: Hazard – A receptacle or switch with a damaged or missing cover plate means that the terminal screws to which the conductors are wired are exposed and could be touched by a person. In addition to this potential hazard, grounding or short circuiting of the conductors in the receptacle or switch can cause equipment, machinery or lighting failure resulting in downtime. Hazard – A light switch has been damaged and will not operate resulting in a loss of light. This results in lost productivity and a condition that can be dangerous. Hazard – Plug blades or pins have been damaged or tampered with and the rating designation has been altered or removed. Altering the contact pattern and blade configuration allows undesirable interchangeability. Different configurations are designed to prevent mating of devices with different ratings. For instance, a single-phase, 125-volt, 3-wire plug will not fit into a three-phase, 120/208V receptacle. This is why it is important during inspections to make sure contacts patterns are intact. Hubbell Recommends... www.hubbellcatalog.com/wiring www.hubbell-wiring.com • Qualified electricians perform all electrical work. • Be aware of strict compliances to NEC and OSHA regulations. • Always disconnect power and use approved lock-out/tag-out procedures while inspecting and performing electrical maintenance work. • Wiring devices, as with all electro-mechanical devices, require periodic inspection and maintenance to assure the safety of the user and the proper day-to-day performance of the product. • The following check list is not inclusive but may point to trouble areas in the installation of wiring devices. ® Wiring Device-Kellems www.hubbell-wiring.com Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • FAX (800) 255-1031 Printed in U.S.A. Specifications subject to change without notice. ® is a registered trademarks of Hubbell Incorporated. WLBVM002 10/10 FPO
HBLTRED5B 价格&库存
很抱歉,暂时无法提供与“HBLTRED5B”相匹配的价格&库存,您可以联系我们找货
