HBL2310
HBL2310
    HUBBELL(哈伯尔公司)
HBL2310 数据手册
Twist-Lock® Devices The Standard for Locking Receptacles Features and Benefits Face color coding by voltage facilitates locating and mating of proper devices All-brass mounting and grounding system provides a lower resistance ground path and greater resistance to corrosion than steel mounting systems High-impact, abuse-resistant nylon face Boss diameter is 1.562" on 20 and 30A devices for simplifying installation and accessory selection Wire restraint recess for both back and side wiring, greatly reduces the possibility of loosening the terminal connection Glass-Reinforced thermoplastic polyester base (RTP) has the desirable characteristics of a thermoset material, including heat, flame resistance and dimensional stability. The impact resistance it provides, however, is much greater than that of a thermoset HBL2310 #10 silicon bronze terminal screw provides greater strength and resistance to corrosion and stripping. Anti-rotational clamp has a stop to limit the amount of cocking when only one side is used. Accommodates both back and side wiring One-piece contact with long spring arm (low stress) and oxide cutting nibs: prevents stress and overheating associated with riveted contact and short spring arms Twist-Lock® receptacles combine functional design features, unparalleled quality to deliver pace-setting performance. The high-impact nylon face of each Hubbell Twist-Lock receptacle has a colored ring. Keyed to an internationally recognized color coding scheme, this ring enables mating devices to be matched quickly. It's just one more example of user-oriented thinking at Hubbell. The terminals in each Hubbell Twist-Lock receptacle are mechanically and electrically the finest available. These terminals incorporate unique design features to contain and hold conductors, including an external back wiring “wraparound” clamp, a wire restraint recess and more. The materials used in every receptacle are of the highest quality. The all brass mounting system provides a safer, lower resistance ground path than those made of steel. The thick wall base is constructed of an engineered thermoplastic to offer the benefits of a thermoset, yet with much greater impact resistance. Hubbell Twist-Lock Receptacles: Voltage color coding on the outside. Proven designs and quality materials on the inside. Any way you look at them, they are the standard of the industry. 125V www.hubbell-wiring.com 250V ® 277V AC 480V AC Wiring Device-Kellems 600V AC 125/250V B-13
HBL2310 价格&库存
很抱歉,暂时无法提供与“HBL2310”相匹配的价格&库存,您可以联系我们找货
