HBL2320SR
HBL2320SR
    HUBBELL(哈伯尔公司)
HBL2320SR 数据手册
Today, you know us for this. Next, you’ll be demanding this. Hubbell’s Safety-Shroud™ Twist-Lock® System For Enhanced Personal Safety and Abuse Resistance. Hubbell raises the standard of safety again with the Hubbell Safety-Shroud Twist-Lock® System. There’s no more fail-safe or foolproof way to protect personnel and equipment. Hubbell’s unique Safety-Shroud design all but eliminates accidental or inadvertent contact with partially inserted plugs. The same is true with exposure to arching. The Hubbell Safety-Shroud TwistLock device is also built to protect itself. It’s impactresistant, tough enough to take the rough pounding the workplace can dish out, and it’s Safety-Shroud shields plugs against bending and breaking. Hubbell Safety-Shroud Twist-Lock devices are compatible with most NEMA locking installations and comply with OSHA lockout/tagout standards. Receptacles are available in angle, straight and semi-flush styles for low profile, “perfect fit” installations everywhere, every time. There you have it — the Hubbell Safety-Shroud Twist-Lock System — rugged, reliable protection that puts safety first and ensures safety lasts. NO POSTAGE NECESSARY IF MAILED IN THE BUSINESS REPLY MAIL UNITED STATES FIRST-CLASS MAIL PERMIT NO. Milford, CT Hubbell Wiring Device-Kellems 185 Plains Road Milford, CT 06460 See reverse for details. Printed In U.S.A. Specifications subject to change without notice. ® Registered trademark of Hubbell Incorporated H5117 Hubbell Safety-Shroud™ Twist-Lock® Safety-Shroud Receptacles Safety-Shroud Plug Features and Benefits Semi-flush receptacle mounting provides lowest installed profile when plug is not in use with receptacle. This device is designed for installation on two-gang boxes. • Mates with most NEMA locking connector bodies. • Virtually eliminates bent and broken plug blades. • Provides protection for personnel by reducing chance of inadvertent contact with blades when connecting or disconnecting energized devices. Straight receptacle housing provides a low installed profile when plug is not in use with receptacle. This device is designed for installation on single-gang boxes. • Reduces exposure to arcing when connecting or disconnecting under load. • Extends life of mating receptacles by eliminating damage caused by insertion of bent blades. • Complies with California Code of Regulation, which requires shrouding for devices exceeding 300 volts. Angle receptacle housing provides low installed profile when plug is in use with receptacle. This device is designed for installation on single-gang boxes. • Lockout/tagout hole allows compliance to OSHA regulation 29 CFR 1910.147. • Allows engagement with Mechanical Interlock Enclosure which virtually prevents make and break under load. Features and Benefits • Internal keying on receptacle aligns blades for quick mating of devices. • Accepts all NEMA locking plugs, allowing interchangeability with existing devices. • Catalog number and color-coded voltage rating are visible when in use. • All screws are combination Phillips/slotted head. • Engineered thermoplastic housing is impact and corrosion-resistant, for use in heavy-duty industrial environments. 20 Ampere Safety-Shroud Twist-Lock Devices Rating 2 Pole 3 Wire Voltage 125 250 277V AC 3 Pole 4 Wire 125/250 3Ø250V AC 3Ø480V AC 4 Pole 5 Wire 3ØY120/ 208V AC NEMA Config. Ref. Number L5-20 Catalog Numbers AC Angle Surface HP Configurations Housing Mounting Rating Male Female One Gang One Gang 1 HBL2310AR HBL2310SR Semi-Flush Two Gang HBL2310SR2 Safety Shroud Male Plug HBL2311S NEMA Locking Devices Flanged Male Inlet HBL2315 L6-20 2* HBL2320AR HBL2320SR HBL2320SR2 HBL2321S HBL2323 HBL2325 L7-20 2 HBL2330AR HBL2330SR HBL2330SR2 HBL2331S HBL2333 HBL2335 L14-20 2 (1)** HBL2410AR HBL2410SR HBL2410SR2 HBL2411S HBL2413 HBL2415 L15-20 3 (1)** HBL2420AR HBL2420SR HBL2420SR2 HBL2421S HBL2423 HBL2425 L16-20 5 (1)** HBL2430AR HBL2430SR HBL2430SR2 HBL2431S HBL2433 HBL2435 L21-20 2 HBL2510AR HBL2510SR HBL2510SR2 HBL2511S HBL2513 HBL2515 Configurations Connector Male Female Body HBL2313 30 Ampere Safety-Shroud Twist-Lock Devices Rating 2 Pole 3 Wire Voltage 125 250 NEMA Config. Ref. Number L5-30 Catalog Numbers AC Angle Surface HP Configurations Housing Mounting Rating Male Female One Gang One Gang 2 HBL2610AR HBL2610SR Semi-Flush Two Gang HBL2610SR2 Safety Shroud Male Plug HBL2611S L6-30 2* HBL2620AR HBL2620SR HBL2620SR2 HBL2621S HBL2623 HBL2625 2 (2)** HBL2710AR HBL2710SR HBL2710SR2 HBL2711S HBL2713 HBL2715 L15-30 3 HBL2720AR HBL2720SR HBL2720SR2 HBL2721S HBL2723 HBL2725 L16-30 10 HBL2730AR HBL2730SR HBL2730SR2 HBL2731S HBL2733 HBL2735 L17-30 — HBL2740AR HBL2740SR HBL2740SR2 HBL2741S HBL2743 HBL2745 L21-30 3 HBL2810AR HBL2810SR HBL2810SR2 HBL2811S HBL2813 HBL2815 3 Pole L14-30 4 Wire 125/250V AC 3Ø250V AC 3Ø480V AC 3Ø600V AC 4 Pole 5 Wire 3ØY120/ 208V AC NEMA Locking Devices Flanged Male Inlet HBL2615 Configurations Connector Male Female Body HBL2613 Only receptacles and plugs 480V AC or less are HP rated. * Also suitable for 208V. ** HP rating is phase to neutral. To get a FREE Hubbell Add-A-Shroud, please complete and return this postcard. Name Company Address City State Phone Fax E-Mail Please send me the following Add-A-Shroud: (check one box) The Add-A-Shroud devices allow the conversion of existing 20A and 30A, 3 to 5 wire Hubbell Insulgrip® Twist-Lock® devices to a Safety Shroud Twist-Lock Plug. 20-30A 3 wire 4 & 5 wire Add-A-Shroud HBLSS3 HBLSS45 ‰ HBLSS3 3 Wire Twist-Lock Plug ‰ HBLSS4 4 & 5 Wire Twist-Lock Plug H5117 Zip Code
HBL2320SR 价格&库存
很抱歉,暂时无法提供与“HBL2320SR”相匹配的价格&库存,您可以联系我们找货
