HBL2623VBK
HBL2623VBK
    HUBBELL(哈伯尔公司)
HBL2623VBK 数据手册
Twist-Lock® Devices 30 Ampere, 125, 250 Volts and 277 Volts AC 2 Pole, 3 Wire Grounding X W G W G G Y 30A 125V NEMA L5-30R UL/CSA 2 HP Connector Bodies Watertight Safety-Shroud® IP66 SUITABILITY Description Cord Dia. Catalog Number Black Valox® housing, white Valox® clamps. Reverse service, black Valox® housing, white Valox® clamps (use with HBL2615SWR), (Not shown). .360"-.930" (9-24) .360"-.930" (9-24) HBL2613SW HBL2613SR Insulgrip® 30A 277V AC NEMA L7-30R UL/CSA 3 HP 30A 250V NEMA L6-30R UL/CSA 2 HP UL Type 4x, 12 HBL2623SW – – IP20 3.86" (98.0) Cord Dia. Catalog Number .360"-.930" (9-24) .360"-.930" (9-24) .360"-.930" (9-24) .360"-.930" (9-24) HBL2613 HBL2623 HBL2613F HBL2623F – HBL26CM13 HBL26CM23 – HBL2613BK HBL2623BK – HBL2633 Note: See page B-51 for accessories. IP20 Description Cord Dia. Catalog Number Yellow nylon. .590"-.930" (15.0-23.6) .590"-.930" (15.0-23.6) .590"-.930" (15.0-23.6) HBL2613VY Corrosion resistant, yellow nylon. Black nylon. HBL26CM13V HBL2613VBK HBL2613SW SUITABILITY Black and white nylon. Valise® 4.38" (111.1) – Description Heat stabilized, gray nylon, 220° F (104° C). Corrosion resistant, yellow nylon. All black nylon. 2.56" (65.0) 2.26" (57.4) 1.97" (50.0) HBL2623 2.60" (66.0) 1.78" (45.2) SUITABILITY HBL2623VY – HBL2613VY – – 2.69" (68.3) HBL2623VBK – 3.75" (95.3) Note: See page B-51 for accessories. Receptacles Watertight Safety-Shroud® IP66 SUITABILITY Description Catalog Number Gray Valox® housing and flange, back wired. HBL2610SW UL Type 4x, 12 HBL2620SW 3.75" (95.3) HBL2610SW – 3.14" (79.8) Note: See page B-54 for accessories. Safety-Shroud® 1.50" (38.1) Twist-Lock® IP20 Description Catalog Number Gray Valox® angle housing, one gang, back wired. Gray Valox® surface mounting, one gang, back wired. Gray Valox® semi-flush, two gang, back wired. HBL2610AR HBL2610SR HBL2610SR2 SUITABILITY HBL2620AR HBL2620SR HBL2620SR2 – – – 4.57" (116.1) Note: See page B-54 for accessories. Single Flush Receptacles IP20 SUITABILITY Description Catalog Number Black nylon face, back and side wired. Blue nylon face, back and side wired. Isolated ground, orange nylon face, back and side wired. Corrosion resistant, yellow nylon face, back and side wired. Ring terminal connection. HBL2610 HBL2610M6 IG2610 HBL2620 HBL2620M6 IG2620 HBL2630 – – HBL26CM10 HBL26CM20 – HBL2610RT HBL2620RT – Note: See page B-50 for accessories. 2.88" (73.2) HBL2620AR 1.58" (40.1) 4.56" (115.8) Insulgrip® Flanged Receptacles Description Catalog Number Nylon casing, back wired. Heat stabilized, gray nylon, 220° F (104° C). HBL2616 HBL2616F HBL2626 HBL2626F HBL2636 – Note: See page B-50 for accessories. Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. www.hubbell-wiring.com 2.84" (72.1) HBL2620SR Dimensions in Inches (mm) ® Wiring Device-Kellems B-27
HBL2623VBK 价格&库存
很抱歉,暂时无法提供与“HBL2623VBK”相匹配的价格&库存,您可以联系我们找货
