HBL26410
HBL26410
    HUBBELL(哈伯尔公司)
HBL26410 数据手册
Hubbellock® Devices 60 Ampere, 600 Volts AC 3 Pole, 4 Wire Grounding and 4 Pole, 5 Wire Grounding 3P 4W 4P 5W IP30 GR GR Y SUITABILITY X W Y Z Z Connector Bodies 4.88" (124.0) 1.09" (27.7) X 60A 600V 3.19" (81.0) 60A 600V AC Description Cord Dia. Catalog Number Black phenolic interior with yellow thermoplastic sleeve over steel cover. .920"-1.450" (23.36-36.83) HBL26418 Black phenolic interior with blue thermoplastic sleeve over steel cover. 1.00"-1.50" (25.40-38.10) – HBL26418 – HBL26516 5.44" (138.2) 1.09" (27.7) IP44 Receptacles 3.19" (81.0) SUITABILITY Description Catalog Number Black phenolic interior with short aluminum housing and lift cover. HBL26410 – Black phenolic interior with long aluminum housing and lift cover. HBL26420 – – Black phenolic interior with long aluminum housing with lift cover and blue finish. HBL26516 1.75" (44.5) 3.63" (92.2) HBL26520 3.50" (88.9) sq. 2.88" (73.2) IP30 Flanged Receptacles 1.84" (46.7) .25 DIA. SUITABILITY Description Catalog Number Black phenolic interior with steel housing and flange. HBL26421 – – Black phenolic interior with steel housing and flange with blue finish. 3.63" (92.2) 4.88" (124.0) HBL26521 3.50" (88.9) sq. Receptacle Box and Adapter Plates HBL26410 2.88" (73.2) HBL26420 (Box requires one adapter) Description Catalog Number Box, cast aluminum, only for 60A Hubbellock receptacles. HBL26401 Straight adapter plate. HBL26402 45° adapter plate. HBL26404 Note: Straight or angle adapter plate must be used when mounting a 60A receptacle to HBL26401 box. Cannot be used with round flanged receptacles and inlets. See page B-68 for additional information. 4.88" (123.9) 3.63" (92.2) 3.50" (88.9) sq. 2.88" (73.2) HBL26520 3.31" (84.1) 4.52" (114.8) 4.53" (102.13) 2.69" (68.3) 3.50" (88.9) 4.13" (104.9) 2.86" 4.12" (72.6) (104.6) 2.69" (68.3) 2.86" (72.6) 3.31" (84.1) HBL26421 HBL26521 Dimensions in Inches (mm) www.hubbell-wiring.com ® Wiring Device-Kellems B-67
HBL26410 价格&库存
很抱歉,暂时无法提供与“HBL26410”相匹配的价格&库存,您可以联系我们找货
