HBL2725ST
HBL2725ST
    HUBBELL(哈伯尔公司)
    HUBBELL WIRING DEVICES - HBL2725ST - POWER ENTRY CONN, NEMA L15-30P, 30A/250V
HBL2725ST 数据手册
® Twist-Lock Devices 30A 3-Phase Delta 250V AC, 3-Pole 4-Wire Spring Terminated Flanged Inlet Features Faster termination time No need for screwdriver and torque wrench Spring Termination eliminates strand relaxation Funnel shaped wire entry for ease of termination. Backwired termination for ease of installation Ordering Information Description Nylon casing, back wired. Device Color White UPC Number 78358568166 Catalog Number HBL2725ST Listings Listed to UL 498 Fed.Spec. W-C-596 Certified to CSA C22.2 No.42 Specifications Housing Terminal Retainer Plunger Blades Terminal Spring Clamp Assemby Screws Mounting Screw Weight (lbs) Nylon Nylon Nylon Copper Alloy Spring Steel Zinc Plated Tri-drive Nickel Plated Brass, 8- 32 Thread 0.25 Performance Electrical Current Interrupting Dielectric Voltage Mechanical Terminal Accommodation Terminal Identification Environmental Flammability Moisture Resistance Operating Temperatures Certified for current interrupting at full rated current Withstands 3,000V minimum #14 AWG - #6 AWG solid or #14AWG - #8AWG stranded copper wire Terminals identified in accordance with UL 498 HB or better per UL94/CSA 22.2 No.0.17 IP20 Suitability Maximum Continuous 75°C, Minimum -40°C (w/o impact) Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. Online Resources eCatalog
HBL2725ST 价格&库存
很抱歉,暂时无法提供与“HBL2725ST”相匹配的价格&库存,您可以联系我们找货
