HBL5361
HBL5361
    HUBBELL(哈伯尔公司)
HBL5361 数据手册
Marine Products Marine Products Receptacles Inside the Boat Style Line® Receptacles „ High-Impact nylon face resists breaking, chipping and cracking. „ Will accept locking fork terminal to comply with ABYC standards. „ Available in 4 colors for any decor with matching wall plates. „ Smooth, high-gloss finish for rich appearance. Style Line Series Description 15A 125V brown duplex receptacle. See note A. Same as #HBL2132M except ivory. See note A. Same as #HBL2132M except white. See note A. Same as #HBL2132M except gray. See note A. HBL213MI Catalog Numbers HBL2132M* HBL2132MI HBL2132MW* HBL2132MGY Commercial Series CRO15 CRO20I HBL5251 HBL5361I Description 15A 125V brown duplex receptacle. See note A. Same as #CRO15 except gray. See note A. Same as #CRO15 except ivory. See note A. 20A 125V brown duplex receptacle. See note A. Same as #CRO20 except black. See note A. Same as #CRO20 except gray. See note A. Same as #CRO20 except ivory. See note A. Same as #CRO20 except white. See note A. 15A 125V brown single receptacle. Same as #HBL5251 except ivory. 20A 125V brown single receptacle. Same as #HBL5361 except ivory. Catalog Numbers CRO15 CRO15GRY* CRO15I* CRO20* CRO20BLK* CRO20GRY* CRO20I CRO20WHI* HBL5251 HBL5251I* HBL5361* HBL5361I Corrosion Resistant Series Description 15A 125V yellow corrosion resistant duplex receptacle. Use where salt or other corrosive elements are a problem. Same as #HBL52CM62 except ivory. Catalog Numbers HBL52CM62* HBL52CM62I Special Application Series Description Catalog Numbers Illuminated receptacle 15A 125V grounding. A high quality HBL8200ILI receptacle with something extra: an illuminated face. Ideal for use in halls or as a gentle night light. HBL52CM62I HBL8200ILI Outlet Box Receptacles Description Plastic switch/receptacle box. Measures 3 9/32" x 2 3/16" x 2 1/2" (83.3 x 55.6 x 63.5) deep. For mounting in walls without studs. A support strap is provided which pulls box tightly against back side of wall. Catalog Numbers HBL6079 Note: Will accept locking fork terminal to comply with ABYC standards. *Not shown. HBL6079 www.hubbell-marine.com 36 Dimensions in Inches (mm) Marine Products Marine Products Switches & Weatherproof Switch Plates 15 and 20 Ampere, 120-277 Volt Commercial Series Description Single-pole toggle switch for controlling AC load from one point, brown handle. See note A. Same as #CS115 except gray handle. See note A. Same as #CS115 except ivory handle. See note A. Same as #CS115 except office white handle. See note A. Same as #CS115 except white handle. See note A. Three-way toggle switch for controlling AC load from two points, brown handle. See note A. Same as #CS315 except gray handle. See note A. Same as #CS315 except ivory handle. See note A. Same as #CS315 except office white handle. See note A. Same as #CS315 except white handle. See note A. Catalog Numbers CS115* CS115GY* CS115I CS115OW* CS115W* CS315* CS115I CS315GY* CS315I* CS315OW* CS315W* Special Application Series Description Catalog Numbers 20A 120V toggle switch with neon lamp set in ivory handle. HBL1221IL Handle illuminates when switch is in “OFF” position. 20A 120V three-way toggle switch with illuminated ivory handle for HBL1223IL* controlling AC load from two points. Handle illuminates when “OFF.” 20A 120V single-pole toggle switch with neon lamp set in clear HBL1221PL red handle. Handle illuminates when switch is “ON.” Serves as instant reminder that current is flowing to an appliance. 20A 120V three-way toggle switch for controlling AC load from two HBL1223PL* points. Red handle illuminates when “ON.” Single-pole PresSwitch® for controlling AC load from one point. HBL1281 Switch activated brown button. Same as #HBL1281 except ivory button. HBL1281I* Three-way PresSwitch® for controlling AC load from two points. HBL1283† Switch activated brown button. Same as #HBL1283 except ivory button. HBL1283I*† Yellow neoprene weatherproof plate for use only with PresSwitches. HBL17CM50† PresSwitch button is activated when bubble is pressed. Not CSA. Clear silicone rubber weatherproof bubble plate for use with all HBL1795 AC toggle switches and PresSwitches. Also ideal for use with lighted handle toggle switches. Not CSA. HBL1221IL HBL1221PL HBL1281 HBL1283 HBL17CM50 HBL1795 Outlet Box Description Plastic switch/receptacle box. Measures 3 9/32" x 2 3/16" x 2 1/2"(83.3 x 55.6 x 63.5) deep. For mounting in walls without studs. A support strap is provided which pulls box tightly against back side of wall. Not CSA. Catalog Numbers HBL6079 Note: Will accept locking fork terminal to comply with ABYC standards. *Not shown. †Not UL Listed. Dimensions in Inches (mm) 37 www.hubbell-marine.com Switches HBL6079 Marine Products Marine Products Wall Plates, TV & Phone Plates Inside the Boat Smooth High Impact Nylon Mid-Size Series PJ1 – PJ1W PJ1X PJ2 – PJ2W PJ2X PJ8 – PJ8W PJ8X PJ82 – PJ82W PJ82X PJ26 PJ26G – PJ26X PJ262 – – PJ262X PJ7 – PJ7W PJ7X Smooth Metal Stainless Brass Steel B1 S1 – – – – – – B2 S2 – – – – – – B8 S8 – – – – – – B82 S82 – – – – – – B26 S26 – – – – – – B262 S262 – – – – – – B7 S7 – – – – – – B18 – – – Color Ivory Gray White Brown Ivory Gray White Brown Ivory Gray White Brown Ivory Gray White Brown Ivory Gray White Brown Ivory Gray White Brown Ivory Gray White Brown Gangs One One One One Two Two Two Two One One One One Two Two Two Two One One One One Two Two Two Two One One One One Standard Series P1 P1G P1W P1X P2 P2G P2W P2X P8 P8G P8W P8X P82 P82G P82W P82X HPS1I HPS1G HPS1WA HPS1 HPS2I HPS2G HPS2WA HPS2 P7 P7G P7W P7X Ivory Gray White Brown Two Two Two Two P18 P18G P18W P18X PJ18 – PJ18W PJ18X Ivory White Brown Two Two Two – – – PJ126 – PJ126WA – PJ126X – S126 – – Ivory Gray White Brown One One One One P14 P14G P14W P14X – – – – – – – – S13 – – – 6 Conductor Telephone Jack Ivory Brown One One – – PJ216 PJ216X – – – – (Two openings) TV plate with RG59 Connector. Ivory One – PJ212 – – P1 P2 P8 P82 HSP1 HSP2 P7 S18 – – – P18 PJ126 Wall Plates P14 PJ216 PJ212 (Not CSA) www.hubbell-marine.com 38 Dimensions in Inches (mm)
HBL5361 价格&库存
很抱歉,暂时无法提供与“HBL5361”相匹配的价格&库存,您可以联系我们找货
