HBL8215C
HBL8215C
    HUBBELL(哈伯尔公司)
HBL8215C 数据手册
Straight Blade Devices 15A, 125V, 2 Pole, 3 Wire Grounding Hospital Grade Plug Features Beveled housing prevents snagging Powerful, offsetting cord grips clamp on individual conductors Ordering Information Description Black and white nylon Cord Diameter UPC .230"-.720"(5.8-18. 783585179209 3) Catalog Number HBL8215C Listings UL Listed to UL498 File No. E2186 Certified to CSA, C22.2, No. 42 File 285 Fed. Spec. W-C-596 Specifications Housing Terminal Retainer Blades Cord Clamp Terminal Screws Terminal Clamp Assembly Screws Nylon PBT .06" (1.5) Brass Nylon Brass Plated steel Plated steel Performance Electrical Current Interrupting Dielectric Voltage Certified for current interrupting at full rated current Withstands 2000V AC minimum Mechanical Product Identification Ratings are a permanent part of the device Terminal Accommodation #18-10 AWG Terminal Identification Terminals identified in accordance with UL 498 and CSA Environmental Flammability IP Suitability Operating Temperatures UL 94 HB or better IP20 Maximum continuous 75°C; minimum -40°C (w/o impact) Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. Resources Customer Use Drawing eCatalog
HBL8215C 价格&库存
很抱歉,暂时无法提供与“HBL8215C”相匹配的价格&库存,您可以联系我们找货
