HBLDS3SSP
HBLDS3SSP
    HUBBELL(哈伯尔公司)
    HUBBELL WIRING DEVICES - HBLDS3SSP - DISCONNECT SW, SQUARE TOP, 3P, 30A, 600V
HBLDS3SSP 数据手册
inSIGHT Circuit-Lock® 30A Disconnects with LED Indicators TM Insight (n): the power or act of seeing into a situation* Hubbell’s new 30A Circuit-Lock Disconnect with integral phase indication LEDs redefines the benchmark for safety by providing insight into the enclosure while in use. Six highly visible LEDs (3 line side/3 load side) communicate the electrical status of the switch by phase. This voltage detection feature significantly improves existing safety and maintenance procedures by visually providing personnel critical information prior to removing the enclosure cover; e.g. a welded contact or dropped phase. Hubbell inSIGHT phase indicating disconnect switches are available in non-metallic and stainless steel versions. Replacement covers are available for upgrades to existing installations. With an ever growing focus on safety improvements Hubbell inSIGHT disconnects provide a difference you literally can see. TM TM FEATURES  Six highly visible integral phase identification LEDs  External LEDs provide secondary means of visual confirmation of make/break on all phases  Cover cannot be removed with switch in the “ON” position  Certified by NSF for hygiene in Food Processing applications  Highly visible red handle which meets OSHA LO/TO capabilities  Available in 30 Amp non-metallic and stainless steel versions, with or without JOG switch  UL witnessed IP69k and UL Type 4X and 12 Environmental ratings IP69k *Definition per www.merriam-webster.com inSIGHT Verification of Opening of Load Side Contacts TM Circuit-Lock® 30A Disconnects with LED Indicators inSIGHT TM 30 Amp Unfused Disconnect Switches with LEDs Description Non-Metallic* Stainless Steel Square Top Stainless Steel Sloped Top Disconnect switch with LEDs HBLDS3P HBLDS3SSP HBLDS3SSRP Disconnect with Jog Switch and LEDs HBLDS3PJ — HBLDS3SSRPJ LED Replacement Covers Description Non-Metallic* Stainless Steel Square Top Stainless Steel Sloped Top Replacement cover for 30A switches with LEDs HBLDS3RCP HBLDS3SSRCP HBLDS3SSRRCP *Laser Marked Auxiliary Contacts Description Catalog Number “Break After Main Break”, 1 set of n/o contacts, 1 set of n/c contacts HBLAC1 “Break Before Main Break”, 1 set of n/o contacts for use with variable frequency drives HBLAC2 Rating Information National Sanitation Foundation (NSF) Known as The Most Trusted Name in Food Safety™, NSF International has been helping businesses in the agriculture, processing, food equipment, restaurant and retail industries to navigate the food safety and regulatory environment for nearly 70 years. Water & Dust Ingress Protection: IP69k IP69k Water Test Extremely Hot (176˚) and High Pressure Water (1450 psi) sprayed from various angles. IP69k Dust Test Device is placed in a dust chamber for 8 hours while a vacuum tries to pull dust into the sealed device. © 2014 NSF International. All rights reserved. Visit hubbell-wiring.com to see Hubbell's complete line of 30-200 Amp Disconnects 30A Labelless Disconnects Disconnects for use with VFD 30A Labelless Disconnects with JOG Switch 200A Disconnects www.hubbell-wiring.com Hubbell Wiring Systems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 • Phone (800) 288-6000 • FAX (800) 255-1031 Printed in U.S.A. Specifications subject to change without notice. WLFDS008 4/17
HBLDS3SSP 价格&库存
很抱歉,暂时无法提供与“HBLDS3SSP”相匹配的价格&库存,您可以联系我们找货
