HBL13R22
HBL13R22
    HUBBELL(哈伯尔公司)
    HUBBELL WIRING DEVICES - HBL13R22 - SW DISCONNECTOR, 2P, 30A, 600VAC, FLANGE
HBL13R22 数据手册
Switched Disconnects and Enclosures ® Circuit-Lock 30A 2-Pole NEMA 3 and 3R Enclosures with Switch, Features Non-metallic enclosure Ideal for use on outdoor equipment Ordering Information Description HBL7832D in NEMA 3R non-metallic enclosure, Ideal for use on outdoor equipment UPC Number 783585680958 Catalog Number HBL13R22 Listings UL 508 CSA-C22.2 No.14 Specifications Enclosure Material Water Ingress Thermoplastic 3 Performance Electrical Dielectric Voltage Electrical Life Max. Working Voltage Short Circuit Current Ratings (SCCR): (Motor Disconnect) Mechanical Mechanical Life Terminal Accommodations Wire Type Environmental Flammability Operating Temperature 2,200V AC minimum for 1 minute Min. 6,000 Cycles at rated switch load 600V AC RMS 60A max. when protected by J fuses 10,000 minimum cycles #10 AWG Max. Solid and stranded copper wire only Online Resources UL94HB/VO Max. Continous: 75°C; Min. Continuous: -40°C without impact Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. Customer Use Drawing eCatalog Installation Instructions
HBL13R22 价格&库存
很抱歉,暂时无法提供与“HBL13R22”相匹配的价格&库存,您可以联系我们找货
