HBL2323
HBL2323
    HUBBELL(哈伯尔公司)
HBL2323 数据手册
Twist-Lock® Devices 20 Ampere, 125, 250 Volts and 277 Volts AC 2 Pole, 3 Wire Grounding W X G W G G Y 20A 125V NEMA L5-20R UL/CSA 1 HP Connector Bodies Watertight Safety-Shroud® 20A 250V NEMA L6-20R UL/CSA 2 HP IP66 SUITABILITY Description Cord Dia. Catalog Number Black Valox® housing, white Valox® clamps. .360"-.930" (9-24) HBL2313SW Insulgrip® 20A 277V AC NEMA L7-20R UL/CSA 2 HP UL Type 4x, 12 HBL2323SW IP20 HBL2333SW 2.56" (65.0) 4.38" (111.1) SUITABILITY Description Cord Dia. Catalog Number Black and white nylon. .360"-.930" (9-24) HBL2313 HBL2323 Corrosion resistant, yellow nylon. .360"-.930" (9-24) HBL23CM13 HBL23CM23 – All black nylon. .360"-.930" (9-24) HBL2313BK HBL2323BK – Cord clamps with removable inserts. All black nylon. .360"-.930" (9-24) HBL2313EBK HBL2323EBK – HBL2323SW HBL2333 3.86" (98.0) 2.26" (57.4) 1.97" (50.0) HBL2313 Note: See page B-51 for accessories. 2.60" (66.0) Valise® IP20 SUITABILITY Description Cord Dia. Catalog Number Yellow nylon. .325"-.720" (8.26-18.3) HBL2313VY HBL2323VY Black nylon. .325"-.720" (8.26-18.3) HBL2313VBK HBL2323VBK – 1.78" (45.2) HBL2333VBK HBL2313VY Note: See page B-51 for accessories. 2.69" (68.3) Receptacles Watertight Safety-Shroud® Description Gray Valox® IP66 SUITABILITY UL Type 4x, 12 3.75" (95.3) Catalog Number housing and flange, back wired. HBL2310SW HBL2320SW HBL2330SW Note: See page B-54 for accessories. Safety-Shroud® Twist-Lock® IP20 3.75" (95.3) SUITABILITY Description Catalog Number Gray Valox® angle housing, one gang, back wired. HBL2310AR HBL2320AR HBL2330AR Gray Valox® surface mounting, one gang, back wired. HBL2310SR HBL2320SR HBL2330SR Gray Valox® semi-flush, two gang, back wired. HBL2320SR2 HBL2330SR2 HBL2310SR2 HBL2320SW 3.14" (79.8) Note: See page B-54 for accessories. 4.57" (116.1) Single Flush Receptacles IP20 SUITABILITY Description Catalog Number Black nylon face, back and side wired. HBL2310 HBL2320 Blue nylon face, back and side wired. HBL2310M7 HBL2320M4 – Isolated ground, orange nylon face, back and side wired. IG2310 IG2320 – Corrosion resistant, yellow nylon face, back and side wired. HBL23CM10 Ring terminal connection. HBL2310RT HBL2330 – 2.88" (73.2) HBL2320AR 1.58" (40.1) – HBL2320RT – Note: See page B-50 for accessories. Insulgrip® 1.50" (38.1) 4.56" (115.8) Flanged Receptacles Description Catalog Number Nylon casing, back wired. HBL2316 HBL2326 HBL2336 Note: See page B-50 for accessories. HBL2320SR Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. www.hubbell-wiring.com 2.84" (72.1) Dimensions in Inches (mm) ® Wiring Device-Kellems B-19
HBL2323 价格&库存
很抱歉,暂时无法提供与“HBL2323”相匹配的价格&库存,您可以联系我们找货
