HBL2820ST
HBL2820ST
    HUBBELL(哈伯尔公司)
    HUBBELL WIRING DEVICES - HBL2820ST - CONN, POWER ENTRY, NEMA L22-30R, 480V
HBL2820ST 数据手册
30A, 3 Phase Y 277/480V AC, 4 Pole, 5 Wire Grounding Spring Termination Single Flush Receptacle Features Faster termination time No need for screwdriver and torque wrench Spring Termination eliminates strand relaxation High-impact, abuse-resistant nylon face Face color coding by voltage facilitates locating and mating of proper devices Ordering Information Description Nylon face, back and side wire. Device Color Black UPC 783585788531 Catalog Number HBL2820ST Listings Listed to UL 498 Certified to CSA C22.2 No.42 Specifications Face Base Contacts Spring Mounting Strap Nylon Nylon Brass Steel Brass Performance Electrical Current Interrupting Dielectric Voltage Certified for current interrupting at full rated current Withstands 2,000V minimum Mechanical Flammability V2 or better per UL94/CSA 22.2 No.0.17 Terminal Accommodation #10 AWG Solid, #10 AWG to #8 AWG Stranded, #8 AWG Compact Ground Wire #10 AWG Stranded, 5" long Terminal Identification Environmental Moisture Resistance Operating Temperatures Terminals identified in accordance with UL 498 IP20 Suitability Maximum Continuous 75°C; Minimum -40°C (w/o impact) Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. Accessories Plug HBL2821 Wallplate or Weatherproof Cover 1.60" Opening Switched Enclosure SETL3
HBL2820ST 价格&库存
很抱歉,暂时无法提供与“HBL2820ST”相匹配的价格&库存,您可以联系我们找货
