HBL4100P5W
HBL4100P5W
    HUBBELL(哈伯尔公司)
HBL4100P5W 数据手册
IEC Pin and Sleeve Specifications and Horsepower Ratings Performance Electrical Dielectric Withstand Voltage Max. Working Voltage Current Interrupting Temperature Rise Endurance 3000V AC. 600V RMS (i.e., minimum creepage distance 10 millimeters, minimum clearance 8 millimeters, per IEC 60309-1 for devices rated over 500V). Certified for current interrupting at full rated current (Except DC rated devices). Max. 30°C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of 75%. 5,000 connect and disconnect cycles with load for 16A and 20A, 1,000 cycles with load and 1,000 cycles without load for 30A, 32A, 60A and 63A, and 250 cycles with load and 250 cycles without load for 100A and 125A. Mechanical Impact Resistance Cord Grip Cable Retention Cord Accommodation Terminal Identification Product Identification Per CSA C22.2 No. 182.1 / UL1682. Per CSA C22.2 No. 182.1 / UL1682. Round portable service cords of diameters commensurate with the device rating as defined in UL Standard 62, CSA C22.2 No. 49 and the harmonized European Standards. Terminals identified in accordance with North American and IEC conventions. Identification and ratings are a permanent part of the device housing. Environmental Moisture Resistance Ingress Protection Flammability Operating Temperatures Watertight per IEC 60309-1. IP67 Suitability. HB or better per UL 94 or CSA C22.2 No. 0.17. Maximum Continuous 75°C; Minimum - 40°C without impact. Materials Housings Nylon. All Other Materials Resistant to corrosion and chemical attack. Note: Specification sheets for all other Pin and Sleeve catalog numbers are available upon request. Horsepower Ratings for IEC Pin and Sleeve AC Voltage Rating Horsepower Catalog Number 3Ø 250 2 HBL420R9W HBL420P9W HBL420C9W HBL420B9W 3Ø 480 5 HBL420R7W HBL420P7W HBL420C7W HBL420B7W 3Ø 600 7.5 HBL420R5W HBL420P5W HBL420C5W HBL420B5W 3ØY 120/208 .5 HBL520R9W HBL520P9W HBL520C9W HBL520B9W 3ØY 277/480 5 HBL520R7W HBL520P7W HBL520C7W HBL520B7W 3ØY 347/600 7.5 HBL520R5W HBL520P5W HBL520C5W HBL520B5W 3Ø 250 3 HBL430R9W HBL430P9W HBL430C9W HBL430B9W 3Ø 480 7.5 HBL430R7W HBL430P7W HBL430C7W HBL430B7W 3Ø 600 10 HBL430R5W HBL430P5W HBL430C5W HBL430B5W 3ØY 120/208 2 HBL530R9W HBL530P9W HBL530C9W HBL530B9W 3ØY 277/480 7.5 HBL530R7W HBL530P7W HBL530C7W HBL530B7W 3ØY 347/600 10 HBL530R5W HBL530P5W HBL530C5W HBL530B5W 3Ø 250 5 HBL460R9W HBL460P9W HBL460C9W HBL460B9W 3Ø 480 10 HBL460R7W HBL460P7W HBL460C7W HBL460B7W 3Ø 600 15 HBL460R5W HBL460P5W HBL460C5W HBL460B5W 3ØY 120/208 3 HBL560R9W HBL560P9W HBL560C9W HBL560B9W 3ØY 277/480 10 HBL560R7W HBL560P7W HBL560C7W HBL560B7W 3ØY 347/600 15 HBL560R5W HBL560P5W HBL560C5W HBL560B5W 3Ø 250 10 HBL4100R9W HBL4100P9W HBL4100C9W HBL4100B9W 3Ø 480 30 HBL4100R7W HBL4100P7W HBL4100C7W HBL4100B7W 3Ø 600 30 HBL4100R5W HBL4100P5W HBL4100C5W HBL4100B5W 3ØY 120/208 10 HBL5100R9W HBL5100P9W HBL5100C9W HBL5100B9W 3ØY 277/480 30 HBL5100R7W HBL5100P7W HBL5100C7W HBL5100B7W 3ØY 347/600 30 HBL5100R5W HBL5100P5W HBL5100C5W HBL5100B5W www.hubbell-wiring.com ® Wiring Device-Kellems G-17
HBL4100P5W 价格&库存
很抱歉,暂时无法提供与“HBL4100P5W”相匹配的价格&库存,您可以联系我们找货
