Twist-Lock® Devices
15 Ampere, 125, 250 Volts and 277 Volts AC
2 Pole, 3 Wire Grounding
W
IP20
1.91"
(48.5)
SUITABILITY
1.53"
(38.9)
HBL4720C
1.22"
(30.9)
2.11"
(53.6)
1.53"
(38.9)
HBL4720CA
2.63"
(66.8)
Plugs
W
X
G
G
G
Y
15A 125V
NEMA L5-15P
UL/CSA
0.5 HP
15A 250V
NEMA L6-15P
UL/CSA
1.5 HP
15A 277V AC
NEMA L7-15P
UL/CSA
2 HP
Description
Cord Dia.
Catalog Number
Insulgrip plug, black and white nylon.
Multiple drive screws. Fed Spec WC596
.230"-.720"
(5.8-18.3)
HBL4720C
All black nylon.
.230"-.720"
(5.8-18.3)
HBL4720CBK
Insulgrip angle plug, 8 position angle,
black and white nylon. Multiple
drive screws.
.325"-.655"
(8.3-16.6)
HBL4720CA
Insulgrip plug, corrosion resistant,
yellow and white nylon. Multiple
.230"-.720"
(5.8-18.3)
HBL47CM20C HBL45CM70C HBL47CM70C
Elastogrip® plug, yellow elastomer,
dust tight.
300"-.655"
(7.6-16.6)
HBL2447
Elastogrip plug, yellow elastomer,
water/dust tight.
300"-.655"
(7.6-16.6)
HBL24W47
Valise® plug, yellow nylon.
.220"-.660"
(5.6-16.8)
HBL4723VY
Valise® plug, black nylon.
.220"-.660"
(5.6-16.8)
HBL4723VBK HBL4573VBK HBL4773VBK
HBL4570C
HBL4770C
HBL4570CA
HBL4573VY
HBL4770CA
HBL4773VY
Note: See page B-49 for accessories.
1.56"
(39.6)
Flanged Inlets
HBL24W47
1.88"
(47.8)
Description
Catalog Number
Insulgrip flanged inlet, nylon casing,
back wired.
HBL4716C
HBL4586C
HBL4786C
Stainless steel casing, brown phenolic.
HBL4716*
HBL4586*
HBL4786*
Corrosion resistant, stainless steel
casing, yellow melamine.
HBL47CM16*
Note: See page B-48 for accessories.
HP ratings are AC only.
Only plugs are HP rated.
See page B-69 for technical information on Insulgrip devices.
*These flanged inlets will not accept Valise® connector bodies.
1.50"
(38.1)
HBL4723VY
2.56"
(65.0)
2.19"
(55.6)
1.69"
(42.9)
.16"
(4.1)
DIA.
1.72"
(43.7)
HBL4716C
1.09"
(27.7)
1.75"
(44.5)
2.31"
(58.7)
1.50"
(38.1)
1.94"
(49.3)
.16" (4.1) DIA.
HBL4716
Dimensions in Inches (mm)
B-10
Wiring Device-Kellems
www.hubbell-wiring.com
很抱歉,暂时无法提供与“HBL4570C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2+526.357002+68.46950
- 10+369.0778010+48.01030
- 25+338.1097025+43.98190
- 50+328.2971050+42.70550
