HBL560C9W
HBL560C9W
    HUBBELL(哈伯尔公司)
HBL560C9W 数据手册
SECTION G Table of Contents HBL® Watertight IEC Pin and Sleeve Product Page Products at a Glance G-2 Configurations Chart G-3 IEC Pin and Sleeve Watertight Devices G-6 Advantage™ Series Switch-Rated Devices G-10 Corrosion Resistant Devices G-12 Data Center Pin and Sleeve G-13 Back Boxes G-14 Accessories G-15 Dimensions G-16 Horsepower Ratings G-19 ® Unfused Circuit-Lock Mechanical Interlocks Devices and “Reverse Service” G-21 Accessories and Dimensions G-22 ® Fused Circuit-Lock Mechanical Interlocks Devices and Accessories G-25 Dimensions G-26 www.hubbell-wiring.com Circuit-Lock® Unfused and Fused Mechanical Interlocks Advantage™ Series Switch-Rated Devices Product Page Low Profile Pin and Sleeve Devices and Specifications G-28 Dimensions G-29 IEC Pin and Sleeve Terminal Identification G-30 ® UL 1686 C1 Insulgrip Pin and Sleeve Style I and Style II Devices G-34 “Reverse Service” Style I and II Devices G-35 Back Boxes and Accessories G-36 Dimensions G-37 Insulgrip® Mechanical Interlocks Style II, Fused and Unfused Devices G-41 Dimensions G-42 Hazardous Location Devices Mechanical Interlocks and Plugs G-44 Dimensions G-44 ® Wiring Device-Kellems G-1 Pin and Sleeve Devices/Mechanical Interlocks Products at a Glance IEC Watertight Devices • Provide safe and dependable performance in the most demanding environments • Heavy duty non-conductive nylon construction provides impact and corrosion protection • Thermoset polyester contact carriers withstand high temperatures and provide resistance to electrical tracking Advantage™ Series Pin and Sleeve Switch-Rated Devices • Advantage™ series devices are approved as disconnecting means for both motor circuitry and branch circuits • Robust and durable housing, UV-stabilized, impact and corrosion-resistant PBT housing is designed to withstand harsh industrial environments Circuit-Lock® Mechanical Interlocks • IEC pin and sleeve devices are color coded by voltage for easy identification • Available in either fused or non-fused versions • IEC reverse service units available for safely connecting generators Corrosion Resistant Devices • This superior grade of IEC and Insulgrip devices are ideal for the most demanding environments • Nickel-plated brass on the IEC and nickelplated Tellurium copper on the Insulgrip contacts prevent corrosion and heat rise Insulgrip® NEMA 4X UL 1686 C1 Devices • Metallic where you want it and non-metallic where you need it • This tough product line is NEMA 4X rated for use in the harshest environments • Devices are fully interchangeable with other manufacturers of UL1686 C1 devices Back Boxes and Accessories • A complete line of metallic and nonmetallic back boxes, angle adapters, closure caps and liquidtight adapters are available • Accessories aid with installation efficiencies and support the various applications in which the products are used G-2 ® Wiring Device-Kellems Low Profile Devices • 90° Angled plugs and recessed receptacles allow for connections in tight spaces • Cords can be controlled easily along the wall • The integrated cord grips limit strain on terminals and prevent strain on plugs Hazardous Location Devices • Copper-free aluminum construction with electrostatically applied polyester/epoxy finish to prevent corrosion • Large visible rotary handle with ON/OFF indicator allows a quick means of disconnecting power www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks IEC Configurations Chart Singly Rated Configurations Voltage Hubbell Pin and Sleeve products are designed and manufactured to meet the International Standard IEC 60309-1 and IEC 60309-2. This device standard calls out a singly rated, non-interchangeable configuration for every voltage and type of service throughout the world. Pin and sleeve device housings are color coded by voltage rating. The voltage is determined by the location of the female ground contact relative to the housing keyway. Simply by manufacturing the device with a ground contact in a certain “clock” position, the device will be rated for a particular voltage system. The diagram shows the keying position and the color coding that is associated with each voltage. 3Ø 250V 2P Gr ole ou 11 12 1 10 2 9 3 4 8 7 6 5 380415V 250V DC 380V 50Hz 440V 60Hz 125V AC 550V DC 480V AC 400V DC 3Ø 480V AC Color re Wi 3 ing nd 3ØY 120/208V ire W 4 ing d 440-460V (60Hz) 3 Gr Pol ou e n 125/250V AC ire W 5 ng di 4 Gr Pol ou e n Rated Voltage 100V - 130V 125V/250V 200V - 250V 277V 380V - 480V 500V - 690V 277V AC 250V AC 380-415V AC 3ØY 277/480V 3Ø 600V AC 3ØY 347/600V 200/346V AC 240/415V AC Typical IEC Pin and Sleeve Catalog Number HBL4100C12W HBL 4 100 C 12 W Hubbell Catalog Number 4 Wire 100 Amp Watertight Female Ground Sleeve at “12” O’Clock (125/250V) “C” Connector Explanation 1 (HBL) Designates 2 First Digit 3 Next Series Of Digits 4 Letter 5 Hubbell Catalog 3-3 wire Preceding a letter P-Plug Number 4-4 wire 20-20 Amp R-Receptacle 5-5 wire 30-30 Amp C-Connector 60-60 Amp B-Inlet 100-100 Amp MI-Mechanical Interlock MIF-Mechanical Interlock Fused www.hubbell-wiring.com ® 6 Letter: W Last Digit(s) After the letter. This denotes Watertight the position of the ground sleeve and the assigned voltage in the receptacle as it relates to the hours of the clock. This is done to eliminate interchangeability between devices with different voltages. Wiring Device-Kellems G-3 Pin and Sleeve Devices/Mechanical Interlocks Features and Benefits RoHS IP67 SUITABILITY Watertight Devices Hubbell’s IEC 60309 Pin and Sleeve plugs, connectors, inlets and receptacles are the highest performing products available. The HBL® series of IEC pin and sleeve were designed for the demanding North American market. Hubbell was the first and is still only manufacturer of IEC 60309 devices in the USA and have numerous of innovative features noted below. G-4 Housing Design • Insulated non-metallic housing, super tough, non-conductive and chemical resistant for heavy duty industrial environments • IEC pin and sleeve devices are color coded by voltage for easy identification • Self-closing gasketed cover, detents into position to fully close automatically Liquidtight Conduit Adapters • Aluminum or non-metallic adapters are available to provide a means for attaching flexible liquidtight metal conduit to rear of Hubbell Pin and Sleeve plug or connector Powerful Mechanical Cord Grip • Hubbell’s design incorporates two molded-in teeth to securely grip the outer cable jacket, and internal conductors to prevent slippage and strain on terminations • Captive barrel nuts ease assembly and allow higher tightening torque for maximum cord retention Sequential Contact Engagement • Ground makes first and breaks last. Neutral makes second and breaks second (to prevent a momentary over-voltage on components connected phase to neutral) • Phase contacts make last and break first Watertight Cord Entrance • The tapered bore entrance creates high compression forces on sealing gland, providing a watertight seal around cord • Individual solid neoprene glands are supplied to match a full range of cord sizes and assure watertight performance Multi-Contact Spring • (60/63 and 100/125 Amp) Recessed within the female sleeve, provides and maintains high unit pressure on mating pins to minimize temperature rise • Broaches oxide film to achieve low resistance contact for cooler operation ® Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks Features and Benefits RoHS IP67 SUITABILITY Watertight Devices The IEC line of plugs and connectors are made with a rugged super tough, one-piece housing. The thermoset polyester contact carrier provides a high resistance to electrical tracking. They withstand higher temperatures which may result from overload or arcing. The heavy-duty, external cord grip provides superior strain relief on the conductors. Hubbell’s horsepower rated plugs and receptacles meet NEC 430.109(F) requirements and recognized as an approved disconnecting/“line of sight” disconnecting means. Housing Design • Rugged one-piece housing, thick wall construction protects internal components, eliminates joints preventing infiltration of contaminants • Amperage/voltage rating and catalog number molded in housing for easy identification Shrouded Pins • Super tough plug shroud protects pins from deforming from physical abuse • Protects the user from the possibility of touching live contacts during insertion and withdrawal of mating parts • Solid one-piece pins, machined from solid brass for longer life and reliable electrical contact Safety • Lockout/Tagout, tapered opening on plug shroud accommodates up to ³⁄₈ inch (9.7mm) lock shackle diameter Thermoset Polyester Contact Carrier • Molded thermoset polyester provides high resistance to electrical tracking • Withstands higher temperatures which may result from overload or arcing • Thermoset properties provide dimensional stability for this critical assembly Cord Grips • Heavy duty external cord grips provide maximum cord retention to maintain secure terminations Swivel Pressure Pads • 16/20 and 30/32 Amp devices feature patented swiveling pressure pad terminal screws and prevent damage to conductor strands. 60/63 and 100/125 Amp devices feature large hex-head stainless steel screws which provide higher torque levels for secure terminations www.hubbell-wiring.com ® Wiring Device-Kellems G-5 IP67 Pin and Sleeve Devices/Mechanical Interlocks Rating Poles Configuration and Recep./ Plug/ Amps Wires Conn. Inlet Watertight Devices AC Voltage Receptacle Plug Connector Accessories Inlet Back Boxes Non­­-Metallic Metallic* 16 2P 3W 100-130V HBL316R4W HBL316P4W HBL316C4W HBL316B4W† BB2030N 2P 3W 220-240V HBL316R6W HBL316P6W HBL316C6W HBL316B6W BB2030N 3P 4W 380-415V HBL416R6W HBL416P6W HBL416C6W HBL416B6W† BB2030N 4P 5W 220/380V 240/415V HBL516R6W HBL516P6W HBL516C6W HBL516B6W BB2030N 20 2P 3W 125V HBL320R4W HBL320P4W HBL320C4W HBL320B4W BB2030N 2P 3W 250V HBL320R6W HBL320P6W HBL320C6W HBL320B6W BB2030N 2P 3W 480V HBL320R7W HBL320P7W HBL320C7W HBL320B7W BB2030N 3P 4W 125/250V HBL420R12W HBL420P12W HBL420C12W HBL420B12W BB2030N 3P 4W 3Ø 250V HBL420R9W HBL420P9W HBL420C9W HBL420B9W BB2030N 3P 4W 3Ø 480V HBL420R7W HBL420P7W HBL420C7W HBL420B7W BB2030N 3P 4W 3Ø 600V HBL420R5W HBL420P5W HBL420C5W HBL420B5W BB2030N HBL520R9W HBL520P9W HBL520C9W HBL520B9W BB2030N HBL520R7W HBL520P7W HBL520C7W HBL520B7W BB2030N HBL520R5W HBL520P5W HBL520C5W HBL520B5W BB2030N 4P 5W 4P 5W 4P 5W 3ØY 120/208V 3ØY 277/480V 3ØY 347/600V 30 2P 3W 125V HBL330R4W HBL330P4W HBL330C4W HBL330B4W BB2030N 2P 3W 250V HBL330R6W HBL330P6W HBL330C6W HBL330B6W BB2030N 2P 3W 480V HBL330R7W HBL330P7W HBL330C7W HBL330B7W BB2030N 3P 4W 125/250V HBL430R12W HBL430P12W HBL430C12W HBL430B12W BB2030N 3P 4W 3Ø 250V HBL430R9W HBL430P9W HBL430C9W HBL430B9W BB2030N 3P 4W 3Ø 480V HBL430R7W HBL430P7W HBL430C7W HBL430B7W BB2030N 3P 4W 3Ø 600V HBL430R5W HBL430P5W HBL430C5W HBL430B5W BB2030N HBL530R9W HBL530P9W HBL530C9W HBL530B9W BB2030N HBL530R7W HBL530P7W HBL530C7W HBL530B7W BB2030N HBL530C5W HBL530B5W BB2030N 4P 5W 3ØY 120/208V 3ØY 277/480V 4P 5W 3ØY 347/600V HBL530R5W HBL530P5W 32 2P 3W 100-130V HBL332R4W† HBL332P4W† HBL332C4W† HBL332B4W† BB2030N 2P 3W 220-240V HBL332R6W HBL332P6W HBL332C6W HBL332B6W BB2030N 3P 4W 380-415V HBL432R6W HBL432P6W HBL432C6W HBL432B6W BB2030N HBL432R3W HBL432P3W HBL432C3W HBL432B3W† BB2030N HBL532R6W HBL532P6W HBL532C6W HBL532B6W BB2030N 4P 5W 3P 4W 4P 5W 380V 50Hz 440V 60Hz 220/380V 240/415V SUITABILITY BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W RoHS Replacement Interiors Closure Caps Recep./ Conn. Plug/ Inlet PC320 IN320BF IN320BM PC320 IN320BF IN320BM PC420 IN420DF IN420DM PC520 IN520EF† IN520EM PC320 IN320AF IN320AM PC320 IN320BF IN320BM PC320 IN320BF IN320BM PC420 IN420CF IN420CM PC420 IN420DF IN420DM PC420 IN420DF IN420DM PC420 IN420DF IN420DM PC520 IN520EF† IN520EM PC520 IN520EF† IN520EM PC520 IN520EF† IN520EM PC3430 IN330AF IN330AM† PC3430 IN330BF IN330BM PC3430 IN330BF IN330BM PC3430 IN430CF IN430CM PC3430 IN430DF IN430DM PC3430 IN430DF IN430DM PC3430 IN430DF IN430DM PC530 IN530EF IN530EM PC530 IN530EF IN530EM PC530 IN530EF IN530EM PC3430 IN330BF IN330BM PC3430 IN330BF IN330BM PC3430 IN430DF IN430DM PC3430 IN430DF IN430DM PC530 IN530EM IN530EF Note: See page G-14 and G-15 for back boxes and accessories, G-16 and G-17 for product dimensions, G-18 and G-19 for product specifications and HP ratings. See page G-15 for closure caps, purchased separately. PC320, PC420, PC520, PC3430, PC530 are not UL or CSA. *These boxes are cast aluminum, suitable for IP54 requirements and are finished with enamel paint. †Consult factory. G-6 ® Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks Rating Poles Configuration and Recep./ Plug/ Amps Wires Conn. Inlet 60 63 Watertight Devices AC Voltage Receptacle Plug IP67 SUITABILITY Accessories Connector Inlet Replacement Interiors Back Boxes Closure Non­­-Metallic Metallic* Caps 2P 3W 125V HBL360R4W HBL360P4W HBL360C4W HBL360B4W BB60N 2P 3W 250V HBL360R6W HBL360P6W HBL360C6W HBL360B6W BB60N 2P 3W 480V HBL360R7W HBL360P7W HBL360C7W HBL360B7W BB60N 3P 4W 125/250V HBL460R12W HBL460P12W HBL460C12W HBL460B12W BB60N 3P 4W 3Ø 250V HBL460R9W HBL460P9W HBL460C9W HBL460B9W BB60N 3P 4W 3Ø 480V HBL460R7W HBL460P7W HBL460C7W HBL460B7W BB60N 3P 4W 3Ø 600V HBL460R5W HBL460P5W HBL460C5W HBL460B5W BB60N 4P 5W 3ØY 120/208V HBL560R9W HBL560P9W HBL560C9W HBL560B9W BB60N 4P 5W 3ØY 277/480V HBL560R7W HBL560P7W HBL560C7W HBL560B7W BB60N 4P 5W 3ØY 347/600V HBL560R5W HBL560P5W HBL560C5W HBL560B5W BB60N 2P 3W 220-240V HBL363R6W HBL363P6W HBL363C6W HBL363B6W BB60N 3P 4W 380-415V HBL463R6W HBL463P6W HBL463C6W HBL463B6W BB60N 4P 5W 220/380V 240/415V HBL563R6W HBL563P6W HBL563C6W HBL563B6W BB60N BB601W BB602W BB601W BB602W BB601W BB602W BB601W BB602W BB601W BB602W BB601W BB602W BB601W BB602W BB601W BB602W BB601W BB602W BB601W BB602W BB601W BB602W BB601W BB602W BB601W BB602W BB1001W BB1002W BB1001W BB1002W BB1001W BB1002W RoHS Recep./ Conn. Plug/ Inlet PC60 IN360AF IN360AM PC60 IN360BF IN360BM† PC60 IN360BF IN360BM† PC60 IN460CF IN460CM PC60 IN460DF IN460DM PC60 IN460DF IN460DM PC60 IN460DF IN460DM PC60 IN560EF IN560EM† PC60 IN560EF IN560EM† PC60 IN560EF IN560EM† PC60 IN360BFS IN360BMS† PC60 IN460DFS IN460DMS PC60 IN560EFS† IN560EMS 100 2P 3W 125V HBL3100R4W HBL3100P4W HBL3100C4W HBL3100B4W BB100N 2P 3W 250V HBL3100R6W HBL3100P6W HBL3100C6W HBL3100B6W BB100N 2P 3W 480V HBL3100R7W HBL3100P7W HBL3100C7W HBL3100B7W BB100N 3P 4W 125/250V HBL4100R12W HBL4100P12W HBL4100C12W HBL4100B12W BB100N BB1001W PC100 IN4100CF† IN4100CM BB1002W 3P 4W 3Ø 250V HBL4100R9W HBL4100P9W HBL4100C9W HBL4100B9W BB100N BB1001W PC100 IN4100DF BB1002W IN4100DM 3P 4W 3Ø 480V HBL4100R7W HBL4100P7W HBL4100C7W HBL4100B7W BB100N BB1001W PC100 IN4100DF BB1002W IN4100DM 3P 4W 3Ø 600V HBL4100R5W HBL4100P5W HBL4100C5W HBL4100B5W BB100N BB1001W PC100 IN4100DF BB1002W IN4100DM 4P 5W 3ØY 120/208V HBL5100R9W HBL5100P9W** HBL5100C9W HBL5100B9W BB100N 4P 5W 3ØY 277/480V HBL5100R7W HBL5100P7W HBL5100C7W HBL5100B7W BB100N 4P 5W 3ØY 347/600V HBL5100R5W HBL5100P5W HBL5100C5W HBL5100B5W BB100N 125 2P 3W 220-240V HBL3125R6W HBL3125P6W HBL3125C6W HBL3125B6W BB100N 3P 4W 380-415V HBL4125R6W HBL4125P6W HBL4125C6W HBL4125B6W BB100N 4P 5W 220/380V 240/415V HBL5125R6W HBL5125P6W HBL5125C6W HBL5125B6W BB100N BB1001W BB1002W BB1001W BB1002W BB1001W BB1002W BB1001W BB1002W BB1001W BB1002W BB1001W BB1002W PC100 IN3100AF IN3100AM PC100 IN3100BF IN3100BM† PC100 IN3100BF IN3100BM† PC100 IN5100EF IN5100EM PC100 IN5100EF IN5100EM PC100 IN5100EF IN5100EM PC100 IN3100BFS† IN3100BMS† PC100 IN4100DFS IN4100DMS PC100 IN5100EFS IN5100EMS Note: See page G-14 and G-15 for back boxes and accessories, G-16 and G-17 for product dimensions, G-18 and G-19 for product specifications and HP ratings. All 63A and all 125A devices have pilot pins or contacts. See page G-15 for closure caps, purchased separately. PC60 and PC100 are not UL or CSA. *These boxes are cast aluminum, suitable for IP54 requirements and are finished with enamel paint. **Short housing plug HBL5100P9WSH. IP22 suitability. †Consult factory. www.hubbell-wiring.com ® Wiring Device-Kellems G-7 Pin and Sleeve Devices/Mechanical Interlocks IP69k Features and Benefits Advantage™ Series Pin and Sleeve Switch-Rated Hubbell Wiring Device-Kellems Advantage™ Series Pin and Sleeve SwitchRated Devices are IEC 60309-2 compatible devices that are approved as a disconnecting means for motor and branch circuits. Compact design, this device is similar in size to standard IEC 60309-2 devices. Robust and durable housing, UV-stabilized, impact and corrosion-resistant PBT housing is designed to withstand harsh industrial environments. Stainless steel hardware provides superior corrosion resistance in wet and harsh environments Receptacles mount to standard Hubbell IEC Pin and Sleeve back boxes. G-8 Housing Design • Rugged one-piece housing, thick wall construction protects internal components, eliminates joints preventing infiltration of contaminants • IEC pin and sleeve devices are color coded by voltage for easy identification Heavy Duty External Cord Grips • Provides maximum cord retention to maintain unstressed terminations • Pocketed recess for screws deters slippage of the screwdriver and are conveniently located on the same side for easy installation Ease of Use • Ergonomic design puts the Advantage™ into the palm of your hands with the easy-to-use leverage grip design from Hubbell Spring-Loaded Cover • Spring-loaded to the open position, reminding users that the cover must be secured to ensure maximum ingress protection • Impact resistant cover arm compact and durable internal swing arm is fully shrouded protecting it from damage Spring-Loaded Disconnect Button • Oversized for easy actuation with gloved hands Full Line of Accessories • Advantage series receptacles have same mounting pattern as our standard receptacles, for non-metallic and metallic back boxes (see page G-14) • Full offering of liquidtight adapters (see page G-15) ® Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks IP69k Features and Benefits Advantage™ Series Pin and Sleeve Switch-Rated The Advantage™ Series has a UL witnessed IP69k and 4X,12 environmental rating, two power-indicating LEDs, continuous ground engagement, labelless laser markings and a compact and ergonomic design. Hubbell’s Pin and Sleeve connections have always been safe – that hasn’t changed. The Advantage™ series simply has more… Advantages. The Hubbell Advantages Sleek and Modern Design • The ergonomic device is easy to keep clean making it ideal for hygienic food processing facilities Permanent Labelless Markings • Product ratings are laser-marked into the device and will not wash off for easy permanent identification Continuous Ground Engagement • Unswitched feed-through ground pin is first-to-make and last-to-break followed by switched neutral and phase contact(s) Superior Water Ingress Protection • UL witnessed IP69k and UL Type 4X and 12. Device is built to withstand wet and harsh environments IP69k IEC 60309 Singularly Rated Device • Mates with existing installed base of IEC 60309-2 pin and sleeve devices. Color coded by voltage for easy identification of mating devices Power Indicating LED Lights • Highly visible and long lasting green LED lights on both sides of the device provide visual verification of power when connected PWR www.hubbell-wiring.com ® Wiring Device-Kellems G-9 Pin and Sleeve Devices/Mechanical Interlocks Rating IP69k Pin and Sleeve Devices Poles Configuration and Recep./ Plug/ Amps Wires Conn. Inlet AC Voltage Connector Receptacle HBLS330R4W HP Accessories Mating Plug** IP67 Inlet Back Boxes Closure Caps 30 2P 3W 125V HBLS330C4W 2 HBLS330P4W HBL330B4W BB2030N PC3430 32 2P 3W 100-130V HBLS332C4W HBLS332R4W 2 HBLS332P4W HBL332B4W BB2030N PC3430 30 2P 3W 250V HBLS330C6W* HBLS330R6W* 5 HBLS330P6W* HBL330B6W* BB2030N PC3430 32 2P 3W 220-240V 30 2P 3W 480V HBLS330C7W HBLS330R7W 10 HBLS330P7W HBL330B7W BB2030N PC3430 30 3P 4W 125/250V HBLS430C12W HBLS430R12W 2 HBLS430P12W HBL430B12W BB2030N PC3430 30/32 3P 4W 3Ø 250V HBLS430C9W* HBLS430R9W* 10 HBLS430P9W* HBL430B9W* BB2030N PC3430 30 3P 4W 3Ø 480V HBLS430C7W HBLS430R7W 20 HBLS430P7W HBL430B7W BB2030N PC3430 30 3P 4W 3Ø 600V HBLS430C5W HBLS430R5W 30 HBLS430P5W HBL430B5W BB2030N PC3430 380-415V HBLS430C6W* HBLS430R6W* 7.5 HBLS430P6W* HBL430B6W* BB2030N PC3430 30/32 3P 4W 32 3P 4W 380-440V HBLS432C3W HBLS432R3W 10 HBLS432P3W HBL432B3W BB2030N PC3430 30 4P 5W 3ØY 347/600V HBLS530C5W HBLS530R5W 30 HBLS530P5W HBL530B5W BB2030N PC530 30 4P 5W HBLS530C6W* HBLS530R6W* 7.5 HBLS530P6W* HBL530B6W* BB2030N PC530 32 4P 5W 200/346240/415V 220/380V 240/415V 30 4P 5W 3ØY 277/480V HBLS530C7W HBLS530R7W 20 HBLS530P7W HBL530B7W BB2030N PC530 30/32 4P 5W 3ØY 120/208V HBLS530C9W* HBLS530R9W* 10 HBLS530P9W* HBL530B9W* BB2030N PC530 Note: *Certain IEC configurations allow for a single product to be certified as both a North American (Series 2) and International amperage (Series 1). These products are marked accordingly with both the UL Listing and UL Classified markings. **Mating plug required to maintain 4X/IP69k ratings when used with ADVANTAGE™ Series Connections. ADVANTAGE™ Series Receptacles have the same mounting pattern as standard Hubbell IEC pin and sleeve. Materials Specifications Part Material Connector Receptacle Cover Temperature Rise < 30°C PBT X X Dielectric Voltage Min 2,200V AC Cover Gasket Neporene X X Electrical Life Housing PBT X X X Min 6,000 Cycles at rated switch load (p.f.= .75-.80) Gasket Santoprene X X X Max Working Voltage 600V AC X X Current Interrupting Certified for current interrupting at full rated current and voltage Horsepower Locked Rotor Test 50 Operations at 600% of full load motor current (p.f.= .40-.50) Short Circuit 100kA when protected by 100A Class J fuse or 125A RK1 fuse Endurance Min 10,000 mating cycles Flammability HB or Better per UL 94 or CSA C22.2 No. 0.17 Female Contact Carrier Nylon Male Contact Carrier Thermoset Plug/Inlet X Phase, Ground Sleeves Brass X X Sleeve Springs X X Beryllium Copper with Silver Plating Pins Brass Glands Solid Neoprene X X X Cord Clamps PBT X X Clamp Nut Nickel-Plated Brass X Screws Stainless Steel (300 Series) X Locking Ring PBT Switch Contacts Laminated Silver G-10 X X X X X ® Operating Temperature Max Continuous +75°C; Min continous -40°C Environmental Type 4X, 12 and IP69k UV Resistance All materials are UV stabilized X Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks Rating IP69k Pin and Sleeve Devices Poles Configuration and Recep./ Plug/ Amps Wires Conn. Inlet AC Voltage Connector Receptacle HBLS360C4W HBLS360R4W HBLS360C6W* HP Accessories Mating Plug** Inlet** Back Boxes Closure Caps 3 HBLS360P4W HBLS360B4W BB60N PC60 HBLS360R6W* 7.5 HBLS360P6W* HBLS360B6W* BB60N PC60 60 2P 3W 125V 60 2P 3W 250V 63 2P 3W 220-240V 60 2P 3W 480V HBLS360C7W HBLS360R7W 15 HBLS360P7W HBLS360B7W BB60N PC60 60 3P 4W 125/250V HBLS460C12W HBLS460R12W 30 HBLS460P12W HBLS460B12W BB60N PC60 60/63 3P 4W 3Ø 250V HBLS460C9W* HBLS460R9W* 10 HBLS460P9W* HBLS460B9W* BB60N PC60 60 3P 4W 3Ø 480V HBLS460C7W HBLS460R7W 30 HBLS460P7W HBLS460B7W BB60N PC60 60 3P 4W 3Ø 600V HBLS460C5W HBLS460R5W 40 HBLS460P5W HBLS460B5W BB60N PC60 380-415V HBLS460C6W* HBLS460R6W* 10 HBLS460P6W* HBLS460B6W* BB60N PC60 3ØY 347/600V HBLS560C5W HBLS560R5W 40 HBLS560P5W HBLS560B5W BB60N PC60 200/346240/415V HBLS560C6W* HBLS560R6W* 10 HBLS560P6W* HBLS560B6W* BB60N PC60 4P 5W 3ØY 277/480V HBLS560C7W HBLS560R7W 30 HBLS560P7W HBLS560B7W BB60N PC60 60/63 4P 5W 3ØY 120/208V HBLS560C9W* HBLS560R9W* 10 HBLS560P9W* HBLS560B9W* BB60N PC60 60/63 3P 4W 60 4P 5W 60/63 4P 5W 60 Note: *Certain IEC configurations allow for a single product to be certified as both a North American (Series 2) and International amperage (Series 1). These products are marked accordingly with both the UL Listing and UL Classified markings. **Mating plug or inlet required to maintain 4X/IP69k ratings when used with ADVANTAGE™ Series Connections. ADVANTAGE™ Series Receptacles have the same mounting pattern as standard Hubbell IEC pin and sleeve. Just add a "P" suffix for Pilot pin for 60 amp devices. Optional Pilot Pin Available on All 60A Devices The Pilot Pin is smaller than the ground and phase pins and are designed to make after main and break before main breaks. This pin can be used to communicate with auxiliary devices within your facility. They are “Break before main break” and by design are the last contact in the sequence to make and first to break. Rating Amps Poles/ Wires 60/63 3P 4W Pin and Sleeve Devices AC Voltage 3Ø 250V Connector with Pilot Sleeve Receptacle with Pilot Sleeve Plug with Pilot Pin Inlet with Pilot Pin HBLS460C9WP* HBLS460R9WP* HBLS460P9WP* HBLS460B9WP* Note: *Just add a "P" suffix for Pilot pin for 60 amp devices. Dimensions A Description Connector B C D E Receptacle F G 30A 9.9" (251.5) 4.5" (114.3) 1.06" (27.2) 3.83" (97.3) 3.13" (79.4) 3.75" (95.2) 4.5" (114.3) 60A 12.22" (310.4) 5.17" (131.3) 1.85" (47.0) 4.77" (121.2) 3.88" (98.6) 4.52" (114.8) 5.09" (129.3) Ø .22" (5.59) X 4 G B A D C E F Dimensions in Inches (mm) www.hubbell-wiring.com ® Wiring Device-Kellems G-11 Pin and Sleeve Devices/Mechanical Interlocks IP67 Corrosion Resistant Devices that Withstand the Most Abusive Environments SUITABILITY RoHS Hubbell offers a superior grade of 100A IEC Pin and Sleeve designed for use in the most demanding environments. These devices feature nickel plated solid brass pins for long life and reliable electrical contact in the most corrosive environments. They have a high visibility yellow supertough nylon housing. The heavy duty external cord clamps provide maximum cord retention to maintain secure terminations. The screws and fasteners are made from stainless steel. • Food Processing • Water Treatment • Meat Packing • Agriculture • Factory • Washdown • Construction • Outdoor Entertainment • Temporary Power Standard Service Rating Amps 100 Poles And Wires Configuration Recep./ Conn. Plug Watertight Devices AC Voltage Receptacle Plug Accessories Connector Back Boxes Non­­-Metallic Metallic* Closure Caps 3P 4W 125/250V M4100R12 M4100P12 M4100C12 BB100N BB1001W BB1002W PC100 4P 5W 3ØY 120/208V M5100R9 M5100P9 M5100C9 BB100N BB1001W BB1002W PC100 4P 5W 3ØY 277/480V M5100R7 M5100P7 M5100C7 BB100N BB1001W BB1002W PC100 "Reverse Service" Rating Amps 100 Poles And Wires Configuration Conn. Inlet Watertight Devices AC Voltage Inlet Plug Accessories Connector Back Boxes Non­­-Metallic Metallic* Closure Caps 3P 4W 125/250V M4100B12R — M4100C12R BB100N BB1001W BB1002W PC100 4P 5W 3ØY 120/208V M5100B9R — M5100C9R BB100N BB1001W BB1002W PC100 4P 5W 3ØY 277/480V M5100B7R — M5100C7R BB100N BB1001W BB1002W PC100 Note: *These boxes are cast aluminum, suitable for IP54 requirements and are finished with enamel paint. See page Y-17 for corrosion resistant cord sets. G-12 ® Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks IP67 Data Center DC Rated Pin and Sleeve Devices RoHS SUITABILITY In today’s environmentally conscious world, energy savings is a pinnacle part of going green. DC (Direct Current) is being used to reduce power consumption and decrease the amount of infrastructure needed to energize specific types of data center equipment. Electrical devices provide a means of connecting DC power. Hubbell is the first manufacturer to introduce a series of IEC Pin and Sleeve devices configured for the UL1686 eight o’clock ground position for DC voltage (Disconnecting use only). Hubbell’s IEC DC rated pin and sleeve line has been qualified by UL to the requirements of DC voltage. The thermoset polyester contact carrier provide high resistance to electrical tracking, it withstands higher temperatures for this type of demanding application. The solid one-piece pins are machined from solid brass for longer life and reliable electrical contact. In addition, the heavy-duty external cord grips provide maximum cord retention to maintain secure terminations. Finally, the super tough, color coded, non-conductive V-0 rated PBT housing is heavy duty for safety and protecting the internal components. Rating Amps 30 60 100 Poles And Wires Configuration Recep./ Conn. Plug Watertight Devices DC Voltage Receptacle Plug Connector 2P 3W 550V HBL330R8WDC HBL330P8V0DC HBL330C8V0DC 2P 3W 550V HBL360R8WDC* HBL360P8V0DC HBL360C8V0DC 2P 3W 550V HBL3100R8WDC HBL3100P8V0DC HBL3100C8V0DC 4P 5W 400V HBL5100R8WDC HBL5100P8V0DC HBL5100C8V0DC Note: *Inlet available - HBL360B8WDC. IP67 RoHS SUITABILITY Dual Certified Pin and Sleeve Devices Hubbell’s dual certified pin and sleeve devices are ideal for the data center and high tech server industry. They are UL Listed to UL1682 for the North American market and are TUV Rheinland Certified for the European and International market. Customers can use the same plug and connector for multiple electrical configurations. They reduce the number of SKU’s end users have to use if they sell to both domestic and overseas customers. These devices are IP67 rated, RoHs compliant and showcase all the inherent safety benefits of their V-0 rated PBT housing and internal components. Rating Amps 30/32 60/63 Poles And Wires Configuration Recep./ Conn. Plug Watertight Devices AC Voltage Receptacle Plug Connector Inlet 3P 4W 380-415V HBL430R6V02 HBL430P6V02 HBL430C6V02 HBL430B6V02 4P 5W 200/346V 240/415V HBL530R6V02 HBL530P6V02 HBL530C6V02 HBL530B6V02 3P 4W 380-415V HBL460R6V02 HBL460P6V02 HBL460C6V02 HBL460B6V02 4P 5W 200/346V 240/415V HBL560R6V02 HBL560P6V02 HBL560C6V02 HBL560B6V02 www.hubbell-wiring.com ® Wiring Device-Kellems G-13 Pin and Sleeve Devices/Mechanical Interlocks RoHS Back Boxes Hubbell manufactures an extensive line of back boxes for use with IEC Pin and Sleeve devices. Each back box is designed to give the user the maximum amount of wiring room while achieving grounding to metallic conduit. Hubbell back boxes are available in non-metallic and cast metal versions. Non-Metallic 15º Angle Back Box BB60N Description NPT Hub Size* Back box for 16, 20, 30 and 32A devices. 1" Catalog Number BB2030N Back box for 60 and 63A devices. 1¼" BB60N Back box for 100 and 125A devices. 1½" BB100N Note: *Hub is not included; order one of the following Raco® part numbers: 1 in. = 1704, 1¼ in. = 1705, 1½ in. = 1706. These boxes meets IP67 requirement and Type 4X requirements when installed with a watertight conduit hub. Metallic 15º Angle Back Box and Adapter** Description BB601W NPT Hub Size Back box for 16, 20, 30 and 32A devices. Back box for 60 and 63A devices. Back box for 100 and 125A devices. Angle adapter only for 60, 63, 100 and 125A devices. Catalog Number ¾" BB201W 1" BB301W 1¼" BB601W 1½" BB602W 1½" BB1001W 2" BB1002W – AA6010015 Note: **These boxes are cast aluminum, suitable for IP54 requirements and are finished with enamel paint. FW6010055 Metallic 55º Angle Back Box and Adapter** Description NPT Hub Size Catalog Number Feed-thru box back box and adapter for 16, 20, 30 and 32A devices. 1" AB203055 Angle adapter only. – AA203055 Back box and adapter for 60, 63, 100 and 125A devices. Angle adapter only. 1½" FW6010055 – AA6010055 Note: **These boxes are cast aluminum, suitable for IP54 requirements and are finished with enamel paint. FT202W Metallic Feed-Thru Back Box** Description NPT Hub Size Feed-thru box for 16, 20, 30 and 32A devices. Catalog Number ¾" FT202W 1" FT302W Note: **These boxes are cast aluminum, suitable for IP54 requirements and are finished with enamel paint. Metallic Four-Way 15º Angle Back Box** FW60100 Description NPT Hub Size Four-way box for 60, 63, 100 and 125A devices. 1½" Catalog Number FW60100 Note: **These boxes are cast aluminum, suitable for IP54 requirements and are finished with enamel paint. Straight Wall Box Adapter HBL2030AP Description Catalog Number Adapts 16, 20, 30 and 32A Watertight IEC Pin and Sleeve devices to 2-gang, device boxes and FD boxes. HBL2030AP Angle Wall Box Adapter AA2030PS G-14 Description Catalog Number Adapts 16, 20, 30 and 32A Watertight IEC Pin and Sleeve devices to standard wall boxes. AA2030PS Note: Adapts 20 and 30A Watertight Pin and Sleeve receptacle to single, 2-gang standard wall box and 4 or 4¹¹⁄₁₆⁄₁₆ inch square for non-watertight applications. ® Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks Accessories Closure Caps Cap assemblies provide watertight sealing to a disconnected male IEC Pin and Sleeve plug or inlet. Manufactured of the same tough non-metallic material as the watertight IEC Pin and Sleeve devices for corrosion and abuse resistance. Description Catalog Number Fits all 16 and 20A, 3 wire plugs and inlets. Fits all 16 and 20A, 4 wire plugs and inlets. Fits all 16 and 20A, 5 wire plugs and inlets. Fits all 30 and 32A, 3 and 4 wire plugs and inlets. Fits all 30 and 32A, 5 wire plugs and inlets. Fits all 60 and 63A plugs and inlets. Fits all 100 and 125A plugs and inlets. PC320 PC420 PC520 PC3430 PC530 PC60 PC100 PC3430 Cover Assemblies Replacement cover assemblies for use with watertight connector bodies and receptacles. Kit contains cover, arm assembly and installation tool. Description Catalog Number Fits all 16 and 20A, 3 wire watertight female devices. Fits all 16 and 20A, 4 wire watertight female devices. Fits all 16 and 20A, 5 wire watertight female devices. Fits all 30 and 32A, 3 and 4 wire watertight female devices. Fits all 30 and 32A, 5 wire watertight female devices. Fits all 60 and 63A watertight female devices. Fits all 100 and 125A watertight female devices. CA320 CA420 CA520 CA3430 CA530 CA60 CA100 CA3430 Cord Clamp and Locking Ring Replacement cord clamp and locking ring for use with IEC plugs, connectors and inlets. Description Cord Clamp and Locking Ring Locking Ring Only Fits all 16 and 20A, 3 wire plugs, connectors and inlets. Fits all 16 and 20A, 4 wire plugs, connectors and inlets. Fits all 16 and 20A, 5 wire plugs, connectors and inlets. Fits all 30 and 32A, 3 and 4 wire plugs, connectors and inlets. Fits all 30 and 32A, 5 wire plugs, connectors and inlets. Fits all 60 and 63A plugs, connectors and inlets. Fits all 100 and 125A plugs, connectors and inlets. CC320 CC420 CC520† CC3430 CC530† CC60 CC100 LR320* LR420* LR520* LR3430* LR530* LR60* LR100* CC3430 Note: *Locking Ring only for plugs and inlets. †Consult factory. LR3430 Liquidtight Adapters Machined aluminum adapters are available to provide a means for attaching flexible liquidtight metal conduit to rear of a Hubbell Pin and Sleeve plug or connector. To install, remove cord grip and two gland cap screws. Use screws to attach adapter. Kellems® liquidtight conduit connectors are available to control arc of bend and to prevent conduit pull-out where vibration, motion or strain is present. These grips interface directly with Hubbell’s liquidtight adapters and are available in a wide variety of NPT sizes and configurations. Consult your local code grounding requirements before using liquidtight adapters. Liquidtight Adapters Rating of Hubbell Pin and Sleeve Device Liquidtight Conduit Size Aluminum Non-Metallic Optional Kellems Liquidtight Conduit Grip 16 and 20 Amp 3 and 4 Wire ½" NPT ¾" NPT ½" NPT ¾" NPT 1" NPT ½" NPT ¾" NPT 1" NPT 1¼" NPT 1¼" NPT 1½" NPT SAA12 SAA34 SAB12 SAB34 SAB100 SAC12 SAC34 SAC100 SAC125 SAD125 SAD150 — — — — — SAC12NM SAC34NM SAC100NM — — — 074093402 074093403 074093402 074093403 074093404 074093402 074093403 074093404 074093405 074093405 074093406 16 and 20 Amp 5 wire and 30 and 32 Amp 3 and 4 wire 30 and 32 Amp 5 wire and 60 and 63 Amp (all) 100 and 125 Amp (all) www.hubbell-wiring.com ® SAB34 074093403 Wiring Device-Kellems G-15 Pin and Sleeve Devices/Mechanical Interlocks Plug Dimensions Plug Type B A Short Housing Plug B A B Cord Grip Range HBL320P 6.61" (167.8) 2.87" (73.0) .330"-.830" (8.4-21.1) HBL420P 7.00" (177.8) 3.19" (81.0) .330"-.830" (8.4-21.1) HBL520P 7.65" (194.3) 3.50" (89.0) .330"-.830" (8.4-21.1) HBL330P 8.05" (204.5) 3.74" (95.0) .375"-1.250" (9.5-31.8) HBL430P 8.05" (204.5) 3.74" (95.0) .375"-1.250" (9.5-31.8) HBL530P 8.54" (216.9) 4.02" (102.0) .500"-1.450" (12.7-36.8) HBL360P, HBL460P, HBL560P 10.15" (257.8) 4.49" (114.0) .500"-1.450" (12.7-36.8) HBL3100P, HBL4100P, M4100P, HBL5100P, M5100P 12.63" (320.8) 4.92" (125.0) 1.065"-1.940" (27.1-49.3) Short Housing Plug Dimensions Type A HBL5100P9WSH A B Cord Grip Range 8.30" (210.82) 4.92" (125.0) 1.065"-1.940" (27.1-49.3) Connector Body Dimensions Connector Body Type B A Inlet B D A B Cord Grip Range HBL320C 7.49" (190.3) 3.33" (84.6) .330"-.830" (8.4-21.1) HBL420C 7.90" (200.6) 3.66" (93.0) .330"-.830" (8.4-21.1) HBL520C 8.54" (216.9) 3.94" (100.0) .330"-.830" (8.4-21.1) HBL330C 9.05" (229.9) 4.27" (108.5) .375"-1.250" (9.5-31.8) HBL430C 9.05" (229.9) 4.27" (108.5) .375"-1.250" (9.5-31.8) HBL530C 9.68" (245.8) 4.70" (119.5) .500"-1.450" (12.7-36.8) HBL360C, HBL460C, HBL560C 11.15" (283.2) 5.10" (129.5) .500"-1.450" (12.7-36.8) HBL3100C, HBL4100C, M4100C, HBL5100C, M5100C 13.57" (344.7) 5.71" (145) 1.065"-1.940" (27.1-49.3) Inlet Dimensions Type A C E F ⁷⁄₃₂" (5.5) Dia. (4 Holes) Receptacle A B C D E F HBL320B 2.54" (64.5) 1.85" (47.0) 1.14" (29.0) 2.72" (69.0) 3.75" (95.3) 3.13" (79.5) HBL420B 2.54" (64.5) 2.11" (53.6) 1.14" (29.0) 2.72" (69.0) 3.75" (95.3) 3.13" (79.5) HBL520B 2.54" (64.5) 2.41" (61.2) 1.14" (29.0) 2.72" (69.0) 3.75" (95.3) 3.13" (79.5) HBL330B 2.99" (76.0) 2.49" (63.2) 1.04" (26.5) 2.72" (69.0) 3.75" (95.3) 3.13" (79.5) HBL430B 2.99" (76.0) 2.49" (63.2) 1.04" (26.5) 2.72" (69.0) 3.75" (95.3) 3.13" (79.5) HBL530B 2.99" (76.0) 2.75" (69.9) 1.04" (26.5) 2.80" (71.0) 3.75" (95.3) 3.13" (79.5) HBL360B, 4.04" (102.6) HBL460B, HBL560B 2.97" (75.5) 1.18" (30.0) 3.46" (88.0) 4.50" (114.3) 3.88" (98.5) HBL3100B, 4.53" (115) HBL4100B, M4100B, HBL5100B, M5100B 3.44" (87.5) 1.95" (49.5) 3.94" (100.0) 5.50" (139.7) 4.88" (124.0) Receptacle Dimensions A D B E F ⁷⁄₃₂" (5.5) Dia. (4 Holes) Type A B C D E F HBL320R 3.33" (84.5) 2.78" (70.6) 1.02" (26.0) 2.72" (69.0) 3.75" (95.3) 3.13" (79.5) HBL420R 3.66" (93.0) 2.78" (70.6) 1.02" (26.0) 2.72" (69.0) 3.75" (95.3) 3.13" (79.5) HBL520R 3.94" (100.0) 2.78" (70.6) 1.02" (26.0) 2.72" (69.0) 3.75" (95.3) 3.13" (79.5) C HBL330R 4.27" (108.5) 3.09" (78.5) 1.16" (29.5) 2.72" (69.0) 3.75" (95.3) 3.13" (79.5) HBL430R 4.27" (108.5) 3.09" (78.5) 1.16" (29.5) 2.72" (69.0) 3.75" (95.3) 3.13" (79.5) HBL530R 4.70" (119.4) 3.09" (78.5) 1.16" (29.5) 2.83" (71.9) 3.75" (95.3) 3.13" (79.5) HBL360R, 5.10" (129.5) HBL460R, HBL560R 4.07" (103.4) 1.69" (43.0) 3.46" (88.0) 4.50" (114.3) 3.88" (98.6) HBL3100R, 5.71" (145) HBL4100R, M4100R, HBL5100R, M5100R 4.23" (107.4) 2.46" (62.5) 3.95" (100.3) 5.50" (139.7) 4.88" (123.9) Note: 20, 30, 60 and 100A devices are dimensionally equivalent to 16, 32, 63 and 125A devices, respectively. Dimensions in Inches (mm) G-16 ® Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks Non-Metallic 15º Angle Back Box E NPT Hub Size A Inch (mm) B Inch (mm) C Inch (mm) D Inch (mm) E Inch (mm) F Inch (mm) Cubic Inch Capacity Catalog Number 1" 5.67" (144.0) 4.44" (112.8) 4.05" (102.9) 3.91" (99.3) 2.35" (59.7) 4.92" (125.0) 30.00" BB2030N Back box for 60 & 63A devices. 1¼" 7.76" (197.0) 5.16" (131.0) 5.87" (149.0) 4.72" (120.0) 2.99" (76.0) 6.94" (176.0) 70.00" BB60N Back box for 100 & 125A devices. 1½" 8.21" 6.23" (209.0) (158.0) 6.31" (160.3) 5.71" (145.0) 3.99" (101.0) 7.41" (188.0) 120.00" BB100N Description Back box for 16, 20, 30 & 32A devices. F C A 15° B D Non-Metallic Angle Box Note: *Hub is not included; order one of the following Raco® part numbers: 1 inch = 1704, 1¼ inch = 1705, 1½ inch = 1706. These boxes meet IP67 requirement and Type 4X requirements when installed with a watertight conduit hub. Metallic 15º Angle Back Box E A Inch (mm) B Inch (mm) C Inch (mm) D Inch (mm) E Inch (mm) F Inch (mm) Cubic Inch Capacity Catalog Number Back box for 16, 20, 30 & 32A devices. ¾" 5.12" (130.2) 4.00" (101.6) 4.19" (106.4) 3.75" (95.3) 3.00" (76.2) 4.00" (101.6) 30.00" BB201W Back box for 16, 20, 30 & 32A devices. 1" 5.12" (130.2) 4.00" (101.6) 4.19" (106.4) 3.75" (95.3) 3.00" (76.2) 4.00" (101.6) 30.00" BB301W Back box for 60 & 63A devices. 1¼" 7.25" (184.2) 5.25" (133.4) 6.00" (152.4) 4.50" (114.3) 3.75" (95.3) 6.19" (157.2) 80.00" BB601W Back box for 60 & 63A devices. 1½" 7.25" (184.2) 5.25" (133.4) 6.00" (152.4) 4.50" (114.3) 3.75" (95.3) 6.19" (157.2) 80.00" BB602W Back box for 100 &125A devices. 1½" 8.12" 6.75" (206.4) (171.5) 6.88" (174.6) 5.50" (139.7) 4.75" (120.7) 6.94" (176.2) 130.00" BB1001W 6.88" (174.6) 5.50" (139.7) 4.75" (120.7) 6.94" (176.2) 130.00" BB1002W Back box for 100 & 125A devices. 2" 8.12" 6.75" (206.4) (171.5) Description B Inch (mm) C Inch (mm) D Inch (mm) E Inch (mm) F Inch (mm) Cubic Inch Capacity 6.80" (172.4) 6.60" (167.0) 5.63" (142.9) 4.50" (114.3) 3.74" (95.0) – 42.27" AB203055 Angle adapter for 16, 20, 30 & 32A devices. – 4.89" (124.3) 3.33" (84.6) 4.29" (109.0) 3.75" (95.2) 2.50" (63.5) – 25.00" AA203055 8.00" 7.75" (202.9) (196.8) 6.90" (174.8) 6.00" (152.4) – 100.00" FW6010055 4.48" (113.7) 6.00" (152.4) 6.75" (171.4) 6.00" (152.4) – 79.00" AA6010055 C Inch (mm) D Inch (mm) E Inch (mm) – 6.75" (171.4) D Metallic 15º Angle Box Catalog Number 1" Angle adapter for 60, 63, 100 & 125A devices. 15° E C 55° A Inch (mm) 1½" 8.50" (215.9) F B A Feed-thru box and angle adapter for 16, 20, 30 & 32A devices. Back box and angle adapter for 60, 63, 100 & 125A devices. C B Metallic 55º Angle Back Box and Adapter NPT Hub Size A 41 Description NPT Hub Size D Metallic 55º Angle Box E 48 CU. IN. C A F Metallic Feed-Thru Back Box Description NPT Hub Size A Inch (mm) B Inch (mm) F Inch (mm) Cubic Inch Capacity Catalog Number Feed-thru box for 16, 20, 30 & 32A devices. ¾" 8.25" 3.06" (209.6) (77.8) 7.14" (181.4) 4.50" (114.3) 3.75" (95.3) 3.13" (79.5) 48.00" FT202W Feed-thru box for 16, 20, 30 & 32A devices. 1" 8.25" 3.06" (209.6) (77.8) 7.14" (181.4) 4.50" (114.3) 3.75" (95.3) 3.13" (79.5) 48.00" FT302W B D Metallic Feed-Thru Box D E B Metallic Four-Way 15º Angle Back Box B Inch (mm) C Inch (mm) D Inch (mm) E Inch (mm) Four-way box for 60, 1½" 8.75" 9.75" 63, 100 & 125A devices. (222.3) (247.7) 7.75" (196.9) 6.75" (171.5) 6.00" (152.4) Description NPT Hub Size A Inch (mm) F Inch (mm) Cubic Inch Capacity Catalog Number – 210.00" FW60100 Note: These boxes are cast aluminum, suitable for IP54 requirements and are finished with enamel paint. These boxes withstand a 500-hour salt spray test as well as UL rain tight and external icing test. A C Metallic Four-Way Angle Box Dimensions in Inches (mm) www.hubbell-wiring.com ® Wiring Device-Kellems G-17 Pin and Sleeve Devices/Mechanical Interlocks Watertight Materials Part Material Plug Housing Zytel® ST801 Nylon Locking Ring Reinforced Thermoplastic Polyester Sealing Gasket Solid Neoprene Cord Clamp Reinforced Thermoplastic Polyester Gland Cap Reinforced Thermoplastic Polyester Gland Solid Neoprene Cord Clamp Screws Stainless Steel (300 Series) Clamp Nut Nickel-Plated Brass Gland Clamp Screws Stainless Steel (300 Series) Contact Carrier High-Impact Thermoset Retainer High-Impact Thermoset Ground, Phase Pins Brass (M-Series - Nickel-plated brass) Terminal Screws Stainless Steel (300 Series) Assembly Screws Stainless Steel (300 Series) Listed to standard UL1682/CSA C22.2 No. 182.1-02, Plugs, Receptacles and cable connectors of the Pin and Sleeve Type. UL Classified to IEC Standards 603091 (Plugs, Socket Outlets, and Couplers for Industrial Purposes) for Series I (European) rated voltages and services. When used with cord, these devices require no further investigation by UL for equipment Classification to IEC 435 or IEC 380. Connector Body Housing Zytel® ST801 Nylon Cord Clamps Reinforced Thermoplastic Polyester Glands Solid Neoprene Cover Arms Reinforced Thermoplastic Polyester Arm Springs Stainless Steel (17-7 type) Covers Reinforced Thermoplastic Polyester Cover Screw Nickel-plated brass Rotating Sealing Disc Polycarbonate Gaskets Solid Neoprene Contact Carrier High-Impact Thermoset Retainer High-Impact Thermoset Phase, Ground Sleeves Brass Sleeve Spring 20A and 30A Stainless Steel (300 Series); others are Beryllium Copper multi-contact inserts with silver plating Terminal Screws Stainless Steel (300 Series) Assembly Screws Stainless Steel (300 Series) Inlet Housing Locking Ring Mounting Flange Mounting Screws Contact Carrier Retainer Ground, Phase Pins Terminal Screws Assembly Screws (2) Gaskets Zytel® 101 Nylon Reinforced Thermoplastic Polyester Zytel® 101 Nylon Stainless Steel (300 Series) High-Impact Thermoset High-Impact Thermoset Brass (M-Series - Nickel-plated brass) Stainless Steel (300 Series) Stainless Steel (300 Series) Solid Neoprene Receptacle Housing Zytel® 101 Nylon Mounting Flange Zytel® 101 Nylon Arm Spring Stainless Steel (17-7 type) Cover Arm Reinforced Thermoplastic Polyester Cover Reinforced Thermoplastic Polyester Cover Screw Nickel-plated brass Rotating Sealing Disc Polycarbonate Gaskets Solid Neoprene Mounting Screws Stainless Steel (300 Series) Terminal Screws Stainless Steel (300 Series) Phase, Ground Sleeves Brass Sleeve Spring 20A and 30A Stainless Steel (300 Series); others are Beryllium Copper multi-contact inserts with silver plating Specifications Typical Specification Manufacturer’s Identification Description Type Rating Configuration Certification Hubbell HBL520P9W Plug, Power Supply 3 Pole + Neutral + Earth 20A, 120/208V AC, 3 Phase WYE UL 1686 C2, IEC 60309-2, Clock Position 9, Watertight UL Listed, File E146032 Receptacles and Inlets, E146033 Plugs and Connectors, UL Standard UL1682 and UL 1686C2, CSA Certified File LR280C for Plugs, Connectors Inlets and LR285C for Receptacle CSA StandardC22.2 No. 182.1, UL Classified to IEC 60309-1 IEC 60309-2 ® Zytel is registered trademark of E.I. DuPont. PBT is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. G-18 ® Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks Performance Electrical Dielectric Withstand Voltage Max. Working Voltage Current Interrupting Temperature Rise Endurance 3000V AC. 600V RMS (i.e., minimum creepage distance 10 millimeters, minimum clearance 8 millimeters, per IEC 60309-1 for devices rated over 500V). Certified for current interrupting at full rated current (Except DC rated devices). Max. 30°C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of 75%. 5,000 connect and disconnect cycles with load for 16A and 20A, 1,000 cycles with load and 1,000 cycles without load for 30A, 32A, 60A and 63A, and 250 cycles with load and 250 cycles without load for 100A and 125A. Mechanical Impact Resistance Cord Grip Cable Retention Cord Accommodation Terminal Identification Product Identification Per CSA C22.2 No. 182.1 / UL1682. Per CSA C22.2 No. 182.1 / UL1682. Round portable service cords of diameters commensurate with the device rating as defined in UL Standard 62, CSA C22.2 No. 49 and the harmonized European Standards. Terminals identified in accordance with North American and IEC conventions. Identification and ratings are a permanent part of the device housing. Environmental Moisture Resistance Ingress Protection Flammability Operating Temperatures Watertight per IEC 60309-1. IP67 Suitability. HB or better per UL 94 or CSA C22.2 No. 0.17. Maximum Continuous 75°C; Minimum - 40°C without impact. Materials Housings Nylon. All Other Materials Resistant to corrosion and chemical attack. Note: Specification sheets for all other Pin and Sleeve catalog numbers are available upon request. Horsepower Ratings for Hubbell IEC Pin and Sleeve Devices* Single Phase Wire Amps Count 20 20 20 20 20 20 30 30 30 30 30 30 30 60 60 60 60 60 60 60 60 100 100 100 100 100 100 100 100 3 3 3 4 4 4 3 3 3 3 4 4 4 3 3 3 3 3 4 4 4 3 3 3 3 3 4 4 4 3-Phase Voltage 125V 250V 480V 125/250 (208L-L) 125/250 (250L-L) 125/250 (125L-N) 125V 250V 480V 550VDC 125/250 (208L-L) 125/250 (250L-L) 125/250 (125L-N) 125V 250V 480V 250VDC 550VDC 125/250 (208L-L) 125/250 (250L-L) 125/250 (125L-N) 125V 250V 480V 250VDC 550VDC 125/250 (208L-L) 125/250 (250L-L) 125/250 (125L-N) Clock Catalog Number 4 6 7 12 12 12 4 6 7 8 12 12 12 4 6 7 3 8 12 12 12 4 6 7 3 8 12 12 12 HBL320x4W HBL320x6W HBL320x7W HBL420x12W HBL420x12W HBL420x12W HBL330x4W HBL330x6W HBL330x7W HBL330X8 HBL430x12W HBL430x12W HBL430x12W HBL360x4W HBL360x6W HBL360x7W HBL360x3W HBL360x8W HBL460x12W HBL460x12W HBL460x12W HBL3100x4W HBL3100x6W HBL3100x7W HBL3100x3W HBL3100x8W HBL4100x12W HBL4100x12W HBL4100x12W New HP Rating 1 2 5 2 2 1 2 3 7.5 N/A 3 3 2 2 3 7.5 N/A N/A 3 3 2 5 15 30 N/A N/A 10 15 5 Wire Amps Count 20 20 20 20 20 20 20 20 30 30 30 30 30 30 30 30 60 60 60 60 60 60 60 60 100 100 100 100 100 100 100 100 100 4 4 4 4 5 5 5 5 4 4 4 5 5 5 4 5 4 4 4 4 5 5 5 5 4 4 4 4 5 5 5 5 5 Voltage 3Ø 250V 3Ø 480V 3Ø 600V 3Ø 380-415V 3ØY 120/208V 3ØY 277/480V 3ØY 347/600V 3Ø 240/415V 3Ø 250V 3Ø 480V 3Ø 600V 3ØY 120/208V 3ØY 277/480V 3ØY 347/600V 3Ø 380/415V 3Ø 200/346-240/415 3Ø 250V 3Ø 480V 3Ø 600V 3Ø 380-415VAC 3ØY 120/208V 3ØY 277/480V 3ØY 347/600V 3Ø 200/346-240/415 3Ø 250V 3Ø 480V 3Ø 600V 3Ø 380-415V 3ØY 200/346-240/415V 400VDC 3ØY 120/208V 3ØY 277/480V 3ØY 347/600V Clock Catalog Number 9 7 5 6 9 7 5 6 9 7 5 9 7 5 6 6 9 7 5 6 9 7 5 6 9 7 5 6 6 8 9 7 5 Present HP New HP Rating Rating HBL420x9W HBL420x7W HBL420x5W HBL420x6W HBL520x9W HBL520x7W HBL520x5W HBL520x6W HBL430x9W HBL430x7W HBL430x5W HBL530x9W HBL530x7W HBL530x5W HBL430x6W HBL530x6W HBL460x9W HBL460x7W HBL460x5W HBL460x6W HBL560x9W HBL560x7W HBL560x5W HBL560x6W HBL4100x9W HBL4100x7W HBL4100x5W HBL4100x6W HBL5100x6W HBL5100x8W HBL5100x9W HBL5100x7W HBL5100x5W 2 5 7.5 0.5 5 7.5 3 7.5 10 2 7.5 10 5 10 15 3 10 15 10 30 30 10 30 30 5 10 10 7.5 3 10 10 5 7.5 15 20 5 15 20 10 10 7.5 20 25 10 7.5 20 25 10 15 40 50 30 30 N/A 15 40 50 Note: *Horsepower Ratings are NOT standardized amongst different Pin and Sleeve manufacturers. www.hubbell-wiring.com ® Wiring Device-Kellems G-19 Pin and Sleeve Devices/Mechanical Interlocks Features and Benefits IP67 SUITABILITY Unfused Circuit-Lock® Pin and Sleeve Mechanical Interlocks The National Electrical Code (NEC®) requires a separate disconnect means within sight of all motor loads. The NEC requires the disconnecting means in a motor-circuit be listed as “Suitable as Motor Disconnect” if the motor is rated greater than 2 HP. Hubbell’s revolutionary Circuit-Lock interlock incorporates the disconnect switch and receptacle in one compact, non-metallic and economical unit. Removing the plug and locking it out provides a visual means of verifying equipment has been disconnected. All Circuit-Lock mechanical interlocks can be locked out as a method of compliance with the OSHA Lockout/Tagout regulation. The switch cannot be turned ON until the plug is completely engaged, and the plug cannot be removed until the switch is turned OFF. At the same time, it eliminates the possibility of making or breaking the circuit under load or making a casual or “lazy” connection. The non-metallic enclosure can be connected to the metallic conduit and not interfere with the ground continuity. In addition, these horsepower rated units are durable, watertight and easy to install. And they are compatible with IEC 60309-2 plugs. These Circuit-Lock units are available in 20, 30, 60 and 100A models, and in 3, 4 and 5 wire configurations that are designed to the IEC 60309-1 and 60309-2 standards. Hubbell’s Circuit-Lock Mechanical Interlocks are also available in “Reverse Service” versions. These units incorporate the disconnect switch and reverse service receptacle (inlet) in one compact, non-metallic and economical unit. These units are available in 30, 60 and 100A models, 4 wire configurations. HBL430MI7W Housing Design • Insulated non-metallic housing, super tough, non-conductive and chemical resistant for heavy duty industrial environments • IEC pin and sleeve devices are color coded by voltage for easy identification • Self-closing gasketed cover, detents into position to fully close automatically Interior Design • Large gears enclosed in a gear box assembled on one plane to eliminate possible gear jumping • Horsepower rated disconnect switch handles large motor loads • DIN rail mounted switch for easy installation and replacement Safety • Lockable handle to meet OSHA Lockout/Tagout regulations • Two-stage interlocking mechanism to help defeat tampering • Watertight conduit hub and grounding plate for use on metallic conduit (IP67 suitability) Liftcover • Replaceable spring-loaded liftcover with gasket for a watertight seal • Pre-wired IEC Pin and Sleeve receptacle • Reverse service has dependable solid brass pins for longer life and reliable electrical contact Identification • Color coded rating pad and receptacle mount to signify voltage Installation • Comes with brass inserts and stainless steel screws for higher torque and better sealing • Three molded-in conduit drill points are located on top, bottom and back surface of enclosure • Adjustable mounting feet are ductile to allow mounting on irregular surfaces NEC® is a registered trademark of the National Fire Protection Association (NFPA). G-20 ® Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks Enclosure Type 4X, 12 IP67 SUITABILITY Unfused Circuit-Lock® Devices Rating Reverse Service Amps Poles and Wires 20 3P 4W 120/240V HBL420MI12W HBL420P12W — — 3P 4W 3Ø 240V HBL420MI9W HBL420P9W — — 3P 4W 3Ø 480V HBL420MI7W HBL420P7W — — 3P 4W 3Ø 600V HBL420MI5W HBL420P5W — — 2P 3W 120V HBL330MI4W HBL330P4W — — 2P 3W 240V HBL330MI6W HBL330P6W — — 2P 3W 480V HBL330MI7W HBL330P7W — — 3P 4W 120/240V HBL430MI12W HBL430P12W — — 3P 4W 3Ø 240V HBL430MI9W HBL430P9W HBL430MI9WR HBL430P9WR 3P 4W 3Ø 480V HBL430MI7W HBL430P7W HBL430MI7WR HBL430P7WR 3P 4W 3Ø 600V HBL430MI5W HBL430P5W HBL430MI5WR HBL430P5WR 4P 5W 3ØY 120/208V HBL530MI9W HBL530P9W — — 4P 5W 3ØY 277/480V HBL530MI7W HBL530P7W — — 4P 5W 3ØY 347/600V HBL530MI5W HBL530P5W — — 32 3P 4W 380V 50HZ440V 60Hz HBL432MI3W HBL432P3W — — 60 2P 3W 120V HBL360MI4W HBL360P4W — — 2P 3W 240V HBL360MI6W HBL360P6W — — 2P 3W 480V HBL360MI7W HBL360P7W — — 3P 4W 120/240V HBL460MI12W HBL460P12W HBL460MI12WR HBL460P12WR 3P 4W 3Ø 240V HBL460MI9W HBL460P9W HBL460MI9WR HBL460P9WR 3P 4W 3Ø 480V HBL460MI7W HBL460P7W HBL460MI7WR HBL460P7WR 3P 4W 3Ø 600V HBL460MI5W HBL460P5W HBL460MI5WR HBL460P5WR 4P 5W 3ØY 120/208V HBL560MI9W HBL560P9W — — 4P 5W 3ØY 277/480V HBL560MI7W HBL560P7W — — 4P 5W 3ØY 347/600V HBL560MI5W HBL560P5W — — 2P 3W 240V HBL3100MI6W HBL3100P6W — — 3P 4W 120/240V HBL4100MI12W HBL4100P12W HBL4100MI12WR HBL4100P12WR 3P 4W 3Ø 240V HBL4100MI9W HBL4100P9W HBL4100MI9WR HBL4100P9WR 3P 4W 3Ø 480V HBL4100MI7W HBL4100P7W HBL4100MI7WR HBL4100P7WR 3P 4W 3Ø 600V HBL4100MI5W HBL4100P5W HBL4100MI5WR HBL4100P5WR 4P 5W 3ØY 120/208V HBL5100MI9W HBL5100P9W — 30 100 Configuration Recep. Plug AC Voltage Mechanical Interlock Mating Plug Mechanical Interlock Mating Plug — Note: 20, 30 and 32A – 1 inch NPT hub supplied; 60 and 100A – 1¼ inch hub supplied. www.hubbell-wiring.com ® Wiring Device-Kellems G-21 Pin and Sleeve Devices/Mechanical Interlocks Auxiliary Contacts for 20, 30, 32, 60 and 100A Switch, NEMA A600 Pilot Duty Description Catalog Number “Break After Main Break”, 1 set of n/o contacts, 1 set of n/c contacts. “Break Before Main Break”, 1 set of n/o contacts. HBLAC1 HBLAC2 Ground Block HBLAC1 Description Catalog Number For 20, 30 and 32A switches. For 60 and 100A switches. HBL30RGB HBL60100RGB Neutral Block HBLAC2 Description Catalog Number For 20, 30 and 32A switches. For 60A switches. For 100A switches. HBL30RNB HBL60RNB HBL100RNB Watertight Closure Plug Kits Description Catalog Number For 20, 30 and 32A Circuit-Lock Unfused and Fused Pin and Sleeve mechanical interlocks. MICPK30 For 60 and 100A Circuit-Lock Unfused and Fused Pin and Sleeve mechanical interlocks. MICPK60 Replacement Flip Covers HBL30RNB HBL30RGB Description Catalog Number For 20A mechanical interlocks. For 30 and 32A, 3 and 4 wire mechanical interlocks. For 30A, 5 wire mechanical interlocks. For 60A mechanical interlocks. For 100A mechanical interlocks. CA420MI CA3430MI CA530MI CA60MI CA100MI Replacement Switches Description Catalog Number For 20A mechanical interlocks. For 30 and 32A mechanical interlocks. For 60 and 100A mechanical interlocks. HBLDS3RS HBL30MIRS HBLDS60100RS Replacement Mounting Feet MICPK30 Description Catalog Number For 20, 30, 32, 60 and 100A mechanical interlocks. HBLRFT2* Dimensions KEY CA3430MI HBL30MIRS A B C D E F G H I J K L M HUB SIZE 20A and 30A Inches (mm) 60A Inches (mm) 100A Inches (mm) 7.75" (196.9) 6.87" (174.5) 4.75" (120.7) 1.02" (25.9) 1.60" (40.6) 11.00" (279.4) 8.75" (222.3) 8.00" (203.2) 10.12" (257.0) 6.88" (174.8) 1.93" (49.0) 11.25" (285.8)** 7.75" (196.9) 1.00" NPT 7.75" (196.9) 6.87" (174.5) 4.75" (120.7) 1.02" (25.9) 1.46" (37.1) 12.75" (323.9) 8.75" (222.3) 9.75" (247.7) 11.87" (301.5) 6.88" (174.8) 2.09" (53.1) 13.65" (346.7) 8.60" (218.4) 1.25" NPT 7.75" (196.9) 6.87" (174.5) 4.75" (120.7) 1.02" (25.9) 1.46" (37.1) 12.75" (323.9) 8.75" (222.3) 9.75" (247.7) 11.87" (301.5) 6.88" (174.8) 2.09" (53.1) 13.65" (346.7) 9.30" (236.2) 1.25" NPT Note: *Package of 10 feet and 10 screws. **30 and 32A, 3 and 4W = 11.50" (292.1); 30A, 5W = 11.59" (294.4). A B C D E J F K H L I HBLRFT2 G Dimensions in Inches (mm) G-22 ® Wiring Device-Kellems M www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks Typical Specifications Manufacturer’s Identification Description Electrical Type Rating Configuration Enclosure Type Ingress Protection Enclosure Material Certification Hubbell HBL430MI7W Circuit-Lock® Pin and Sleeve Mechanical Interlock 3 Pole + Earth 30A, 480V AC, 3 Phase IEC 60309-2, UL1686 C2, Clock position 7 Indoor and Outdoor - 4X (Watertight, Washdown); Indoor - 12 (Dust-tight, Falling Dirt and Noncorrosive Liquids) IP67 Suitability Non-metallic, enclosure suitable for metallic conduit UL Listed, CSA Certified Note: This device provides on/off switched control of a plug connected load and includes an interlocking feature to prevent the plug from being disconnected while the receptacle is energized. The switch cannot be turned “ON" until the plug is inserted properly, and the plug cannot be removed until the switch is turned “OFF." Materials Part Material Part Material Base Handle Enclosure Gasket Shaft Seal Enclosure Screws Hinge Pins PBT PBT Neoprene Neoprene Stainless Steel 300 Series Nickel Plated Brass Top Conduit Hub Shaft Ground Plate Enclosure Inserts Hinge Spring PBT Zinc PBT Galvanized Steel Brass Stainless Steel 300 Series Performance Electrical Dielectric Voltage Max. Working Voltage Current Interrupting Short Circuit Withstand Rating Operations Withstands 3,000V AC Min. 600V AC RMS. Certified for current interrupting at full rated current and voltage. Suitable for use on a circuit capable of delivering not more than 10,000 RMS symmetrical amperes at the voltage rating of the receptacle. 20A and 30A models: Suitable for use on a circuit capable of delivering not more than 65,000 RMS symmetrical amperes, 600V when protected by class “J” fuses rated 30A. Mechanical 10,000 cycles, electrical 6,000 cycles. Mechanical Impact Resistance Terminal Identification Product Identification Mounting In accordance with UL 746C. In accordance with UL, CSA and international conventions. Identification and ratings are part of the external label and molded into the receptacle mount. External adjustable feet. Environmental Moisture Resistance Ingress Protection Flammability Operating Temperature UV Resistance Indoor and Outdoor - 4X (Watertight, Washdown); Indoor - 12 (Dust-tight, Falling Dirt and Noncorrosive Liquids). IP67 Suitability. UL94-5VA and V-0 Classification. Max. Continuous +75°C; Min. Continuous -40°C. All materials are UV stabilized. Horsepower Ratings Amps AC Voltage Rating Horsepower Mechanical Interlock Mating Plug 20 20 20 20 30 30 30 30 30 30 30 30 30 30 32 60 60 60 60 60 60 60 60 60 60 100 100 100 100 100 100 120/240V AC 3Ø 240V AC 3Ø 480V AC 3Ø 600V AC 120V AC 240V AC 480V AC 120/240V AC 3Ø 600V AC 3Ø 480V AC 3Ø 250V AC 3ØY 347/600V AC 3ØY 277/480V AC 3ØY 120/208V AC 380V AC 50Hz – 440V AC 60Hz 120V AC 240V AC 480V AC 120/240V AC 3Ø 600V AC 3Ø 480V AC 3Ø 250V AC 3ØY 347/600V AC 3ØY 277/480V AC 3ØY 120/208V AC 240V AC 120/240V AC 3Ø 600V AC 3Ø 480V AC 3Ø 250V AC 3ØY 120/208V AC 2 5 10 10 2 3 (208-240V AC) 7.5 3 (208-240V AC) 20 15 7.5 20 15 5 15 (440V AC 3Ø 60Hz) 3 7.5 (208-240V AC) 20 7.5 (208-240V AC) 40 30 15 40 30 15 15 (10 @ 208V AC) 15 50 50 25 (208-240V AC) 20 HBL420MI12W HBL420MI9W HBL420MI7W HBL420MI5W HBL330MI4W HBL330MI6W HBL330MI7W HBL430MI12W HBL430MI5W HBL430MI7W HBL430MI9W HBL530MI5W HBL530MI7W HBL530MI9W HBL432MI3W HBL360MI4W HBL360MI6W HBL360MI7W HBL460MI12W HBL460MI5W HBL460MI7W HBL460MI9W HBL560MI5W HBL560MI7W HBL560MI9W HBL3100MI6W HBL4100MI12W HBL4100MI5W HBL4100MI7W HBL4100MI9W HBL5100MI9W HBL420P12W HBL420P9W HBL420P7W HBL420P5W HBL330P4W HBL330P6W HBL330P7W HBL430P12W HBL430P5W HBL430P7W HBL430P9W HBL530P5W HBL530P7W HBL530P9W HBL432P3W HBL360P4W HBL360P6W HBL360P7W HBL460P12W HBL460P5W HBL460P7W HBL460P9W HBL560P5W HBL560P7W HBL560P9W HBL3100P6W HBL4100P12W HBL4100P5W HBL4100P7W HBL4100P9W HBL5100P9W www.hubbell-wiring.com ® Wiring Device-Kellems G-23 Pin and Sleeve Devices/Mechanical Interlocks Features and Benefits IP66 SUITABILITY Fused Circuit-Lock® Pin and Sleeve Mechanical Interlocks Hubbell Circuit-Lock® Pin and Sleeve Mechanical Interlocks are a revolutionary design that incorporates a disconnect switch and pin and sleeve receptacle in a compact non-metallic unit. These devices offer maximum safety by preventing users from mating or breaking a circuit under load—Hubbell’s interlock mechanism detects the presence of a plug and prevents it from being removed when the switch is in the "ON" position. It features a high visibility red handle that can be locked in the OFF position to meet OSHA lockout/tagout regulations. The enclosure door can be locked to prevent unauthorized access. The rugged, corrosion-resistant Type 4X PBT enclosure features adjustable mounting feet for flexible installation, while the receptacle’s springloaded cover with gasket is dust tight and provides a watertight seal when turned and locked. The patented Plug-Check™ mechanism detects the presence of the plug. It operates as a clutch to engage the handle with the switch and captures the plug. This action prevents the plug from being removed until the switch is turned OFF. HBL460MIF5W G-24 Housing Design • Non-metallic enclosure meets UL 50E Type 4X (watertight), 12 (dust-tight) and IP66 suitability requirements. Enclosure is molded of rugged thermoplastic PBT to resist abuse, corrosion and enhance safety • Stainless steel ¼ turn door fasteners for quick, easy access to fuses Interior Design • Compact Fused Disconnect Switch accepts Class “J” fuses. Fuse holders are top mounted for easy access • The switch accepts auxiliary contacts for control circuit applications including the ON/OFF control of remote pilot lights or signal for programmable controllers Safety • High visibility red handle can be locked in the OFF position as a method of compliance with OSHA lockout requirements. Accepts up to a ⁵⁄₁₆ inch padlock shackle • Replaceable spring-loaded receptacle liftcover with gasket ensures dust tight rating; liftcover provides watertight seal when turned and locked Contact Carrier • Thermoset polyester contact carrier provides resistance to electrical tracking and withstands higher temperatures • Thermoset properties provide excellent dimensional stability, low moisture absorption and superior dielectric strength Enclosure Door • Removable door for ease of wiring and installation • Enclosure door can be locked to prevent unauthorized access. Additionally, if the switch is ON, the door cannot be opened Installation • Three molded-in conduit drill points are located on the top, bottom and back surface of enclosure. Conduit hub provided: 30A 1 in. NPT, 60A 1¼ in. NPT • Conduit hub and adjustable mounting feet (4) are ductile to allow mounting on irregular surfaces ® Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks IP66 Enclosure Type 4X, 12 SUITABILITY Fused Circuit-Lock® Devices Rating Amps Poles and Wires 30 3P 4W 60 Configuration Recep./ Plug/ Conn. Inlet Mechanical Interlock Mating Plug 120/240V HBL430MIF12W HBL430P12W 3P 4W 3Ø 240V HBL430MIF9W HBL430P9W 3P 4W 3Ø 480V HBL430MIF7W HBL430P7W 3P 4W 3Ø 600V HBL430MIF5W HBL430P5W 4P 5W 3ØY 277/480V HBL530MIF7W HBL530P7W 4P 5W 3ØY 347/600V HBL530MIF5W HBL530P5W 3P 4W 120/240V HBL460MIF12W HBL460P12W 3P 4W 3Ø 240V HBL460MIF9W HBL460P9W 3P 4W 3Ø 480V HBL460MIF7W HBL460P7W 3P 4W 3Ø 600V HBL460MIF5W HBL460P5W 4P 5W 3ØY 120/208V HBL560MIF9W HBL560P9W AC Voltage HBL430MIF12W Gray Style Switch HBLACFSNO HBL30MIFRS Black Style Switch Note: 30A – 1 inch NPT hub supplied; 60A – 1¼ inch hub supplied. Replacement Auxiliary Contacts Description Black Style Switch Catalog Number Gray Style Switch Catalog Number Auxiliary contact, normally open, A600 pilot duty, break before break. ACFSNO HBLACFSNO Auxiliary contact, normally closed, A600 pilot duty, break before break. ACFSNC HBLACFSNC ACFSNO Note: Auxiliary contacts are specific to the style switch noted and are NOT interchangeble. All new installations are shipped with gray style switch. Replacement Switches Description Gray Style Switch Catalog Number For 30A fused switches. HBL30MIFRS For 60A fused switches. Gray Style switch will retro fit Black Style switch. HBL60MIFRS MICPK30 Watertight Closure Plug Kits Description Catalog Number For 30A Circuit-Lock® unfused and fused Pin and Sleeve mechanical interlocks. MICPK30 For 60 and 100A Circuit-Lock® unfused and fused Pin and Sleeve mechanical interlocks. MICPK60 Replacement Flip Covers Description Catalog Number For 30A, 3 and 4 wire mechanical interlocks. CA3430MI For 30A, 5 wire mechanical interlocks. CA530MI For 60A mechanical interlocks. CA60MI CA3430MI Replacement Mounting Feet Description Catalog Number Replacement mounting feet and screws for 30 and 60A fused mechanical interlocks. HBLRFT2 ∆ HBLRFT2 Note: ∆ Package of 10 feet and 10 screws. www.hubbell-wiring.com ® Wiring Device-Kellems G-25 Pin and Sleeve Devices/Mechanical Interlocks Specifications Materials Typical Specifications Manufacturer’s Identification Description Electrical Type Rating Configuration Enclosure Type Certification Hubbell HBL460MIF7W Fused Circuit-Lock Pin and Sleeve Mechanical Interlock 3 Pole + Earth 60A, 480V AC, 3 Phase IEC 60309-2, UL1686C2, Clock Position 7 Indoor and Outdoor - 4X (Watertight, Washdown) Indoor - 12 (Dust-tight, Falling dirt) UL Listed for US and Canada Part Material Base and Top Handle Conduit Hub Enclosure Gasket Shaft Shaft Seal Ground Plate Enclosure Screws Mounting Inserts Hinge Pin Hinge Spring PBT PBT Zinc, 30A-1", 60A-1¼" NPT Neoprene Brass Neoprene Galvanized Steel Stainless Steel Brass Nickel-Plated Brass Stainless Steel Note: This device provides fused switched control of a plug connected load and includes an interlocking feature to prevent the plug from being disconnected or the fuse door opened while the receptacle is energized. The switch cannot be turned on until the plug is inserted properly. Performance Electrical Dielectric Voltage Max. Working Voltage Current Interrupting Short Circuit Withstand Rating Withstands 3,000V AC Min. 600V AC. Certified for current interrupting at full rated current and voltage. Suitable for use on a circuit capable of delivering not more than 200,000 RMS symmetrical amperes at the voltage rating of receptacle. Mechanical 10,000 cycles minimum. Operations Mechanical Impact Resistance Terminal Identification Product Ratings Mounting In accordance with UL 746C. In accordance with UL, CSA and international conventions. Ratings are part of the external label and molded into the receptacle mount and color-coded. External adjustment feet. Environmental Moisture Resistance Ingress Protection Flammability Operating Temperatures UV Resistance Fuse Types Indoor and Outdoor - 4X (Watertight, Washdown); Indoor - 12 (Dust-tight, Falling dirt). IP66 Suitability. UL94-5VA and V-0 Classification. Max. Continuous +75°C; Min. Continuous -40°C. All materials are UV stabilized. UL Listed Class “J”. CSA Certified HRCI-J. Horsepower Ratings Amps AC Voltage Rating Standard Maximum** Mechanical Interlock Use Pin and Sleeve Plug 30 30 30 30 30 30 60 60 60 60 60 3Ø 600V AC 3Ø 480V AC 3Ø 240V 120/240V AC 3ØY 277/480V 3ØY 347/600V 3Ø 600V AC 3Ø 480V AC 3Ø 240V AC 120/240V AC 3ØY 120/208V 7.5 5 3 1.5* 5 7.5 15 15 7.5 3* 7.5 20 15 7.5 3* 15 20 50 30 15 10* 15 HBL430MIF5W HBL430MIF7W HBL430MIF9W HBL430MIF12W HBL530MIF7W HBL530MIF5W HBL460MIF5W HBL460MIF7W HBL460MIF9W HBL460MIF12W HBL560MIF9W HBL430P5W HBL430P7W HBL430P9W HBL430P12W HBL530P7W HBL530P5W HBL460P5W HBL460P7W HBL460P9W HBL460P12W HBL560P9W Note: *208-240V AC L-L. **Requires time delay fuses. Dimensions 7.27" (184.7) 1.51" (38.4) 30A 1.68" (42.7) 60A 10.18" (258.6) 9.31" (236.5) 3.60" (91.4) 7.19" (182.6) 11.46" (291.6) 12.37" (314.2) 15.03" (381.8) 14.48" (367.8) 15.36" (390.1) 2.69" (68.3) 30A 2.83" (71.9) 60A 8.43" (214.1) Dimensions in Inches (mm) G-26 ® Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks RoHS Features and Benefits 20 and 30 Amps Low Profile Hubbell’s Low Profile Pin and Sleeve devices were designed to save space without sacrificing pin and sleeve strength, safety and convenience. The small compact design of these plugs is ideal for indoor applications where space is at a premium. These devices are fully interchangeable with standard IEC 60309 pin and sleeve. They are a perfect fit for tight situations frequently found in hotels, restaurants, convention centers, warehouses, assembly benches and offices. L430R9 L430P9 Housing Design • Nylon construction, both interior and exterior are made of tough, durable nylon • Shrouded, recessed pins are protected from impact and abuse Cord Grip • Integrated cord grip limits strain on terminals, keeps cord connected Safety • Large markings for easy recognition results in ease of wiring on the assembly line or in the field • Shroud protects personnel from exposure to arcing Brass Box Terminal • Permits high clamping pressure on conductors without damaging wire strands for best electrical conductivity • Solid one-piece pins construction, for long life, reliable electrical contact and maximum conductivity Identification • Color coding for quick, easy visual identification of mating devices • Ratings and certification are molded into the nylon housing for easy identification and reordering Split Sleeves • Self-adjusting stainless steel springs assure constant contact pressure (20A and 30A). On 60A devices, Beryllium copper insert with multiple contact points assures easy insertion and a tight fit • Stainless steel terminal screws resist rust and corrosion www.hubbell-wiring.com ® Wiring Device-Kellems G-27 Pin and Sleeve Devices/Mechanical Interlocks RoHS Low Profile Devices Rating Devices Cord Diameter Configuration Amps Poles and Wires 20 3P 4W 3Ø 250V — L420R9 .350" - .710" (8.3 - 15.9) 30 3P 4W 125/250V L430P12 L430R12 .390" - .775" (9.9 - 19.7) 30 3P 4W 3Ø 250V L430P9 L430R9 .390" - .775" (9.9 - 19.7) Amps Poles and Wires Plug Receptacle 60 3P 4W Amps Poles and Wires 60 4P 5W 100 4P 5W Recep./ Plug/ Conn. Inlet AC Voltage Plug Configuration Recep./ Plug/ Conn. Inlet AC Voltage A460P9 Min. Max. Inches (mm) A460R9 A460R9KIT .75" - 1.25" (19.1 - 31.8) Plug Receptacle Min. Max. Inches (mm) 3ØY 120/208V A560P9 HBL560R9W .89" - 1.42" (22.6 - 36.1) 3ØY 120/208V A5100P9 HBL5100R9W 1.34" - 1.50" (34.0 - 38.1) 3Ø 250V With Cover: Configuration Recep./ Plug/ Conn. Inlet AC Voltage Specifications Application Guide Electrical Dielectric Withstand Voltage Max. Working Voltage Current Interrupting Temperature Rise Endurance 3000V AC 250V RMS Certified for current interruption at full rated current. Max. 30°C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of 75%. Up to 5,000 connect and disconnect cycles at full rated current and voltage. Mechanical Impact Resistance Cord Grip Cable Retention Cord Accommodation Terminal Identification Product Identification Per CSA C22.2 No. 182.1 / UL1682 Per CSA C22.2 No. 182.1 / UL1682 Round portable service cords of diameters commensurate with the device rating as defined in UL standard 62, CSA C22.2 No. 49 and the European Standards. Terminals identified in accordance with North American convention. Ratings are a permanent part of the device housing. Environmental Flammability Ingress Protection Operating Temperatures HB or better per UL94 or CSA C22.2 No. 0.17 IP22 Suitability Maximum Continuous 75° C; Minimum -40°C without impact ® Zytel and Rynite are registered trademarks of E.I. DuPont Corp. G-28 Min. Max. Inches (mm) Receptacle ® Agriculture Indoor location and maintenance. Chemical Processing Indoor location and maintenance. Construction Indoors for added safety and abuse resistance. Entertainment Indoor location and maintenance. Food Service Food service areas where aesthetics and space are concerns. Light Manufacturing Indoor locations and maintenance. Manufacturing Light assembly areas, stamping operations and maintenance areas. Military Warehouse and maintenance areas. Materials Plug Material Case Zytel® 101 Nylon Shroud Zytel® 101 Nylon Pin Carrier 20 & 30A Zytel® 101 Nylon Pin and Carrier 60A High-Impact Thermoset Pins Brass CDA#360 Assembly Screws Stainless Steel (300 series) Terminal Screws Stainless Steel (300 series) Receptacle Body Zytel® 101 Nylon Sleeve Carrier 20 & 30A Zytel® 101 Nylon Sleeve Carrier 60A High-Impact Thermoset Sleeves Brass CDA #360 Assembly Screws Stainless Steel (300 series) Terminal Screws Stainless Steel (300 series) Adapter Plate 20 & 30A Galvanized Steel Adapter Plate 60A Aluminum Wall Trim Plate Zytel® 101 Nylon Panel Mount Trim Plate Stainless Steel (300 series) Note: See page G-29 for product dimensions. Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks Plug Dimensions Type A B C D Cord Range Diameter L430P12 2.97" (75.4) 4.18" (106.2) 3.50" (88.9) 1.71" (43.4) .390"-.775" (9.9-19.7) A460P9 3.38" (85.9) 4.25" (108.0) 7.00" (177.8) – .75"-1.25" (19.1- 31.8) A5100P9 4.92" (125.00) 5.07" (128.81) 8.60" (218.35) – 1.34"-1.50" (34.0- 38.1) Plugs D Angled Plugs C A C C B A A B 30A B 60A 100A Wall Mount Receptacle Dimensions Type A B C D E F L420R9 2.60" (66.0) 2.81" (71.4) 2.28" (57.9) 2.38" (60.5) – – L430R12 3.12" (79.2) 3.12" (79.2) 2.77" (70.4) 2.76" (70.1) – – A460R9 4.50" (114.3) 4.50" (114.3) 4.48" (113.8) – 3.62" (91.9) .50" (12.7) Wall Mount Receptacles A A C B D C B F 20 and 30A E 60A Adapter Plate (Included with “L” and “A” series receptacles) 4.75" Sq. (120.7) 4.75" Sq. (120.7) 4.75" Sq. (120.7) Panel Cutout 2.55" (64.8) 2.13" (54.1) 2.55" (64.8) 2.13" (54.1) 20A Mounting 2-gang box 30A Mounting 2-gang box 60A Mounting 2-gang box and 4¹¹⁄₁₆" box 20A 2.62" (66.5) dia. 2.83" (71.9) dia. 30A Dimensions in Inches (mm) www.hubbell-wiring.com ® Wiring Device-Kellems G-29 Pin and Sleeve Devices/Mechanical Interlocks IEC Pin and Sleeve Terminal Identification – Rear View Terminal Marking Pattern* Rating Description Domestic Receptacle and Connector International Domestic International Plug and Inlet Domestic White 3 Wire 125V AC 277V AC 3 Wire White L+ 100-130V Green 250V AC 480V AC 600V AC Green L+ 200-250V 380-415V AC L+ Green 4 Wire Green Green White White N L1 L2 — Green Pilot 4 Wire Pilot L2 380-415V AC L2 L3 L1 L1 Green White 5 Wire (3ØY) 120/208V AC 277/480V AC 347/600V AC L2 L1 Green (3Ø ∆) 250V AC 480V AC 600V AC 220/380V 50Hz 250/440V 60Hz 200/346V to 240/415V 50 and 60Hz L3 Green L+ N 125/250V AC 1ØY 120/208V International Green Pilot L2 N L3 L1 Green White Pilot L2 L3 L1 N Green Note:  *Location of grounding contact position will change as clock positions assigned to specific voltages change. Pilot contacts supplied on 4 and 5 wire, 63 and 125 Amp international rated devices. G-30 ® Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks Ground Path To reduce the likelihood of electrical shock, the National Electrical Code requires that non-current carrying metallic components be grounded. Insulgrip Pin and Sleeve wiring devices offer two styles of grounding. Style I HBL430PS1W HBL430RS1W Receptacles achieve grounding by attaching the ground conductor to the ground screw inside the back box and utilizing the metallic receptacle shell as a ground source (see 3P 4W Style I illustration). Plugs and connectors establish grounding by means of connecting the flexible cable ground conductor to a ground terminal within each device, which, in turn, is grounded through the metallic plug or connector shroud. Any exposed metallic components are suitably grounded in the Style I offering. Style II HBL430PS2W HBL430RS2W The Style II ground path offers two means of achieving the proper ground path. In addition to utilizing the same grounding method as in the Style I product, the Style II version incorporates a separate ground pin and sleeve (see 3P 4W Style II illustration). This provides a second ground path. The ground pin on Style II devices is longer than other pins, meaning that they “make first" and “break last," assuring protection for people and equipment. New Pole and Wire Terminology Style I Style II New Old No. of Contacts New Old No. of Contacts 2P 3W 3P 4W 4P 5W 2W 2P 3W 3P 4W 4P 2 3 4 2P 3W 3P 4W 2W 3P 3W 4P 3 4 www.hubbell-wiring.com ® Wiring Device-Kellems G-31 Pin and Sleeve Devices/Mechanical Interlocks TYPE 4X Features and Benefits UL 1686 C1 Insulgrip® Pin and Sleeve Devices UL standard 1686-C1 configurations are uniform throughout the industry. That means Hubbell–the name that sets the standard for pin and sleeve performance, reliability, durability, innovation and ease of use should be your standard. Hubbell's line of heavy duty Insulgrip® Pin and Sleeve wiring devices not only offers complete interchangeability, it delivers the goods when it comes to superior design and construction. Hubbell Insulgrip Pin and Sleeve devices are engineered and built to handle today’s most demanding work environments, making Hubbell the unsurpassed heavyweight in the heavy duty market. G-32 Housing Design • Thermoplastic housing provides excellent insulating, impact, corrosion, and UV resistant properties. Protects users and internal components in the roughest of environments • Spring-loaded, gasketed cover provides a UL Type 4X watertight, dust-tight seal on connectors and receptacles Liquidtight Conduit Adapters • Machined aluminum adapters are available to provide a means for attaching flexible liquidtight metal conduit to rear of Hubbell Pin and Sleeve plug or connector Powerful Mechanical Cord Grip • Hubbell’s design incorporates two molded-in teeth to securely grip the outer cable jacket, and internal conductors to prevent slippage and strain on terminations • Captive barrel nuts ease assembly and allow higher tightening torque for maximum cord retention Terminal Entrance Holes • Large, square funneled entrance holes isolate each conductor to protect against shorts due to stray conductor strands • Tapered hole provides a fast and easy guide into the termination chamber • Pin chamber confines arcing within the interior chamber during make and break cycle of mating devices, minimizes arc tracking Watertight Cord Entrance • The tapered bore entrance creates high compression forces on sealing gland, providing a watertight seal around cord • Individual solid neoprene glands are supplied to match a full range of cord sizes and assure watertight performance Anti-Vibration Box Terminals • Interlocking box terminals ensure that terminal screws remain secure and cannot loosen • The floating box is designed to obtain high-torque values without damaging stranded conductors ® Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks TYPE 4X Features and Benefits UL 1686 C1 Insulgrip® Pin and Sleeve Devices Metallic where you want It, non-metallic where you need it. Different from traditional all-metallic devices, Hubbell Pin and Sleeve wiring devices are designed to provide metallic shrouding where you want it and a non-metallic housing where you need it. What’s more, Hubbell’s watertight Insulgrip Pin and Sleeve wiring devices are designed with safety first and foremost. We created the line with plant facility maintenance personnel and a safer industrial work environment in mind. To greatly reduce the likelihood of electrical shock, we developed our exclusive nonmetallic watertight system, meaning that with Hubbell on the job, the mix of electricity and water isn’t the threat it once was. So, whether the job calls for a welding outlet in a dry location or a motor disconnect in a wet location, step up to Hubbell Pin and Sleeve wiring devices. Housing Design • Thermoplastic housing provides excellent insulating, impact, corrosion, and UV resistant properties. Protects users and internal components in the roughest of environments • Locking ring provides a UL Type 4X watertight and dust-tight seal when the male and female devices are connected Shrouded Sleeves • Housing seal provides a watertight and dust-tight seal when mated with receptacle or connector • Protects the user from the possibility of touching live contacts during insertion and withdrawal of mating parts • Shroud protects contact sleeves from deforming from physical abuse Interior Design • Sleeve O-ring seal provides a watertight and dust-tight seal around the sleeves. Assures that contamination will not enter wire chamber • All-brass sleeve contacts provide Thermoset Polyester Contact Carrier • Molded thermoset polyester provides high resistance to electrical tracking • Withstands higher temperatures which may result from overload or arcing • Thermoset properties provide dimensional stability for this critical assembly Product Marking • Catalog number and rating visible while in use. Markings are color coded differentiating Style I and Style II devices Beryllium Copper Spring-Pin Design (Patented) • Maintains high unit pressure on mating sleeves. Ensures reliable electrical contact while minimizing heat rise due to normal pin wear over time reliable electrical contact with mating pins, also with minimum heat build-up over time www.hubbell-wiring.com ® Wiring Device-Kellems G-33 Pin and Sleeve Devices/Mechanical Interlocks TYPE 4X** Rating Amps 30 2P 3W 600/250 HBL330RS1W HBL330PS1W HBL330CS1W IN330FS1 IN330MS1 3P 4W 600/250 HBL430RS1W HBL430PS1W HBL430CS1W IN430FS1 IN430MS1 4P 5W 600/250 HBL530RS1W HBL530PS1W HBL530CS1W IN530FS1 IN530MS1 2P 3W 600/250 HBL360RS1W HBL360PS1W HBL360CS1W IN360FS1 IN360MS1 3P 4W 600/250 HBL460RS1W HBL460PS1W HBL460CS1W IN460FS1 IN460MS1 4P 5W 600/250 HBL560RS1W HBL560PS1W HBL560CS1W IN560FS1 IN560MS1 2P 3W 600/250 HBL3100RS1W HBL3100PS1W HBL3100CS1W IN3100FS1 IN3100MS1 3P 4W 600/250 HBL4100RS1W HBL4100PS1W HBL4100CS1W IN4100FS1 IN4100MS1 4P 5W 600/250 HBL5100RS1W HBL5100PS1W HBL5100CS1W IN5100FS1 IN5100MS1 3P 4W 600/250 HBL4200RS1W HBL4200PS1W HBL4200CS1W IN4200FS1† IN4200MS1† 4P 5W 600/250 HBL5200RS1W HBL5200PS1W HBL5200CS1W IN5200FS1† IN5200MS1† 100 200 Maximum Voltage AC/DC Replacement Interiors Poles and Wires 60 Receptacle/ Connector Configuration* Style I Devices Plug Receptacle Rating Style II Devices Plug Replacement Interiors Amps 30 2P 3W 600/250 HBL330RS2W HBL330PS2W HBL330CS2W IN330FS2 IN330MS2 3P 4W 600/250 HBL430RS2W HBL430PS2W HBL430CS2W IN430FS2 IN430MS2 2P 3W 600/250 HBL360RS2W HBL360PS2W HBL360CS2W IN360FS2 IN360MS2 3P 4W 600/250 HBL460RS2W HBL460PS2W HBL460CS2W IN460FS2 IN460MS2 2P 3W 600/250 HBL3100RS2W HBL3100PS2W HBL3100CS2W IN3100FS2 IN3100MS2 3P 4W 600/250 HBL4100RS2W HBL4100PS2W HBL4100CS2W IN4100FS2 IN4100MS2 2P 3W 600/250 HBL3200RS2W HBL3200PS2W HBL3200CS2W IN3200FS2† IN3200MS2 † 3P 4W 600/250 HBL4200RS2W HBL4200PS2W HBL4200CS2W IN4200FS2† IN4200MS2 † 100 200 Maximum Voltage AC/DC Connector & Receptacle Poles and Wires 60 Receptacle/ Connector Configuration* Connector Receptacle Rating Amps Poles and Wires 200 4P 5W Receptacle/ Connector Configuration* Plug Connector Corrosion Resistant Devices Maximum Voltage AC/DC Receptacle M5200RS1 600/250 Plug M5200PS1 Connector & Receptacle Plug Accessories Connector M5200CS1 Back Boxes MB2003W MB2004W Angle Adapter AA20045 Note: *CAUTION: To avoid electrical shock, review premises carefully and DO NOT use if Pin and Sleeve configuration (design) is already in a circuit having a rating differing from the rating of this device. **While in use or with cover closed. †Consult factory. Corrosion resistant cord sets are available on page Y-17 of this catalog. G-34 ® Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks TYPE 4X** Rating Amps Poles and Wires 30 2P 3W 600/250 3P 4W 60 100 200 Receptacle/ Connector Configuration* “Reversed Service” Style I Devices Maximum Voltage AC/DC Receptacle Connector HBL330RS1WR HBL330PS1WR HBL330CS1WR IN330MS1 IN330FS1 600/250 HBL430RS1WR HBL430PS1WR HBL430CS1WR IN430MS1 IN430FS1 4P 5W 600/250 HBL530RS1WR HBL530PS1WR HBL530CS1WR IN530MS1 IN530FS1 2P 3W 600/250 HBL360RS1WR HBL360PS1WR HBL360CS1WR IN360MS1 IN360FS1 3P 4W 600/250 HBL460RS1WR HBL460PS1WR HBL460CS1WR IN460MS1 IN460FS1 4P 5W 600/250 HBL560RS1WR HBL560PS1WR HBL560CS1WR IN560MS1 IN560FS1 2P 3W 600/250 HBL3100RS1WR HBL3100PS1WR HBL3100CS1WR IN3100MS1 IN3100FS1 3P 4W 600/250 HBL4100RS1WR HBL4100PS1WR HBL4100CS1WR IN4100MS1 IN4100FS1 4P 5W 600/250 HBL5100RS1WR HBL5100PS1WR HBL5100CS1WR IN5100MS1 IN5100FS1 3P 4W 600/250 HBL4200RS1WR HBL4200PS1WR HBL4200CS1WR IN4200MS1† IN4200FS1† 4P 5W 600/250 HBL5200RS1WR HBL5200PS1WR HBL5200CS1WR IN5200MS1† IN5200FS1† Rating 30 2P 3W 600/250 3P 4W 200 Receptacle/ Connector Configuration* “Reversed Service” Style II Devices Amps 100 Connector & Receptacle Plug Poles and Wires 60 Replacement Interiors Maximum Voltage AC/DC Replacement Interiors Connector & Receptacle Plug Connector HBL330RS2WR HBL330PS2WR HBL330CS2WR IN330MS2 IN330FS2 600/250 HBL430RS2WR HBL430PS2WR HBL430CS2WR IN430MS2 IN430FS2 2P 3W 600/250 HBL360RS2WR HBL360PS2WR HBL360CS2WR IN360MS2 IN360FS2 3P 4W 600/250 HBL460RS2WR HBL460PS2WR HBL460CS2WR IN460MS2 IN460FS2 2P 3W 600/250 HBL3100RS2WR HBL3100PS2WR HBL3100CS2WR IN3100MS2 IN3100FS2 3P 4W 600/250 HBL4100RS2WR HBL4100PS2WR HBL4100CS2WR IN4100MS2 IN4100FS2 2P 3W 600/250 HBL3200RS2WR HBL3200PS2WR HBL3200CS2WR IN3200MS2† IN3200FS2 † 3P 4W 600/250 HBL4200RS2WR HBL4200PS2WR HBL4200CS2WR IN4200MS2† IN4200FS2 † Rating Amps Poles and Wires 200 4P 5W Receptacle/ Connector Configuration* Receptacle Plug “Reversed Service” Corrosion Resistant Devices Maximum Voltage AC/DC 600/250 Receptacle M5200BS1R Plug Connector M5200CS1R — Plug Accessories Back Boxes MB2003W MB2004W Angle Adapter AA20045 Note: *CAUTION: To avoid electrical shock, review premises carefully and DO NOT use if Pin and Sleeve configuration (design) is already in a circuit having a rating differing from the rating of this device. **While in use or with cover closed. †Consult factory. Corrosion resistant cord sets are available on page Y-17 of this catalog. www.hubbell-wiring.com ® Wiring Device-Kellems G-35 Pin and Sleeve Devices/Mechanical Interlocks Insulgrip Pin and Sleeve Metallic Back Boxes Hubbell manufactures an extensive line of back boxes for use with UL 1686 Pin and Sleeve devices. Each back box is designed to give the user the maximum amount of wiring room while achieving grounding to metallic conduit. Metallic 30º Angle Back Box* MB301W Description Amps NPT Hub Size Catalog Number Back box for 30A devices. 30 30 ¾" 1" MB301W MB302W Metallic 15º Angle Back Box* MB304W Description Amps NPT Hub Size Catalog Number Back box for 60A devices. 60 60 60 1" 1¼" 1½" MB601W MB602W MB603W Metallic Feed-Thru Back Box* Description Amps NPT Hub Size Catalog Number Straight feed-thru box for 30A devices. Straight feed-thru box for 60A devices. 30 30 60 60 60 ¾" 1" 1" 1¼" 1½" MB303W MB304W MB604W MB605W MB606W Metallic Four-Way Angle Back Box* MB601003W Description Amps NPT Hub Size Catalog Number Four-way 15° angle box for 60 and 100A devices. 60/100 60/100 60/100 200 200 200 1¼" 1½" 2" 2" 2½" - MB601002W MB601003W MB601004W MB2003W MB2004W AA20045 Four-way 45° angle box for 200A devices. 45° Angle adapter only for 200A devices. MB601006W Metallic Four-Way Feed-Thru 15º Angle Back Box* Description Amps NPT Hub Size Catalog Number Four-way feed-thru, 15° angle for 60 and 100A devices. 60/100 60/100 60/100 1¼" 1½" 2" MB601006W MB601007W MB601008W Note: *These boxes are cast aluminum, suitable for IP54 requirements and are finished with enamel paint. Replacement Cord Clamp and Locking Ring MB2003W Description Used on Cord Clamp Catalog Number Locking Ring Catalog Number Fits all 30A plugs and connectors. Fits all 60A plugs and connectors. All 3, 4, 5 wire 4 wire (Style 2) and all 5 wire All 3 wire and 4 wire (Style 1) 4 wire (Style 2) and all 5 wire All 3 wire and 4 wire (Style 1) All 3, 4, 5 wire CC3430 CC60 CC60 CC100 CC100 CC201 ILR1** ILR2** ILR3** ILR4** ILR5** — Rating of Hubbell Pin and Sleeve Device Liquidtight Conduit Size Hubbell Liquidtight Adapter Optional Kellems Liquidtight Conduit Grip 30 Amp ½" NPT ¾" NPT 1" NPT 1" NPT 1¼" NPT 1¼" NPT 1½" NPT SAB12 SAB34 SAB100 SAC100 SAC125 SAD125 SAD150 074093402 074093403 074093404 074093404 074093405 074093405 074093406 Fits all 100A plugs and connectors. CC3430 Fits all 200A plugs and connectors. Note: **Locking Ring only. ILR1 Liquidtight Adapters SAB34 60 Amp 074093403 G-36 100 Amp ® Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks Plug Dimensions Connector Body Dimensions A Amps 30 B Style II Style I 330P 7.53" (191) 7.53" (191) 3.00" (76) 3.00" (76) .375-1.20" (9.5-30.5) 430P 7.53" (191) 7.53" (191) 530P 7.53" (191) 60 A Type Style I Style II Cord Grip Range Amps Style II Style I 330C 8.38" (213) 8.38" (213) 3.74" (95) 3.74" (95) .375-1.20" (9.5-30.5) 3.00" (76) 3.00" (76) .375-1.20" (9.5-30.5) 430C 8.38" (213) 8.38" (213) 3.74" (95) 3.74" (95) .375-1.20" (9.5-30.5) 3.00" (76) 530C 8.38" (213) 360C 9.90" (251) 9.90" (251) 3.50" (89) 3.50" (89) .500-1.45" (12.7-36.8) 460C 9.90" (251) 10.10" (256) 3.50" (89) 3.80" (96) .500-1.45" (12.7-36.8) 30 .375-1.20" (9.5-30.5) 360P 9.40" (239) 9.40" (239) 3.40" (86) 3.40" (86) .500-1.45" (12.7-36.8) 460P 9.40" (239) 9.40" (239) 3.40" (86) 3.70" (94) .500-1.45" (12.7-36.8) 560P 9.40" (239) B Type Style I 3.70" (94) 60 .500-1.45" (12.7-36.8) 100 3100P 10.70" (272) 10.70" (272) 3.70" (94) 3.70" (94) .925-1.94" (27.0-49.3) Style II 3.74" (95) 560C 10.10" (256) Cord Grip Range .375-1.20" (9.5-30.5) 3.80" (96) .500-1.45" (12.7-36.8) 100 3100C 11.70" (297) 11.70" (297) 4.50" (114)4.50" (114).925-1.94" (27.0-49.3) 4100P 10.70" (272) 10.90" (277) 3.70" (94) 4.00" (102) .925-1.94" (27.0-49.3) 4100C 11.70" (297) 11.90" (302) 4.50" (114)4.70" (119) .925-1.94" (27.0-49.3) 5100P 10.90" (277) 5100C 11.90" (302) 200 3200P 4.00" (102) 11.13" (282) .925-1.94" (27.0-49.3) 6.35" (161) 1.00-2.50" (25.4-63.5) 200 3200C 4.70" (119) 13.65" (346) .925-1.94" (27.0-49.3) 7.00 (177) 1.00-2.50" (25.4-63.5) 4200P 11.13" (282) 11.13" (282) 6.35" (161) 6.70" (170) 1.00-2.50" (25.4-63.5) 4200C 13.65" (346) 13.65" (346) 7.00" (177)7.39 (187) 1.00-2.50" (25.4-63.5) 5200P 11.13" (282) 5200C 13.65" (346) 6.70" (170) 1.00-2.50" (25.4-63.5) 7.39" (187) A 1.00-2.50" (25.4-63.5) A B B Receptacle Dimensions A B C D E Amps Type Style I Style II Style I Style II Style I Style II Style I Style II Style I Style II 30 330R 2.72" (69) 2.72" (69) 3.40" (86) 3.40" (86) 3.89" (99) 3.89" (99) 3.19" (81) 3.19" (81) 1.37" (35) 1.37" (35) 430R 2.72" (69) 2.72" (69) 3.40" (86) 3.40" (86) 3.89" (99) 3.89" (99) 3.19" (81) 3.19" (81) 1.37" (35) 1.37" (35) 60 100 530R 2.72" (69) 360R 3.50" (89) 3.50" (89) 4.25" (108) 3.40" (86) 4.25" (108) 4.66" (118) 4.66" (118) 4.42" (112) 4.42" (112) 1.54" (39) 1.54" (39) 460R 3.50" (89) 3.50" (89) 4.25" (108) 4.25" (108) 4.66" (118) 4.66" (118) 4.42" (112) 4.42" (112) 1.54" (39) 1.54" (39) 560R 3.50" (89) 4.25" (108) 3.19" (81) 4.66" (118) 1.37" (35) 4.42" (112) 1.54" (39) 3100R 3.50" (89) 3.50" (89) 4.25" (108) 4.25" (108) 4.66" (118) 4.70" (119) 5.30" (135) 5.30" (135) 1.54" (39) 1.54" (39) 4100R 3.50" (89) 3.50" (89) 4.25" (108) 4.25" (108) 4.66" (118) 4.70" (119) 5.30" (135) 5.30" (135) 1.54" (39) 1.54" (39) 5100R 3.50" (89) 200 3.89" (99) 4.25" (108) 3200R 6.50" (165) 4200R 6.50" (165) 6.90" (170) 5200R 6.90" (170) 7.00" (177) 7.00" (177) 7.39" (187) D A 4.66" (118) 7.39" (187) 5.30" (135) 5.63" (143) 5.63" (143) 5.63" (143) 5.63" (143) 7.76" (197) 7.76" (197) 7.76" (197) 7.76" (197) A E 1.54" (39) D .99" (25) .99" (25) .99" (25) .99" (25) E C C B B 30, 60 and 100 Amp 200 Amp Dimensions in Inches (mm) www.hubbell-wiring.com ® Wiring Device-Kellems G-37 Pin and Sleeve Devices/Mechanical Interlocks Metallic Angle Back Box NPT Hub Size A Inch (mm) B Inch (mm) C Inch (mm) D Inch (mm) E Inch (mm) F Inch (mm) 30° Angle back box for 30A devices. ¾" 4.87" (124.0) 2.94" (75.0) 4.02" (102.0) 3.40" (86.0) 4.25" (108.0) 2.12" (54.0) MB301W 1" 4.87" (124.0) 2.94" (75.0) 4.02" (102.0) 3.40" (86.0) 4.25" (108.0) 2.12" (54.0) MB302W 15° Angle back box for 60A devices. 1" – 4.80" (121.9) – – 5.25" (133.4) 2.69" (68.3) MB601W 1¼" – 4.80" (121.9) – – 5.25" (133.4) 2.69" (68.3) MB602W 1½" – 4.80" (121.9) – – 5.25" (133.4) 2.69" (68.3) MB603W Description E A C F B D Metallic Angle Box Catalog Number Metallic Feed-Thru Back Box E Description Back box for 30A devices. A C B D Back box for 60A devices. NPT Hub Size A Inch (mm) B Inch (mm) C Inch (mm) D Inch (mm) E Inch (mm) F Inch (mm) ¾" 5.35" (136.0) 2.91" (74.0) 4.53" (115.0) 3.59" (91.0) 2.62" (67.0) – MB303W 1" 5.35" (136.0) 2.91" (74.0) 4.53" (115.0) 3.59" (91.0) 2.62" (67.0) – MB304W 1" 6.50" (165.1) 3.80" (97.0) 5.75" (146.1) 4.50" (114.3) 3.50" (88.9) – MB604W 1¼" 6.50" (165.1) 3.80" (97.0) 5.75" (146.1) 4.50" (114.3) 3.50" (88.9) – MB605W 1½" 6.50" (165.1) 3.80" (97.0) 5.75" (146.1) 4.50" (114.3) 3.50" (88.9) – MB606W Metallic Feed-Thru Box Catalog Number Metallic Four-Way Angle Back Box E 15° Angle fourway box for 60 and 100A devices. C A B Description D Metallic Four-Way Angle Box 45° Angle fourway box for 200A devices. 45° Angle adapter only for 200A devices. E Four-way Feed-thru box for 60 and 100A devices. C 15° B A Inch (mm) B Inch (mm) C Inch (mm) D Inch (mm) E Inch (mm) F Inch (mm) Catalog Number 1¼" 7.92" (201.0) 8.52" (216.0) 7.00" (178.0) 6.14" (156.0) 4.88" (124.0) – MB601002W 1½" 7.92" (201.0) 8.52" (216.0) 7.00" (178.0) 6.14" (156.0) 4.88" (124.0) – MB601003W 2" 7.92" (201.0) 8.52" (216.0) 7.00" (178.0) 6.14" (156.0) 4.88" (124.0) – MB601004W 2" 10.82" (274.8) 9.86" (250.4) 9.50" (241.3) 8.17" (207.5) 6.75" (171.5) – MB2003W 2½" 10.82" (274.8) 9.86" (250.4) 9.50" (241.3) 8.17" (207.5) 6.75" (171.5) – MB2004W – 8.00" (203.2) 6.00" (152.4) 7.00" (178.0) 8.00" (203.2) 7.00" (178.0) – AA20045 Metallic Four-Way Feed-Thru 15º Angle Back Box Description A NPT Hub Size D Metallic Feed-Thru Angle Box NPT Hub Size A Inch (mm) B Inch (mm) C Inch (mm) D Inch (mm) E Inch (mm) F Inch (mm) Catalog Number 1¼" 7.98" (202.7) 8.55" (217.2) 7.00" (178.0) 6.14" (156.0) 4.88" (124.0) – MB601006W 1½" 7.98" (202.7) 8.55" (217.2) 7.00" (178.0) 6.14" (156.0) 4.88" (124.0) – MB601007W 2" 7.98" (202.7) 8.55" (217.2) 7.00" (178.0) 6.14" (156.0) 4.88" (124.0) – MB601008W Note: These boxes are cast aluminum, suitable for IP54 requirements and are finished with enamel paint. Dimensions in Inches (mm) G-38 ® Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks Materials (30, 60, 100, and 200 Amp) Typical Specification Plug Material Manufacturer’s ID Description Electrical Type Max. Rating Configuration Certification Housing PBT 357 (200A Aluminum) Plug Shroud Aluminum Cord Clamps Rynite® SST35 (200A Aluminum) Clamp Nut Nickel Plated Brass Gland Cap Rynite® SST35 Gland Neoprene O-Rings, Gaskets & Seals Neoprene Contact Carrier Thermoset Polyester Retainer Thermoset Polyester Sleeves Brass (M-Series - Nickel-plated tellurium copper) Box Terminal Heat Treated & Zinc Plated Steel Screws (Terminal, Assembly & Set) Stainless Steel (300 Series) Ground Standoff Brass Ground Bracket Nickel Plated Spring Bronze Locking Ring Epoxy Painted Aluminum Connector Body Housing PBT 357 (200 Amp Aluminum) Connector Shroud Epoxy Painted Aluminum Cord Clamps Rynite® SST35 Clamp Nut Nickel Plated Brass Gland Cap Rynite® SST35 (200A Aluminum) Gland Neoprene O-Rings, Gaskets & Seals Neoprene Contact Carrier Thermoset Polyester Retainer Thermoset Polyester Pin Brass (M-Series - Nickel-plated tellurium copper) Pin Spring Beryllium Copper Box Terminal Heat Treated & Zinc Plated Steel Screws (Terminal, Assembly & Set) Stainless Steel (300 Series) Ground Standoff Brass Ground Bracket Nickel Plated Spring Bronze Cover Epoxy Painted Aluminum Cover Arm Epoxy Painted Aluminum Spring Guide Stainless Steel (300 Series) Springs (Arm & Wave) Stainless Steel (300 Series) Spring Washer Stainless Steel (300 Series) Hinge Bushing Aluminum Rivet Aluminum Receptacle Housing/Flange Epoxy Painted Aluminum O-Rings, Gaskets & Seals Neoprene Contact Carrier Thermoset Polyester Retainer Thermoset Polyester Pin Brass (M-Series - Nickel-plated tellurium copper) Pin Spring Beryllium Copper Box Terminal Heat Treated & Zinc Plated Steel Screws (Terminal, Assembly & Set) Stainless Steel (300 Series) Ground Standoff Brass Ground Bracket Steel Cover Epoxy Painted Aluminum Cover Arm Epoxy Painted Aluminum Spring Guide Stainless Steel (300 Series) Springs (Arm & Wave) Stainless Steel (300 Series) Spring Washer Stainless Steel (300 Series) Hinge Bushing Aluminum Rivet Aluminum Hubbell HBL430PS2W Plug, Power Supply 3 Pole + Earth 30 Amp, 600V AC, 250V DC, 50-400Hz UL 1686, Watertight, C1 Configuration UL Listed, UL Standard 1682, UL 50, and UL 1010 (plugs only), CSA Certified to CSA Spec. C22.2 No. 182.1, No. 94 and No. 159 (plugs only), UL Listed and CSA Certified Type 4X Performance Electrical Dielectric Voltage Withstands 3,000V AC. Max. Working Voltage 600V AC RMS (i.e., minimum creepage and clearance distance of 6.4 millimeters, per UL 1682). Current Interrupting Certified for current interrupting at full rated current. Temperature Rise Max. 30°C temperature rise at full rated current after 50 cycles of overload at 150% of rated current. Endurance Up to 1,000 connect and disconnect cycles at full rated current and voltage. Mechanical Impact Resistance Cord Grip Cable Retention Cord Accommodation Terminal Identification Product Identification Per CSA C22.2, No. 182.1, UL 1682. Per CSA C22.2, No. 182.1, UL 1682. Round portable service cords of diameters commensurate with the device rating as defined in UL. Standard 62, CSA C22.2 No. 49 and the harmonized European Standards. Terminals identified in accordance with UL 1686 (1, 2, 3, Green). Identification and ratings are permanently fastened to the device housing. Environmental Hose Down & Moisture Type 3, 4, 4X per UL 50E and CSA 22.2, No. 94. Resistance Flammability (Enclosure) UL 94V-0 and CSA C22.2 No. 0.17. Operating Temperatures Maximum Continuous 75°C; Minimum -40°C without impact -25° with impact. Hazardous Location Class I, Division I & II, Groups B, C & D and (30, 60 & 100A) Class II, Division I & II, Groups F & G per (plug only) UL 1010 & CSA 22.2, No. 159. Materials Housings All Other Materials PBT 357 (200A Aluminum). Resistant to corrosion and chemical attack. Watertight Application Guide Industry Watertight. Agriculture Chemical Processing Construction Entertainment Food Processing Food Service Light Manufacturing Manufacturing Military Outdoor for fans, heaters, pumps, etc. Where subject to water, corrosion. Outdoors subject to severe weather conditions. Outdoors subject to severe weather. Where subject to water, corrosion. Areas subject to wash downs & heavy cleaning. Subjected to cleaning, solvents & chemicals. Where subject to water, corrosion. Outdoor construction or maintenance. Rynite® is a registered trademark of E.I. DuPont Corp. www.hubbell-wiring.com ® Wiring Device-Kellems G-39 Pin and Sleeve Devices/Mechanical Interlocks Features and Benefits Style II Insulgrip® Mechanical Interlocks Hubbell Circuit-Lock® Pin and Sleeve Mechanical Interlocks are a revolutionary design that incorporates a disconnect switch and pin and sleeve receptacle in a compact non-metallic unit. These devices offer maximum safety by preventing users from mating or breaking a circuit under load—Hubbell’s interlock mechanism detects the presence of a plug and prevents it from being removed when the switch is in the "ON" position. It features a high visibility red handle that can be locked to meet OSHA lockout/tagout regulations, and the enclosure door can be locked to prevent unauthorized access. The rugged, corrosion-resistant Type 4X PBT enclosure features adjustable mounting feet for flexible installation, while the receptacle’s spring-loaded cover with gasket is dust tight and provides a watertight seal when turned and locked. The patented Plug-Check™ mechanism detects the presence of the plug. It operates as a clutch to engage the handle with the switch and captures the plug. This action prevents the plug from being removed until the switch is turned OFF. HBL430MIFS2W G-40 Housing Design • Non-metallic enclosure meets UL 50E Type 4X (watertight), 12 (dust-tight) and IP66 suitability requirements. Enclosure is molded of rugged thermoplastic PBT to resist abuse, corrosion and enhance safety. All external hardware is stainless steel • Stainless steel ¼ turn door fasteners for quick, easy access to fuses Interior Design • Compact Fused Disconnect Switch accepts Class “J” fuses. Fuse holders are top mounted for easy access • The switch accepts auxiliary contacts for control circuit applications including the ON/OFF control of remote pilot lights or signal for programmable controllers Safety • High visibility red handle can be locked in the OFF position as a method of compliance with OSHA lockout requirements. Accepts up to a ⁵⁄₁₆ inch padlock shackle • Replaceable spring-loaded receptacle liftcover with gasket ensures dust tight rating; liftcover provides watertight seal when turned and locked Contact Carrier • Thermoset polyester contact carrier provides resistance to electrical tracking and withstands higher temperatures • Thermoset properties provide excellent dimensional stability, low moisture absorption and superior dielectric strength Enclosure Door • Removable door for ease of wiring and installation • Enclosure door can be locked to prevent unauthorized access. Additionally, if the switch is ON, the door cannot be opened Installation • Three molded-in conduit drill points are located on the top, bottom and back surface of enclosure. Conduit hub provided: 30A 1 in. NPT, 60A 1¼ in. NPT • Conduit hub and adjustable mounting feet (4) are ductile to allow mounting on irregular surfaces ® Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks TYPE 4X** Style II - Fused Fused Insulgrip® Mechanical Interlocks Rating Amps Poles and Wires 30 3P 4W 600/250 HBL430MIFS2W HBL430PS2W 60 3P 4W 600/250 HBL460MIFS2W HBL460PS2W Receptacle/ Connector Configuration* Maximum Voltage AC/DC Mechanical Interlock Mating Plug HBL430MIFS2W Style II - Unfused Gray Style Switch Unfused Insulgrip® Mechanical Interlocks Rating HBLACFSNO Amps Poles and Wires 30 3P 4W 600/250 HBL430MIS2W HBL430PS2W 60 3P 4W 600/250 HBL460MIS2W HBL460PS2W Receptacle/ Connector Configuration* Maximum Voltage AC/DC Mechanical Interlock Mating Plug HBL30MIFRS Black Style Switch Note: 30A – 1 inch NPT hub supplied; 60A – 1¼ inch hub supplied. *CAUTION: To avoid electrical shock, review premises carefully and DO NOT use if Pin and Sleeve configuration (design) is already in a circuit having a rating differing from the rating of this device. **While in use or with cover closed. Replacement Auxiliary Contacts Description Black Style Switch Gray Style Switch Auxiliary contact, normally open, A600 pilot duty, break before break. Auxiliary contact, normally closed, A600 pilot duty, break before break. ACFSNO ACFSNC HBLACFSNO HBLACFSNC ACFSNO Note: Auxiliary contacts are specific to the style switch noted and are NOT interchangeble. All new installations are shipped with gray style switch. Replacement Switches Description Gray Style Switch For 30A fused switches. For 60A fused switches. Gray Style switch will retro fit Black Style switch. For 30A unfused switches. For 60A unfused switches. Gray Style switch will retro fit Black Style switch. HBL30MIFRS HBL60MIFRS HBL30MISRS HBL60MISRS MICPK30 Watertight Closure Plug Kits Description Catalog Number For 30A Circuit-Lock® unfused and fused Pin and Sleeve mechanical interlocks. For 60 and 100A Circuit-Lock® MICPK30 MICPK60 unfused and fused Pin and Sleeve mechanical interlocks. Replacement Mounting Feet Description Catalog Number Replacement mounting feet and screws for 30 and 60A fused mechanical interlocks. HBLRFT2 ∆ Note: ∆ Package of 10 feet and 10 screws. www.hubbell-wiring.com ® HBLRFT2 Wiring Device-Kellems G-41 Pin and Sleeve Devices/Mechanical Interlocks Typical Specifications Performance Manufacturer’s Identification Hubbell HBL460MIFS2W Description Fused Insulgrip® Pin and Sleeve Mechanical Interlock Electrical Type 3 Pole + Earth Rating 60A, 250VDC/600VAC Configuration Per UL 1686 C1 Enclosure Type (UL 50E) Indoor & Outdoor - 4X (Watertight, Washdown) Indoor - 12 (Dust Tight, Falling Dirt) Ingress Protection IP66 Suitability Certification UL Listed for US and Canada Electrical Note: This device provides fused switched control of a plug connected load and includes an interlocking feature to prevent the plug from being disconnected or the door from opening­while the receptacle is energized. The switch cannot be turned on until the plug is fully inserted. Materials Part Dielectric Voltage Max. Working Voltage Current Interrupting Short Circuit Withstand Rating Operations Withstands 3,000VAC Min. 250VDC/600VAC. Certified for current interrupting at full rated current and voltage. Suitable for use on a circuit capable of delivering not more than 200,000 RMS symmetrical amperes at the voltage rating of receptacle. Mechanical 10,000 cycles minimum. Mechanical Impact Resistance Terminal Identification Product Ratings Mounting In accordance with UL 746C. In accordance with UL, CSA and international conventions. Ratings are part of the external label and molded into the receptacle housing. External adjustable feet. Environmental Material Base, Door and Handle PBT Conduit Hub Zinc, 30A – 1 in., 60A – 1¼ in. NPT Enclosure Gasket Neoprene and Shaft Seal Shaft and Mounting Inserts Brass Ground Plate Galvanized Steel Enclosure Screws Stainless Steel and Hinge Spring Hinge Pin Nickel-Plated Brass Contact Carrier Thermoset Polyester Moisture Resistance Ingress Protection Flammability Operating Temperatures UV Resistance Fuse Types Indoor & Outdoor - 4X (Watertight, Washdown); Indoor - 12 (Dust-tight, Falling dirt). IP66 Suitability. UL94-5VA and V-0 Classification. Max. Continuous +60°C; Min. Continuous -40°C w/o impact. All exposed insulating materials are UV stabilized. UL Listed Class “J”. CSA Certified HRCI-J. Horsepower Ratings 30A Horsepower Ratings 60A Horsepower Ratings 3 Phase A.C. 3 Phase A.C. Standard Maximum* 200-240V 3 7.5 480V 5 15 600V 7.5 20 Standard Maximum* 200-240V 7.5 15 480V 15 30 600V 15 50 Note: *Requires time delay fuses. Dimensions 7.27" (184.7) 10.18" (258.6) 9.31" (236.5) 7.19" (182.6) 1.51" (38.4) 30A 1.68" (42.7) 60A 3.60" (91.4) 11.46" (291.6) 12.37" (314.2) 15.03" (381.8) 14.48" (367.8) 15.36" (390.1) 4.00" (101.6) 30A 5.00" (127.0) 60A 8.43" (214.1) Note: 30A – 1 inch NPT hub supplied; 60A – 1¼ inch hub supplied. Dimensions in Inches (mm) G-42 ® Wiring Device-Kellems www.hubbell-wiring.com Pin and Sleeve Devices/Mechanical Interlocks Features and Benefits Hazardous Location Non-Fused Mechanical Interlocks and Plugs Hubbell’s Hazardous Location Line of Non-Fused UL 1686 Mechanical Interlock Disconnect Switches are typically used for applications with the presence of flammable gasses or vapors, ignitable dusts and fibers. They are also suitable for use in outdoor or indoor damp, wet and dirty locations or in areas where frequent wash downs, heavy rain, or water spray routinely occurs. These switches are compact in size to reduce cost and make it easier to position on the wall or piece of equipment. The enclosures are made of copper-free aluminum and have a polyester/epoxy finish to prevent corrosion. The high visibility handles can be locked out to comply with OSHA lock out/tag out regulations. VSQ Hazardous Location Ratings Class I, Div. 1 & 2, Groups B,C,D Class I, Zones I & 2, Groups IIB+H2, IIA Class II, Div. 1 & 2, Groups F & G Class lll NEMA 3, 4, 4X, 7 (B,C,D), 9 (F,G) HBLVP3485 HBLVSQ3034 Housing Design • Copper-free aluminum construction with electrostatically applied polyester/ epoxy finish to prevent corrosion • Compact NEMA 4X enclosure and footfrint allows easy installation in tight locations Internal Design • Auxiliary contact (late-make early-break) contact rated 10 amp, 1/3 HP at 125/250V AC can be used for operating pilot lights or starter coils • Internal switch horsepower rated as “suitable as a motor disconnect” • Feed-through construction Safety • Lockable handle to meet OSHA Lockout/Tagout regulations • Large visible rotary handle with ON/OFF indicator allows a quick means of disconnecting power • Handle mechanism is chemical resistant PBT thermoplastic Plug Locking Ring • NEMA 4X environmental rating with cover engaged or when mated with a 4X plug Mechanism • Plug and switch are interlocked. Switch cannot be turned ON without fully inserted plug Plug cannot be removed with switch in ON position • Plug held in place when switch is OFF for convenience. Pull operated release mechanism Fully Interchangeable • Product is UL1686 and is fully interchangeable with other UL1686 configured and listed devices www.hubbell-wiring.com ® Wiring Device-Kellems G-43 Pin and Sleeve Devices/Mechanical Interlocks 30 and 60 Amp Non-Fused UL1686 Mechanical Interlocks and Plugs Amp Circuit Mechanical Interlock Metallic Plug Insulgrip Plug 30 Amp 600V AC 2W 3P HBLVSQ3023 HBLVP3385 HBL330PS2W 3W 4P HBLVSQ3034 HBLVP3485 HBL430PS2W 60 AMP 600V AC 2W 3P HBLVSQ6023 HBLVP6385 HBL360PS2W 3W 4P HBLVSQ6034 HBLVP6485 HBL460PS2W Note: Early break contact comes standard with mechanical interlocks. HBLVSQ 30 Amp models come standard with 1 inch drilled and tapped conduit openings top and bottom plus two 1 inch x ¾ inch reducers and one ¾ inch close-up plug for maximum flexibility. 60 amp models come with one 1½ inch opening on top and bottom and one 1½ inch close-up plug. HBLVSQ3034 Horsepower Ratings (VAC)* Amp 30 Amp 60 Amp HBLVP3485 Circuit 120 240 480 600 Catalog Number 1Ø 2 5 10 15 HBLVSQ3023 3Ø 3 7.5 15 20 HBLVSQ3034 1Ø – 10 15 20 HBLVSQ6023 3Ø – 10 25 30 HBLVSQ6034 Note: *Internal switch only. HBL430PS2W Dimensions Mechanical Interlocks A B C D 30A 5.75 (146) 10.50 (267) 9.75 (248) 3.75 (95) 3.13 (79) 8.13 (206) 60A 8.13 (206) 14.16 (360) 11.28 (287) 4.03 (102) 2.50 (64) 11.38 (289) A F C D E B E F A B C D E 30A Both Plugs 6.69 (170) 3.00 (76) 1.88 (48) 5.38 (137) 2.53 (64) 60A, 3 Pole 8.81 (224) 3.38 (86) 2.25 (57) 6.50 (165) 3.00 (76) 60A, 4 Pole 8.81 (224) 3.69 (94) 2.53 (64) 6.50 (165) 3.00 (76) A B E C D Wire Range Reg. Stranded Extra Flex Grip Range 30A #10 – #6 #10 – #8 .55–1.2 (14–30) 60A #6 – #4 #6 – #4 .65–1.5 (16–38) Dimensions in Inches (mm) G-44 ® Wiring Device-Kellems www.hubbell-wiring.com
HBL560C9W 价格&库存
很抱歉,暂时无法提供与“HBL560C9W”相匹配的价格&库存,您可以联系我们找货
