HBL61CM65
HBL61CM65
    HUBBELL(哈伯尔公司)
HBL61CM65 数据手册
Product Datasheet -- HBL61CM65 http://www.hubbellcatalog.com/wiring/section-a-datasheet.asp?FAM=S... Product Datasheet 1 of 2 2-Pole 3-Wire Grounding, 20A 125V, 5-20R, with Lift Cover and Boot, Multiple Drive Screws, Gray Product Specifications Product Type Standard NEMA Amperage Voltage 20A 125V Poles and Wires 2 Pole, 3-Wire Grounding Wiring Method Side Wire Only Hospital Grade ? No Receptacle Grade Flange Style Heavy Duty Spec Grade Weatherproof Enhancement Corrosion Resistance Color NEMA No. Horsepower 5-20R 1 Type Rating 2 Pole, 3 Wire, Grounding 20A, 125V Certification UL Listed, File E2186, Meets NEMA WD-6 requirements Listed to UL Standard 498, Certified to CSA, C22.2, No. 42 Terminal Screw #8-32 Brass, Multiple Drive Material Ground Screw Material #8-32 Brass, Multiple Drive (Green) Base Material Nylon Power Contacts Material Mounting Screw Material Dielectric Voltage Current Interrupting Temperature Rise Terminal Identification .040" (1.0) Brass Stainless Steel Withstands 2,000V minimum. Certified for current interrupting at full rated current. Max 30°C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of 75%.. Terminals identified in accordance with UL498 (Brass, White, Green). 13/12/2010 11:58 Product Datasheet -- HBL61CM65 2 of 2 http://www.hubbellcatalog.com/wiring/section-a-datasheet.asp?FAM=S... Terminal Accommodation Product Identification Ratings are a permanent part of the device. Flammability UL 94 V2. Operating Temperatures M Drawings Catalog Page #14-#10 AWG copper stranded or solid conductor only. Maximum continuous 75°C, minimum -40°C (w/o impact). Click here for M-Drawing Click here for catalog page A28 Catalog Section UPC Number Click here for Section-A 783585808673 Weight in LBs 0.250 NEMA Configuration 13/12/2010 11:58
HBL61CM65 价格&库存
很抱歉,暂时无法提供与“HBL61CM65”相匹配的价格&库存,您可以联系我们找货
