HBL8300HRED
HBL8300HRED
    HUBBELL(哈伯尔公司)
HBL8300HRED 数据手册
SECTION L Table of Contents HBL® Extra Heavy Duty Industrial Series Surge Protection Devices Industrial and Commercial Series GFCIs Product Page Product Page HBL® Extra Heavy Duty Hospital Grade Duplex Receptacles Extra Heavy Duty Industrial GFCI Receptacles L-12 Products at a Glance L-2 Commercial GFCI Receptacles Features and Benefits L-3 Tamper-Resistant L-13 L-4 L-14 L-5 Standard L-15 L-8 Hospital Grade Surge Protection Devices L-16 L-10 Hubbellock® Plugs, Connectors and Receptacles L-17 L-10 Hubbellock® Mobile X-Ray Devices L-18 Duplex and Style SNAPConnect® Line® Decorator Receptacles Hubbell-PRO Receptacles USB Charger Receptacles Single and 4-PLEX® Receptacles Tamper-Resistant and Weather Resistant Hospital Grade Plugs, Connector Bodies and Receptacles 15 and 20A, 125V L-11 15 and 20A, 250V L-11 www.hubbell-wiring.com ® Wiring Device-Kellems L-1 Hospital Products Products at a Glance HBL® Extra Heavy Duty Hospital Grade • Hospital Grade with green dot symbol • One-piece nickel-plated integral ground strap • ID marking surface for quick circuit identification • Square head, 10-thread bronze center rivet • Deep nylon body design increases impact and chemical resistance • Hospital and Specification Grade SpikeShield® Surge Suppression Plug Strips • Tamper-Resistant, NOT Plug Resistant™ • UL2930 HCOA’s • Power indicating LED • UL1449 SPD’s available • Steel mounting strap, self-grounding • 15A and 20A versions • Compact size requires minimal space • 6 foot or 15 foot cords available Extra Heavy Duty SNAPConnect® • USB versions in several models Hubbell-PRO Heavy Duty • Hospital and Specification Grade • Tamper-Resistant, NOT Plug Resistant™ • Power LED feature • Circuit ID marking area • Steel mounting strap, self-grounding • Assembled in USA USB Charger Receptacles • Two Type-C, Type A&C and Type A port configurations, high power 5 Amp, 5 Volt USB output • Heavy duty stainless steel USB ports; rated for 10,000 cord insertions and removals • Patented Hubbell Tamper-Resistant technology uses cam action shutters. The friction-free design of the mechanism’s doors requires much less force • Available in SNAPConnect® Hubbellock® Devices • Nylon cover, thermoset interior • Armored, epoxy filled, rubber cord grip • Black, back wired • Mobile X-Ray devices 4-PLEX Receptacles • Hospital Grade and Surge • Mounts directly to 4-inch square box • "A" and "B" circuit ID molded into face • Removable knockouts for mounting to octagon concrete ring or box • Heavy duty, triple wipe, brass power and ground contacts L-2 ® Wiring Device-Kellems www.hubbell-wiring.com Hospital Products Features and Benefits Hubbell “Hospital Grade” Devices UL requirements for Hospital Grade devices is more stringent than those for standard devices. Hubbell receptacles are designed to meet and exceed the standards. • Exclusive nickel-plated bypass contact design increases contact pressure, lowering the operating temperature. • Four point grounding system provides redundant grounding for low resistance ground continuity in high abuse areas. • High tech reinforced thermoplastic polyester (RTP) back is tough and heat resistant. Because of these features and others, the benefit is performance, reliability, and value for any health care facility. HBL8200GY Housing Design • Reinforced thermoplastic base provides superior thermal, electrical and mechanical properties • Providing contact stability, this high performance material will reduce heat buildup giving you long lasting performance • Deep body design increases impact and chemical resistance Terminals • External wiring clamps allow for visual inspection of the terminals • Unique strand containment feature on the terminal “bundles” the wire, ensuring 100% clamping of wire strands and reducing heat from the termination One-Piece Mounting Strap • Back wired ground terminal allows faster, easier installation • One-piece nickel-plated brass integral ground strap for greater corrosion resistance • Patented ground contact provides redundant grounding Contacts • Exclusive bypass contacts are made of nickel-plated brass alloy, increasing blade retention, insuring reliable uninterrupted flow of power • Barbed assembly arms reduce possibility of face/base separation Identification • I.D. marking surface provides quick, sure circuit identification • All Hospital Grade devices are marked with the green dot symbol, required by UL Center Rivet • Square head, 10-thread bronze center rivet won’t rotate, reduces stripping and resists corrosion www.hubbell-wiring.com ® Wiring Device-Kellems L-3 Hospital Products IP20 SUITABILITY 15A 125V NEMA 5-15R UL CSA 0.5 HP HBL® Extra Heavy Duty Hospital Grade Receptacles Duplex 20A 125V NEMA 5-20R UL CSA 1 HP Description Color Catalog Number Flush, thermoplastic polyester face, back and side wired. Black Blue Brown Gray Ivory Light Almond Red White HBL8200BK – HBL8200 HBL8200GY HBL8200I HBL8200LA HBL8200RED HBL8200W – HBL8300BL HBL8300 HBL8300GY HBL8300I HBL8300LA HBL8300RED HBL8300W Flush, LED illuminated face, back and side wired. Gray Ivory Red White HBL8200ILGY HBL8200ILI HBL8200ILR HBL8200ILW HBL8300ILGY HBL8300ILI HBL8300ILR HBL8300ILW Tamper-Resistant receptacle with wire leads. Complies with requirements of NEC® article 517-18(c). Brown Gray Ivory Light Almond Red White HBL8200SGA HBL8200SGGYA HBL8200SGIA HBL8200SGLA HBL8200SGRA HBL8200SGWA HBL8300SGA HBL8300SGGYA HBL8300SGIA HBL8300SGLA HBL8300SGRA HBL8300SGWA Isolated ground∆. Orange Red IG8200 IG8200R IG8300 IG8300R Description Color Catalog Number MRI receptacle, flush, thermoplastic polyester face, back and side wired. Ivory Light Almond Red White HBL8200IMRI HBL8200LAMRI HBL8200RMRI HBL8200WMRI Description Color Catalog Number Flush, thermoplastic polyester face, back, and side wired. Fed. Spec. verified. Brown Gray Green Ivory Light Almond Red White HBL8200H HBL8200HG – HBL8200HI HBL8200HLA HBL8200HRED HBL8200HW HBL8200GY HBL8300SGA MRI Receptacle, Duplex HBL8300RMRI HBL8300IMRI HBL8300LAMRI HBL8300RMRI HBL8300WMRI Slender/Compact, Duplex HBL8300H HBL8300HG HBL8300HGN HBL8300HI HBL8300HLA HBL8300HRED HBL8300HW Style Line® Decorator* HBL8200ILW Description Color Catalog Number Flush, nylon face, back and side wired. Brown Gray Ivory Office White Red White HBL2172 HBL2172GY HBL2172I – HBL2172R HBL2172WA Isolated ground∆. Ivory Orange White – – – HBL2182 HBL2182GY HBL2182I HBL2182OW HBL2182R HBL2182WA IG2182I IG2182 IG2182WA Note: ∆See section M for additional information on isolated ground devices. *Not Fed. Spec. Listed. See pages A-48 and A-49 for accessories. See page Tech-10 for Tamper-Resistant description. See section N for wallplates. HBL2172 Dimensions in Inches (mm) L-4 NEC® is a registered trademark of the National Fire Protection Association (NFPA). ® Wiring Device-Kellems www.hubbell-wiring.com Hospital Products IP20 1.56" (39.7) SUITABILITY Extra Heavy Duty Hospital Grade SNAPConnect® Duplex 15A 125V NEMA 5-15R UL CSA 0.5 HP Color Catalog Number Hospital grade, finder groove, nylon face, modular receptacle which requires pigtailed connector below. Black Brown Gray Ivory Light Almond Red White Black Brown Gray Ivory Light Almond Red White Black Brown Gray Ivory Light Almond Red White Black Brown Gray Ivory Light Almond Red White Orange Red Black Brown Gray Ivory Light Almond Red White Orange Red Black Brown Gray Ivory Light Almond Red White Orange Red SNAP8200BKA SNAP8200A SNAP8200GYA SNAP8200IA SNAP8200LAA SNAP8200RA SNAP8200WA SNAP8200BKNA SNAP8200NA SNAP8200GYNA SNAP8200INA SNAP8200LANA SNAP8200RNA SNAP8200WNA SNAP8200BKTRA SNAP8200TRA SNAP8200GYTRA SNAP8200ITRA SNAP8200LATRA SNAP8200RTRA SNAP8200WTRA SNAP8200BKSCTRA SNAP8200SCTRA SNAP8200GYSCTRA SNAP8200ISCTRA SNAP8200LASCTRA SNAP8200RSCTRA SNAP8200WSCTRA SNAP8200IGTRA SNAP8200RIGTRA SNAP8200BKL SNAP8200L SNAP8200GYL SNAP8200IL SNAP8200LAL SNAP8200RL SNAP8200WL SNAP8200IGL SNAP8200RIGL SNAP8200BKLTRA SNAP8200LTRA SNAP8200GYLTRA SNAP8200ILTRA SNAP8200LALTRA SNAP8200RLTRA SNAP8200WLTRA SNAP8200IGLTRA SNAP8200RIGLTRA Hospital grade, Tamper-Resistant, smooth nylon face, modular receptacle which requires pigtailed connector below. Assembled in USA. Hospital grade, Tamper-Resistant, Split Circuit, smooth nylon face, modular receptacle which requires pigtailed connector below. Assembled in USA. Isolated ground∆, Hospital grade, Tamper-Resistant. Hospital grade, with Power Indicating LED, smooth nylon face, modular receptacle which requires pigtailed connector below. Assembled in USA. Isolated ground∆, Hospital grade, with Power Indicating LED. Hospital grade, Tamper-Resistant, with Power Indicating LED, smooth nylon face, modular receptacle which requires pigtailed connector below. Assembled in USA. Isolated ground∆, Hospital grade, TR with Power Indicating LED. 2.62" (66.5) 3.28" (83.3) Description Hospital grade, smooth nylon face, modular receptacle which requires pigtailed connector below. Assembled in USA. 20A 125V NEMA 5-20R UL CSA 1 HP SNAP8300BKA SNAP8300A SNAP8300GYA SNAP8300IA SNAP8300LAA SNAP8300RA SNAP8300WA SNAP8300BKNA SNAP8300NA SNAP8300GYNA SNAP8300INA SNAP8300LANA SNAP8300RNA SNAP8300WNA SNAP8300BKTRA SNAP8300TRA SNAP8300GYTRA SNAP8300ITRA SNAP8300LATRA SNAP8300RTRA SNAP8300WTRA SNAP8300BKSCTRA SNAP8300SCTRA SNAP8300GYSCTRA SNAP8300ISCTRA SNAP8300LASCTRA SNAP8300RSCTRA SNAP8300WSCTRA SNAP8300IGTRA SNAP8300RIGTRA SNAP8300BKL SNAP8300L SNAP8300GYL SNAP8300IL SNAP8300LAL SNAP8300RL SNAP8300WL SNAP8300IGL SNAP8300RIGL SNAP8300BKLTRA SNAP8300LTRA SNAP8300GYLTRA SNAP8300ILTRA SNAP8300LALTRA SNAP8300RLTRA SNAP8300WLTRA SNAP8300IGLTRA SNAP8300RIGLTRA .86" (21.9) SNAP8300WA 1.64" (41.7) 2.62" (66.5) 3.28" (83.3) .86" (21.9) SNAP8300LATR 1.64" (41.7) 2.62" (66.5) 3.28" (83.3) .86" (21.9) SNAP8300L 1.64" (41.7) .86" (21.9) SNAP8300RLTR 1.63" (41.3) SNAPConnect® Extra Heavy Duty Hospital Grade Single Receptacles Hospital Grade 20A 125V Color 15A 125V Almond Black Blue Brown Gray Ivory Light Almond Red White SNAP8210AL SNAP8210BK SNAP8210BL SNAP8210 SNAP8210GY SNAP8210I SNAP8210LA SNAP8210R SNAP8210W www.hubbell-wiring.com SNAP8310AL SNAP8310BK SNAP8310BL SNAP8310 SNAP8310GY SNAP8310I SNAP8310LA SNAP8310R SNAP8310W Hospital Grade 15A 125V SNAP8210ALTR SNAP8210BKTR SNAP8210BLTR SNAP8210TR SNAP8210GYTR SNAP8210ITR SNAP8210LATR SNAP8210RTR SNAP8210WTR 2.62" (66.5) 3.28" (83.3) Tamper-Resistant 20A 125V SNAP8310ALTR SNAP8310BKTR SNAP8310BLTR SNAP8310TR SNAP8310GYTR SNAP8310ITR SNAP8310LATR SNAP8310RTR SNAP8310WTR ® 3.28" (83.3) 2.00" (50.8) .922" (23.4) SNAP8310GY Dimensions in Inches (mm) Wiring Device-Kellems L-5 Hospital Products IP20 1.64" (41.7) SUITABILITY 2.62" (66.5) 3.28" (83.3) .86" (21.9) Description Color Catalog Number Hospital grade, Style Line® decorator, flush, nylon face, modular receptacle which requires pigtailed connector below. Black Brown Gray Ivory Light Almond Red White Black Brown Gray Ivory Light Almond Red White Black Brown Gray Ivory Light Almond Red White Black Brown Gray Ivory Light Almond Red White Orange Red Black Brown Gray Ivory Light Almond Red White Orange Red Black Brown Gray Ivory Light Almond Red White Orange Red SNAP2172BKA SNAP2172A SNAP2172GYA SNAP2172IA SNAP2172LAA SNAP2172RA SNAP2172WA SNAP2172BKNA SNAP2172NA SNAP2172GYNA SNAP2172INA SNAP2172LANA SNAP2172RNA SNAP2172WNA SNAP2172BKTRA SNAP2172TRA SNAP2172GYTRA SNAP2172ITRA SNAP2172LATRA SNAP2172RTRA SNAP2172WTRA SNAP2172BKSCTRA SNAP2172SCTRA SNAP2172GYSCTRA SNAP2172ISCTRA SNAP2172LASCTRA SNAP2172RSCTRA SNAP2172WSCTRA SNAP2172IGTRA SNAP2172RIGTRA SNAP2172BKL SNAP2172L SNAP2172GYL SNAP2172IL SNAP2172LAL SNAP2172RL SNAP2172WL SNAP2172IGL SNAP2172RIGL SNAP2172BKLTRA SNAP2172LTRA SNAP2172GYLTRA SNAP2172ILTRA SNAP2172LALTRA SNAP2172RLTRA SNAP2172WLTRA SNAP2172IGLTRA SNAP2172RIGLTRA SNAP2182A 1.64" (41.7) Hospital grade, Style Line® decorator, flush, nylon face, modular receptacle which requires pigtailed connector below. Assembled in USA. 2.62" (66.5) 3.28" (83.3) .86" (21.9) SNAP2182ITR 1.64" (41.7) Hospital grade, Tamper-Resistant, Style Line® decorator, flush, nylon face, modular receptacle which requires pigtailed connector below. Assembled in USA. Hospital grade, Tamper-Resistant, Split Circuit, Style Line® decorator, flush, nylon face, modular receptacle which requires pigtailed connector below. Assembled in USA. 2.62" (66.5) 3.28" (83.3) .86" (21.9) SNAP2182RL Isolated ground∆, Hospital grade, Tamper-Resistant. Hospital grade, with Power Indicating LED, Style Line® decorator, flush, nylon face, modular receptacle which requires pigtailed connector below. Assembled in USA. 1.64" (41.7) 2.62" (66.5) 3.28" (83.3) .86" (21.9) SNAP2182GYLTR .78" (19.8) 1.48" (37.6) .63" (16.0) SNAP1RA Dimensions in Inches (mm) L-6 15A 125V NEMA 5-15R UL CSA 0.5 HP Extra Heavy Duty Hospital Grade SNAPConnect® Style Line® Decorator Isolated ground∆, Hospital grade, with Power Indicating LED. Hospital grade, Tamper-Resistant, with Power Indicating LED, Style Line® decorator, flush, nylon face, modular receptacle which requires pigtailed connector below. Assembled in USA. Isolated ground∆, Hospital grade, TR with Power Indicating LED. 20A 125V NEMA 5-20R UL CSA 1 HP SNAP2182BKA SNAP2182A SNAP2182GYA SNAP2182IA SNAP2182LAA SNAP2182RA SNAP2182WA SNAP2182BKNA SNAP2182NA SNAP2182GYNA SNAP2182INA SNAP2182LANA SNAP2182RNA SNAP2182WNA SNAP2182BKTRA SNAP2182TRA SNAP2182GYTRA SNAP2182ITRA SNAP2182LATRA SNAP2182RTRA SNAP2182WTRA SNAP2182BKSCTRA SNAP2182SCTRA SNAP2182GYSCTRA SNAP2182ISCTRA SNAP2182LASCTRA SNAP2182RSCTRA SNAP2182WSCTRA SNAP2182IGTRA SNAP2182RIGTRA SNAP2182BKL SNAP2182L SNAP2182GYL SNAP2182IL SNAP2182LAL SNAP2182RL SNAP2182WL SNAP2182IGL SNAP2182RIGL SNAP2182BKLTRA SNAP2182LTRA SNAP2182GYLTRA SNAP2182ILTRA SNAP2182LALTRA SNAP2182RLTRA SNAP2182WLTRA SNAP2182IGLTRA SNAP2182RIGLTRA Note: ∆See section M additional information on isolated ground devices. See page A-16 for additional information on SNAPConnect® features. See page Tech-10 for Tamper-Resistant and LED Power Indicators description. See pages A-50 and A-51 for accessories. See section N for wallplates. SNAPConnect® Right Angle Pigtailed Connector Description Wire Type General Use Assembled in USA Clear right angle terminal with 6 inch leads #12 AWG THHN/THWN-2; Polycarbonate housing material Solid Stranded SNAP1RA SNAP2RA SNAP1RNA SNAP2RNA Note: For Assembled in USA products, must order connector with NA suffix. ® Wiring Device-Kellems www.hubbell-wiring.com Hospital Products 1.75" (44.5) SNAPConnect® GFCI LED Hospital Grade , Assembled in USA Description Hospital Grade SNAPConnect GFCI LED, self-grounding staple, requires connector below, sold separately. Rating Color 15 and 20A Almond Black 125V AC Brown Gray Ivory Light Almond Red White 15A 125V NEMA 5-15R UL CSA 0.5 HP 20A 125V NEMA 5-20R UL CSA 1 HP Meets UL Standard 943 Class A GFCI 2.76" (70.0) 3.28" (83.3) Catalog Number GFRST82SNAPAL GFRST82SNAPBK GFRST82SNAP GFRST82SNAPGY GFRST82SNAPI GFRST82SNAPLA GFRST82SNAPR GFRST82SNAPW GFRST83SNAPAL GFRST83SNAPBK GFRST83SNAP GFRST83SNAPGY GFRST83SNAPI GFRST83SNAPLA GFRST83SNAPR GFRST83SNAPW 1.10" (27.8) GFRST83SNAPR 1.75" (44.5) SNAPConnect® GFCI LED Hospital Grade , Tamper and Weather Resistant, Assembled in USA Description Hospital Grade SNAPConnect GFCI TR/WR, self-grounding staple, requires connector below, sold separately. Rating Color 15 and 20A Almond Black 125V AC Brown Gray Ivory Light Almond Red White Catalog Number GFTWRST82SNAPAL GFTWRST82SNAPBK GFTWRST82SNAP GFTWRST82SNAPGY GFTWRST82SNAPI GFTWRST82SNAPLA GFTWRST82SNAPR GFTWRST82SNAPW GFTWRST83SNAPAL GFTWRST83SNAPBK GFTWRST83SNAP GFTWRST83SNAPGY GFTWRST83SNAPI GFTWRST83SNAPLA GFTWRST83SNAPR GFTWRST83SNAPW 2.76" (70.0) 3.28" (83.3) 1.10" (27.8) GFTWRST83SNAPI 1.75" (44.5) SNAPConnect® USB Charger Hospital Grade , Duplex Receptacles 15A 125V NEMA 5-15R UL CSA 0.5 HP Description Color Catalog Number Hospital Grade SNAPConnect USB Charger, Tamper-Resistant Style Line® decorator duplex receptacle, two USB type 2.0 ports 3 Amp, 5 Volt DC, 15 or 20 Amp, 125 Volt AC. Black Brown Gray Ivory Light Almond Red White SNAP8200USBBK SNAP8200USB SNAP8200USBGY SNAP8200USBI SNAP8200USBLA SNAP8200USBR SNAP8200USBW SNAPConnect® Surge Protection Hospital Grade , Tamper-Resistant Receptacle with Power Indicating LED 20A 125V NEMA 5-20R UL CSA 1 HP SNAP8300USBBK SNAP8300USB SNAP8300USBGY SNAP8300USBI SNAP8300USBLA SNAP8300USBR SNAP8300USBW 15A 125V NEMA 5-15R UL CSA 0.5 HP Description Color Catalog Number Hospital Grade SNAPConnect Surge supression, Tamper-Resistant, smooth face, duplex receptacle. Blue Gray Ivory Light Almond Red White SNAP8262S SNAP8262GYS SNAP8262IS SNAP8262LAS SNAP8262RS SNAP8262WS 2.62" (66.5) 3.28" (83.3) 20A 125V NEMA 5-20R UL CSA 1 HP 1.54" (39.1) SNAP8300USBW 1.75" (44.5) 2.62" (66.5) 3.28" (83.3) SNAP8362S SNAP8362GYS SNAP8362IS SNAP8362LAS SNAP8362RS SNAP8362WS 1.33" (33.8) SNAP8262S .78" (19.8) 1.48" (37.6) SNAPConnect® Right Angle Pigtailed Terminal .63" (16.0) Description Wire Type General Use Assembled in USA Clear right angle terminal with 6 inch leads, 600V, #12 AWG THHN/THWN-2, Polycarbonate housing material. Solid Stranded SNAP1RA SNAP2RA SNAP1RNA SNAP2RNA Note: See page Tech-10 for Tamper-Resistant and Weather Resistant descriptions. www.hubbell-wiring.com SNAP1RA Dimensions in Inches (mm) ® Wiring Device-Kellems L-7 Hospital Products Features and Benefits Hubbell-PRO Heavy Duty Receptacles • Automatic self-grounding staple • Combination Tamper-Resistant and LED for pediatric emergency circuits • Nylon face and base construction • Circuit ID marking area • Back and side wiring • Tri drive screws • Steel mounting strap 8200REDLTRA 1.57" (39.9) 15A 125V NEMA 5-15R UL CSA 0.5 HP Hubbell-PRO Heavy Duty Hospital Grade Receptacles Duplex 2.73" (69.3) 3.28" (83.3) 1.15" (29.1) Description Color Catalog Number Hospital grade, smooth nylon face, back and side wired. Assembled in USA. Black Brown Gray Ivory Light Almond Red White 8200BK 8200 8200GY 8200IV 8200LA 8200RED 8200WHI 8300BK 8300 8300GY 8300IV 8300LA 8300RED 8300WHI Hospital grade, Tamper-Resistant, smooth nylon face, back and side wired. Assembled in USA. Black Brown Gray Ivory Light Almond Red White 8200BKTRA 8200TRA 8200GYTRA 8200IVTRA 8200LATRA 8200REDTRA 8200WTRA 8300BKTRA 8300TRA 8300GYTRA 8300IVTRA 8300LATRA 8300REDTRA 8300WTRA Hospital grade, with Power Indicating LED, smooth nylon face, back and side wired. Assembled in USA. Black Brown Gray Ivory Light Almond Red White 8200BKL 8200L 8200GYL 8200IVL 8200LAL 8200REDL 8200WL 8300BKL 8300L 8300GYL 8300IVL 8300LALM 8300REDL 8300WL Hospital grade, Tamper-Resistant, with Power Indicating LED, smooth nylon face, back and side wired. Assembled in USA. Black Brown Gray Ivory Light Almond Red White 8200BKLTRA 8200LTRA 8200GYLTRA 8200IVLTRA 8200LALTRA 8200REDLTRA 8200WLTRA 8300BKLTRA 8300LTRA 8300GYLTRA 8300IVLTRA 8300LALTRA 8300REDLTRA 8300WLTRA 8200LA 1.57" (39.9) 2.73" (69.3) 3.28" (83.3) 1.15" (29.1) 8200TRA 1.57" (39.9) 3.28" (83.3) 2.73" (69.3) 20A 125V NEMA 5-20R UL CSA 1 HP Note: See pages A-48 and A-49 for accessories. See page Tech-10 for Tamper-Resistant and LED Power Indicators description. See section N for wallplates. 1.15" (29.1) 8200REDLTRA Dimensions in Inches (mm) L-8 The products listed on this page are Assembled in USA, and many are Buy American Compliant. Please contact Hubbell with any certification requirements. ® Wiring Device-Kellems www.hubbell-wiring.com Hospital Products Features and Benefits Hubbell-PRO Heavy Duty Receptacles • Automatic self-grounding staple • Combination Tamper-Resistant and LED for pediatric emergency circuits • Nylon face and base construction • Circuit ID marking area • Back and side wiring • Tri drive screws • Steel mounting strap 2182IVLTRA 15A 125V NEMA 5-15R UL CSA 0.5 HP Hubbell-PRO Heavy Duty Hospital Grade Receptacles Style Line® Decorator 1.57" (39.9) 20A 125V NEMA 5-20R UL CSA 1 HP Description Color Catalog Number Hospital grade, Style Line® decorator, flush, nylon face, back and side wired. Assembled in USA. Black Brown Gray Ivory Light Almond Red White 2172BK 2172 2172GY 2172IV 2172LA 2172RED 2172W 2182BK 2182 2182GY 2182IV 2182LA 2182RED 2182W Hospital grade, Tamper-Resistant, Style Line® decorator, flush, nylon face, back and side wired. Assembled in USA. Black Brown Gray Ivory Light Almond Red White 2172BKTRA 2172TRA 2172GYTRA 2172IVTRA 2172LATRA 2172REDTRA 2172WTRA 2182BKTRA 2182TRA 2182GYTRA 2182IVTRA 2182LATRA 2182REDTRA 2182WTRA Hospital grade, with Power Indicating LED, Style Line® decorator, flush, nylon face, back and side wired. Assembled in USA. Black Brown Gray Ivory Light Almond Red White 2172BKL 2172L 2172GYL 2172IVL 2172LAL 2172REDL 2172WL 2182BKL 2182L 2182GYL 2182IVL 2182LAL 2182REDL 2182WL Hospital grade, Tamper-Resistant, with Power Indicating LED, Style Line® decorator, flush, nylon face, back and side wired. Assembled in USA. Black Brown Gray Ivory Light Almond Red White 2172BKLTRA 2172LTRA 2172GYLTRA 2172IVLTRA 2172LALTRA 2172REDLTRA 2172WLTRA 2182BKLTRA 2182LTRA 2182GYLTRA 2182IVLTRA 2182LALTRA 2182REDLTRA 2182WLTRA 2.73" (69.3) 3.28" (83.3) 1.15" (29.1) 2172LATRA 1.57" (39.9) 2.73" (69.3) 3.28" (83.3) 1.15" (29.1) 2172L 1.57" (39.9) 3.28" (83.3) Note: See pages A-48 and A-49 for accessories. See page Tech-10 for Tamper-Resistant and LED Power Indicators description. See section N for wallplates. 2.73" (69.3) 1.15" (29.1) The products listed on this page are Assembled in USA, and many are Buy American Compliant. Please contact Hubbell with any certification requirements. www.hubbell-wiring.com ® 2182IVLTRA Dimensions in Inches (mm) Wiring Device-Kellems L-9 Hospital Products 1.75" (44.5) 15A 125V NEMA 5-15R UL CSA 0.5 HP Hospital Grade USB Charger Type-C, Type A&C and Type A 3.28" (83.3) 2.61" (66.3) 1.82" (46.1) Description Color Catalog Number Hospital Grade USB Charger Outlet: two Type-C port configurations, high power 5 Amp, 5 Volt USB output, Tamper-Resistant duplex receptacle, USB ports rated 10,000 cycles. Black Brown Gray Ivory Light Almond Red White USB8200C5BK USB8200C5 USB8200C5GY USB8200C5I USB8200C5LA USB8200C5R USB8200C5W USB8300C5BK USB8300C5 USB8300C5GY USB8300C5I USB8300C5LA USB8300C5R USB8300C5W Hospital Grade USB Charger Outlet: one Type A and one Type-C port configurations, high power 5 Amp, 5 Volt USB output, Tamper-Resistant duplex receptacle, USB ports rated 10,000 cycles. Black Brown Gray Ivory Light Almond Red White USB8200AC5BK USB8200AC5 USB8200AC5GY USB8200AC5I USB8200AC5LA USB8200AC5R USB8200AC5W USB8300AC5BK USB8300AC5 USB8300AC5GY USB8300AC5I USB8300AC5LA USB8300AC5R USB8300AC5W Hospital Grade USB Charger Outlet: two Type A port configurations, high power 5 Amp, 5 Volt USB output, Tamper-Resistant duplex receptacle, USB ports rated 10,000 cycles. Black Brown Gray Ivory Light Almond Red White USB8200A5BK USB8200A5 USB8200A5GY USB8200A5I USB8200A5LA USB8200A5R USB8200A5W USB8300A5BK USB8300A5 USB8300A5GY USB8300A5I USB8300A5LA USB8300A5R USB8300A5W USB8300C5W 1.75" (44.5) 3.28" (83.3) 2.61" (66.3) 1.82" (46.1) USB8200AC5W 1.63" (41.4) HBL® Extra Heavy Duty Hospital Grade Single Receptacles 3.28" (83.3) 1.94" (49.3) .92” (23.4) .1” (2.5) IP20 SUITABILITY Description Color Catalog Number Flush, nylon face, back and side wired, Fed. Spec. verified. Almond Brown Gray Ivory Red White – HBL8210 HBL8210GY HBL8210I HBL8210R HBL8210W HBL8310AL HBL8310 HBL8310GY HBL8310I HBL8310R HBL8310W Panel mount on 1.94 in. (49.2) centers. Brown Ivory HBL8284 HBL8284I – HBL8384I Isolated ground∆. Orange IG8210 IG8310 1.19" (30.2) HBL8210GY 20A 125V NEMA 5-20R UL CSA 1 HP Note: ∆See section M for additional information on isolated ground devices. 4.30” sq. (109.2) 4-PLEX® Hospital Grade 3.02” (76.7) 3.38” (85.9) HBL415HI Color Catalog Number 4 outlet high impact resistant Polycarbonate construction. Mount to 4 in. square box. Brown Gray Ivory Red White HBL415H – HBL415HI HBL415HR HBL415HW .38" (9.7) 3.28" (83.3) 4.78" (121.4) .19" (4.8) 2.75" (69.9) HBL420H HBL420HGY HBL420HI HBL420HR HBL420HW 4-PLEX® Accessories Description Color Catalog Number 4-PLEX adapter plates for 1- and 2-gang, device boxes. Brown Gray Ivory Red White HBL4AP HBL4APGY HBL4API HBL4APR HBL4APW 1.75" (44.5 ) 3.38"sq. (85.9) HBL4API Receptacles Description HBL4AP HBL4APGY HBL4API HBL4APR HBL4APW Note: See page A-25 for additional information on 4-PLEX devices. Dimensions in Inches (mm) L-10 ® Wiring Device-Kellems www.hubbell-wiring.com Hospital Products G IP20 G W W SUITABILITY Hospital Grade 15A 125V NEMA 5-15P UL CSA Plugs 20A 125V NEMA 5-20P UL CSA Insulgrip® HBL8215C Description Cord Diameter Catalog Number Black and white nylon. .230"-.720" (5.8-18.3) HBL8215C HBL8315C Transparent housing. .230"-.720" (5.8-18.3) HBL8215CT HBL8315CT 8 position angle plug, transparent housing. .250"-.655" (6.4-16.6) HBL8215CAT* HBL8315CAT* Valise® Description Cord Diameter Catalog Number White nylon. .300"-.660" (7.6-16.8) HBL8115V Insulation displacement, white nylon. .300"-.360" (7.6-9.1) HBL8013V* Note: *Not Fed. Spec. Listed. See page A-49 for accessories HBL8364V − G G IP20 SUITABILITY Hospital Grade Plugs 15A 250V NEMA 6-15P UL CSA 1.5 HP 20A 250V NEMA 6-20P UL CSA 2 HP Valise® HBL8115V Description Cord Diameter Catalog Number Valise plug, white nylon. .300"-.660" (7.6-16.8) HBL8666V HBL8464V Note: HP ratings listed above are based on 208 to 240V AC only. IP20 SUITABILITY Hospital Grade Insulgrip® Connector Bodies 15A 125V NEMA 5-15R UL CSA 0.5 HP 20A 125V NEMA 5-20R UL CSA 1 HP Description Cord Diameter Catalog Number Black and white nylon. .230"-.720" (5.8-18.3) HBL8219C HBL8319C Transparent housing. .230"-.720" (5.8-18.3) HBL8219CT HBL8319CT HBL8219C Valise® Description Cord Diameter Catalog Number White nylon. .300"-.660" (7.6-16.8) HBL8119V Note: See page A-49 for accessories. Hospital Grade Valise® HBL8219CT – G Connector Bodies Description Cord Diameter White nylon. .300"-.660" (7.6-16.8) G 15A 250V NEMA 6-15R UL CSA 1.5 HP 20A 250V NEMA 6-20R UL CSA 2 HP Catalog Number – HBL8469V G HBL® Extra Heavy Duty Hospital Grade Receptacles Duplex G 15A 250V NEMA 6-15R UL CSA 1.5 HP Description Color Catalog Number Flush, thermoplastic polyester face, back and side wired, multiple drive screws. Brown Ivory HBL8600 HBL8600I 20A 250V NEMA 6-20R UL CSA 2 HP HBL8400 HBL8400I HBL8600I Note: See page A-48 for accessories. See section N for wallplates. www.hubbell-wiring.com Dimensions in Inches (mm) ® Wiring Device-Kellems L-11 Hospital Products Meets UL Standard 943 Class A GFCI Features and Benefits Extra Heavy Duty Hospital Grade GFCI Receptacles Tamper-Resistant and Weather Resistant 10kA Short Circuit Current Rating Limits improper access to energized contacts • Exclusive patented tamper-resistant protection through switching technology • Continually tests and monitors for people protection automatically • Patented self test diagnostics Power indication • Steady “ON” GREEN LED provides indication of power Ground fault indicator • Steady “ON” RED LED provides visual indication of a ground fault condition; flashing red indicates device has lost capability to provide protection No power at face if reverse wired • Open circuit condition eliminates false assumption of protection at face Durable face with V-0 flammability rating • Polyester face cover GFR8300SGI AUTOGUARD® Self Test GFCI Receptacles Tamper-Resistant and Weather Resistant Description Rating Flush, polyester face, back and side wired, multiple drive screws. GFR8300SGW 15 and 20A 125V AC 15A 125V NEMA 5-15R UL CSA 0.5 HP 20A 125V NEMA 5-20R UL CSA 1 HP Color Catalog Number Black Brown Gray Ivory Red White GFR8200SGBK GFR8200SG GFR8200SGGY GFR8200SGI GFR8200SGR GFR8200SGW GFR8300SGBK GFR8300SG GFR8300SGGY GFR8300SGI GFR8300SGR GFR8300SGW Note: GFCI type receptacles should not be used in critical care patient areas or for electrical life support equipment applications because of the possibility of power interruption. All GFCI receptacles listed above are furnished with both a matching color nylon wallplate, and a SS26 302/304 super stainless steel wallplate. 20 amp feed-through capability. See page Tech-10 for Tamper-Resistant and Weather Resistant descriptions. GFCI Receptacle Specifications per GFCI Products Listed (Pages L-12 to L-15) Trip Level Trip Time Frequency Voltage Amperage Maximum Interrupting Capacity Operating Temperature Maximum Humidity Listings and Standards Codes 4 to 6 mA. .025 second nominal. 60 Hz. 120V AC +10% - 15% (102V to 132V). 15A/20A, 20A Feed Thru. 10,000A. -35°C to 66°C or -30°F to 150°F. 95%. Meets UL498 for receptacles, UL943 Class A for GFCIs UL File E41978. CSA Certified. Meets all NEC® and CEC requirements. NEMA WD-6 ANSI 73. NEC® is a registered trademark of the National Fire Protection Association (NFPA). L-12 ® Wiring Device-Kellems www.hubbell-wiring.com Hospital Products Meets UL Standard 943 Class A GFCI Features and Benefits Commercial Tamper-Resistant GFCI Receptacles • Patented shutter design for tamper-resistant protection • Compliant with NEC® 406.12 and NEC® 517-18(c) • Patented AUTOGUARD® self test technology includes disconnecting power to the receptacle if critical components are damaged and GFCI protection is lost • Alarm version provides audible notification of a trip condition GFTRST83B 15A 125V NEMA 5-15R UL CSA 0.5 HP Hospital Grade Tamper-Resistant Description Rating 20A 125V NEMA 5-20R UL CSA 1 HP Color Catalog Number Night Light Two LED Night Lights, Flush, nylon face, back and side wired, multiple drive screws, self-grounding staple. 15 and 20A 125V AC Almond Black Brown Gray Ivory Light Almond Red White GFTRST82ALNL GFTRST82BKNL GFTRST82NL GFTRST82GYNL GFTRST82INL GFTRST82LANL GFTRST82RNL GFTRST82WNL GFTRST83ALNL GFTRST83BKNL GFTRST83NL GFTRST83GYNL GFTRST83INL GFTRST83LANL GFTRST83RNL GFTRST83WNL Alarm, Flush, nylon face, back and side wired, multiple drive screws, self-grounding staple. 15 and 20A 125V AC Almond Black Brown Gray Ivory Light Almond Red White GFTRST82ALB GFTRST82BKB GFTRST82B GFTRST82GYB GFTRST82IB GFTRST82LAB GFTRST82RB GFTRST82WB GFTRST83ALB GFTRST83BKB GFTRST83B GFTRST83GYB GFTRST83IB GFTRST83LAB GFTRST83RB GFTRST83WB GFTRST83WNL GFTRST83GYB Product Dimensions Inches (mm) E GFCI Receptacle A 3.27 (83.1) B 2.75 (69.8) C 1.75 (44.5) D 1.47 (37.4) E 1.10 (27.9) A B C www.hubbell-wiring.com D Dimensions in Inches (mm) ® Wiring Device-Kellems L-13 Hospital Products Meets UL Standard 943 Class A GFCI Features and Benefits Commercial Tamper and Weather Resistant GFCI Receptacles • Patented shutter design for tamper-resistant protection • Meets NEC® requirements for TR (517-18c) and WR (406.9), UV and corrosion resistance for harsh and damp applications • Patented AUTOGUARD® self test technology • Protects against line and load reversal, no power to the face or downstream if device is miswired GFTWRST83WIG GFTWRST82AL Description GFTWRST83GYU GFTWRST82BKIG 15A 125V NEMA 5-15R UL CSA 0.5 HP Hospital Grade • Tamper-Resistant Weather Resistant Rating 20A 125V NEMA 5-20R UL CSA 1 HP Color Catalog Number Standard, Flush, nylon face, back and side wired, multiple drive screws, self-grounding staple. 15 and 20A 125V AC Almond Black Brown Gray Ivory Light Almond Red White GFTWRST82AL GFTWRST82BK GFTWRST82 GFTWRST82GY GFTWRST82I GFTWRST82LA GFTWRST82R GFTWRST82W GFTWRST83AL GFTWRST83BK GFTWRST83 GFTWRST83GY GFTWRST83I GFTWRST83LA GFTWRST83R GFTWRST83W Assembled in USA, Flush, nylon face, back and side wired, multiple drive screws, self-grounding staple. 15 and 20A 125V AC Almond Black Brown Gray Ivory Light Almond Red White GFTWRST82ALU GFTWRST82BKU GFTWRST82U GFTWRST82GYU GFTWRST82IU GFTWRST82LAU GFTWRST82RU GFTWRST82WU GFTWRST83ALU GFTWRST83BKU GFTWRST83U GFTWRST83GYU GFTWRST83IU GFTWRST83LAU GFTWRST83RU GFTWRST83WU Isolated Ground, Flush, nylon face, back and side wired, multiple drive screws, self-grounding staple. 15 and 20A 125V AC Almond Black Brown Gray Ivory Light Almond Red White GFTWRST82ALIG GFTWRST82BKIG GFTWRST82IG GFTWRST82GYIG GFTWRST82IIG GFTWRST82LAIG GFTWRST82RIG GFTWRST82WIG GFTWRST83ALIG GFTWRST83BKIG GFTWRST83IG GFTWRST83GYIG GFTWRST83IIG GFTWRST83LAIG GFTWRST83RIG GFTWRST83WIG SNAPConnect®, Flush, nylon face, back and side wired, multiple drive screws, self-grounding staple. 15 and 20A 125V AC Almond Black Brown Gray Ivory Light Almond Red White GFTWRST82SNAPAL GFTWRST82SNAPBK GFTWRST82SNAP GFTWRST82SNAPGY GFTWRST82SNAPI GFTWRST82SNAPLA GFTWRST82SNAPR GFTWRST82SNAPW GFTWRST83SNAPAL GFTWRST83SNAPBK GFTWRST83SNAP GFTWRST83SNAPGY GFTWRST83SNAPI GFTWRST83SNAPLA GFTWRST83SNAPR GFTWRST83SNAPW GFTWRST83SNAPI SNAPConnect® Right Angle Pigtailed Terminal Description SNAP1RA L-14 Wire Type Clear right angle terminal with 6 inch leads Solid #12 AWG THHN/THWN-2; Polycarbonate Stranded housing material. ® Wiring Device-Kellems General Use Catalog Number Assembled in USA Catalog Number SNAP1RA SNAP2RA SNAP1RNA SNAP2RNA www.hubbell-wiring.com Hospital Products Meets UL Standard 943 Class A GFCI Features and Benefits Commercial Standard Hospital Grade • GFCI Receptacles • Fed. Spec UL Listed, Hospital Grade • Green power indicator and red trip indicator • Patented AUTOGUARD® self test technology • Flush, nylon face, back and side wired, multiple drive screws, self-grounding staple 15A 125V NEMA 5-15R UL CSA 0.5 HP Hospital Grade • GFCI Receptacles Rating Rating Standard, Flush, nylon face, back and side wired, multiple drive screws, self-grounding staple. 15 and 20A 125V AC Assembled in USA, Flush, nylon face, back and side wired, multiple drive screws, self-grounding staple. 15 and 20A 125V AC Night Light Two LED Night Lights, 15 and 20A 125V AC Alarm, Flush, nylon face, back and side wired, multiple drive screws, self-grounding staple. 15 and 20A 125V AC SNAPConnect®, Flush, nylon face, back and side wired, multiple drive screws, self-grounding staple. 15 and 20A 125V AC Flush, nylon face, back and side wired, multiple drive screws, self-grounding staple. Color Catalog Number Almond Black Brown Gray Ivory Light Almond Red White Almond Black Brown Gray Ivory Light Almond Red White Almond Black Brown Gray Ivory Light Almond Red White Almond Black Brown Gray Ivory Light Almond Red White Almond Black Brown Gray Ivory Light Almond Red White GFRST82AL GFRST82BK GFRST82 GFRST82GY GFRST82I GFRST82LA GFRST82R GFRST82W GFRST82ALU GFRST82BKU GFRST82U GFRST82GYU GFRST82IU GFRST82LAU GFRST82RU GFRST82WU GFRST82ALNL GFRST82BKNL GFRST82NL GFRST82GYNL GFRST82INL GFRST82LANL GFRST82RNL GFRST82WNL GFRST82ALB GFRST82BKB GFRST82B GFRST82GYB GFRST82IB GFRST82LAB GFRST82RB GFRST82WB GFRST82SNAPAL GFRST82SNAPBK GFRST82SNAP GFRST82SNAPGY GFRST82SNAPI GFRST82SNAPLA GFRST82SNAPR GFRST82SNAPW 20A 125V NEMA 5-20R UL CSA 1 HP GFRST83AL GFRST83BK GFRST83 GFRST83GY GFRST83I GFRST83LA GFRST83R GFRST83W GFRST83ALU GFRST83BKU GFRST83U GFRST83GYU GFRST83IU GFRST83LAU GFRST83RU GFRST83WU GFRST83ALNL GFRST83BKNL GFRST83NL GFRST83GYNL GFRST83INL GFRST83LANL GFRST83RNL GFRST83WNL GFRST83ALB GFRST83BKB GFRST83B GFRST83GYB GFRST83IB GFRST83LAB GFRST83RB GFRST83WB GFRST83SNAPAL GFRST83SNAPBK GFRST83SNAP GFRST83SNAPGY GFRST83SNAPI GFRST83SNAPLA GFRST83SNAPR GFRST83SNAPW GFRST82WNL GFRST82R GFRST83INL GFRST83BKB SNAPConnect® Right Angle Pigtailed Terminal Description Wire Type General Use Catalog Number Assembled in USA Catalog Number Clear right angle terminal with 6 inch leads #12 AWG THHN/THWN-2; Polycarbonate housing material. Solid Stranded SNAP1RA SNAP2RA SNAP1RNA SNAP2RNA www.hubbell-wiring.com ® GFRST83SNAPGY Wiring Device-Kellems L-15 Hospital Products Surge Protection Devices 1.75" (44.3) Hospital Grade 2.62" (66.5) 3.31" (84.0) 1.33" (33.8) SNAP8362GYS 1.30" (33.0) Circuit Guard® Receptacles 2.62" (66.5) 1.75" (44.5) 1.13" (28.7) Color Catalog Number SNAPConnect® Tamper-Resistant, surge supression receptacle, smooth face, duplex. Requires connector on page L-15, sold separately. Blue Gray Ivory Light Almond Red White SNAP8262S SNAP8262GYS SNAP8262IS SNAP8262LAS SNAP8262RS SNAP8262WS SNAP8362S SNAP8362GYS SNAP8362IS SNAP8362LAS SNAP8362RS SNAP8362WS Surge suppression receptacles with light and alarm, 240 joules/15000A per mode. Almond Blue Gray Ivory Red White HBL8262ALSA HBL8262SA HBL8262GYSA HBL8262ISA HBL8262RSA HBL8262WSA HBL8362ALSA HBL8362SA HBL8362GYSA HBL8362ISA HBL8362RSA HBL8362WSA Isolated ground, surge suppression receptacles with light and alarm, 240 joules/15000A per mode. Blue Gray Ivory Orange Red White IG8262SA IG8262GYSA IG8262ISA IG8262OSA IG8262RSA IG8262WSA IG8362SA IG8362GYSA IG8362ISA IG8362OSA IG8362RSA IG8362WSA 4-PLEX® surge suppression receptacles with lights, 80 joules/6500A per mode. Blue Ivory Red – – – HBL420HS HBL420HIS HBL420HRS Note: See page Tech-10 for Tamper-Resistant and LED Power Indicators descriptions. HBL8362ISA .92" (23.4) 20A 125V NEMA 5-20R UL CSA 1 HP Description 1.23" (31.2) 3.28" (83.3) 15A 125V NEMA 5-15R UL CSA 0.5 HP .1" (2.5) 4.30" sq. (109.2) 3.02" (76.7) 3.38" (85.9) 4-PLEX® Accessories Description Color Catalog Number 4-PLEX Adapter Plates for 1- and 2-gang, and 4 in. (101.6) square device boxes. Blue Ivory Red HBL4APBL HBL4API HBL4APR 4-PLEX Portable Box. Portable 4 in. (101.6) square box with cord grip. Accepts up to .66 in. (16.8) diameter cord. Ivory HBL4PBI Note: 4-PLEX Box is not UL Listed. HBL420HS UL2930 Listed UL2930 Health Care Outlet Assembly (HCOA) Description # of Outlets Cord Length Color 15 Amp 20 Amp HBL6MG620 UL 2930 HCOA with L-N Surge Protection 6 6' White HBL6MG6 6 15' White HBL6MG15 HBL6MG1520 UL 2930 HCOA Relocatable Power Tap (RPT) 6 6' White HBL6MGRPT6 HBL6MGRPT620 6 15' White HBL6MGRPT15 HBL6MGRPT1520 HBL6MGRPT620 Listed to UL1449 SpikeShield® Surge Protective Devices (SPD) with Tamper-Resistant Receptacles and Heavy Duty Plug Description HBL6HGUSB6 15 Amp 20 Amp Type 3 SPD, Heavy Duty Metal Housing # of Outlets 6 Cord Length Color 6' White HBL6HG6 HBL6HG620 6 15' White HBL6HG15 HBL6HG1520 UL Type 3 SPD, Heavy Duty Metal Housing with 2-port USB 4 6' White HBL6HGUSB6 — Dimensions in Inches (mm) L-16 ® Wiring Device-Kellems www.hubbell-wiring.com Hospital Products Hubbellock® Plugs, Connector Bodies and Receptacles For Hospital Use Only + Hubbellock® Plugs and Connector Bodies 20A 125V AC 20A 125V AC Description Plugs Connector Bodies Nylon cover, thermoset interior. HBL23014HGB HBL23001HGB Armored, epoxy filled, rubber cord grip. HBL23004HG – Note: Cord clamp range for plug and connector .300" to .660" (7.6 to 16.8). Receptacles Description Catalog Number – Black, back wired. HBL23000HG Wallplates Description Catalog Number Stainless steel 302/304, single-gang. HBL23901HG Stainless steel 302/304, three-gang for two receptacles. HBL23909HG Note: Suffix HG or HGB type for hospital use only. IP30 SUITABILITY 20A 125V AC Explosion Proof Plug Description Catalog Number Plug, with, epoxy kit, accepts #12 or #14 type SO cable. HBL24312 Hazardous to Non-hazardous Location Receptacle Conversion Kits Conversion kits for replacement of explosion proof receptacles listed above, with non-explosion proof receptacles, in the hospital areas formerly classified as hazardous locations and now classified non-hazardous locations due to the change from flammable anesthetizing gases to nonflammable anesthetizing gases. For Conversion To: Catalog Number 20A, 125V, duplex receptacle (Hubbell HBL830 Series). Includes adapter ring and stainless steel wall plate for duplex receptacle (receptacle not included). HBL24300RKD 20A, 125V, Hospital Hubbellock receptacle (Hubbell HBL23000HG) or 20A, 125V, straight blade single receptacle (Hubbell HBL8310 series). Includes adapter ring and stainless wall plate for single receptacle ( receptacle not included. HBL24300RKS HBL24300RKD Duplex retrofit kit accepts 20A duplex straight blade hospital grade receptacles (HBL8300, HBL8300I, IG8300, etc.). Order receptacles separately. 24352 Low-profile style explosion-proof receptacle (now discontinued). HBL24300RKS Single retrofit accepts hospital only Hubbellock single receptacles (Hubbell HBL23000HG) or 20A single straight blade hospital grade receptacles (Hubbell HBL8310, HBL8310I, IG8310, etc.). Order receptacles separately. Dimensions in Inches (mm) www.hubbell-wiring.com ® Wiring Device-Kellems L-17 Hospital Products Hubbellock® Mobile X-Ray Devices IP30 SUITABILITY 50A 250V AC Mobile X-Ray Plugs 60A 250V AC Description Catalog Number Plug, with epoxy kit, less cord clamp. HBL25515 HBL25615 Plug, with cord clamp, less epoxy kit. HBL25525 HBL25625 Note: Cord clamp range of plugs with cord clamps .830" to 1.3" (21.1 to 33.0). 50A plugs fit 50A or 60A receptacles. Mobile X-Ray Receptacles 50A 250V AC 60A 250V AC Description Catalog Number Receptacle with stainless steel plate assembly. HBL25505 HBL25605 Receptacle with cast aluminum plate assembly. HBL25503 HBL25603 Replacement receptacle interior. – IN16494 Accessory Description Catalog Number Box stamped steel 8" x 8" x 4" (203.2 x 203.2 x 101.6), accommodates 50A and 60A mobile X-ray receptacles. Knockout sizes 1¼", 1½" and 2". HBL25509 Dimensions in Inches (mm) L-18 ® Wiring Device-Kellems www.hubbell-wiring.com
HBL8300HRED 价格&库存
很抱歉,暂时无法提供与“HBL8300HRED”相匹配的价格&库存,您可以联系我们找货
