HBL1547
HBL1547
    HUBBELL(哈伯尔公司)
HBL1547 数据手册
Product Datasheet HBL1547 -- Straight Blade Products, Elastogrip Series Connector Body 2-Pole 3-Wire Grounding, 15A 125V, 5-150R, Yellow Elastomer, DustTight Product Specifications Product Type Body Style Straight Standard NEMA Amperage 15A Voltage 125V Poles and Wires 2 Pole, 3-Wire Grounding Hospital Grade ? No Plug/Connector Grade Elastogrip Enhancement Dust Tight Color NEMA No. 5-15R Cord Dia. .300"-.655" (7.6-16.6) Type 2 Pole, 3 Wire, Grounding Rating 15A, 125V Certification UL Listed to UL498 File E1706, CSA Certified to C22.2 No. 42 File 280 IP Suitability IP20 Housing Material PVC-Yellow Retainer Material Polycarbonate-Clear Cord Clamp Material Nylon-Yellow Contact Blades Material .060" (1.5) Brass Ground Contact Blade Material .040" (1.0) Copper Alloy Terminal Screw Material #8-32 Brass, Multiple Drive Ground Screw Material #8-32 Brass, Multiple Drive (Green) Contact Holder Material Nylon-Natural Power Contacts Material .040" (1.0) Copper Alloy Dielectric Voltage Withstands 2,000V minimum. Current Interrupting Certified for current interrupting at full rated current. Temperature Rise Max 30°C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of 75%.. Terminal Identification Terminals identified in accordance with UL498 (Brass, White, Green). Terminal Accommodation #14-#10 AWG copper stranded or solid conductor only. Product Identification Ratings are a permanent part of the device. Flammability UL 94 HB or better. Operating Temperatures Maximum continuous 75°C, minimum -40°C (w/o impact). UPC Number 783585013039 Weight in LBs 0.200 Link to Drawing Library Click here for Library Link to PDF Catalog Click here for Catalog NEMA Configuration
HBL1547 价格&库存
很抱歉,暂时无法提供与“HBL1547”相匹配的价格&库存,您可以联系我们找货
