HBL2320
HBL2320
    HUBBELL(哈伯尔公司)
    HBL2320
HBL2320 数据手册
TWIST-LOCK® and HUBBELLOCK® Devices Index Rating 15A 125V 15A 125V 20A 250V Features and Benefits 15A 125V Features and Benefits 15A 125V, 250V and 277V AC Features and Benefits Features and Benefits Features and Benefits Features and Benefits Features and Benefits Compatibility Chart 20A 125V, 250V and 277V AC 20A 125V, 250V and 277V AC 20A 347V, 480V AC and 600V AC 30A 125V, 250V and 277V AC 30A 125V, and 250V 30A 480V AC and 600V AC 50A 125V, 250V and 480V AC 50A 250V DC and 600V AC 15A 125/250V 20 and 30A 125/250V 20A 125/250V, 3Ø 250V AC and 3Ø 480V AC 30A 125/250V and 3Ø 250V AC 30A 3Ø 480V AC and 3Ø 600V AC 50A 125/250V, 3Ø 250V AC, and 3Ø 480V AC 50A 600V AC, 250V DC 20A 3Ø Y 120/208V AC, 277/480V AC and 347/600V AC 30A 3Ø Y 120/208V AC, 277/480V AC and 347/600V AC 20A and 30A 3Ø Y 120/208V AC 20A 3Ø Y 120/208V AC, 277/480V AC and 347/600V AC 30A 3Ø Y 120/208V AC, 277/480V AC and 347/600V AC 20A 250V, 10A 600V AC 30A 250V, 600V AC and 20A 3Ø Y 120/208V AC 400 Hz 10A, 15A, 20A, and 30A 125V and 250V Dimensions in Inches (mm) 3P 4W, Twist-Lock Grounding Devices 3P 4W, Twist-Lock Grounding Devices 3P 4W, Twist-Lock Grounding Devices B-40–42 B-43–45 B-46 3P 4W, Twist-Lock Grounding Devices 4P 4W, Twist-Lock Non-Grounding Devices B-47 B-48 4P 4W, Twist-Lock Non-Grounding Devices B-49 4P 4W, Twist-Lock Non-NEMA, Non-Grounding Devices 4P 5W, Twist-Lock Grounding Devices B-50 B-51–53 4P 5W, Twist-Lock Grounding Device B-54–56 4P 5W, Twist-Lock Non-NEMA, Grounding Devices 4P 5W, Variload® Twist-Lock Grounding Devices B-57 B-58 Non-NEMA, Not UL Listed Devices Switched Twist-Lock and Hubbellock Enclosures Switched Safety-Shroud Twist-Lock Enclosure Accessories Back Boxes for Watertight Receptacles Add-A-Shroud 50 Amp Twist-Lock Accessories Hubbellock Devices 2P 3W, Hubbellock Grounding Devices 3P 4W, Hubbellock Grounding Devices 3P 4W, Hubbellock Grounding Devices 3P 4W, Hubbellock Grounding Devices 4P 5W, Hubbellock Grounding Devices 4P 5W, Hubbellock Grounding Devices 2P 3W, Hubbellock Grounding Not UL Listed Devices B-59–61 B-62–63 B-64–65 B-66–71 B-72 B-73 B-74 B-75 B-76 B-77 B-78 B-79 B-80 B-81 B-82 Technical Information B-83–88 www.hubbell-wiring.com Index Features and Benefits 20A 125V 30A 600V AC, 20A 250V DC 30A 480V AC 60A 600V AC 30A 600V AC, 20A 250V DC 60A 600V AC 20A 125V AC or DC or 10A 250V DC and 480V AC Type Page Number 2P 2W, Midget Twist-Lock Non-Grounding Devices B-2 2P 2W, Twist-Lock Non-Grounding Devices B-3 2P 2W, Twist-Lock Non-Grounding Devices B-4 Midget Twist-Lock Devices B-5 2P 3W, Midget Twist-Lock Grounding Devices B-6–7 15A Twist-Lock Devices B-9 2P 3W, Twist-Lock Grounding Devices B-10–12 20A and 30A Twist-Lock Devices B-14–15 50A Twist-Lock Devices B-16 20A and 30A Watertight Safety-Shroud Twist-Lock Devices B-17–18 20A and 30A Safety-Shroud Twist-Lock Devices B-19 CIRCUIT-LOCK Unfused Safety-Shroud Mechanical Interlock B-20 Twist-Lock Devices B-21 2P 3W, Twist-Lock Grounding Devices B-22–24 2P 3W, Valise® Twist-Lock Grounding Devices B-25 2P 3W, Twist-Lock Grounding Devices B-26 2P 3W, Twist-Lock Grounding Devices B-27–29 2P 3W, Valise Twist-Lock Grounding Devices B-30 2P 3W, Twist-Lock Grounding Devices B-31 2P 3W, Twist-Lock Grounding Devices B-32 2P 3W, Twist-Lock Grounding Devices B-33 3P 3W, Midget Twist-Lock Non-Grounding Devices B-34–35 3P 3W, Twist-Lock Non-Grounding Devices B-36 3P 4W, Twist-Lock Grounding Devices B-37–39 Locking Devices Section B Locking Devices TWIST-LOCK® Devices 2 Pole, 2 Wire, Non-Grounding 15 Ampere, 125 Volts Midget TWIST-LOCK Flanged Receptacle, Plug, Connector Body and Flanged Inlet W W NEMA ML-1R 15A 125V NEMA ML-1P 15A 125V 1.63" (41.4) 1.38" (35.1) Flanged Receptacle .16" (4.1) DIA. .78" (19.8) 1.03" (26.2) Description Stainless steel flange, exposed terminals. – Male Plug HBL7468 IP20 1.06" (26.9) Connector Body Cord Dia. .220”-.385” (5.6-9.8) IP20 1.77" (45.0) Catalog Number – HBL7465V SUITABILITY Description Valise connector body, black nylon, polarized. HBL7465V HBL7468 SUITABILITY Description Valise® plug, black nylon. 1.25" (31.8) Catalog Number Cord Dia. .220”-.385” (5.6-9.8) Catalog Number HBL7464V – Flanged Inlets 1.06" (26.9) .97" (24.6) HBL7464V Description Stainless steel flange, polarized, exposed terminals. Stainless steel flange, not polarized, exposed terminals. Catalog Numbers – HBL7467 – HBL7466 Weatherproofing Accessories 1.63" (41.4) 1.38" (35.1) .16" (4.1) DIA. .94" (23.9) 1.06" (26.9) HBL7466, HBL7467 Description Catalog Numbers Seal-tite® cover, black elastomer, for use with a HBL7465V when HBL7490V** * used with a HBL7464V connector body or a HBL7464V connector when used with a flanged inlet. Seal-tite cover, black elastomer, for use with a HBL7464V connector HBL7459V** * body and combination of HBL7465V plug and HBL7490V cover. Closure cover for use with HBL7466 or HBL7467. HBL4890 * Bead chain is nickel-plated. ** IP55 suitability when installed and used properly with plug and connector body combinations. * Not UL Listed. 2P 2W, 15A, 125V HBL4890 HBL7459V B-2 HBL7490V www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 2 Pole, 2 Wire Non-Grounding 15 Ampere, 125 Volts Receptacles, INSULGRIP® Plug, Connector Body, Flanged Inlet and Flanged Receptacles 1.00" (25.4) Receptacles Description Duplex, flush, black phenolic. Single, flush, black phenolic. Single, panel mount, 115 /16” (49.2) centers, black phenolic. W W NEMA L1-15R 15A 125V UL Listed 0.5 HP NEMA L1-15P 15A 125V UL Listed 0.5 HP 3.28" (83.3) #6-32 TAP 1.53" (38.8) Catalog Numbers HBL7540 – HBL7535 – HBL7498 – 2.75" (69.9) 1.11" (28.2) 1.19" (30.2) 1.33" (33.8) HBL7540 Insulgrip Plug IP20 SUITABILITY Description Black and white nylon, polarized. Multiple drive screws. Insulgrip Connector Body Cord Dia. .230”-.720” (5.8-18.3) Catalog Number – HBL7545C 1.00" (25.4) 1.63" (41.4) 3.28" 2.38" 1.39" (83.3) (60.5) (35.3) IP20 Description Black and white nylon. Multiple drive screws. SUITABILITY Cord Dia. .230”-.720” (5.8-18.3) #6-32 TAP Catalog Number HBL7506C – 1.19" (30.2) HBL7535 Insulgrip Flanged Inlet Description Nylon casing, polarized, backwired, Multiple drive screws. Catalog Number – HBL7524C 1.00" (25.4) #8-32TAP 1.94" 1.39" (49.3) (35.3) 1.63" (41.4) Flanged Receptacles Description Insulgrip nylon casing, backwired. Multiple drive screws. Metal flange, stainless steel casing, black phenolic, exposed terminals. Catalog Numbers HBL7526C – 1.39" (35.3) 1.19" (30.2) HBL7498 HBL7526 – Notes: Only receptacles and plugs are HP rated. HP ratings are AC only. See pages B-66 and B-67 for accessories. 1.53" (38.9) 1.91" (48.5) 2.19" (55.6) 2.56" (65.0) 2.19" (55.6) HBL7545C 2.56" (65.0) 2.78" (70.6) .16" (4.1) DIA. 1.69" (42.9) 1.53" (38.9) 1.72" (43.7) 1.72" (43.7) HBL7524C Dimensions in Inches (mm) 2P 2W, 15A, 125V 1.69" (42.9) .16" (4.1) DIA. www.hubbell-wiring.com 1.41" (35.8) HBL7506C B-3 Locking Devices TWIST-LOCK® Devices 2 Pole, 2 Wire Non-Grounding 20 Ampere, 250 Volts Receptacles, INSULGRIP® Plug, Connector Body Flanged Inlet, Flanged Receptacles 1.30" 1.41" (33.0) (35.8) NEMA L2-20R 20A 250V UL Listed 2 HP Receptacles 1.39" 2.38" 3.28" (35.3) (60.5) (83.3) 2.09" (53.1) 1.11" (28.2) #6-32 TAP Description Single, black phenolic. Single, mounted on 4” (101.6) round box cover, black phenolic. NEMA L2-20P 20A 250V UL Listed 2 HP Catalog Numbers HBL7210B HBL7217B – – HBL7210B Insulgrip Plug 1.53" (38.9) Cord Dia. .220”-.720” (5.6-18.3) Catalog Number – HBL7102C Cord Dia. .220”-.720” (5.6-18.3) Catalog Number HBL7101C Insulgrip Connector Body 1.91" (48.5) Description Black and white nylon. Multiple drive screws. HBL7102C 2.78" (70.6) 1.41" (35.8) 1.53" (38.9) 2.56" (65.0) 2.19" (55.6) – Insulgrip Flanged Inlet Description Nylon casing, back wired, polarized. Multiple drive screws. HBL7101C .16" (4.1) DIA. Description Black and white nylon, polarized. Multiple drive screws. Catalog Number – HBL8815C Flanged Receptacles 1.72" (43.7) 1.69" (42.9) Description Insulgrip nylon casing, back wired. Multiple drive screws. Metal flange, stainless steel casing, black phenolic, exposed terminals. Catalog Numbers HBL8809C – HBL3226 – Notes: Only receptacles and plugs are HP rated. Horsepower ratings listed above are AC only. See pages B-66 and B-67 for accessories. HBL8815C 2.56" (65.0) 2.19" (55.6) .16" (4.1) DIA. 1.72" (43.7) 2P 2W, 20A, 250V 1.69" (42.9) HBL8809C 1.88" (47.8) .16"(4.1) DIA. 1.83" (46.4) 1.42" (36.1) HBL3226 B-4 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices Midget TWIST-LOCK Devices Totally insulated body adds extra measure of safety. Abuse resistant nylon housing. Assembly screws have multiple drive heads for screwdriver versatility. Only two assembly screws are needed to close this device, make the wire terminations and retain the cord. Patented locking lugs interlock the two sections together when the device is assembled providing a secure assembly in abusive environment. Nylon webs join two sections together which makes assembly of the device quick and easy. The insulation displacement terminal reduces the time required for wire preparation and provides uniformity in the quality of termination. Powerful, cord-gripping jaws designed to eliminate conductor slip and strain on terminals. Hubbell’s Valise® insulation displacement terminal for Midget Twist-Lock plugs and connector bodies are the right choice for economy, wiring speed and long life. Dimensions in Inches (mm) www.hubbell-wiring.com B-5 Features and Benefits “TURN & PULL” marking is highly visible, reducing possible damages to equipment by attempting disconnection prior to unlocking. Locking Devices TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 15 Ampere, 125 Volts Midget TWIST-LOCK® Devices W 2.06" (52.3) 1.75" (44.5) 1.00" (25.4) .15" (3.8) DIA. 1.14" (29.0) HBL7596N 2.06" (52.3) 1.75" (44.5) GR NEMA ML-2R 15A 125V Flanged Receptacles Description Exposed terminals, black nylon flange. Exposed terminals, stainless steel flange. Covered terminals, stainless steel flange, accepts cord .500” (12.7) in dia. NEMA ML-2P 15A 125V Catalog Numbers HBL7596N – HBL7596 – HBL7598 – Male Plugs IP20 SUITABILITY .16" (4.1) DIA. .97" (24.6) 1.17" (29.7) HBL7596 2.06" (52.3) 1.75" (44.5) .16" (4.1) DIA. W GR Description Valise® male plug, black nylon, insulation displacement terminals. Black nylon cover, phenolic body, multiple drive screw terminals. Angle plug, black nylon cover, phenolic body, multiple drive screw terminals. Cord Dia. .300”-.430” (7.6-10.9) .281”-.421” (7.1-10.7) .335”-.421” (8.5-10.7) Catalog Numbers – HBL7594V – HBL7594 – HBL7570 Weatherproof Accessory IP55** SUITABILITY Description Seal-Tite® cover, black elastomer, for use with a HBL7594V plug when used with a HBL7593V connector body or a HBL7593V connector body when used with a flanged inlet. Catalog Number HBL7495V** * Notes: These devices are not interchangeable with any other devices in this catalog. All male ground pins are sleeves and female device grounds are split pin. **IP55 Suitability when installed and used properly with plug and connector body combination. * Not UL Listed. 1.25" (31.8) 1.17" (29.7) HBL7598 1.61" (40.9) 1.19" (30.2) HBL7594V 2.00" (50.8) 1.69" (42.9) 1.59" (40.4) 2P 3W, 15A, 125V .86" (21.8) 1.17" (29.7) 1.13" (28.7) 1.17" (29.7) HBL7594 B-6 HBL7495V HBL7570 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 15 Ampere, 125 Volts Midget TWIST-LOCK® Devices W W GR Connector Bodies NEMA ML-2R 15A 125V IP20 SUITABILITY Description Valise® connector body, black nylon, insulation displacement terminals. Black nylon cover, phenolic body, screw terminals. Angle connector body, black nylon cover, phenolic body, screw terminals. Cord Dia. .300”-.430” (7.6-10.9) .281”-.421” (7.1-10.7) .335”-.421” (8.5-10.7) 1.98" (50.4) GR NEMA ML-2P 15A 125V 1.19" (30.2) Catalog Numbers HBL7593V – HBL7593 – HBL7571 – HBL7593V 2.42" (61.5) Flanged Inlets Description Exposed terminals, black nylon flange. Exposed terminals, stainless steel flange. Covered terminals, stainless steel flange, accepts cord .500” (12.7) dia. Weatherproof Accessories 1.13" (28.7) Catalog Numbers – HBL7595N – HBL7595 – HBL7551 HBL7593 1.69" (42.9) IP55** SUITABILITY Description Seal-Tite® cover, black elastomer, for use with a HBL7593V connector body and a combination of HBL7594V plug and HBL7495V cover. Closure cover for use with HBL7595 or HBL7595N. 1.17" (29.7) Catalog Numbers HBL7440V** * 1.28" (32.5) HBL4889 * Notes: These devices are not interchangeable with any other devices in this catalog. All male ground pins are sleeves and female device grounds are split pin. **IP55 Suitability when installed and used properly with plug cover and connector body combination. * Not UL Listed. 1.17" (29.7) HBL7571 2.06" (52.3) 1.75" (44.5) .15" (3.8) DIA. 1.00" (25.4) 1.28" (32.5) HBL7595N 2P 3W, 15A, 125V 2.06" (52.3) 1.75" (44.5) .16" (4.1) DIA. 1.00" (25.4) HBL7440V Dimensions in Inches (mm) 1.22" (31.0) HBL4889 www.hubbell-wiring.com HBL7595 B-7 Locking Devices TWIST-LOCK® Devices Locking Devices TWIST-LOCK® Devices INSULGRIP® 15 Ampere Plugs and Connector Bodies Featuring Integral VARI-SIZE® Cord Grip Individually molded face for each blade configuration keeps debris out of plug interior. Roomy wiring chamber provides ample space for wiring. Individual wiring terminals are completely enclosed in their own separate chambers. Powerful, offsetting cord grips clamp on individual conductors and outer cord jacket to prevent strain on terminals. Ribbed nylon housing is impact and chemical resistant. Beveled housing prevents snagging when dragged across uneven surfaces. Multiple drive screw heads provide screwdriver versatility. Pocketed recess for cord grip screws deters slippage of the screwdriver. VARI-SIZE pointer set to “smaller than gauge” position. Cord diameter range is .230”-.360” (5.8-9.0). Accepts slotted and Phillips head drivers. Transparent angled wiring entrance holes permit “straight in” conductor insertion. Catalog number is visible on the device while in use for easy identification. Powerful offsetting cord grips clamp on individual conductors and outer cord jacket to prevent strain on terminations. www.hubbell-wiring.com B-9 Features and Benefits Dimensions in Inches (mm) Integral VARI-SIZE® insert adjusts to a wide range of cord sizes: .230”-.720” (5.8-18.3). Locking Devices TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 15 Ampere, 125, 250 Volts and 277 Volts AC Duplex and Single Receptacles G 1.70" (43.2) W X G W G Y 3.28" (83.3) 2.735" (69.5) Duplex Receptacles, Back and Side Wired NEMA L5-15R 15A 125V UL/CSA 0.5 HP Description Flush, brown RTP face. Flush, ivory RTP face. Catalog Numbers HBL4700* HBL4550* HBL4750* HBL4700I* – – NEMA L6-15R 15A 250V UL/CSA 1.5 HP NEMA L7-15R 15A 277V AC UL/CSA 2 HP Fed Spec WC596 Special Purpose Duplex Receptacles Back and Side Wired HBL4700 Description Isolated ground, flush, orange RTP face. Corrosion resistant, yellow RTP face. 1.27" (32.3) HBL4710 HBL4760 Special Purpose Single Receptacles, Back and Side Wired 1.27" (32.3) 1.42" (36.1) HBL4713 Catalog Numbers HBL4710 HBL4560 Single Receptacle, Back and Side Wired Description Flush, black nylon face. 1.94" 1.75" 1.38" (49.3) (44.5) (35.1) – – Fed Spec WC596 3.28" (83.3) 2.38" 1.38" (60.5) (35.1) Catalog Numbers IG4700A* IG4550A* HBL47CM00* – Description Isolated ground, flush, orange nylon face. Single, black nylon face mounted on a 4” (101.6) round box cover. Panel mount, black nylon face, side wired only, 1.75” or 1.937” (44.5 or 49.2) mounting centers. Catalog Numbers IG4710 IG4560 HBL4711 – HBL4761 HBL4713 HBL4763 HBL4563 2P 3W, 15A, 125V, 250V and 277V AC Notes: HP ratings are AC only. RTP is an abbreviation for reinforced thermoplastic polyester. See Section J for full line of isolated ground devices. See pages B-66 and B-67 for accessories. *Supplied with break-off tabs for split circuit wiring. B-10 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 15 Ampere, 125, 250 Volts and 277 Volts AC Plugs and Connector Bodies W G X W G 1.91" (48.5) G Y Plugs Description Insulgrip® plug, black and white nylon. Multiple drive screws. IP20 SUITABILITY Cord Dia. .230”-.720” (5.8-18.3) NEMA L5-15P 15A 125V UL/CSA 0.5 HP NEMA L6-15P 15A 250V UL/CSA 1.5 HP Catalog Numbers HBL4720C™ HBL4570C NEMA L7-15P 15A 277V AC UL/CSA 2 HP 1.53" (38.9) HBL4770C HBL4720C 2.63" (66.8) Fed Spec WC596 Insulgrip plug, corrosion resistant, yellow and white nylon. Multiple drive screws. .230”-.720” (5.8-18.3) HBL47CM20C HBL45CM70C HBL47CM70C 1.56" (39.6) Fed Spec WC596 Elastogrip® plug, yellow 300”-.655” elastomer, dust tight. (7.6-16.6) Elastogrip plug, yellow 300”-.655” elastomer, water/dust tight.(7.6-16.6) Valise® plug, .220”-.660” yellow nylon. (5.6-16.8) Valise plug, .220”-.660” black nylon. (5.6-16.8) HBL2447 – – HBL24W47* – – HBL4723VY HBL4573VY HBL4773VY HBL24W47 1.88" (47.8) HBL4723VBK HBL4573VBK HBL4773VBK 1.50" (38.1) Note: *Watertight plug IP55 suitability when installed and used with watertight connector body. G W X G G HBL4723VY 2.78" (70.6) W Y Connector Bodies NEMA L6-15R 15A 250V UL/CSA Catalog Numbers HBL4729C™ HBL4579C NEMA L7-15R 15A 277V AC UL/CSA HBL4779C HBL47CM29C HBL45CM79C HBL47CM79C HBL2547 – – HBL25W47* – – HBL4729VY HBL4579VY HBL4779VY HBL4729C 1.75" (44.5) 4.00" (101.6) HBL25W47 2.59" (65.8) HBL4729VBK HBL4579VBK HBL4779VBK 1.50" (38.1) Notes: See pages B-66 and B-67 for accessories. HP ratings are AC only. Only plugs are HP rated. For technical information on Insulgrip devices see page B-83. *Watertight connector body IP55 suitability when closure plug inserted or when installed and used properly with watertight plug. Dimensions in Inches (mm) 1.41" (35.8) 1.53" (38.9) 2P 3W, 15A, 125V, 250V and 277V AC Description Cord Dia. Insulgrip connector .230”-.720” body, black and white nylon.(5.8-18.3) Multiple drive screws. Insulgrip connector body, .230”-.720” corrosion resistant, (5.8-18.3) yellow and white nylon. Multiple drive screws. Elastogrip connector body, .300”-.655” yellow elastomer, dust tight. (7.6-16.6) Elastogrip connector body, .300”-.655” yellow elastomer, (7.6-16.6) water/dust tight. Valise connector body, .220”-.660” yellow nylon. (5.6-16.8) Valise connector body, .220”-.660” black nylon. (5.6-16.8) NEMA L5-15R 15A 125V UL/CSA www.hubbell-wiring.com HBL4729VY B-11 Locking Devices TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 15 Ampere, 125, 250 Volts and 277 Volts AC Angle Devices, Flanged Inlets, and Flanged Receptacles 1.22" (30.9) X W W G G G Y IP20 SUITABILITY 2.11" (53.6) Angle Plugs Description Insulgrip® plug, 8 position angle, black and white nylon. Multiple drive screws. 1.53" (38.9) HBL4720CA NEMA L5-15P 15A 125V UL/CSA 0.5 HP Cord Dia. .325”-.655” (8.3-16.6) 2.56" (65.0) 2.19" (55.6) IP20 SUITABILITY Angle Connector Body 1.72" (43.7) 1.69" (42.9) HBL4715C Description Cord Dia. Insulgrip connector body, .325”-.655” 8 position angle, (8.3-16.6) black and white nylon. Multiple drive screws. 2.31" (58.7) 1.94" (49.3) .16" (4.1) DIA. 1.36" (34.5) HBL4715 2P 3W, 15A, 125V, 250V and 277V AC 2.56" (52.3) 2.19" (55.6) Flanged Receptacles Description Insulgrip flanged receptacle, nylon casing, back wired. Stainless steel casing, brown phenolic. Corrosion resistant, stainless steel casing, yellow melamine. 1.72" (43.7) 1.69" (42.9) 2.31" (58.7) 1.94" (49.3) 1.75" (44.5) 1.09" (27.7) HBL4716 W G NEMA L6-15R 15A 250V UL/CSA Catalog Number HBL4729CA – NEMA L7-15R 15A 277V AC UL/CSA – W X G W G NEMA L5-15R 15A 125V UL/CSA NEMA L6-15R 15A 250V UL/CSA NEMA L7-15R 15A 277V AC UL/CSA Catalog Numbers HBL4715C HBL4585C HBL4785C HBL4715 HBL4785 HBL4585 HBL47CM15 G – – W X G G Y Flanged Inlets HBL4716C 1.50" (38.1) HBL4770CA Y NEMA L5-15R 15A 125V UL/CSA W .16" (4.1) DIA. X G NEMA L7-15P 15A 277V AC UL/CSA 2 HP Y 1.50" (38.1) B-12 W G 1.75" (44.5) .16" (4.1) DIA. Catalog Numbers HBL4720CA HBL4570CA G .16" (4.1) DIA. NEMA L6-15P 15A 250V UL/CSA 1.5 HP Description Insulgrip flanged inlet, nylon casing, back wired. Stainless steel casing, brown phenolic. Corrosion resistant, stainless steel casing, yellow melamine. NEMA L5-15P 15A 125V UL/CSA NEMA L6-15P 15A 250V UL/CSA NEMA L7-15P 15A 277V AC UL/CSA Catalog Numbers HBL4716C HBL4586C HBL4786C HBL4716* HBL4786* HBL47CM16* HBL4586* – – Notes: See pages B-66 and B-67 for accessories. Only plugs are HP rated. HP ratings are AC only. *These flanged inlets will not accept Valise® connector bodies. www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices Locking Devices The Standard for Locking Receptacles Features and Benefits High-impact, abuse-resistant nylon face. Face color coding by voltage facilitates locating and mating of proper devices. All-brass mounting and grounding system provides a lower resistance ground path and greater resistance to corrosion than steel mounting systems. Boss diameter is 1.562" on 20 and 30A devices for simplifying installation and accessory selection. Glass-Reinforced thermoplastic polyester base (RTP) has the desirable characteristics of a thermoset material, including heat, flame resistance and dimensional stability. The impact resistance it provides, however, is much greater than that of a thermoset. Features and Benefits One-piece contact with long spring arm (low stress) and oxide cutting nibs: prevents stress and overheating associated with riveted contact and short spring arms. #10 silicon bronze terminal screw provides greater strength and resistance to corrosion and stripping. Anti-rotational clamp has a stop to limit the amount of cocking when only one side is used. Accommodates both back and side wiring. Wire restraint recess for both back and side wiring, greatly reduces the possibility of loosening the terminal connection. On the high-impact nylon face of each Hubbell Twist-Lock® receptacle is a ring of color. Keyed to an internationally recognized color coding scheme, this ring enables mating devices to be matched quickly. It’s just one more example of user-oriented thinking at Hubbell. Twist-Lock receptacles have always held advantages over conventional ones. Today’s TwistLock receptacles maintain the advantage by combining functional design features, unparalleled quality and pace-setting performance. The terminals in each Hubbell Twist-Lock receptacle are mechanically and electrically the finest available. These terminals incorporate unique design features to contain and hold conductors, including an external backwiring B-14 “wraparound” clamp, a wire restraint recess and more. The materials used in every receptacle are of the highest quality. The all brass mounting system provides a safer, lower resistance ground path than those made of steel. The thick wall base is constructed of an engineered thermoplastic to offer the benefits of a thermoset, yet with much greater impact resistance. Hubbell Twist-Lock Receptacles: Voltage color coding on the outside. Proven designs and quality materials on the inside. Any way you look at them, they’re the standard of the industry. 125V www.hubbell-wiring.com 250V 277V AC 480V AC 600V AC 125/250V Dimensions in Inches (mm) Locking Devices 20 and 30 Ampere Plugs and Connector Bodies: The Difference Is INSULGRIP®...and a Whole Lot More Features and Benefits Funneled holes to permit "straightin" conductor insertion. Wiring chambers separate and positively insulate conductors and promote easy inspection. Improved terminations include #10 multiple drive screws and thicker .080" clamping nuts. Tough ribbed nylon housing for secure gripping. Insulated nylon construction to keep non-current carrying parts from becoming energized. Two-part cord grip tightens with two screws for maximum retention force. Broad gripping area to accommodate wide range of cable diameters. Integral dust shield protects wiring chamber from dust or contaminants. Single-piece shield/housing eliminates need for separate step at installation. Self-threading screws specially designed for secure assembly. Product indentification is visible while device is in use. Markings include catalog number and ratings printed in the IEC color scheme on the current-carrying portion of the device. course, we maintained traditional Insulgrip features and benefits. Like the most powerful cord grip in the industry. Insulgrip’s cord gripping design actually clamps the conductors, not just the cable jacket. We kept the same nylon body and housing material for resistance to industrial chemicals, solvents and hydrocarbons. And, the front of each plug is still molded to its specific blade configuration, leaving no holes to invite debris or contamination (plus we added a new dust shield). We restyled the cord grips for a clean, one-piece look—and made them stronger at the same time. And we introduced a whole new easier to read identification system. And more, all the while, of Of course, the Hubbell Twist-Lock® line of plugs and connectors remains the broadest in the industry. So if you prefer proven performance, innovation and selection—Hubbell has you covered. Dimensions in Inches (mm) www.hubbell-wiring.com B-15 Features and Benefits They’re new and better than ever. They’re the same and better than anything else on the market. They’re 20 and 30 amp Insulgrip plugs and connectors. We kept the same classic integrity, rock-solid construction and safety features that have made these devices the industry standard. But, we added enhancements because good is never good enough for Hubbell. We improved the contacts with better terminations and an exclusive double rivet design for the female contacts. Locking Devices 50 Ampere Plugs and Connector Bodies: The Difference Is INSULGRIP®...and a Whole Lot More Features and Benefits Super tough nylon housing offers better impact qualities than regular nylon. Stainless steel shroud cannot be distorted to mate with the wrong device. Housing assembly latch slotted to fit standard flat-blade screwdriver providing secure assembly and fast disassembly for wiring. Padlockable shroud allows compliance to OSHA lockout tagout regulation 29 CFR 1910 .147. Thermoplastic polyester interior provides heat resistance and impact strength. 6/6 nylon nose – thermoplastic polyester terminal cover provides heat resistance in terminal area and impact strength of nose piece. Three-piece thermoplastic clamp assembly with stainless steel fast lead screws provides a more consistent, durable grip. Sealed cable entry keeps out moisture and dust. Box terminal with hex socket threaded slug is superior because it permits high clamping pressure on conductors without damaging strands. Features and Benefits Heavy-duty design for heavy-duty applications. These Hubbell 50A Twist-Lock plugs and connector bodies are built to go where you need power...even in some of the harshest environments. On the outside, 50A plugs and connectors are made of Super tough nylon for better impact resistance. On the plug, the stainless steel shroud not only provides protection and durability, but safety as well. That’s because the rigid construction cannot be distorted, thus minimizing the possibility of mating incorrect devices. One-piece grounding contact on 4-wire devices provides a more reliable grounding system for a safer device. On the inside are the kinds of features that separate Hubbell from all the rest. The cord grip has been designed with offset gripping jaws to securely hold the conductors – not just the cord jacket. Hubbell’s box terminals speed wiring and provide a superior termination. The plug’s Rynite® thermoplastic interior provides excellent heat resistance without compromising strength. In all, it’s the combination of function and performance that Hubbell demands of all its products. And it’s why we’ll never add a feature that compromises performance. Rynite is a registered trademark of E. I. Dupont. B-16 www.hubbell-wiring.com Dimensions in Inches (mm) Hubbell Leads the Way in Safety…Again Features and Benefits Next-Generation Hubbell Twist-Lock: Here Today Introducing the next generation of the original: the Hubbell Twist-Lock. The Hubbell 20A and 30A Insulgrip® Twist-Lock product line has been expanded to provide a complete family of Safety-Shroud TwistLock devices. In this all-new line, plug blades are protected by a fixed shroud that shields the blades from possible deformation and, even more importantly, virtually eliminates user contact with an energized partially connected plug. These products set an entirely new standard for improved safety and reliability, and are available in two distinct series: • Safety-Shroud Twist-Lock • Watertight Safety-Shroud Twist-Lock The Watertight Safety-Shroud Twist-Lock series has achieved a UL Type 4X rating, which is capable of withstanding the ingress of water under hose-down conditions. The entire outer shell is molded of a high impact UL 94V-0 rated engineered thermoplastic. A complete line of receptacles, plugs, connector bodies and inlets is available in the most commonly required configurations and ratings. The Safety-Shroud Twist-Lock series is intended for installation where watertightness is not a factor, but the added safety of the shrouded design is highly desirable. Here again, the Safety-Shroud™ is molded of an engineered thermoplastic for a very high level of impact resistance. In order to satisfy every application and every need, Hubbell offers this series in three different styles of receptacles—surface, angle and semi-flush. Whether the needs are maintenance and repair, renovation or new construction, there is a receptacle design to accommodate your needs. In addition, this series offers Safety-Shroud plugs and even a separate Safety-Shroud kit that can be used to convert the standard Insulgrip Twist-Lock plug into the shrouded design. To provide an additional measure of safety in the workplace, Hubbell goes beyond shrouding to provide mechanically interlocked enclosures, designed expressly for use with this series, that virtually prevent the connecting and disconnecting of equipment under load. It’s another Hubbell first in the industry...the Mechanically Interlocked Twist-Lock. Hubbell Twist-Lock with our new Safety-Shroud: changes the standard of safety forever. Dimensions in Inches (mm) Watertight Mechanical Interlock For SafetyShroud Twist-Lock Hubbell’s CIRCUIT-LOCK® enclosure line has been expanded to include a mechanical interlock designed for use with the new SafetyShroud Twist-Lock line. The addition of this mechanical interlock will complete your Safety-Shroud Twist-Lock industrial wiring system. The mechanical interlock is a breakthrough in design and virtually eliminates the possibility of making or breaking the circuit under load. Safety-Shroud Twist-Lock Where watertightness is not a factor—but the added margin of safety from the Hubbell Safety-Shroud Twist-Lock is—we offer a total product line for all applications. In addition to Safety-Shroud plugs, the new line includes nonwatertight receptacles in three styles—angle, surface and semi-flush to satisfy every installation need. Back Boxes Hubbell manufactures an extensive line of back boxes for use with the new Safety Shroud Twist-Lock system. Each back box is designed to give the user the maximum amount of wiring room while achieving grounding to metallic conduit. Hubbell back boxes are available in non-metallic and cast metal versions. www.hubbell-wiring.com Introduction As always, it’s extremely important to us that all our products achieve a high level of compatibility with your existing Twist-Lock device installations. First and foremost, the new Safety-Shroud series embodies the basic NEMA configurations. Therefore, all shrouded receptacles easily accept the standard NEMA locking plugs already in use in your facility. A complete compatibility chart appears on page B-21 to explain every circumstance. Watertight Safety-Shroud Twist-Lock® This Type 4X rated product line is offered in a complete family consisting of plugs, connector bodies, receptacles and inlets. Tough and tight, these products are unequaled in performance in even the most hostile applications. Locking Devices Safety-Shroud TWIST-LOCK® System B-17 Locking Devices Watertight Safety-Shroud TWIST-LOCK® System Receptacles, Plugs, Connector Bodies and Flanged Inlets Features and Benefits Closure cap is included for environmental seal when device is not in use. Alignment arrows and lock and unlock symbols provide a visual indication that devices are properly connected. One-piece, engineered thermoplastic housing is impact-resistant for heavyduty industrial environments. External keying provides quick mating of devices. Blades are recessed for protection against bending and breaking. Cord grip screw recess minimizes screwdriver slippage. All screws are #10 multiple drive head. One-step automatic Neoprene sealing gland and engineered thermoplastic guard assure sealing when device is fully connected. Catalog number and color-coded voltage rating are easily visible even when in use. Universal Neoprene Diaphragm Seal Spring-Loaded Cover Panel Or Box Mount Receptacles And Inlets Safety-Shroud Seal accommodates a wide range of cord sizes from #16-3 Type SJ to #8-5 Type S, SO. Features and Benefits • High impact, thermoplastic housing for heavy-duty industrial environments. • Catalog number and color-coded voltage rating are easily visible when in use. • Stainless Steel 302/304, #10 multiple drive head mounting screws provide corrosion resistance. • Mounting screw recesses minimize screwdriver slippage. • Lockout/tagout hole on inlets allow compliance to OSHA regulation 29 CFR 1910.147. • Neoprene closure cap provided with inlets for environmental seal when not in use. • Accepts all mating NEMA locking plugs and most connector bodies, allowing interchangeability with existing devices. B-18 www.hubbell-wiring.com One-step push-to-close spring-loaded cover with latch allows for fast opening and closing of lift cover. Result: environmental sealing is assured. • Virtually eliminates bent and broken plug blades, leading to longer equipment life. • Extends life of mating receptacles by eliminating damage caused by insertion of bent blades. • Extra protection for personnel by significantly reducing chance of inadvertent contact with blades when connecting or disconnecting energized receptacles and connector bodies. • Reduces exposure to arcing when connecting or disconnecting plugs under load. • Compliance with California Code of Regulations, Title 8, Article 51, subsection 2510.7(b), which requires shrouding for devices exceeding 300 volts. • Lockout/tagout hole allows compliance with OSHA regulation 29 CFR 1910.147. • Sealing gland and thermoplastic guard assure sealing when fully connected. Dimensions in Inches (mm) Receptacles and Plugs Features and Benefits Impact resistant shroud made of engineered thermoplastic protects blades against bending or breaking. Catalog number and color-coded voltage rating are visible even when in use. Alignment arrows and lock and unlock symbols provide a visual indication that devices are properly connected. Locking Devices Safety-Shroud TWIST-LOCK® System External keying on plug devices allows quick mating of devices. Lockout/tagout hole allows compliance with OSHA regulation 29 CFR 1910.147. All screws are #10 multiple drive head. Engineered thermoplastic housing is impact and corrosion resistant, making it suitable for heavy-duty industrial environments. Safety-Shroud Plug Features and Benefits • Mates with most NEMA locking connector bodies. • Virtually eliminates bent and broken plug blades. • Provides protection for personnel by reducing chance of inadvertent contact with blades when connecting or disconnecting energized devices. • Reduces exposure to arcing when connecting or disconnecting under load. Straight receptacle housing provides a low installed profile when plug is not in use with receptacle. This device is designed for installation on singlegang boxes. Angle receptacle housing provides low installed profile when plug is in use with receptacle. This device is designed for installation on single-gang boxes. Receptacle Features and Benefits • Internal keying on receptacles aligns blades for quick mating of devices. • Accepts all NEMA locking plugs, allowing interchangeability with existing devices. Dimensions in Inches (mm) • Catalog number and color-coded voltage rating are visible when in use. • All screws are #10 multiple drive head. www.hubbell-wiring.com • Engineered thermoplastic housing is impact and corrosion-resistant, for use in heavy-duty industrial environments. B-19 Features and Benefits Semi-flush receptacle mounting provides lowest installed profile when plug is not in use with receptacle. This device is designed for installation on 2 gang boxes. • Extends life of mating receptacles by eliminating damage caused by insertion of bent blades. • Complies with California Code of Regulation, which requires shrouding for devices exceeding 300 volts. • Lockout/tagout hole allows compliance to OSHA regulation 29 CFR 1910.147. • Allows engagement with Mechanical Interlock Enclosure which virtually prevents make and break under load. Locking Devices Switched Safety Enclosures CIRCUIT-LOCK® Unfused Safety-Shroud TWIST-LOCK® Mechanical Interlock Features and Benefits Angled 20 or 30 Amp Hubbell Watertight Safety-Shroud Twist-Lock receptacle provides watertight, low profile and mechanical interlock capabilities. Lockable handle provides lockout protection for greater safety and compliance with OSHA lockout requirements. Enclosure back is designed for top, bottom or back feed options. Heavy-duty interlock linkage prevents make and break under load. Horsepower rated switch. Moveable feet may be used in horizontal or vertical position. Features and Benefits Heavy-duty internal frame bonds conduit and all grounds and has a DIN rail to accommodate the switch. Hubbell introduces the first mechanical interlock for TwistLock. This new, unfused mechanical interlock for watertight Safety-Shroud TwistLock integrates a watertight receptacle with a linked disconnect switch to provide a mechanically interlocked receptacle. This virtually eliminates the possibility of making or breaking the circuit B-20 Premolded conduit entry hole is offset to prevent water condensation from falling directly on to interior electrical components. Also speeds installation by making it easier to pull conductors. while under load or making a casual or “lazy” connection. The switch cannot be turned “ON” until the plug is properly inserted and locked, and the plug cannot be removed until the switch is turned “OFF.” All these protective features are included in a compact Type 4X hose-directed water and corrosion resistant enclosure that allows for top, bottom or back feed options. The www.hubbell-wiring.com non-metallic enclosure is nonconductive, yet has an internal frame to assure ground continuity with metallic conduit. In addition, this interlock works with all Safety-Shroud Twist-Lock plugs. The new unfused mechanical interlock for watertight Safety-Shroud TwistLock can be locked out as a method of compliance with OSHA lockout/tagout regulations. Dimensions in Inches (mm) Compatibility and Environmental Protection Watertight Safety-Shroud™, Safety-Shroud and NEMA Devices Twist-Lock Connector Bodies Twist-Lock Receptacles Swit ched Twis t-Lo Enc ck® losu PSJO re CAT. IST OTN SSFITNO. XXXXX FIT ISTI TIEH EWRQX SALAK QQ J SKA OF F Watertight SafetyShroud Mechanical Watertight Interlock Safety-Shroud Enclosure Safety-Shroud Locking Devices TWIST-LOCK® System ON CAUTIO owtosn N: Saitiew istelsls townf wthuilietioeta tiesntof ATTEN oenls.sothe sitieb sothe TION: othes toehs Alsritw oetyhen ot l itehwopt heta sithethlslei dithe ithelsltoenll otehl sl lsjtel tihehhll . Switched Enclosure NEMA Watertight SafetyShroud NEMA Twist-Lock Plugs Watertight SafetyShroud YES Type 4X, Type 12 YES Type 4X, Type 12K YES Type 1 NO NO YES Type 4X, Type 12 YES Type 1 SafetyShroud YES Type 1 YES Type 1 YES Type 1 NO NO YES Type 1 YES Type 1 NEMA YES Type 1 NO YES Type 1 YES Type 3R YES Type 1 YES Type 1 YES Type 1 NEMA NA NA NA NA NA NO YES Type 1 Watertight SafetyShroud NA NA NA NA NA YES Type 4X, Type 12 YES Type 1 Twist-Lock Inlets Indoor Type 3R Raintight Type 4X Hose-directed water and corrosion resistant Type 12 Dust tight, dripproof without knockouts Type 12K Dust tight, dripproof with knockouts YES Interchangeable NO Does not interchange NA Not Applicable Refer to section W for full description of enclosure types. Dimensions in Inches (mm) www.hubbell-wiring.com B-21 Compatibility and Environmental Protection Chart Type 1 Locking Devices TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 20 Ampere, 125, 250 Volts and 277 Volts AC Receptacles, INSULGRIP® Connector Bodies, Flanged Devices and Plugs 1.70" (43.2) 1.23" (31.2) X W G Y 2.67" (67.8) 1.56" 2.38" 3.28" (39.6) (60.5) (83.3) #6-32 TAP .98" (24.9) HBL2310 2.26" (57.4) 1.97" (50.0) HBL2313 120° Single Flush Receptacles, Back and Side Wired NEMA L5-20R 20A 125V UL/CSA 1 HP NEMA L6-20R 20A 250V UL/CSA 2 HP NEMA L7-20R 20A 277V AC UL/CSA 2 HP Description Black nylon face. Isolated ground, orange nylon face. Corrosion resistant, yellow nylon face. Catalog Numbers HBL2310 HBL2320 IG2310 IG2320 HBL23CM10 – HBL2330 – – Insulgrip Connector Bodies IP20 3.86" (98.0) SUITABILITY Description Catalog Numbers Black and white nylon. HBL2313 HBL2323 Corrosion resistant, yellow nylon. HBL23CM13 HBL23CM23 Note: Cord clamp range .360 ”-.930 ” (9-24). HBL2333 – Insulgrip Flanged Receptacles Description Nylon casing, back wired. 2.88" (73.2) Catalog Numbers HBL2316 HBL2326 HBL2336 .19" (4.8) DIA. 120° W X G 1.25" R. (31.8) W G G Y 2.09" (53.1) Insulgrip Plugs IP20 2.04" (51.8) SUITABILITY Description Black and white nylon. Corrosion resistant, yellow nylon. HBL2316 2P 3W, 20A, 125V, 250V and 277V AC W G G NEMA L5-20P 20A 125V UL/CSA 1 HP NEMA L6-20P 20A 250V UL/CSA 2 HP Catalog Numbers HBL2311 HBL2321 HBL23CM11 HBL23CM21 NEMA L7-20P 20A 277V AC UL/CSA 2 HP HBL2331 – Notes: Cord grip range .360”-.930 ” (9-24). See page B-73 for Add-A-Shroud™ kit. 2.75" (69.9) Insulgrip Flanged Inlets 2.26" (57.4) 1.97" (50.0) Catalog Numbers HBL2315 HBL2325 HBL2335 Notes: See pages B-68 and B-69 for accessories. See page B-63 for switched enclosure. For technical information see page B-83. HP ratings are AC only. Only receptacles and plugs are HP rated. HBL2311 120° Description Nylon casing, back wired. 2.88" (73.2) .19" (4.8) DIA. 120° 1.25" R. (31.8) 2.09" (53.1) 2.04" (51.8) HBL2315 B-22 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 20 Ampere, 125, 250 Volts and 277 Volts AC Watertight Safety-Shroud TWIST-LOCK® System IP66 UL Listed, CSA Certified to Type 4, 4X, & 12 2.69" (68.3) SUITABILITY W X W G 3.75" (95.3) G G Y Watertight Safety-Shroud Receptacles, Back Wired NEMA L5-20R 20A 125V UL/CSA 1 HP NEMA L6-20R 20A 250V UL/CSA 2 HP* Description Catalog Numbers Gray Valox® housing & flange. HBL2310SW HBL2320SW Note: Receptacles only fit boxes listed on Page B-72. NEMA L7-20R 20A 277V AC UL/CSA 2 HP HBL2330SW 3.75" (95.3) 1.50" (38.1) HBL2320SW Watertight Safety-Shroud Connector Bodies Description Black Valox housing, White Valox clamps. Catalog Numbers HBL2313SW HBL2323SW W HBL2333SW W X G 2.56" (65.0) 4.38" (111.1) G G Y Watertight Safety-Shroud Plugs Description Black Valox housing, White Valox clamps. NEMA L5-20P 20A 125V UL/CSA 1 HP NEMA L6-20P* 20A 250V UL/CSA 2 HP* Catalog Numbers HBL2311SW HBL2321SW HBL2323SW NEMA L7-20P 20A 277V AC UL/CSA 2 HP HBL2331SW 2.78" (70.6) Description Gray Valox housing and flange. Catalog Numbers HBL2315SW HBL2325SW HBL2321SW HBL2335SW Notes: Only receptacles and plugs 480V AC or less are HP rated. *Also suitable for 208V. HP ratings are AC only. Cord grip range for plugs and connector bodies .300”–.930” (9–24), #16-3 Type SJ to #8-3 Type S, SO. For technical information see page B-84. CIRCUIT-LOCK® Unfused Safety-Shroud Mechanical Interlock for Twist-Lock® Receptacles Description Mechanical Interlock accommodates 20A and 30A watertight safety-shroud receptacles. Catalog Number HBLMITL** 2.28" (57.9) 3.75" (95.3) 1.63" (41.4) 3.75" (95.3) HBL2325SW Note: **Not shown, see pages B-64 and B-65 for details. ®Valox is a registered trademark of General Electric Company. Dimensions in Inches (mm) www.hubbell-wiring.com B-23 2P 3W, 20A, 125V, 250V and 277V AC 4.50" (114.3) Watertight Safety-Shroud Flanged Inlets Locking Devices TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 20 Ampere, 125, 250 Volts and 277 Volts AC Safety-Shroud TWIST-LOCK® System 3.14" (79.8) X W G W G G Y Safety-Shroud Twist-Lock Receptacles, Back Wired 4.57" (116.1) Description Angle housing one gang. Surface mounting one gang. Semi-flush two gang. 2.88" (73.2) NEMA L5-20R 20A 125V UL/CSA 1 HP NEMA L6-20R 20A 250V UL/CSA 2 HP* NEMA L7-20R 20A 277V AC UL/CSA 2 HP Catalog Numbers HBL2310AR HBL2320AR HBL2330AR HBL2310SR HBL2320SR HBL2330SR HBL2310SR2 HBL2320SR2 HBL2330SR2 Notes: See page B-72 for box mounting application. Housing and flange, gray Valox®. HBL2320AR 1.58" (40.1) W IP20 4.56" (115.8) SUITABILITY Insulgrip Connector Bodies W X G G G Y NEMA L5-20R 20A 125V UL/CSA NEMA L6-20R 20A 250V UL/CSA Description Catalog Numbers Black and white nylon. HBL2313 HBL2323 Note: Cord grip range .360 ”-.930 ” (9-24). 2.84" (72.1) NEMA L7-20R 20A 277V AC UL/CSA HBL2333 HBL2320SR W .77" (19.6) W X G G G Y IP20 Safety-Shroud Male Plugs 5.12" (130.0) 2P 3W, 20A, 125V, 250V and 277V AC SUITABILITY NEMA L5-20P 20A 125V UL/CSA 1 HP NEMA L6-20P* 20A 250V UL/CSA 2 HP* Description Catalog Numbers Black and white nylon body, HBL2311S HBL2321S white Valox® shroud. Note: Cord clamp range .360 ”-.930 ” (9-24). 5.12" (130.0) NEMA L7-20P 20A 277V AC UL/CSA 2 HP HBL2331S HBL2320SR2 3.86" (98.0) X W W G G G Y 2.26" (57.4) 1.97" (50.0) Insulgrip® Flanged Inlets Description Nylon casing, back wired. HBL2323 NEMA L5-20P 20A 125V UL/CSA NEMA L6-20P 20A 250V UL/CSA 2 HP Catalog Numbers HBL2315 HBL2325 NEMA L7-20P 20A 277V AC UL/CSA 2 HP HBL2335 Note: Only receptacles and plugs 480V AC or less are HP rated. *Also suitable for 208V AC. HP ratings are AC only. For technical information, see page B-83. 2.26" (57.4) 2.04" (51.8) 3.97" (100.8) HBL2321S ®Valox B-24 is a registered trademark of General Electric Company. www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 20 Ampere, 125, 250 Volts and 277 Volts AC VALISE® Plugs and Connector Bodies IP20 W SUITABILITY X W G G G Y NEMA L5-20P 20A 125V UL/CSA 1 HP Valise Plugs Description Yellow nylon. Corrosion resistant, yellow nylon. Black nylon. Cord Dia. .325”-.720” (8.26-18.3) .325”-.720” (8.26-18.3) .325”-.720” (8.26-18.3) NEMA L6-20P 20A 250V UL/CSA 2 HP Catalog Numbers HBL2311VY HBL2321VY HBL23CM11V NEMA L7-20P 20A 277V AC UL/CSA 2 HP HBL2331VY – 2.50" (63.5) 1.78" (45.2) – HBL2311VBK HBL2321VBK HBL2331VBK W G X HBL2311VY W G G Y Valise Connector Bodies Description Yellow nylon. Black nylon. Cord Dia. .325”-.720” (8.26-18.3) .325”-.720” (8.26-18.3) NEMA L5-20R 20A 125V UL/CSA NEMA L6-20R 20A 250V UL/CSA NEMA L7-20R 20A 277V AC UL/CSA Catalog Numbers HBL2313VY HBL2323VY – 2.60" (66.0) 1.78" (45.2) HBL2313VBK HBL2323VBK HBL2333VBK HBL2313VY Notes: Connector bodies are not HP rated. HP ratings are AC only. See page B-88 for technical information. Weatherproof Accessories IP55** SUITABILITY 2P 3W, 20A, 125V, 250V and 277V AC Description Catalog Numbers Yellow Seal-Tite® elastomer triple seal cover for use with Valise HBL60CM31V* plugs when used in cord set and Valise connector bodies when used with flanged inlet. Yellow Seal-Tite elastomer triple seal cover for use with HBL60CM32V* Valise connector bodies. HBL60CM31V Note: **When installed and used properly with plug and connector body combinations. * Not UL Listed, CSA Certified HBL60CM32V Dimensions in Inches (mm) www.hubbell-wiring.com B-25 Locking Devices TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 20 Ampere, 347, 480 and 600 Volts AC Receptacles, INSULGRIP® Connector Bodies, Flanged Devices and Plugs 1.70" (43.2) 1.23" (31.2) Single Flush Receptacles, Back and Side Wired 2.67" (67.8) X W 1.56" 2.38" 3.28" (39.6) (60.5) (83.3) Description Black nylon face. Isolated ground, orange nylon face. X G G G Y Y NEMA L24-20R 20A 347V AC UL/CSA Y NEMA L8-20R 20A 480V AC UL/CSA 3 HP Catalog Numbers HBL3720 HBL2340 – IG2340 NEMA L9-20R 20A 600V AC UL/CSA HBL2350 – #6-32 TAP .98" (24.9) HBL2340 3.86" (98.0) Insulgrip Connector Bodies IP20 2.26" (57.4) 1.97" (50.0) SUITABILITY Description Catalog Numbers Black and white nylon. HBL3723 HBL2343 Note: Cord clamp range .360 ”-.930 ” (9-24). HBL2353 HBL2343 2.88" (73.2) 120° 1.25" R (31.8) 120° 2P 3W, 20A, 347V AC, 480V AC and 600V AC .19" (4.8) DIA. Insulgrip Flanged Receptacles Description Nylon casing, back wired. Catalog Numbers HBL3726 HBL2346 HBL2356 2.09" (53.1) 2.04" (51.8) X W X G G HBL2346 Y Insulgrip Plugs IP20 2.75" (69.9) SUITABILITY Description Black and white nylon. 2.26" (57.4) 1.97" (50.0) NEMA L24-20P 20A 347V AC UL/CSA Y G Y NEMA L8-20P 20A 480V AC UL/CSA 3 HP Catalog Numbers HBL3721 HBL2341 NEMA L9-20P 20A 600V AC UL/CSA HBL2351 Notes: Cord clamp range .360 ”-.930 ” (9-24). See page B-73 for Add-A-Shroud™ kit. HBL2341 2.88" (73.2) Insulgrip Flanged Inlets 120° 1.25" R (31.8) .19" 120° (4.8) DIA. 2.09" (53.1) 2.04" (51.8) Description Nylon casing, back wired. Catalog Numbers HBL3725 HBL2345 HBL2355 Notes: Only receptacles and plugs up to 480V AC are HP rated. For technical information see page B-83. See pages B-68 and B-69 for accessories. See page B-63 for switched enclosure. HP ratings are AC only. HBL2345 B-26 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 30 Ampere, 125, 250 Volts and 277 Volts AC Receptacles, INSULGRIP® Connector Bodies, Flanged Devices and Plugs X W G 1.70" (43.2) W G 1.23" (31.2) G Y Single Flush Receptacles, Back and Side Wired NEMA L5-30R 30A 125V UL/CSA 2 HP Description Black nylon face. Isolated ground, orange nylon face. Corrosion resistant, yellow nylon face. Catalog Numbers HBL2610 HBL2620 IG2610 IG2620 HBL26CM10 Insulgrip Connector Bodies IP20 Description Black and white nylon. Heat stabilized, gray nylon, 220° F (104° C). Corrosion resistant, yellow nylon. Note: Cord clamp range .360 ”-.930 ” (9-24). NEMA L6-30R 30A 250V UL/CSA 2 HP NEMA L7-30R 30A 277V AC UL/CSA 3 HP HBL2630 – – 2.67" (67.8) #6-32 TAP .98" (24.9) SUITABILITY Catalog Numbers HBL2613 HBL2623 HBL2633 HBL2613F HBL2623F – HBL26CM13 HBL26CM23 – 1.56" 2.38" 3.28" (39.6) (60.5) (83.3) HBL2620 3.86" (98.0) 2.26" (57.4) 1.97" (50.0) HBL2623 Insulgrip Flanged Receptacles 2.88" (73.2) Description Catalog Numbers Nylon casing, back wired. HBL2616 HBL2626 Heat stabilized, gray nylon, 220° F (104° C). HBL2616F HBL2626F HBL2636 – X W G 120° HBL2626 SUITABILITY Description Black and white nylon. Heat stabilized, gray nylon, 220° F (104° C). Corrosion resistant, yellow nylon. NEMA L7-20P 20A 277V AC UL/CSA 2 HP Catalog Numbers HBL2611 HBL2621 HBL2631 HBL2611F HBL2621F – HBL26CM11 HBL26CM21 – 2.75" (69.9) 2.26" (57.4) 1.97" (50.0) Notes: Cord clamp range .360 ”-.930 ” (9-24). See page B-73 for Add-A-Shroud™ kit. HBL2621 Insulgrip Flanged Inlets Description Catalog Numbers Nylon casing, back wired. HBL2615 HBL2625 Heat stabilized, gray nylon, 220° F (104° C). HBL2615F HBL2625F 2.88" (73.2) HBL2635 – Notes: All HP ratings are AC only. Only receptacles and plugs are HP rated. For technical information see page B-83. For accessories see pages B-68 and B-69. See page B-63 for switched enclosure. 120° 1.25" R (31.8) .19" 120° (4.8) DIA. 2.09" (53.1) 2.04" (51.8) HBL2625 Dimensions in Inches (mm) www.hubbell-wiring.com B-27 2P 3W, 30A, 125V, 250V and 277V AC Insulgrip Plugs IP20 NEMA L6-30P 30A 250V UL/CSA 2 HP 2.09" (53.1) 2.04" (51.8) G Y NEMA L5-30P 30A 125V UL/CSA 2 HP 1.25" R (31.8) .19" (4.8) DIA. W G 120° Locking Devices TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 30 Ampere, 125 and 250 Volts Watertight Safety-Shroud TWIST-LOCK® System IP66 SUITABILITY UL Listed, CSA Certified to Type 4, 4X, & 12 2.69" (68.3) W X G G Y Watertight Safety-Shroud Receptacles, Back Wired 3.75" (95.3) 3.75" (95.3) 1.50" (38.1) NEMA L5-30R 30A 125V UL/CSA 2 HP NEMA L6-30R 30A 250V UL/CSA 2 HP* Description Catalog Numbers Gray Valox® housing and flange. HBL2610SW HBL2620SW Note: Receptacles only fit boxes listed on page B-72. HBL2610SW Watertight Safety-Shroud Connector Bodies Description Black Valox housing, white Valox clamps. Catalog Numbers HBL2613SW HBL2623SW 2.56" (65.0) X W 4.38" (111.1) G G HBL2613SW Y Description Black Valox housing, white Valox clamps. 2.78" (70.6) NEMA L6-30P 30A 250V UL/CSA 2 HP* NEMA L5-30P 30A 125V UL/CSA 2 HP Watertight Safety-Shroud Plugs Catalog Numbers HBL2611SW HBL2621SW Watertight Safety-Shroud Flanged Inlets 4.50" (114.3) HBL2611SW Description Catalog Numbers Gray Valox housing and flange. HBL2615SW HBL2625SW Notes: Only receptacles and plugs 480V AC or less are HP rated. *Also suitable for 208V. HP ratings are AC only. Cord grip range for plugs and connector bodies .325”-.930” (9-24). #16-3 Type SJ to #8-3 Type S, SO. For technical information see page B-84. 2.28" (57.9) 3.75" (95.3) 2P 3W, 30A, 125V, 250V CIRCUIT-LOCK® Unfused Safety-Shroud Mechanical Interlock for Twist-Lock® Receptacles 1.63" (41.4) 3.75" (95.3) HBL2615SW Description Mechanical Interlock accommodates 30A watertight Safety-Shroud receptacles. Note: **Not shown, see pages B-64 and B-65. Catalog Number HBLMITL** ®Valox is a registered trademark of General Electric Company. B-28 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 30 Ampere, 125 and 250 Volts Safety-Shroud TWIST-LOCK® System W 3.14" (79.8) X G G Y Safety-Shroud Twist-Lock Receptacles, Back Wired NEMA L5-30R 30A 125V UL/CSA 2 HP Description Angle housing one gang. Surface mounting one gang. Semi-flush two gang. NEMA L6-30R 30A 250V UL/CSA 2 HP* 4.57" (116.1) Catalog Numbers HBL2610AR HBL2620AR HBL2610SR HBL2620SR HBL2610SR2 HBL2620SR2 2.88" (73.2) Notes: See page B-72 for box mounting application. Housing and flange, gray Valox®. HBL2620AR 1.58" (40.1) X W G G Y Insulgrip Connector Bodies IP20 NEMA L5-30R 30A 125V UL/CSA SUITABILITY Description Black and white nylon. Note: Cord clamp range .360 ”-.930 ” (9-24). NEMA L6-30R 30A 250V UL/CSA 4.56" (115.8) Catalog Numbers HBL2613 HBL2623 2.84" (72.1) HBL2620SR X W G G .77" (19.6) Y Safety-Shroud Male Plug IP20 SUITABILITY Description Black and white nylon body, white Valox shroud. Note: Cord clamp range .360 ”-.930 ” (9-24). NEMA L5-30P 30A 125V UL/CSA 2 HP NEMA L6-30P 30A 250V UL/CSA 2 HP* 5.12" (130.0) Catalog Numbers HBL2611S HBL2621S 5.12" (130.0) HBL2620SR2 X W 3.86" (98.0) G G Y NEMA L6-30P 30A 250V UL/CSA 2 HP NEMA L5-30P 30A 125V UL/CSA 2 HP Description Nylon casing, back wired. Catalog Numbers HBL2615 HBL2625 2.26" (57.4) 1.97" (50.0) HBL2623 Notes: Only receptacles and plugs 480V AC or less are HP rated. *Also suitable for 208V. HP ratings are AC only. For technical information see page B-83. 2.26" (57.4) 2.04" (51.8) 3.97" (100.8) HBL2621S ®Valox is a registered trademark of General Electric Company. Dimensions in Inches (mm) www.hubbell-wiring.com B-29 2P 3W, 30A, 125V, 250V Insulgrip Flanged Inlets Locking Devices TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 30 Ampere, 125 and 250 Volts VALISE® Plugs and Connector Bodies X W G G 2.50" (63.5) Y Valise Plugs IP20 1.78" (45.2) Description Yellow nylon. HBL2611VY NEMA L5-30P 30A 125V UL/CSA 2 HP SUITABILITY Corrosion resistant, yellow nylon. Black nylon. Cord Dia. .590”-.930” (15.0-23.6) .590”-.930” (15.0-23.6) .590”-.930” (15.0-23.6) NEMA L6-30P 30A 250V UL/CSA 2 HP Catalog Numbers HBL2611VY HBL2621VY HBL26CM11V HBL2611VBK – HBL2621VBK 2.60" (66.0) X W 1.78" (45.2) G G Y HBL2613VY Valise Connector Bodies IP20 Description Yellow nylon. Corrosion resistant, yellow nylon. Black nylon. SUITABILITY Cord Dia. .590”-.930” (15.0-23.6) .590”-.930” (15.0-23.6) .590”-.930” (15.0-23.6) NEMA L5-30R 30A 125V UL/CSA NEMA L6-30R 30A 250V UL/CSA Catalog Numbers HBL2613VY HBL2623VY HBL26CM13V HBL2613VBK – HBL2623VBK Notes: Connector bodies are not HP rated. HP ratings are AC only. See page B-88 for technical information. 2P 3W, 30A, 125V, 250V AC HBL60CM31V HBL60CM32V Weatherproof Accessories IP55** SUITABILITY Description Catalog Numbers Yellow Seal-Tite® elastomer triple seal cover for use with Valise HBL60CM31V* plugs when used in cord set and Valise connector bodies when used with flanged inlet. Yellow Seal-Tite elastomer triple seal cover for use with Valise HBL60CM32V* connector bodies. Note: **When installed and used properly with plug and connector body combinations. * Not UL Listed, CSA Certified. B-30 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 30 Ampere, 480 and 600 Volts AC Receptacles, INSULGRIP® Connector Bodies, Flanged Devices and Plugs X X 1.70" (43.2) G G Y 1.23" (31.2) Y Single Flush Receptacles, Back and Side Wired NEMA L8-30R 30A 480V AC UL/CSA 5 HP Description Black nylon face. Catalog Numbers HBL2640 HBL2650 NEMA L9-30R 30A 600V AC UL/CSA 1.56" 2.38" 3.28" (39.6) (60.5) (83.3) 2.67" (67.8) #6-32 TAP .98" (24.9) HBL2650 Insulgrip Connector Bodies IP20 3.86" (98.0) SUITABILITY Description Black and white nylon. Note: Cord clamp range .325”-.930 ” (8.25-24). Catalog Numbers HBL2643 HBL2653 2.26" (57.4) 1.97" (50.0) HBL2653 2.88" (73.2) 120° Insulgrip Flanged Receptacles Description Nylon casing, back wired. 1.25" R (31.8) Catalog Numbers HBL2646 HBL2656 .19" (4.8) 120° DIA. 2.09" (53.1) 2.04" (51.8) G G Y SUITABILITY Description Black and white nylon. NEMA L8-30P 30A 480V AC UL/CSA 5 HP Y 2.75" (69.9) NEMA L9-30P 30A 600V AC UL/CSA Catalog Numbers HBL2641 HBL2651 2.26" (57.4) 1.97" (50.0) Notes: Cord clamp range .325”-.930 ” (8.25-24). See page B-73 for Add-A-Shroud™ kit. HBL2651 2.88" (73.2) 120° Insulgrip Flanged Inlets Description Nylon casing, back wired. Notes: Only receptacles and plugs up to 480V AC are HP rated. For technical information see page B-83. HP ratings are AC only. For accessories see pages B-68 and B-69. See page B-63 for switched enclosure. Dimensions in Inches (mm) 1.25" R (31.8) 120° Catalog Numbers HBL2645 HBL2655 www.hubbell-wiring.com .19" (4.8) DIA. 2.09" (53.1) 2.04" (51.8) HBL2655 B-31 2P 3W, 30A, 480V AC and 600V AC Insulgrip Plugs IP20 HBL2656 X X Locking Devices TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 50 Ampere, 125, 250 Volts and 480 Volts AC Receptacles, Connector Bodies, Plugs and Flanged Inlets 2.13" (54.1) Y Y W X X G 2.69" 3.28" (68.3) (83.3) 1.03" (26.2) Receptacles Description Black melamine. Connector Bodies IP20 2.44" (62) G G 50A 125V 50A 250V 50A 480V AC Catalog Numbers CS6370 CS8269 CS8469† SUITABILITY Description Catalog Numbers Nylon housing, Rynite® interior. CS6360C CS8264C Note: Cord clamp range .830 ”-1.100” (21.08-28.19). CS8269 6.34" (161.0) CS8464C Y Y W 2.59" (65.8) Plugs IP20 G SUITABILITY 50A 125V X X G G 50A 250V 50A 480V AC Description Catalog Numbers Nylon housing, Rynite interior. CS6361C CS8265C Note: Cord clamp range .830 ”-1.100” (21.08-28.19). CS8264C CS8465C Flanged Inlets 6.38" (162.0) Description Zinc plated steel casing. thermoplastic interior. 2.59" (65.8) Catalog Numbers CS6377† CS8275 CS8475† Note: See page B-16 for product features. Accessories Weatherproof Boots IP55** CS8265C Description Catalog Numbers Seal-Tite® triple seal black elastomeric cover for plugs when used HBL7716C* in a cord set and connector bodies when used with flanged inlets. Seal-Tite triple seal black elastomeric cover for connector bodies HBL7717C* when used with cord sets. 2P 3W, 50A, 125V, 250V and 480V AC 3.50" (88.9) 90° .19" (4.8) DIA. 1.50"R (38.0) 2.62" (66.5) 2.17" (55.1) CS8275 SUITABILITY Note: Boots shown on page B-74. Weatherproof Receptacle Cover Plates Description Gray thermoplastic, corrosion resistant. Yellow thermoplastic, corrosion resistant. IP44 SUITABILITY Catalog Numbers HBL7774WO HBL77CM74WO Receptacle Wall Plate & Box Cover Description Stainless steel 302/304, smooth. Galvanized Steel fits 4” square, 4 11/16” or 2 gang box Catalog Number S750 HBL50SC Closure Plug for 50A Inlets Description Black closure plug. HBL7774WO Notes: For additional accessories see page B-74. For technical information see page B-85. **When installed and used properly with plug and connector body combinations. †Not CSA Certified. * Not UL Listed, CSA Certified. ®Rynite B-32 Catalog Number HBL4892* is a registered trademark of E. I. Dupont. www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 50 Ampere, 250 Volts DC and 600 Volts AC Receptacle, Connector Body, Plug and Flanged Inlets 2.13" (54.1) Y X G 50A 250V DC 50A 600V AC Receptacle Description Black melamine. Connector Body IP20 2.69" 3.28" (68.3) (83.3) Catalog Number HBL3771 1.03" (26.2) SUITABILITY Description Nylon housing, Rynite® interior. Note: Cord clamp range .830”-1.100” (21.08-28.19). 2.44" (62) Catalog Number HBL3762C HBL3771 6.34" (161.0) .63" (16.0) Y X 2.59" (65.8) G Plug IP20 50A 250V DC 50A 600V AC SUITABILITY Description Nylon housing, Rynite interior. Note: Cord clamp range .830”-1.100” (21.08-28.19). Catalog Number HBL3763C HBL3762C Flanged Inlets 6.38" (162.0) Description Zinc plated steel casing, thermoplastic int. Zinc plated steel casing, thermoplastic int. with lift cover. Accessories Weatherproof Boots IP55** Catalog Numbers HBL3777 HBL3767 2.59" (65.8) HBL3763C SUITABILITY Description Catalog Numbers Seal-Tite triple seal black elastomeric cover for plugs when used HBL7716C in a cord set and connector bodies when used with flanged inlets. Seal-Tite triple seal black elastomeric cover for connector bodies HBL7717C when used with cord sets. Description Gray thermoplastic, corrosion resistant. Yellow thermoplastic, corrosion resistant. SUITABILITY Catalog Numbers HBL7774WO HBL77CM74WO 2.62" (66.5) 2.17" (55.1) HBL3777 Receptacle Wall Plate & Box Cover Description Stainless steel 302/304, smooth. Galvanized Steel fits 4” square, 4 11/16” or 2 gang box .19" (4.8) DIA. 1.50"R (38.0) Catalog Number S750 HBL50SC 2.63" (66.8) 1.50"R (38.0) Closure Plug for 50A Inlets Description Black closure plug. Catalog Number HBL4892 Notes: For additional accessories see page B-74. For technical information see page B-85. **IP55 suitability when installed and used properly with plug and connector body combinations. * Not UL Listed. ® 2.19" (55.6) . 19" (4.8) DIA. 90° 3.50" (88.9) HBL3767 Rynite is a registered trademark of E. I. Dupont. Dimensions in Inches (mm) www.hubbell-wiring.com B-33 2P 3W, 50A, 250V DC and 600V AC Weatherproof Receptacle Cover Plates IP44 3.50" (88.9) 90° Locking Devices TWIST-LOCK® Devices 3 Pole, 3 Wire, Non-Grounding 15 Ampere, 125/250 Volts Midget TWIST-LOCK Flanged Receptacles and Plugs X 2.06" (52.3) 1.75" (44.5) X W W Y Y NEMA ML-3R 15A 125/250V NEMA ML-3P 15A 125/250V Flanged Receptacles 1.00" (25.4) .15" (3.8) DIA. 1.12" (28.4) HBL7487N 2.06" (52.3) 1.75" (44.5) .16" (4.1) DIA. Male Plugs IP20 1.19" (30.2) HBL7487 2.06" (52.3) 1.75" (44.5) Catalog Numbers HBL7487N HBL7487 HBL7489 Weatherproof Boot Cord Dia. .300”-.430” (7.6-10.9) Catalog Numbers – HBL7485V .281”-.421” (7.1-10.7) – HBL7485 .335”-.421” (8.5-10.7) – HBL7432 IP55** SUITABILITY Description Seal-Tite® cover, black elastomer, for use with a HBL7485V or HBL7485 plug when used with a HBL7484V or HBL7484 connector body when used with a flanged inlet. 1.25" (31.8) – – SUITABILITY Description Valise® plug, black nylon, with insulation displacement terminals, multiple drive screws. Black nylon body, phenolic base, multiple drive screw terminals, cord grip. Same as above, except angle cord grip. .97" (24.6) .16" (4.1) DIA. Description Exposed terminals, black nylon flange. Exposed terminals, stainless steel flange, Covered terminals, stainless steel flange, accepts cord .500” (12.7) in diameter. Catalog Number HBL7495V Notes: These devices are not interchangeable with any other devices in this catalog. All male ground pins are solid and all female ground contacts have hollow sleeves. **When installed and used properly with plug and connector body combinations. * Not UL Listed. 1.17" (29.7) HBL7489 1.61" (40.9) 1.19" (30.2) HBL7485V 3P 3W, 15A, 125/250V 2.00" (50.8) 1.59" (40.4) 1.17" (29.7) 1.13" (28.7) HBL7485 1.17" (29.7) 1.69" (42.9) HBL7432 B-34 HBL7495V www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 3 Pole, 3 Wire, Non-Grounding 15 Ampere, 125/250 Volts Midget TWIST-LOCK Devices, Flanged Inlets and Connector Bodies X X W Y Y NEMA ML-3R 15A 125/250V NEMA ML-3P 15A 125/250V Flanged Inlets Description Exposed terminals, black nylon flange. Exposed terminals, stainless steel flange. Connector Bodies IP20 2.06" (52.3) 1.75" (44.5) W Catalog Numbers – HBL7486N – HBL7486 1.27" (32.3) HBL7486N SUITABILITY Description Valise® type, black nylon, with insulation displacement terminals, multiple drive screws. Black nylon body, phenolic base, multiple drive screws, cord grip. Same as above, except for angle cord grip. Cord Dia. .300”-.430” (7.6-10.9) Catalog Numbers HBL7484V – .281”-.421” (7.1-10.7) .335”-.421” (8.5-10.7) HBL7484 – Weatherproof Accessories IP55** .15" (3.8) DIA. 1.00" (25.4) HBL7433 – 2.06" (52.3) 1.75" (44.5) .16" (4.1) DIA. 1.00" (25.4) 1.22" (31) HBL7486 SUITABILITY Description Seal-Tite® cover, black elastomer, for use with a HBL7484V or HBL7484 connector body and a combination of HBL7485V or HBL7485 plug and HBL7495V cover. Closure cover for use with HBL7486 or HBL7486N. Catalog Numbers HBL7440V* 1.97" (50.0) 1.19" (30.2) HBL4889* Notes: These devices are not interchangeable with any other devices in this catalog. All male ground pins are solid and all female ground contacts have hollow sleeves. **IP55 suitability when installed and used properly with plug and connector body combinations. * Not UL Listed. HBL7484V 2.42" (61.5) 2.02" (51.3) 1.13" (28.7) 1.17" (29.7) HBL7484 1.69" (42.9) 3P 3W, 15A, 125/250V 1.28" (32.5) 1.17" (29.7) HBL7433 HBL7440V HBL4889 Dimensions in Inches (mm) www.hubbell-wiring.com B-35 Locking Devices TWIST-LOCK® Devices 3 Pole, 3 Wire Non-Grounding 20 and 30 Ampere, 125/250 Volts Receptacles, INSULGRIP® Connector Bodies, Flanged Devices and Plugs Y 1.39" (35.2) W Y 1.11" (28.2) For Replacement Use Only W X Single Flush Receptacles 1.38" 2.38" 3.61" (34.9) (60.5) (91.6) 2.20" (57.2) X Non-NEMA 20A 125/250V UL Listed Description Black urea face, back wired. Non-NEMA 30A 125/250V UL Listed HP Catalog Numbers HBL7310B HBL3330 #6-32 TAP 1.28" (32.5) HBL7310B 1.71" (43.1) 1.22" (31.0) Insulgrip Connector Bodies IP20 1.57" 2.38" 3.61" (39.8) (60.5)(91.6) 2.50" (63.5) SUITABILITY Description Black and white nylon. Corrosion resistant, yellow nylon. Note: Cord grip range .360 ”-.930 ” (9-24). Catalog Numbers HBL7314C HBL3333C HBL73CM14C – .97" (24.6) #6-32 TAP HBL3330 3.86" (98.0) Insulgrip Flanged Receptacles 1.97" (50.0) 2.26" (57.4) Description Nylon casing, back wired. Catalog Numbers HBL3326C HBL3335C HBL7314C Y 2.88" (73.2) 120° W Y W X 1.25" R (31.8) .19" (4.8) 120° DIA. Insulgrip Plugs IP20 Non-NEMA 20A 125/250V UL Listed SUITABILITY Description Black and white nylon. Corrosion resistant, yellow nylon. Note: Cord grip range .360 ”-.930 ” (9-24). 2.09" (53.1) 2.04" (51.8) X Non-NEMA 30A 125/250V UL Listed HP Catalog Numbers HBL9965C HBL3331C HBL99CM65C – 3P 3W, 20A and 30A, 125/250V HBL3326C 2.75" (69.9) 2.26" (57.4) 1.97" (50.0) Insulgrip Flanged Inlets Description Nylon casing, back wired. Note: See pages B-68 and B-69 for accessories. HBL9965C 2.88" (73.2) 120° Catalog Numbers HBL3325C HBL3334C 1.25" R (31.8) .19" (4.8) DIA. 120° 2.09" (53.1) 2.04" (51.8) CAUTION: To avoid electrical shock, review premises carefully and do not use if slot or blade configuration (design) is already in a circuit having a rating differing from the rating of this device. HBL3325C B-36 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 3 Pole, 4 Wire Grounding 20 Ampere, 125/250 Volts, 3Ø 250 and 3Ø 480 Volts AC Receptacles, INSULGRIP® Connector Bodies, Flanged Devices and Plugs X G X W 1.70" (43.2) X G Y G 1.23" (31.2) Y Y Z Single Flush Receptacles, Back and Side Wired Z NEMA L14-20R 20A 125/250V UL/CSA 2 (1) HP NEMA L15-20R 20A 3Ø 250V AC UL/CSA 3 HP NEMA L16-20R 20A 3Ø 480V AC UL/CSA 5 HP Description Black nylon face. Isolated ground, orange nylon face. Catalog Numbers HBL2410 HBL2420 IG2410 IG2420 2.67" (67.8) 1.56" 2.38" 3.28" (39.6) (60.5) (83.3) HBL2430 – .98" (24.9) #6-32 TAP HBL2410 Insulgrip Connector Bodies IP20 3.86" (98.0) SUITABILITY Description Catalog Numbers Black and white nylon. HBL2413 HBL2423 HBL2433 Corrosion resistant, yellow nylon. HBL24CM13 HBL24CM23 HBL24CM33 Note: Cord clamp range .3 5 ”-1.15 ” (9-29). 2.33" (59.2 ) 2.21" (56.1) HBL2413 3.06" (77.7) 120° Insulgrip Flanged Receptacles Description Nylon casing, back wired. W SUITABILITY Description Black and white nylon. Corrosion resistant, yellow nylon. HBL2436 X G Y .19" (4.8) 120° DIA. 2.27" (57.7) X G Y G Y Z Z NEMA L14-20P 20A 125/250V AC UL/CSA 2 (1) HP NEMA L15-20P 20A 3Ø 250V AC UL/CSA 3 HP NEMA L16-20P 20A 3Ø 480V AC UL/CSA 5 HP 2.23" (56.6) HBL2416 Catalog Numbers HBL2411 HBL2421 HBL2431 HBL24CM11 HBL24CM21 HBL24CM31 2.75" (69.9) 2.33" (59.2) 2.21" (56.1) Notes: Cord clamp range .3 5 ”-1.15 ” (9-29). See page B-73 for Add-A-Shroud™ kit. HBL2411 3.06" (77.7) Insulgrip Flanged Inlets Description Nylon casing, back wired. 120° Catalog Numbers HBL2415 HBL2425 Notes: All HP ratings are AC only. HP ratings not in parentheses are phase to phase. HP rating in parentheses is phase to neutral. Only receptacles and plugs are HP rated. See pages B-70 and B-71 for accessories. For technical information see page B-83. See page B-63 for switched enclosure. Dimensions in Inches (mm) 1.34" R (34.0) HBL2435 www.hubbell-wiring.com .19" 120° (4.8) DIA. 2.27" (57.7) 2.23" (56.6) HBL2415 B-37 3P 4W, 20A, 125/250V, 3Ø 250 and 3Ø 480V AC X Insulgrip Plugs IP20 1.34" R (34.0) Catalog Numbers HBL2416 HBL2426 Locking Devices TWIST-LOCK® Devices 3 Pole, 4 Wire Grounding 20 Ampere, 125/250 Volts, 3Ø 250 and 3Ø 480 Volts AC Watertight Safety-Shroud TWIST-LOCK System 2.91" (73.9) IP66 UL Listed, CSA Certified to Type 4, 4X, & 12 SUITABILITY X G 3.75" (95.3) Watertight Safety-Shroud Twist-Lock Receptacles 3.75" (95.3) 1.75" (44.5) HBL2420SW X X W G G Y Y Y Z Z NEMA L14-20R 20A 125/250V UL/CSA 2 (1) HP NEMA L15-20R 20A 3Ø 250V AC UL/CSA 3 HP NEMA L16-20R 20A 3Ø 480V AC UL/CSA 5 HP Description Catalog Numbers Gray Valox® housing and flange. HBL2410SW HBL2420SW HBL2430SW Note: Receptacles only fit boxes listed on page B-72. Watertight Safety-Shroud Connector Bodies Description Black Valox housing, white Valox clamps. 2.75" (69.9) Catalog Numbers HBL2413SW HBL2423SW HBL2433SW 4.38" (111.1) X X X HBL2423SW W Watertight Safety-Shroud Plugs 3P 4W, 20A, 125/250V, 3Ø 250 and 3Ø 480V AC 2.94" (74.7) Description Black Valox housing, white Valox clamp. G Y G Y G Y Z Z NEMA L14-20P 20A 125/250V UL/CSA 2 (1) HP NEMA L15-20P 20A 3Ø 250V AC UL/CSA 3 HP NEMA L16-20P 20A 3Ø 480V AC UL/CSA 5 HP Catalog Numbers HBL2411SW HBL2421SW HBL2431SW 4.50" (114.3) HBL2421SW Watertight Safety-Shroud Inlets 2.44" (62.0) Description Gray Valox housing and flange. 3.75" (95.3) 1.81" (46.0) Catalog Numbers HBL2415SW HBL2425SW HBL2435SW Notes: Only receptacles and plugs 480V AC or less are HP rated. All HP ratings are AC only. HP rating in parentheses is phase to neutral. Cord grip range for plugs and connector bodies .35 ”-1.15 ” (9-29), #16-4 Type SJ to #8-4 Type S, SO. For technical information see page B-84. 3.75" (95.3) HBL2425SW CIRCUIT-LOCK® Unfused Safety-Shroud Mechanical Interlock for Twist-Lock® Receptacles Description Catalog Number Mechanical Interlock accommodates HBLMITL* 20A and 30A watertight Safety-Shroud receptacles. Note: *Not shown, see pages B-64 and B-65 for complete details. ®Valox B-38 is a registered trademark of General Electric Company. www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 3 Pole, 4 Wire Grounding 20 Ampere, 125/250 Volts, 3Ø 250 and 3Ø 480 Volts AC Safety-Shroud TWIST-LOCK® System X G Safety-Shroud Twist-Lock Receptacles W 3.14" (79.8) X X G Y G Y Y Z Z NEMA L14-20R 20A 125/250V UL/CSA 2 (1) HP NEMA L15-20R 20A 3Ø 250V AC UL/CSA 3 HP NEMA L16-20R 20A 3Ø 480V AC UL/CSA 5 HP 4.57" (116.1) Description Catalog Numbers Gray Valox® Angle housing, one gang. HBL2410AR HBL2420AR HBL2430AR Gray Valox Surface mounting, one gang. HBL2410SR HBL2420SR HBL2430SR Gray Valox Semi-flush, two gang. HBL2410SR2 HBL2420SR2 HBL2430SR2 2.85" (72.4) HBL2420AR Note: See page B-72 for box mounting application. Housing and flange gray Valox. 1.71" (43.4) X G IP20 SUITABILITY Insulgrip Connector Bodies X W G X Y G Y Y Z Z NEMA L14-20R 20A 125/250V UL/CSA NEMA L15-20R 20A 3Ø 250V AC UL/CSA NEMA L16-20R 20A 3Ø 480V AC UL/CSA Description Catalog Numbers Black and white nylon. HBL2413 HBL2423 Note: Cord clamp range .35 ”-1.15 ” (9-29). 4.56" (115.8) HBL2433 2.84" (72.1) HBL2420SR X X W .77" (19.6) X G Y G Y Z Z NEMA L14-20P 20A 125/250V UL/CSA 2 (1) HP NEMA L15-20P 20A 3Ø 250V AC UL/CSA 3 HP NEMA L16-20P 20A 3Ø 480V AC UL/CSA 5 HP SUITABILITY Safety-Shroud Twist-Lock Plugs Y Description Catalog Numbers Black and white nylon body, HBL2411S HBL2421S white Valox shroud. Note: Cord clamp range .35 ”-1.15 ” (9-29). 5.12" (130.0) HBL2431S 5.12" (130.0) HBL2420SR2 3.86" (98.0) X W Insulgrip Flanged Inlets Description Nylon casing, back wired. X G Y X G Y G Y Z Z NEMA L14-20P 20A 125/250V UL/CSA NEMA L15-20P 20A 3Ø 250V AC UL/CSA NEMA L16-20P 20A 3Ø 480V AC UL/CSA Catalog Numbers HBL2415 HBL2425 2.33" (59.2) 2.21" (56.1) HBL2423 HBL2435 Notes: Only receptacles and plugs 480V AC or less are HP rated. All HP ratings are AC only. For technical information, see page B-83. HP rating in parentheses is phase to neutral. 2.33" (59.2) 2.21" (56.1) 4.12" (104.6) ®Valox HBL2421S is a registered trademark of General Electric Company. Dimensions in Inches (mm) www.hubbell-wiring.com B-39 3P 4W, 20A, 125/250V, 3Ø 250 and 3Ø 480V AC IP20 G Locking Devices TWIST-LOCK® Devices 3 Pole, 4 Wire Grounding 30 Ampere, 125/250 Volts and 3Ø 250 Volts Receptacles, INSULGRIP® Connector Bodies, Flanged Devices and Plugs 1.70" (43.2) 1.23" (31.2) X X G 2.67" (67.8) 1.56" 2.38" 3.28" (39.6) (60.5)(83.3) W Y G Single Flush Receptacles, Back and Side Wired Y Z NEMA L14-30R 30A 125/250V UL/CSA 2 (2) HP NEMA L15-30R 30A 3Ø 250V AC UL/CSA 3 HP Description Black nylon face. Isolated ground, orange nylon face. Catalog Numbers HBL2710 HBL2720 IG2710 IG2720 .98" (24.9) #6-32 TAP HBL2710 Insulgrip Connector Bodies IP20 2.33" (59.2) 2.21" (56.1) SUITABILITY Description Black and white nylon. Corrosion resistant, yellow nylon. Note: Cord clamp range .35 ”-1.15 ” (9-29). Catalog Numbers HBL2713 HBL2723 HBL27CM13 HBL27CM23 3.86" (98.0) HBL2713 Insulgrip Flanged Receptacles Description Nylon casing, back wired. 3.06" (77.7) 120° Catalog Numbers HBL2716 HBL2726 1.34" R (34.0) W 2.27" (57.7) Insulgrip Plugs IP20 HBL2716 3P 4W, 30A, 125/250V, 3Ø 250V AC SUITABILITY Description Black and white nylon. Corrosion resistant, yellow nylon. 2.23" (56.6) X X .19" (4.8) 120° DIA. Y G G Y Z NEMA L14-30P 30A 125/250V UL/CSA 2 (2) HP NEMA L15-30P 30A 3Ø 250V AC UL/CSA 3 HP Catalog Numbers HBL2711 HBL2721 HBL27CM11 HBL27CM21 Notes: Cord clamp range .35 ”-1.15 ” (9-29). See page B-73 for Add-A-Shroud™ kit. 2.75" (69.9) 2.33" (59.2) 2.21" (56.1) Insulgrip Flanged Inlets Description Nylon casing, back wired. HBL2711 3.06" (77.7) 120° 1.34" R (34.0) Catalog Numbers HBL2715 HBL2725 Notes: HP ratings not in parentheses are phase to phase. HP rating in parentheses is phase to neutral. Only receptacles and plugs are HP rated. See pages B-70 and B-71 for accessories. For technical information see page B-83. See page B-63 for switched enclosure. .19" 120° (4.8) DIA. 2.27" (57.7) 2.23" (56.6) HBL2715 B-40 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 3 Pole, 4 Wire Grounding 30 Ampere, 125/250 Volts and 3Ø 250 Volts AC Watertight Safety-Shroud TWIST-LOCK® System IP66 SUITABILITY UL Listed, CSA Certified to Type 4, 4X, & 12 X G W Y G Y Watertight Safety-Shroud Twist-Lock Receptacles 2.91" (73.9) X Z NEMA L14-30R 30A 125/250V UL/CSA 2 (2) HP NEMA L15-30R 30A 3Ø 250V AC UL/CSA 3 HP 3.75" (95.3) Description Catalog Numbers Gray Valox® housing and flange. HBL2710SW HBL2720SW Note: Receptacles only fit boxes listed on page B-72. 3.75" (95.3) HBL2710SW Watertight Safety-Shroud Twist-Lock Connector Bodies Description Black Valox housing, white Valox clamps. Catalog Numbers HBL2713SW HBL2723SW Description Black Valox housing, white Valox clamps. G Y G W 2.75" (69.9) X X Watertight Safety-Shroud Twist-Lock Plugs 1.75" (44.5) Y Z NEMA L14-30P 30A 125/250V UL/CSA 2 (2) HP NEMA L15-30P 30A 3Ø 250V AC UL/CSA 3 HP 4.38" (111.1) HBL2713SW Catalog Numbers HBL2711SW HBL2721SW Watertight Safety-Shroud Twist-Lock Inlets Description Gray Valox housing and flange. Catalog Numbers HBL2715SW HBL2725SW CIRCUIT-LOCK® Unfused Safety-Shroud Mechanical Interlock for Twist-Lock Receptacles Description Catalog Numbers Mechanical Interlock accommodates HBLMITL* 20A and 30A watertight Safety-Shroud receptacles. Note: *Not shown, see pages B-64 and B-65 for complete details. 4.50" (114.3) HBL2711SW 2.44" (62.0) 3.75" (95.3) 1.81" (46.0) 3.75" (95.3) HBL2715SW ®Valox is a registered trademark of General Electric Company. Dimensions in Inches (mm) www.hubbell-wiring.com B-41 3P 4W, 30A, 125/250V, 3Ø 250V AC Notes: Only receptacles and plugs 480V AC or less are HP rated. All HP ratings are AC only. HP rating in parentheses is phase to neutral. Cord grip range for plugs and connector bodies .35 ”-1.15 ” (9-29), #16-4 Type SJ to #8-4 Type S, SO. For technical information see page B-84. 2.94" (74.7) Locking Devices TWIST-LOCK® Devices 3 Pole, 4 Wire Grounding 30 Ampere, 125/250 Volts and 3Ø 250 Volts AC Safety-Shroud TWIST-LOCK® System 3.14" (79.8) F X S Fed.Spec. G X W Y Safety-Shroud Twist-Lock Receptacles 4.57" (116.1) Description Angle housing one gang. Surface mounting one gang. Semi-flush two gang. Notes: See page B-72 for box mounting application. Housing and flange, gray Valox®. 2.88" (73.2) HBL2710AR Y G Z NEMA L14-30R 30A 125/250V UL/CSA 2 (2) HP NEMA L15-30R 30A 3Ø 250V AC UL/CSA 3 HP Catalog Numbers HBL2710AR HBL2720AR HBL2710SR HBL2720SR HBL2710SR2 HBL2720SR2 1.71" (43.4) X X 4.56" (115.8) G IP20 SUITABILITY Insulgrip Connector Bodies 2.84" (72.1) Description Black and white nylon. Note: Cord clamp range .35 ”-1.15 ” (9-29). HBL2710SR Y G W Y Z NEMA L14-30R 30A 125/250V UL/CSA NEMA L15-30R 30A 3Ø 250V AC UL/CSA Catalog Numbers HBL2713 HBL2723 .77" (19.6) 5.12" (130.0) IP20 SUITABILITY 5.12" (130.0) Safety-Shroud Twist-Lock Plugs HBL2710SR2 2.33" (59.3) G Y G W 3P 4W, 30A, 125/250V, 3Ø 250V AC X X Y Z NEMA L14-30P 30A 125/250V UL/CSA 2 (2) HP NEMA L15-30P 30A 3Ø 250V AC UL/CSA 3 HP Description Catalog Numbers Black and white nylon body, white Valox shroud. Note: Cord clamp range .35 ”-1.15 ” (9-29). HBL2711S HBL2721S 2.21" (56.1) 3.86" (98.0) X HBL2713 W 2.33" (59.3) 2.21" (56.1) 4.12" (104.6) HBL2711S Insulgrip Flanged Inlet Description Nylon casing, back wired. Y G G Y Z NEMA L14-30P 30A 125/250V UL/CSA NEMA L15-30P 30A 3Ø 250V AC UL/CSA Catalog Numbers HBL2715 HBL2725 Notes: Only receptacles and plugs 480V AC or less are HP rated. All HP ratings are AC only. HP rating in parentheses is phase to neutral. For technical information, see page B-83. ®Valox B-42 X is a registered trademark of General Electric Company. www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 3 Pole, 4 Wire Grounding 30 Ampere, 3Ø 480 and 3Ø 600 Volts AC Receptacles, INSULGRIP® Connector Bodies, Flanged Devices and Plugs F G Single Flush Receptacles, Back and Side Wired Description Black nylon face. Not Fed Spec. 1.70" (43.2) X X S Fed.Spec. Y G Z Z NEMA L16-30R 30A 3Ø 480V AC UL/CSA 10 HP NEMA L17-30R 30A 3Ø 600V AC UL/CSA Catalog Numbers HBL2730 HBL2740 Insulgrip Connector Bodies IP20 SUITABILITY Description Black and white nylon. Corrosion resistant, yellow nylon. Note: Cord clamp range .35 ”-1.15 ” (9-29). IP20 SUITABILITY 3.86" (98.0) 2.33" (59.3) Catalog Numbers HBL2736 HBL2746 Y Description Black and white nylon. Corrosion resistant, yellow nylon. X G G Y Z Z NEMA L16-30P 30A 3Ø 480V AC UL/CSA 10 HP NEMA L17-30P 30A 3Ø 600V AC UL/CSA Catalog Numbers HBL2731 HBL2741 HBL27CM31 HBL27CM41 HBL2736 2.75" (69.9) Catalog Numbers HBL2735 HBL2745 Notes: HP ratings listed above are AC only. See pages B-70 and B-71 for accessories. Only receptacles and plugs are HP rated and up to 480V AC only. For technical information see page B-83. See page B-63 for a switched enclosure. www.hubbell-wiring.com 2.33" (59.2) 2.21" (56.1) HBL2731 B-43 3P 4W, 30A, 3Ø 480 and 3Ø 600V AC Insulgrip Flanged Inlets Dimensions in Inches (mm) 2.21" (56.1) HBL2733 Notes: Cord clamp range .35 ”-1.15 ” (9-29). See page B-73 for Add-A-Shroud™ kit. Description Nylon casing, backwired. .98" (24.9) HBL2730 Catalog Numbers HBL2733 HBL2743 HBL27CM33 HBL27CM43 X Insulgrip Plugs 1.56" 2.38" 3.28" (39.6) (60.5) (83.3) 2.67" (67.8) #6-32 TAP Insulgrip Flanged Receptacles Description Nylon casing, back wired. 1.23" (31.2) Y Locking Devices TWIST-LOCK® Devices 3 Pole, 4 Wire Grounding 30 Ampere, 3Ø 480 and 3Ø 600 Volts AC Watertight Safety-Shroud TWIST-LOCK® System UL Listed, CSA Certified to Type 4, 4X, & 12 2.91" (73.9) IP66 3.75" (95.3) SUITABILITY X G Watertight Safety-Shroud Twist-Lock Receptacles 3.75" (95.3) 1.75" (44.5) HBL2730SW X Y G Y Z Z NEMA L16-30R 30A 3Ø 480V AC UL/CSA 10 HP NEMA L17-30R 30A 3Ø 600V AC UL/CSA Description Catalog Numbers Gray Valox® housing and flange. HBL2730SW HBL2740SW Note: Receptacles only fit boxes listed on page B-72. Watertight Safety-Shroud Twist-Lock Connector Bodies Description Black Valox housing, white Valox clamps. 2.75" (69.9) Catalog Numbers HBL2733SW HBL2743SW X Y 4.38" (111.1) HBL2733SW 3P 4W, 30A, 3Ø 480 and 3Ø 600V AC 2.94" (74.7) X G Y G Z Z Watertight Safety-Shroud Twist-Lock Plugs NEMA L16-30P 30A 3Ø 480V AC UL/CSA 10 HP NEMA L17-30P 30A 3Ø 600V AC UL/CSA Description Black Valox housing, white Valox clamps. Catalog Numbers HBL2731SW HBL2741SW Watertight Safety-Shroud Twist-Lock Inlets Description Gray Valox housing and flange. 4.50" (114.3) HBL2731SW Catalog Numbers HBL2735SW HBL2745SW Notes: Only receptacles and plugs 480V AC or less are HP rated. All HP ratings are AC only. Cord grip range for plugs and connector bodies .35”-1.15” (9-29), #16-4 Type SJ to #8-4 Type S, SO. For technical information see page B-84. 2.44" (62.0) CIRCUIT-LOCK® Unfused Safety-Shroud Mechanical Interlock for Twist-Lock Receptacles 3.75" (95.3) 1.81" (46.0) Description Catalog Number Mechanical Interlock accommodates HBLMITL* 20A and 30A watertight Safety-Shroud receptacles. Note: *See pages B-64 and B-65 for complete details. 3.75" (95.3) HBL2735SW ®Valox B-44 is a registered trademark of General Electric Company. www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 3 Pole, 4 Wire Grounding 30 Ampere, 3Ø 480 and 3Ø 600 Volts AC Safety-Shroud TWIST-LOCK® System X G Safety-Shroud Twist-Lock Receptacles Description Angle housing one gang. Surface mounting one gang. Semi-flush two gang. Notes: See page B-72 for box mounting application. Housing and flange, gray Valox®. G Z Z NEMA L17-30R 30A 3Ø 600V AC UL/CSA Description Black and white nylon. Note: Cord clamp range .35”-1.15” (9-29). X Y G Description Black and white nylon body, white Valox shroud. Note: Cord clamp range .35”-1.15” (9-29). Z Z NEMA L17-30R 30A 3Ø 600V AC UL/CSA 2.84" (72.1) X G Y HBL2730SR G Z Z NEMA L16-30P 30A 3Ø 480V AC UL/CSA 10 HP NEMA L17-30P 30A 3Ø 600V AC UL/CSA .77" (19.6) Catalog Numbers HBL2731S HBL2741S 5.12" (130.0) X X G G Y Z Z NEMA L16-30P 30A 3Ø 480V AC UL/CSA NEMA L17-30P 30A 3Ø 600V AC UL/CSA 5.12" (130.0) HBL2730SR2 Catalog Numbers HBL2735 HBL2745 Notes: Only receptacles and plugs 480V AC or less are HP rated. All HP ratings are AC only. For technical information, see page B-83. 3.86" (98.0) 2.33" (59.3) 2.21" (56.1) HBL2733 2.33" (59.3) 2.21" (56.1) 4.12" (104.6) ®Valox HBL2731S is a registered trademark of General Electric Company. Dimensions in Inches (mm) www.hubbell-wiring.com B-45 3P 4W, 30A, 3Ø 480 and 3Ø 600V AC Description Nylon casing, back wired. 4.56" (115.8) Catalog Numbers HBL2733 HBL2743 Y Insulgrip Flanged Inlets 1.71" (43.4) Y NEMA L16-30R 30A 3Ø 480V AC UL/CSA Y Safety-Shroud Twist-Lock Plugs 2.88" (73.2) HBL2730AR X IP20 SUITABILITY 4.57" (116.1) Catalog Numbers HBL2730AR HBL2740AR HBL2730SR HBL2740SR HBL2730SR2 HBL2740SR2 G Insulgrip Connector Bodies Y NEMA L16-30R 30A 3Ø 480V AC UL/CSA 10 HP X IP20 SUITABILITY 3.14" (79.8) X Y Locking Devices TWIST-LOCK® Devices 3 Pole, 4 Wire Grounding 50 Ampere, 125/250 Volts, 3Ø 250 and 3Ø 480V AC Receptacles, Connector Bodies, Plugs and Flanged Inlets 2.13" (54.1) Y Y Y X X X Z W 2.69" 3.28" (68.3) (83.3) Receptacles Description Black melamine. 1.03" (26.2) 2.44" (62.0) Connector Bodies CS6369 50A 3Ø 250V AC UL/CSA Catalog Numbers CS6369 CS8369 W G G 50A 3Ø 250V AC UL/CSA Description Catalog Numbers Nylon cover, Rynite interior. CS6365C CS8365C Note: Cord clamp range .920 ”-1.2” (23.681-30.48). CS6364C X G Z 50A 3Ø 480V AC UL/CSA CS8165C Flanged Inlets 6.38" (162.0) Description Catalog Numbers Zinc plated steel casing, Rynite interior. CS6375*** CS8375 Note: ***See page V-12 for weatherproof inlet. 2.59" (65.8) 3P 4W, 50A, 125/250V, 3Ø 250 and 3Ø 480V AC Y Z 50A 125/250V UL/CSA IP20 SUITABILITY CS8164C X X Plugs CS8169 Y Y 2.59" (65.8) G 50A 3Ø 480V AC UL/CSA IP20 SUITABILITY Description Catalog Numbers Nylon cover, Rynite® interior. CS6364C CS8364C Note: Cord clamp range .920 ”-1.2” (23.681-30.48). 6.34" (161.0) Z G G 50A 125/250V UL/CSA CS8175 Accessories Weatherproof Boots CS6365C IP55** SUITABILITY Description Seal-Tite® triple seal black elastomeric cover for plugs when used in a cord set and connector bodies when used with flanged inlets. Seal-Tite triple seal black elastomeric cover for connector bodies when used with cord sets. Note: Boots shown on page B-74. 3.50" (88.9) 90° .19" (4.8) DIA. 1.50"R (38.0) 2.62" (66.5) Catalog Numbers HBL7716C* HBL7717C* Weatherproof Receptacle Cover Plates Description Gray thermoplastic, corrosion resistant. Yellow thermoplastic, corrosion resistant. Catalog Numbers HBL7774WO HBL77CM74WO 2.17" (55.1) CS6375 Receptacle Wall Plate & Box Cover Description Stainless steel 302/304, smooth. Galvanized Steel fits 4” square, 4 11/16” or 2 gang box Catalog Number S750 HBL50SC Closure Plug for 50A Inlets HBL7774WO Description Catalog Number Black closure plug. HBL4892* Notes: For additional accessories see page B-74. For technical information see page B-85. **When installed and used properly with plug and connector body combination. * Not UL Listed, CSA Certified. ®Rynite B-46 is a registered trademark of E. I. Dupont www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 3 Pole, 4 Wire Grounding 50 Ampere, 600 Volts AC, 250 Volts DC Receptacles, Connector Bodies, Plugs and Flanged Inlets Important Note: Catalog numbers HBL7379, HBL7764C, HBL7765C, HBL7958, HBL7968 are for replacement use only. See other singly rated 50A Twist-Lock® devices in this section. HBL3700 series Twist-Lock devices do not interchange with any other devices in this section. X Y Z X Z Description Black melamine. Connector Bodies 2.69" (68.3) Y G 50A 600V AC 50A 250V DC Receptacles 2.13" (54.1) 3.28" (83.3) G 50A 600V AC 50A 250V DC Catalog Numbers HBL3769 HBL7379 1.03" (26.2) IP20 SUITABILITY 2.44" (62.0) HBL3769 Description Catalog Numbers Nylon cover, Rynite® interior. HBL3764C HBL7764C Note: Cord clamp range .920”-1.20 ” (23.36-30.48). 6.34" (161.0) X Y Z X G Plugs Z 50A 600V AC 50A 250V DC IP20 SUITABILITY G Y 2.59" (65.8) 50A 600V AC 50A 250V DC HBL3764C Description Catalog Numbers Nylon cover, Rynite interior. HBL3765C HBL7765C Note: Cord clamp range .920”-1.20 ” (23.36-30.48). 6.38" (162.0) Flanged Inlets Description Zinc plated steel casing, with lift cover. Zinc plated steel casing, without lift cover. Accessories Weatherproof Boots Catalog Numbers HBL3768 HBL7968 HBL3775 HBL7958 2.59" (65.8) HBL3765C IP55* SUITABILITY Description Catalog Numbers Seal-Tite® triple seal black elastomeric cover for plugs when used HBL7716C** * in a cord set and connector bodies when used with flanged inlets. Seal-Tite triple seal black elastomeric cover for connector bodies HBL7717C** * when used with cord sets. Description Gray thermoplastic, corrosion resistant. Yellow thermoplastic, corrosion resistant. IP44* SUITABILITY 2.19" (55.6) .19" (4.8) DIA. Catalog Numbers HBL7774WO HBL77CM74WO 90° 3.50" (88.9) HBL3768 Receptacle Wall Plate & Box Cover Description Stainless steel 302/304, smooth. Galvanized Steel fits 4” square, 4 11/16” or 2 gang box Closure Plug for 50A Inlets Description Black closure plug. .19" (4.8) DIA. 1.50"R (38.0) Catalog Number HBL4892* Notes: For additional accessories see page B-74. For technical information see page B-85. **When installed and used properly with plug and connector body combination. ®Rynite 3.50" (88.9) 90° Catalog Number S750 HBL50SC is a registered trademark of E. I. Dupont. 2.62" (66.5) 2.17" (55.1) HBL3775 *Not UL Listed, Not CSA Certified. Dimensions in Inches (mm) www.hubbell-wiring.com B-47 3P 4W, 50A, 250V DC and 600V AC Weatherproof Receptacle Cover Plates 2.63" (66.8) 1.50"R (38.0) Locking Devices TWIST-LOCK® Devices 4 Pole, 4 Wire Non-Grounding 20 Ampere, 3Ø Y 120/208, 277/480 and 347/600 Volts AC Receptacles, INSULGRIP® Connector Bodies, Plugs and Flanged Devices 1.70" (43.2) F 1.23" (31.2) X S Fed.Spec. Single Flush Receptacles, Back and Side Wired 2.67" (67.8) 1.56" 2.38" 3.28" (39.6) (60.5) (83.3) Description Black nylon face. X X Y W W Y W Y Z Z Z NEMA L18-20R 20A 3ØY 120/208V AC UL Listed 2 HP NEMA L19-20R 20A 3ØY 277/480V AC UL Listed 5 HP NEMA L20-20R 20A 3ØY 347/600V AC UL Listed Catalog Numbers HBL2440 HBL2450 HBL2460 Not Fed Spec. #6-32 TAP .98" (24.9) Insulgrip Connector Bodies IP20 SUITABILITY HBL2440 Description Catalog Numbers Black and white nylon. HBL2443 HBL2453 Note: Cord clamp range .35 ”-1.15 ” (9-29). HBL2463 Insulgrip Flanged Receptacles 2.33" (59.2) 2.21" (56.1) Description Nylon casing, back wired. Catalog Numbers HBL2446 HBL2456 3.86" (98.0) HBL2443 4P 4W, 20A, 3ØY 120/208, 277/480 and 347/600V AC 3.06" (77.7) W Y Insulgrip Plugs IP20 SUITABILITY Description Black and white nylon. 120° 1.34" R (34.0) .19" 120° (4.8) DIA. 2.27" (57.7) HBL2466 X X X W Y Y W Z Z Z NEMA L18-20P 20A 3ØY 120/208V AC UL Listed 2 HP NEMA L19-20P 20A 3ØY 277/480V AC UL Listed 5 HP NEMA L20-20P 20A 3ØY 347/600V AC UL Listed Catalog Numbers HBL2441 HBL2451 HBL2461 Notes: Cord clamp range .35 ”-1.15 ” (9-29). See page B-73 for Add-A-Shroud™ kit. Insulgrip Flanged Inlets Description Nylon casing, back wired. 2.23" (56.6) Catalog Numbers HBL2445 HBL2455 HBL2465 HBL2446 Accessories Wall Plates IP55** SUITABILITY 2.75" (69.9) 2.33" (59.2) 2.21" (56.1) Description Stainless steel 302/304, smooth, single-gang. Brass, smooth, single-gang. Black, smooth nylon, single-gang. Catalog Numbers S720 B720 P720B Weatherproof Boots IP55* SUITABILITY HBL2441 3.06" (77.7) 120° 1.34" R (34.0) .19" 120° (4.8) DIA. 2.27" (57.7) 2.23" (56.6) HBL2445 B-48 Description Seal-Tite triple seal cover for plug when used on a cord set or when used with flush receptacles or connector body when used with flanged inlets. Black elastomer. Same as above except yellow. Seal-Tite® triple seal cover for connector body, when used on interconnecting cord sets. Black elastomer. Same as above except yellow. Catalog Numbers HBL6035* HBL60CM35* HBL6036* HBL60CM36* Notes: See pages B-70 and B-71 for accessories. HP ratings are for receptacles and plugs only and up to 480V AC only. HP ratings are AC only. **When installed and used properly with plug and connector body combinations. For technical information see page B-83. ** Not UL Listed. www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 4 Pole, 4 Wire Non-Grounding 30 Ampere, 3Ø Y 120/208, 277/480 and 347/600 Volts AC Receptacles, INSULGRIP® Connector Bodies, Flanged Devices and Plugs X F X 1.70" (43.2) X S Fed.Spec. Single Flush Receptacles, Back and Side Wired Description Black nylon face. Y W W Y W Z Z Z NEMA L18-30R 30A 3ØY 120/208V AC UL Listed 3 HP NEMA L19-30R 30A 3ØY 277/480V AC UL Listed 10 HP NEMA L20-30R 30A 3ØY 347/600V AC UL Listed Catalog Numbers HBL2750 HBL2760 1.23" (31.2) Y 1.56" 2.38" 3.28" (39.6) (60.5) (83.3) 2.67" (67.8) HBL2770 Not Fed Spec. Insulgrip Connector Bodies IP20 SUITABILITY Description Catalog Numbers Black and white nylon. HBL2753 HBL2763 Note: Cord clamp range .35 ”-1.15 ” (9-29). #6-32 TAP .98" (24.9) HBL2750 HBL2773 3.86" (98.0) Insulgrip Flanged Receptacles Description Nylon casing, back wired. Catalog Numbers HBL2756 HBL2766 X Y HBL2776 X W X W Y 2.21" (56.1) 2.33" (59.2) HBL2753 W Y Z Z Insulgrip Plugs IP20 SUITABILITY NEMA L18-30P 30A 3ØY 120/208V AC UL Listed 3 HP NEMA L19-30P 30A 3ØY 277/480V AC UL Listed 10 HP NEMA L20-30P 30A 3ØY 347/600V AC UL Listed Description Black and white nylon. Catalog Numbers HBL2751 HBL2761 3.06" (77.7) 120° 1.34" R (34.0) HBL2771 .19" (4.8) DIA. Note: Cord clamp range .35 ”-1.15 ” (9-29). See page B-73 for Add-A-Shroud™ kit. 120° 2.27" (57.7) Insulgrip Flanged Inlets Description Nylon casing, back wired. Catalog Numbers HBL2755 HBL2765 2.23" (56.6) HBL2756 HBL2775 Notes: Horsepower ratings are for receptacles and plugs only and up to 480V AC only. See pages B-70 and B-71 for accessories. For technical information see page B-83. 2.75" (69.9) 2.33" (59.2) 2.21" (56.1) HBL2751 3.06" (77.7) 120° 1.34" R (34.0) .19" (4.8) DIA. 120° 2.27" (57.7) 2.23" (56.6) HBL2755 Dimensions in Inches (mm) www.hubbell-wiring.com B-49 4P 4W, 30A, 3ØY 120/208, 277/480 and 347/600V AC Z Locking Devices TWIST-LOCK® Devices 4 Pole, 4 Wire Non-Grounding 20 and 30 Ampere, 3Ø Y 120/208 Volts AC Receptacles, INSULGRIP® Connector Bodies, Flanged Devices and Plugs W 1.71" (43.4) 1.05" (26.7) Z For Replacement Use Only Receptacles 2.50" (63.5) 1.57" 2.38" 3.61" (39.8) (60.5) (91.7) Description Black urea, back wired. Mounted on a 4” (101.6) round metal cover. Z X Y W Y X Non-NEMA 20A 3Ø Y 120/208V AC UL Listed Non-NEMA 30A 3Ø Y 120/208V AC UL Listed Catalog Numbers HBL7410B HBL3430 HBL7417B – Not Fed Spec #6-32 TAP 1.28" (32.0) HBL7410B Insulgrip Connector Bodies IP20 SUITABILITY Description Black and white nylon. 1.36" (34.6) 1.71" (43.4) Note: Cord grip range for devices .35 ”-1.15 ” (9-29). 1.57" 3.28" 3.61" (39.8) (83.3) (91.7) 2.69" (68.3) Catalog Numbers HBL7413C HBL3433C Insulgrip Flanged Receptacle Description Nylon casing, back wired. Catalog Number HBL7409C – #6-32 TAP W 1.13" (28.7) Z Z X Y W HBL3430 Insulgrip Plugs 3.86" (98.0) 2.21" (56.1) 4P 4W, 20 and 30A, 3ØY 120/208V AC 2.33" (59.2) IP20 SUITABILITY Description Black and white nylon. Y X Non-NEMA 20A 3Ø Y 120/208V AC UL Listed Non-NEMA 30A 3Ø Y 120/208V AC UL Listed Catalog Numbers HBL7411C HBL3431C Notes: Cord grip range for devices .35 ”-1.15 ” (9-29). See page B-73 for Add-A-Shroud™ kit. HBL7413C Insulgrip Flanged Inlet 3.06" (77.7) 120° Description Nylon casing, back wired. 1.34" R (34.0) .19" (4.8) DIA. 120° 2.27" (57.7) Catalog Number HBL7408C – Notes: See pages B-70 and B-71 for accessories. For technical information on Insulgrip plugs, connector bodies and flanged devices see page B-83. 2.23" (56.6) HBL7409C 3.06" (77.7) 120° 2.75" (69.9) 1.34" R (34.0) 2.33" (59.2) 2.21" (56.1) HBL7411C .19" (4.8) DIA. 120° 2.27" (57.7) 2.23" (56.6) CAUTION: To avoid electrical shock, review premises carefully and do not use if slot or blade configuration (design) is already in a circuit having a rating differing from the rating of this device. HBL7408C B-50 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 4 Pole, 5 Wire Grounding 20 Ampere, 3Ø Y 120/208, 277/480 and 347/600 Volts AC Receptacles, INSULGRIP® Connector Bodies, Flanged Devices and Plugs F X S Fed.Spec. Single Flush Receptacles, Back and Side Wired Description Black nylon face. Isolated ground, orange nylon face. W X Y G W 1.70" (43.2) X G Y W G Z Z Z NEMA L21-20R 20A 3ØY 120/208V AC UL/CSA 2 HP NEMA L22-20R 20A 3ØY 277/480V AC UL/CSA 5 HP NEMA L23-20R 20A 3ØY 347/600V AC UL/CSA Catalog Numbers HBL2510 HBL2520* IG2510 – 1.23" (31.2) Y 1.56" 2.38" 3.28" (39.6) (60.5) (83.3) 2.67" (67.8) HBL2530* – #6-32 TAP *Not Fed Spec .98" (24.9) Insulgrip Connector Bodies IP20 SUITABILITY HBL2510 Description Catalog Numbers Black and white nylon. HBL2513 HBL2523 Corrosion resistant, yellow nylon. HBL25CM13 – Note: Cord grip range .35 ”-1.15 ” (9-29). HBL2533 – 2.33" (59.3) 2.21" (56.1) Insulgrip Flanged Receptacles Description Nylon casing, back wired. Catalog Numbers HBL2516 HBL2526 W Y G HBL2513 3.06" (77.7) 120° X W Y G W Z Z Z NEMA L21-20P 20A 3ØY 120/208V AC UL/CSA NEMA L22-20P 20A 3ØY 277/480V AC UL/CSA 5 HP NEMA L23-20P 20A 3ØY 347/600V AC UL/CSA Description Catalog Numbers Black and white nylon. HBL2511 HBL2521 Corrosion resistant, yellow nylon. HBL25CM11 – Note: Cord grip range .35 ”-1.15 ” (9-29). 1.34" R (34.0) .19" (4.8) DIA. 120° 2.27" (57.7) HBL2531 – 2.23" (56.6) HBL2516 Insulgrip Flanged Inlets Description Nylon casing, back wired. Catalog Numbers HBL2515 HBL2525 HBL2535 Notes: Only receptacles and plugs 480V AC or less are HP rated. HP ratings for receptacles and plugs only. All HP rating are AC only. See pages B-70 and B-71 for accessories. See page B-83 for technical data. See page B-63 for switched enclosure. 2.75" (69.8) 2.33" (59.2) 2.21" (56.1) HBL2511 3.06" (77.7) 120° 1.34" R (34.0) .19" (4.8) DIA. 120° 2.27" (57.7) 2.23" (56.6) HBL2515 Dimensions in Inches (mm) www.hubbell-wiring.com B-51 4P 5W, 20A, 3ØY 120/208, 277/480 and 347/600V AC Insulgrip Plugs IP20 SUITABILITY G HBL2536 X X Y 3.86" (98.0) Locking Devices TWIST-LOCK® Devices 4 Pole, 5 Wire Grounding 20 Ampere, 3Ø Y 120/208 Volts AC Watertight Safety-Shroud TWIST-LOCK® System 2.91" (73.9) F S Fed.Spec. IP66 UL Listed, CSA Certified to Type 4, 4X, & 12 SUITABILITY X 3.75" (95.3) W G Y Z 1.75" (44.5) 3.75" (95.3) HBL2510SW Watertight Safety-Shroud Receptacle, Back Wired NEMA L21-20R 20A 3ØY 120/208V AC UL/CSA 2 HP Description Gray Valox® housing and flange. Note: Receptacles only fit boxes listed on page B-72. Catalog Number HBL2510SW Watertight Safety-Shroud Connector Body Description Black Valox housing, white Valox clamps. 2.75" (69.9) Catalog Number HBL2513SW 4.38" (111.1) X HBL2813SW HBL2513SW Y G W Z NEMA L21-20P 20A 3ØY 120/208V AC UL/CSA 2 HP Watertight Safety-Shroud Plug Description Black Valox housing, white Valox clamps. Catalog Number HBL2511SW Watertight Safety-Shroud Flanged Inlet 2.94" (74.7) 4.50" (114.3) HBL2511SW Description Gray Valox housing and flange. Catalog Number HBL2515SW Notes: Cord grip range for plugs and connector bodies .35”-1.15” (9-29), #16-5 Type S, SO to #8-5 Type S, SO. For technical information see page B-84. 4P 5W, 20A, 3ØY 120/208V AC 2.44" (62.0) CIRCUIT-LOCK® Unfused Safety-Shroud Mechanical Interlock for Twist-Lock Receptacles 3.75" (95.3) 1.81" (46.0) Description Mechanical Interlock accommodates 20A and 30A watertight safety shroud receptacles. Note: *See pages B-64 and B-65 for complete details. Catalog Number HBLMITL* 3.75" (95.3) HBL2815SW HBL2515SW ®Valox B-52 is a registered trademark of General Electric Company. www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 4 Pole, 5 Wire Grounding 20 Ampere, 3Ø Y 120/208 Volts AC Safety-Shroud TWIST-LOCK® System F S 3.14" (79.8) X Fed.Spec. W G Y Z NEMA L21-20R 20A 3ØY 120/208V AC UL/CSA 2 HP Safety-Shroud Twist-Lock Receptacles Description Angle housing one gang. Surface mounting one gang. Semi-flush two gang. 4.57" (116.1) Catalog Numbers HBL2510AR HBL2510SR HBL2510SR2 2.88" (73.2) HBL2510AR HBL2810AR Notes: See page B-72 for box mounting application. Housing and flange gray Valox®. 1.71" (43.4) 4.56" (115.8) X W G Y Z Insulgrip Connector Body NEMA L21-20R 20A 3ØY 120/208V AC UL/CSA IP20 SUITABILITY Description Black and white nylon. Note: Cord clamp range .35 “-1.15” (9-29). 2.84" (72.1) HBL2510SR Catalog Number HBL2513 .77" (19.6) 5.12" (130.0) X Y G 5.12" (130.0) W HBL2510SR2 Z Safety-Shroud Twist-Lock Plug IP20 SUITABILITY Catalog Number HBL2511S 2.33" (59.3) 2.21" (56.1) 3.86" (98.0) HBL2513 X Y G W Z 2.33" (59.3) 2.21" (56.1) NEMA L21-20P 20A 3ØY 120/208V AC UL/CSA Insulgrip Flanged Inlet Description Nylon casing, back wired. Catalog Number HBL2515 4.12" (104.6) HBL2511S Notes: Only receptacle and plugs 480V AC or less are HP rated. All HP ratings are AC only. For technical information, see page B-83. ®Valox is a registered trademark of General Electric Company. Dimensions in Inches (mm) www.hubbell-wiring.com B-53 4P 5W, 20A, 3ØY 120/208V AC Description Black and white nylon body, White Valox shroud. Note: Cord clamp range .35”-1.15 “ (9-29). NEMA L21-20P 20A 3ØY 120/208V AC UL/CSA 2 HP Locking Devices TWIST-LOCK® Devices 4 Pole, 5 Wire Grounding 30 Ampere, 3Ø Y 120/208, 277/480 and 347/600 Volts AC Receptacles, INSULGRIP® Connector Bodies, Flanged Devices and Plugs 1.70" (43.2) F 1.23" (31.2) Single Flush Receptacles, Back and Side Wired 1.56" 2.38" 3.28" (39.6) (60.5) (83.3) 2.67" (67.8) X S Fed.Spec. Description Black nylon face. Isolated ground, orange nylon face. W X X Y G W G W Y G Y Z Z Z NEMA L21-30R 30A 3ØY 120/208V AC UL/CSA 3 HP NEMA L22-30R 30A 3ØY 277/480V AC UL/CSA 10 HP NEMA L23-30R 30A 3ØY 347/600V AC UL/CSA Catalog Numbers HBL2810 HBL2820 IG2810 – HBL2830 – #6-32 TAP HBL2810 .98" (24.9) Insulgrip Connector Bodies IP20 SUITABILITY 2.33" (59.3) Description Catalog Numbers Black and white nylon. HBL2813 HBL2823 Corrosion resistant, yellow nylon. HBL28CM13 – Note: Cord grip range .35 ”-1.15 ” (9-29). 2.21" (56.1) 3.86" (98.0) HBL2833 – HBL2813 4P 5W, 30A, 3ØY 120/208, 277/480 and 347/600V AC Insulgrip Flanged Receptacles Description Nylon casing, back wired. 3.06" (77.7) 120° X 1.34" R (34.0) .19" (4.8) DIA. Y 120° 2.27" (57.7) 2.23" (56.6) HBL2816 Catalog Numbers HBL2816 HBL2826 X X W G HBL2836 Y G W Y W G Z Z Z Insulgrip Plugs IP20 SUITABILITY NEMA L21-30P 30A 3ØY 120/208V AC UL/CSA 3 HP NEMA L22-30P 30A 3ØY 277/480V AC UL/CSA 10 HP NEMA L23-30P 30A 3ØY 347/600V AC UL/CSA Description Black and white nylon. Corrosion resistant, yellow nylon. Catalog Numbers HBL2811 HBL2821 HBL28CM11 – HBL2831 – Notes: Grip range .35 ”-1.15 ” (9-29). See page B-73 for Add-A-Shroud™ kit. 2.75" (69.9) 2.33" (59.2) 2.21" (56.1) Insulgrip Flanged Inlets Description Nylon casing, back wired. HBL2811 3.06" (77.7) 120° 1.34" R (34.0) .19" (4.8) DIA. Catalog Numbers HBL2815 HBL2825 HBL2835 Notes: Only receptacles and plugs 480V AC or less are HP rated. HP rating are AC only. See pages B-70 and B-71 for accessories. For technical information see page B-83. See page B-63 for a switched enclosure. 120° 2.27" (57.2) 2.23" (56.6) HBL2815 B-54 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 4 Pole, 5 Wire 30 Ampere, 3Ø Y 120/208 Volts AC Watertight Safety-Shroud Twist-Lock® System IP66 SUITABILITY UL Listed, CSA Certified to Type 4, 4X, & 12K F 2.91" (73.9) S X Fed.Spec. W G Y Z NEMA L21-30R 30A 3ØY 120/208V AC UL/CSA 3 HP Watertight Safety-Shroud Twist-Lock Receptacle Description Gray Valox® housing and flange. Note: Receptacles only fit boxes listed on page B-72. 3.75" (95.3) Catalog Number HBL2810SW 1.75" (44.5) 3.75" (95.3) HBL2810SW Watertight Safety-Shroud Connector Body Description Black Valox housing, white Valox clamps. Catalog Number HBL2813SW 2.75" (69.9) X Y G W 4.38" (111.1) Z HBL2813SW NEMA L21-30P 30A 3ØY 120/208V AC UL/CSA 3 HP Watertight Safety-Shroud Plug Description Black Valox housing, white Valox clamps. Catalog Number HBL2811SW 2.94" (74.7) Watertight Safety-Shroud Flanged Inlet Description Gray Valox housing and flange. Catalog Number HBL2815SW 4.50" (114.3) HBL2811SW Notes: Only receptacles and plugs 480V AC or less are HP rated. HP ratings are AC only. Cord grip range for plugs and connector bodies .35 ”-1.15 ” (9-29), #16-5 Type S, SO to #8-5 Type S, SO. For technical information see page B-84. 2.44" (62.0) CIRCUIT-LOCK® Unfused Safety-Shroud Mechanical Interlock for Twist-Lock Receptacles Description Catalog Number Mechanical Interlock accommodates 20A and 30A HBLMITL* watertight Safety-Shroud receptacles. Note: *Not shown, see pages B-64 and B-65 for complete details. ®Valox 1.81" (46.0) 3.75" (95.3) HBL2815SW is a registered trademark of General Electric Company. Dimensions in Inches (mm) www.hubbell-wiring.com B-55 4P 5W, 30A, 3ØY 120/208V AC 3.75" (95.3) Locking Devices TWIST-LOCK® Devices 4 Pole, 5 Wire Grounding 30 Ampere, 3Ø Y 120/208 Volts AC Safety-Shroud TWIST-LOCK® System 3.14" (79.8) F S X Fed.Spec. W G Y Z 4.57" (116.1) 2.88" (73.2) HBL2810AR Safety-Shroud Twist-Lock Receptacles NEMA L21-30R 30A 3ØY 120/208V AC UL/CSA 3 HP Description Angle housing one gang. Surface mounting one gang. Semi-flush two gang. Catalog Numbers HBL2810AR HBL2810SR HBL2810SR2 Notes: See page B-72 for box mounting application. Housing and flange, gray Valox®. 1.71" (43.4) X 4.56" (115.8) W G Y Z Insulgrip Connector Body 2.84" (72.1) NEMA L21-30R 30A 3ØY 120/208V AC UL/CSA IP20 SUITABILITY Description Black and white nylon. Note: Cord clamp range .35 ”-1.15 ” (9-29). HBL2810SR Catalog Number HBL2813 .77" (19.6) 5.12" (130.0) X Y G W Z 5.12" (130.0) Safety-Shroud Twist-Lock Plug 4P 5W, 30A, 3ØY 120/208V AC HBL2810SR2 2.33" (59.3) NEMA L21-30P 30A 3ØY 120/208V AC UL/CSA 3 HP IP20 SUITABILITY Description Black and white nylon body, white Valox shroud. Note: Cord clamp range .35 ”-1.15 ” (9-29). Catalog Number HBL2811S 2.21" (56.1) X 3.86" (98.0) Y HBL2813 Z 2.33" (59.3) 2.21" (56.1) 4.12" (104.6) W G Insulgrip Flanged Inlet NEMA L21-30P 30A 3ØY 120/208V AC UL/CSA Description Nylon casing, back wired. Catalog Number HBL2815 Notes: Only receptacles and plugs 480V AC or less are HP rated. All HP ratings are AC only. For technical information, see page B-83. ®Valox is a registered trademark of General Electric Company. HBL2811S B-56 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices 4 Pole, 5 Wire Grounding 20 Ampere, 250 Volts, 10 Ampere, 600 Volts AC Receptacle, INSULGRIP® Plug and Connector Body Z For Replacement Use Only Z W Y X GR W GR Receptacle Non-NEMA 20A 250V 10A 600V AC UL/CSA Description Black urea, back wired. Catalog Number HBL3520 1.71" (43.4) Y X Non-NEMA 20A 250V 10A 600V AC UL/CSA 3.61" 2.38" 1.57" (91.7) (60.5) (39.8) 2.50" (63.5) – #6-32 TAP Insulgrip Plug IP20 SUITABILITY Description Black and white nylon. HBL3520 Catalog Number – HBL3521C Insulgrip Connector Body IP20 SUITABILITY Description Black and white nylon. Catalog Number HBL3523C 2.75" (69.9) 2.33" (59.2) 2.21" (56.1) – HBL3521C Insulgrip Flanged Inlet Description Nylon casing, back wired. Catalog Number – HBL3525C 2.33" (59.2) 2.21" (56.1) 3.86" (98.0) Insulgrip Flanged Receptacle Description Nylon casing, back wired. Catalog Number HBL3524C HBL3523C – Notes: Cord grip range for plug and connector body .35 ”-1.15 ” (9-29). See pages B-70 and B-71 for accessories. For technical information on Insulgrip plug and connector body see page B-83. 3.06" (77.7) 120 1.34" R (34.0) 120 2.27" (57.7) CAUTION: To avoid electrical shock, review premises carefully and do not use if slot or blade configuration (design) is already in a circuit having a rating differing from the rating of this device. 2.23" (56.6) HBL3525C 3.06" (77.7) 120 1.34" R (34.0) .19" (4.8) DIA. 120 2.27" (57.7) 2.23" (56.6) HBL3524C Dimensions in Inches (mm) www.hubbell-wiring.com B-57 4P 5W, 20A, 250V, 10A 600V AC .19" (4.8) DIA. Locking Devices TWIST-LOCK® Devices 4 Pole 5 Wire Grounding 30 Ampere, 250 Volts; 30 Ampere, 600 Volts AC and 20 Ampere, 3Ø Y 120/208 Volts AC 400Hz VARILOAD® TWIST-LOCK® Receptacles, Plugs, Connector Bodies and Flanged Inlets #6-32 TAP 1.02" (25.9) 3.28" 2.38" 1.72" (83.3) (60.5) (43.7) 2.69" (68.3) 1.27" (32.3) 1.72" (43.7) In many large plants and laboratories the number of circuits of different ratings and frequency is greater than the number of blade configurations available in conventional wiring devices. Prior to NEMA configuration standardization the solution was “Variload Twist-Lock” devices with four non-interchangeable center pin and slot configurations that can be designated to different circuits. HBL45305 30A, 250V AC/DC 30A, 600V AC 2.13" (54.1) DIA. 1.86" (47.2) Center Pin Configuration .91" (23.1) HBL45315 Receptacles Plugs Connector Bodies Flanged Inlets HBL45105 HBL45115 HBL45135 – HBL45205 HBL45215 HBL45235 – HBL45305 HBL45315 HBL45335 – HBL45915 HBL45935 20A 120/208V 3Ø Y, 400 Hz 1.84" (46.7) DIA. 2.13" (54.1) DIA. .91" (23.1) 2.89" (73.4) HBL45335 HBL45905 HBL45985CL Accessories Plates Description Catalog Numbers Brass, single-gang. Stainless steel, single-gang. B725 S725 Weatherproof Boots IP55** SUITABILITY Description Catalog Numbers 4P 5W, Variload Devices Seal-Tite black elastomer for Variload plugs. HBL6027* Seal-Tite, black elastomer for Variload connector bodies. HBL6028* Note: **When installed and used properly with plug and connector body combinations. * Not UL Listed. CAUTION: To avoid electrical shock, review premises carefully and do not use if slot or blade configuration (design) is already in a circuit having a rating differing from the rating of this device. B-58 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices Not UL Listed, TWIST-LOCK® Devices 3 Pole, 3 Wire and 2 Pole 3 Wire 10 Ampere, 250 Volts, 15 Ampere 125 Volts Receptacles, INSULGRIP® Connector Bodies, Flanged Devices and Plugs 3 Pole 3 Wire 2 Pole 3 Wire For Replacement Use Only CU 1.70" (43.2) CU GR Receptacles Not Grounded Not UL listed Description Duplex, black RTP*. Single, black phenolic. Grounded Not UL listed Catalog Numbers HBL7580 HBL7580G HBL7582 HBL7582G Connector Bodies 3.28" (83.3) 2.735" (69.5) IP20 SUITABILITY Description Insulgrip connector, black and white nylon, multiple drive screws. Insulgrip connector, yellow and white nylon, multiple drive screws. Black phenolic. Catalog Numbers HBL7565C – HBL7565CY HBL7555 HBL7580 – HBL7555G Notes: Cord grip range .230 ”-.720 ” (5.8-18.3). HBL7555 cord grip range .296 ”-.625 ” (7.5-15.9). 2.78" (70.6) 1.41" (35.8) 1.53" (38.9) Flanged Receptacles Description Stainless steel casing. Catalog Numbers HBL7557 HBL7557G Insulgrip Plugs IP20 SUITABILITY Description Black and white nylon, multiple drive screws. Yellow and white nylon, multiple drive screws. Note: Cord grip range .230 ”-.720 ” (5.8-18.3). Not Grounded Not UL listed 2.31" (58.7) 1.94" (49.3) CU Grounded Not UL listed 1.75" (44.4) Catalog Numbers HBL7567C – HBL7567CY – .16"(4.1) 1.34" (34.0) 1.50" (38.1) HBL7557 Flanged Inlets Description Stainless steel casing. Catalog Numbers HBL7556 HBL7556G Notes: See pages B-66 and B-67 for accessories. For technical information on Insulgrip connector bodies and plugs see page B-83. The devices shown on this page are not listed by Underwriters Laboratories Inc. and are for replacement use only in existing installations. *RTP is an abbreviation for reinforced thermoplastic. 1.53" (38.9) 1.91" (48.5) HBL7567C CAUTION: To avoid electrical shock, review premises carefully and do not use if slot or blade configuration (design) is already in a circuit having a rating differing from the rating of this device. 2.31" (58.7) 1.94" (49.3) 1.75" (44.4) .16"(4.1) Dia. 1.13" (28.7) 1.50" (38.1) HBL7556 Dimensions in Inches (mm) www.hubbell-wiring.com B-59 Not UL Listed Devices 3P 3W, 10A, 250V, 15A, 125V CU HBL7565C Locking Devices Not UL Listed TWIST-LOCK® Devices 2 Pole, 3 Wire Grounding 20 and 30 Ampere, 250 Volts Receptacles, INSULGRIP® Connector Bodies and Plugs 1.28" (32.5) #6-32 TAP CU 2.20" 3.61" (55.9) (91.6) Description Black urea, back wired. Description Black and white nylon. HBL7310BG 30A 250V Non NEMA Not UL listed 20A 250V Non-NEMA Not UL Listed Catalog Numbers HBL7310BG HBL3330G Insulgrip Connector Bodies 1.28" (32.6) 1.71" (43.1) GR CU Single Flush Receptacles 2.38" 3.28" (60.5)1.38" (34.9) (83.3) GR For Replacement Use Only 1.05" (26.7) IP20 SUITABILITY Catalog Numbers HBL7314GCB HBL3333GC 1.22" (31.0) GR GR CU CU Insulgrip Plugs 1.57" 2.38" 3.61" (39.8) (60.5)(91.6) 2.50" (63.5) #6-32 TAP Description Black and white nylon. 30A 250V Non NEMA Not UL listed Catalog Numbers HBL9965GCB HBL3331GC Notes: Cord grip range .360 ”-930 ” (9-24). See pages B-68 and B-69 for accessories. For technical information on Insulgrip connector bodies and plugs see page B-83. The devices shown on this page are not listed by Underwriters Laboratories Inc. and are for replacement use only in existing installations. .97" (24.6) HBL3330G CAUTION: To avoid electrical shock, review premises carefully and do not use if slot or blade configuration (design) is already in a circuit having a rating differing from the rating of this device. 3.86" (98.0) 2.26" (57.4) Not UL Listed 2P 3W, 20 and 30A, 250V IP20 SUITABILITY 20A 250V Non-NEMA Not UL Listed 1.97" (50.0) HBL7314GCB 2.75" (69.9) 2.26" (57.4) 1.97" (50.0) HBL9965GCB B-60 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices Not UL Listed TWIST-LOCK® Devices 3 Pole, 4 Wire 20 and 30 Ampere, 250 Volts AC Receptacles, INSULGRIP® Connector Bodies and Plugs GR For Replacement Use Only Z Z 1.28" (32.6) 1.05" (26.7) GR X Y Y X Single Flush Receptacles Description Black phenolic, back and side wired. 20A 250V AC Non-NEMA Not UL Listed 30A 250V AC Non-NEMA Not UL Listed Catalog Numbers HBL7410BG HBL3430G 1.57" (39.8) 2.50" 2.38" 3.61" (63.5) (60.5)(91.6) #6-32 TAP 1.71" (43.4) HBL7410BG Insulgrip Connector Bodies IP20 SUITABILITY Description Black and white nylon. Catalog Numbers HBL7413GCB HBL3433GCB GR 1.36" (34.5) 1.71" (43.4) Z X Z GR Y Y 1.57" 2.38" 3.28" (39.8) (60.5) (83.3) 2.50" (63.5) X Insulgrip Plugs IP20 SUITABILITY Description Black and white nylon. 20A 250V AC Non-NEMA Not UL Listed 30A 250V AC Non-NEMA Not UL Listed #6-32 TAP 1.13" (28.7) Catalog Numbers HBL7411GCB HBL3431GCB HBL3430G Notes: Cord grip range .350 ”-1.150 ” (9-29). See pages B-70 and B-71 for accessories. For technical information on Insulgrip connector bodies and plugs see page B-83. The devices shown on this page are not listed by Underwriters Laboratories Inc. and are for replacement use only in existing installations. 3.86" (98.0) 2.33" (59.2) HBL7413GCB 2.75" (69.9) 2.33" (59.2) 2.21" (56.1) HBL7411GCB Dimensions in Inches (mm) www.hubbell-wiring.com B-61 Not UL Listed 3P 4W, 20 & 30A, 250V AC CAUTION: To avoid electrical shock, review premises carefully and do not use if slot or blade configuration (design) is already in a circuit having a rating differing from the rating of this device. 2.21" (56.1) Locking Devices TWIST-LOCK® Devices Switched Safety Enclosures Switched TWIST-LOCK® and HUBBELLOCK® Enclosures Lockable handle provides lockout protection for greater safety and complies with OSHA lockout requirements. Horsepower rated switch. Angled 20 or 30 Amp Hubbell Twist-Lock receptacle provides low profile and helps control cable arc of bend. Large receptacle gasketless door and hinge assembly. Switched Enclosures Premolded conduit entry hole is offset to prevent water condensation from falling directly on interior electrical components, while speeding installation by making it easier to pull conductors. Heavy-duty internal frame bonds conduit and all grounds and has a DIN rail to accommodate the switch. Moveable feet may be used in horizontal or vertical position or may be removed and premarked holes drilled for Type 1 or 3R installations. Hubbell innovation delivers again. The Switched Twist-Lock and Hubbellock Enclosures integrate a receptacle and a switch to produce distinct advantages for the user. This enclosure replaces box, switch, cover and all in a compact design that meets Type 3R Rainproof or 12K Dust-tight requirements. The receptacle is angled downward for a low profile, and it maintains a low profile while accommodating either a 20 or 30 Amp Twist-Lock receptacle or 30 Amp, 4 wire Hubbellock receptacle. B-62 The enclosure can be used in top, bottom or back feed applications. The handle is designed to be locked in the off position for lockout protection. the receptacle in a compact, nonmetallic enclosure encourages the safe operating practice of disconnecting at the switch rather than the plug and receptacle. Hubbell has developed the Switched Safety Enclosure because users want to be able to disconnect higher voltage devices confidently. Hubbell responded with a line of Switched Safety Enclosures for Twist-Lock and Hubbellock receptacles. The provision of the integral switch and For plants and factories in a wide variety of industries, as well as light industrial facilities, Hubbell’s Switched Enclosures offer an upgrade that’s convenient, compact and easy to install. www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices Switched Enclosure Switched TWIST-LOCK® and HUBBELLOCK® Enclosures UL Listed, CSA Certified Type 3R and 12K Enclosure Rating 4.88" (124.0) IP54 SUITABILITY Switched Enclosure Ready for Twist-Lock® Receptacle Addition Ideal unit for stockroom. This single unit provides the complete enclosure ready to accept any Hubbell 20 or 30A Twist-Lock receptacle. Description Switched Twist-Lock enclosure accommodates any NEMA 2 pole, 3 wire to 4 pole, 5 wire grounding receptacle (sold separately). Auxiliary contact. Auxiliary contact. Ratings Amperage, voltage, and horsepower ratings will be determined by the choice of the NEMA 20 or 30A Twist-Lock receptacle selected. Break after break NO/NC. Break before break NO/NC. Sw it Tw ched is En t-Lock® clo su re PSJO CA IST T. OT SSFITNO. N XX FIT IST XXXX TIE I EW H SA RQ LAKJ QQ SKA OF F ON CA UT ow ION tos : istels nto Saitie ls tiewnf wthw iet sntof uil ioeta AT TE oenlssothe sitieb sotheNTION oth . es oetyh toe : Als ot enl hs wo ritwhe iteh pt thl ta sithe sle dithe ithelsi toenll otehl l tih sl lsjt ehhll el . Catalog Numbers SETL3 11.38" (289.1) HBLAC1 HBLAC2 4.5" (114.3) SETL3 Switched Enclosure Complete with Twist-Lock Receptacle Completely pre-wired with a Twist-Lock receptacle, these application oriented combinations are available to satisfy your needs. Description Switched Twist-Lock enclosure with a prewired HBL2720 receptacle. Switched Twist-Lock enclosure with a prewired HBL2730 receptacle. Use TwistNEMA AmpLock Config. erage Voltage Horsepower Plug L15-30R 30 3Ø 240V AC 3 HBL2721 L16-30R 30 3Ø 480V AC 5 Switched Enclosure Catalog Numbers SE2720A HBL2731 SE2730A Description Switched enclosure for use with 3 pole 4 wire 30A Hubbellock receptacle (sold separately). Auxiliary contact. Auxiliary contact. Dimensions in Inches (mm) Ratings Amperage, voltage, and horsepower ratings will be determined by the choice of the 4 wire Hubbellock receptacle selected. Break after break NO/NC. Break before break NO/NC. Switched Enclosures Switched Enclosure Ready for Hubbellock Receptacle Addition Ideal unit for stockroom. This single unit provides the complete enclosure ready to accept your 30A, 4 wire Hubbellock receptacle choice. Catalog Numbers SEHBL3 HBLAC1 HBLAC2 www.hubbell-wiring.com B-63 Locking Devices TWIST-LOCK® Devices Switched Safety Enclosures CIRCUIT-LOCK® Unfused Safety-Shroud TWIST-LOCK® Mechanical Interlock Angled 20 or 30 Amp Hubbell Watertight Safety-Shroud Twist-Lock receptacle provides watertight, low profile and mechanical interlock capabilities. Lockable handle provides lockout protection for greater safety and compliance with OSHA lockout requirements. Enclosure back is designed for top, bottom or back feed options. Heavy-duty interlock linkage prevents make and break under load. Horsepower rated switch. Moveable feet may be used in horizontal or vertical position. Mechanical Interlock Heavy-duty internal frame bonds conduit and all grounds and has a DIN rail to accommodate the switch. Hubbell offers the only mechanical interlock for Twist-Lock. This new, unfused mechanical interlock for watertight Safety-Shroud TwistLock integrates a watertight receptacle with a linked disconnect switch to provide a mechanically interlocked receptacle. This virtually eliminates the possibility of making or breaking the circuit while under load or making a B-64 Premolded conduit entry hole is offset to prevent water condensation from falling directly on interior electrical components. Also speeds installation by making it easier to pull conductors. casual or “lazy” connection. The switch cannot be turned “ON” until the plug is properly inserted and locked, and the plug cannot be removed until the switch is turned “OFF.” All these protective features are included in a compact Type 4X hose-directed water and corrosion resistant enclosure that allows for top, bottom or back feed options. The non-metallic enclosure is nonconductive, yet has an www.hubbell-wiring.com internal frame to assure ground continuity with metallic conduit. In addition, this interlock works with all Safety-Shroud TwistLock plugs. The new unfused mechanical interlock for watertight Safety-Shroud TwistLock can be locked out as a method of compliance with OSHA lockout/tagout regulations. Dimensions in Inches (mm) Locking Devices TWIST-LOCK Devices Switched Enclosure CIRCUIT-LOCK Unfused Safety Shroud TWIST-LOCK® Mechanical Interlock UL Listed, CSA Certified TYPE 4, 4X and TYPE 12K Enclosure Rating IP66 SUITABILITY 3.19" (81.0) 4.88" (124.0) Ordering Information This unit is a complete enclosure ready to accept any 20 or 30A watertight Safety-Shroud Twist-Lock receptacle. Description Mechanical Interlock accommodates 20A or 30A watertight Safety-Shroud Twist-Lock receptacles. Ratings Catalog Number Amperage, voltage and HP ratings HBLMITL will be determined by the choice of the watertight Safety-Shroud Twist-Lock selected. Suppiled With 3/4” Hub. 11.44" (290.6) Accepts the following watertight Safety-Shroud Twist-Lock receptacles: 20A Rating 2 Pole, 3 Wire 3 Pole, 4 Wire 4 Pole, 5 Wire NEMA Config. Max. Voltage Reference HP AC Number Rating 120 L5-20 1 208-240 L6-20 2.5 277 L7-20 3 120/240 L14-20 2.5 240 3Ø L15-20 5 (3@208V) 480 3Ø L16-20 10 120/208 3ØY L21-20 3 Use Watertight Safety Shroud Twist-Lock Plug Cat. No. HBL2311SW HBL2321SW HBL2331SW HBL2411SW HBL2421SW HBL2431SW HBL2511SW Receptacle Catalog Numbers HBL2310SW HBL2320SW HBL2330SW HBL2410SW HBL2420SW HBL2430SW HBL2510SW NEMA Config. Voltage Reference AC Number 120 L5-30 208-240 L6-30 120/240 L14-30 240 3Ø L15-30 480 3Ø L16-30 600 3Ø L17-30 120/208 3ØY L21-30 Use Watertight Safety Shroud Twist-Lock Plug Cat. No. HBL2611SW HBL2621SW HBL2711SW HBL2721SW HBL2731SW HBL2741SW HBL2811SW Receptacle Catalog Numbers HBL2610SW HBL2620SW HBL2710SW HBL2720SW HBL2730SW HBL2740SW HBL2810SW 4.19" (106.4) HBLMITL 30A Rating 2 Pole, 3 Wire 3 Pole, 4 Wire 4 Pole, 5 Wire Max. HP Rating 1 2.5 2.5 5 10 * 5 Auxiliary Contacts Description Auxiliary contact. Auxiliary contact. Ratings Break after break NO/NC. Break before break NO/NC. Catalog Numbers HBLAC1 HBLAC2 Description Catalog Numbers Ground block. Neutral block. Replacement switch. HBL30RGB HBL30RNB HBLDS3RS Mechanical Interlock Replacement Parts *Notes: HP ratings listed above are AC only. See pages B-70 and B71 for accessories. Only receptacles and plugs are HP rated and up to 480V AC only. For technical information see page B-87. Dimensions in Inches (mm) www.hubbell-wiring.com B-65 Locking Devices TWIST-LOCK® Devices Accessories for 15 Ampere 2 and 3 Wire Duplex, Single Receptacles and Flanged Devices Single-Gang Wall Plate Single Rec. Plate 1.406” (35.7) Dia. Duplex Plate P8 P7 Description Brown nylon, smooth. Ivory nylon, smooth. Stainless steel 302/304, smooth. Brass, smooth. Aluminum, smooth. Weatherproof Plates HBL5206WO HBL5221 Catalog Numbers P8X P7X P8 P7 S8 S7 B8 B7 A8 A7 IP44 SUITABILITY Description Cast aluminum, for standard horizontal box mount. Same as above except FS/FD box mount. Cast aluminum vertical FS/FD box mount. Gray thermoplastic, vertical standard box mount, corrosion resistant. Same as above except yellow. Gray thermoplastic, vertical FS/FD box mount, corrosion resistant. Yellow thermoplastic, vertical FS/FD box mount, corrosion resistant. White thermoplastic, vertical FS/FD box mount, corrosion resistant. Weatherproof Plate for 15A Flanged Inlets and Receptacles Description Gray thermoplastic, corrosion resistant. Catalog Numbers HBL5205WO – HBL5206WO – – HBL7420 HBL5222* – HBL52CM22* – HBL5221* HBL7423WO HBL52CM21* HBL74CM23WO HBL52CM21W* – IP44 SUITABILITY Catalog Number WP1 Notes: All weatherproof plates listed above are UL Listed for wet and damp locations with cover closed. Those with suffix WO are UL Listed with cover open. See Section K for more information. *IP20 Suitability only. Accessories HBL7423WO WP1 B-66 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices Accessories for 15 Ampere 2 and 3 Wire Plugs, Connector Bodies and Flanged Devices Weatherproof, Seal-Tite® Triple Seal Boots for 15A Insulgrip® Devices IP55* SUITABILITY Description Catalog Numbers Black elastomer boot for plugs when used in a cord set and HBL6023 connector bodies when used with a flange inlet. Same as above except yellow elastomer. HBL60CM23 Black elastomer boot for connector bodies when used in HBL6024 cord sets. Same as above except yellow elastomer. HBL60CM24 *When installed and used properly with plug and connector body combinations. HBL6023 Closure Cover Description For use with 3 wire 15A Twist-Lock flush or flanged receptacles. Catalog Number HBL7529 HBL6024 PLUGOUT® Lockout Devices Description Lockout device for 15A & 20A straight blade plugs. Catalog Numbers HLDMP Lockout device for attachable 20 and 30A plugs, straight body HLD or angle types, with or without weatherproof covers. Note: See Section U for more information on PLUGOUT Lockout Devices. HBL7529 3.14" (79.8) 4.22" (107.2) HLDMP 4.27" (108.5) 7.27" (184.7) Accessories HLD Dimensions in Inches (mm) www.hubbell-wiring.com B-67 Locking Devices TWIST-LOCK® Devices Accessories for 20 and 30 Ampere 3, 4 and 5 Wire Receptacles and Flanged Devices S720 Single-Gang Wall Plates Rec. Plate 1.60” (40.64) Dia. Description Black nylon, smooth. Stainless steel 302/304, smooth. Brass, smooth. Catalog Numbers P720B S720 B720 Weatherproof Plates IP44 SUITABILITY Description Cast aluminum, for FS/FD box mounting. Gray thermoplastic, for FS/FD box mounting, corrosion resistant. Same as above except yellow. HBL7425WOA Weatherproof Plate for Flanged Inlets and Flanged Receptacles Description Gray thermoplastic, corrosion resistant. Catalog Numbers HBL7420 HBL7425WOA HBL74CM25WOA IP44 SUITABILITY Catalog Number WP2 Notes: Weatherproof plates are UL Listed for wet and damp location with cover closed. Those with suffix WOA are UL Listed with cover open. Closure Cover for 3 Wire Flanged Inlets Description Rubber closure plug. Note: Closure cover not UL Listed. Not CSA Certified. Catalog Number HBL2899 WP2 Closure Cover for 4 Wire Flanged Inlets Description Rubber closure plug. Note: Closure cover not UL Listed. Not CSA Certified. Catalog Number HBL2898 Accessories HBL2899 B-68 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices Accessories for 20 and 30 Ampere, 3 Wire Plugs and Connector Bodies Weatherproof, Seal-Tite® Triple Seal Boots IP55* SUITABILITY Description Black elastomer boot for plugs when used in a cord set and connector bodies when used in flanged inlets. Same as above except yellow. Black elastomer boot for connector bodies when used in a cord set. Same as above except yellow. Catalog Numbers HBL6031 HBL60CM31 HBL6032 HBL60CM32 HBL6031 Angle Adapter Description Nylon, angle adapter for Insulgrip plugs and connector bodies, cord grip range .325”-.930” (8.3-24). Catalog Number HBL3WAA PLUGOUT® Lockout Devices Description Catalog Numbers Lockout device for attachable 20 and 30A Locking plug HLD straight body,or angle types, with or without weatherproof covers. Lockout device for 20 and 30A 3 wire angle plugs HLD2 and watertight Safety-Shroud Twist-Lock plugs. HBL6032 Notes: See Section U for more information on PLUGOUT Lockout Devices. *When installed and used properly with plug and connector body combinations. Insulgrip Plug and Connector Body Latching Kit When you want to make doubly sure that plugs and connector bodies stay connected, the Hubbell latching kit provides both improved safety and security through a double locking feature that makes unintentional disconnection virtually impossible – even under high vibration situations. The plug and connector body lock once when first connected, then again when you push the special position locking slide into place. HBL3WAA Insulgrip Latching Kit Description For all 3 wire 20A and 30A Twist-Lock Insulgrip plugs and connectors. Catalog Number SK2 6.31" (160.3) 4.27" (108.5) 12.5" (317.5) 7.27" (184.7) Dimensions in Inches (mm) www.hubbell-wiring.com Accessories HLD HLD2 B-69 Locking Devices TWIST-LOCK® Devices Accessories for 20 and 30 Ampere, 4 and 5 Wire Receptacles and Flanged Devices S720 Single-Gang Wall Plates Rec. Plate 1.60” (40.64) Dia. Description Black nylon, smooth. Stainless steel 302/304, smooth. Brass, smooth. Catalog Numbers P720B S720 B720 Weatherproof Plates IP44 SUITABILITY Description Cast aluminum, for FS/FD box mounting. Gray thermoplastic, for FS/FD box mounting, corrosion resistant. Same as above except yellow. Catalog Numbers HBL7420 HBL7425WOA HBL74CM25WOA Weatherproof Plate for Flanged Inlets and Flanged Receptacles IP44 SUITABILITY HBL7425WOA Description Gray thermoplastic, corrosion resistant. Catalog Number WP2 Notes: Weatherproof plates are UL Listed for wet and damp locations with cover closed. Those with suffix WOA are UL Listed with cover open. Accessories WP2 B-70 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices Accessories for 20 and 30 Ampere, 4 and 5 Wire Plugs and Connector Bodies Weatherproof, Seal-Tite® Triple Seal Boots IP55* SUITABILITY Description Seal-Tite triple seal cover for plug when used on a cord set or when used with flush receptacles or connector bodies when used with flanged inlets. Black elastomer. Same as above except yellow. Seal-Tite triple seal cover for connector bodies, when used on interconnecting cord sets. Black elastomer. Same as above except yellow. Catalog Numbers HBL6035 HBL60CM35 HBL6036 HBL6035 HBL60CM36 Angle Adapter Description Nylon, angle adapter for Insulgrip plugs and connectors, cord grip range .350”-1.15” (8.9-29.2). Catalog Number HBL45WAA PLUGOUT® Lockout Device Description Lockout device for attachable 20 and 30A plug straight body or angle types, with or without weatherproof covers. Lockout device for 20 and 30A 4 and 5 wire angle plugs and watertight Safety-Shroud Twist-Lock plugs. Catalog Numbers HLD HBL6036 HLD2 Notes: See Section U for more information on PLUGOUT Lockout Devices. *When installed and used properly, with plug and connector body combinations. Insulgrip Plug and Connector Body Latching Kit When you want to make doubly sure that plugs and connector bodies stay connected, the Hubbell latching kit provides both improved safety and security through a double locking feature that makes unintentional disconnection virtually impossible – even under high vibration situations. The plug and connector body lock once when first connected, then again when you push the special position locking slide into place. HBL45WAA Insulgrip Latching Kit Description For all 4 and 5 wire 20 and 30A Twist-Lock Insulgrip plugs and connectors. Catalog Numbers SK3 6.31" (160.3) 4.27" (108.5) 12.5" (317.5) SK3 Dimensions in Inches (mm) HLD www.hubbell-wiring.com Accessories 7.27" (184.7) HLD2 B-71 Locking Devices TWIST-LOCK® Devices Safety-Shroud TWIST-LOCK® Accessories Non-Metallic Back Box A B C D E F Cubic Hub Inch Inch Inch Inch Inch Inch Inch Catalog Description Size (mm) (mm) (mm) (mm) (mm) (mm) Capacity Number 15° Angle for 1.0* 5.67 4.44 4.05 3.91 2.35 4.92 30 BB2030N 20 and 30A (25.4) (144.0) (112.8) (102.9) (99.3) (59.7) (125.0) (76.2) watertight Safety-Shroud Twist-Lock Notes: Hub is not included; order Raco part number 1704. This box meets IP67 requirement and Type 4X requirements when installed with a watertight conduit hub. BB2030N E Metallic Back Boxes F A C D B E A C F B D Straight Wall Box Adapter Angle Box Description Adapts 20A and 30A Safety-Shroud Twist-Lock receptacles to two gang, device mount, FD boxes. D E B 48 CU. IN. A A B C D E F Cubic Hub Inch Inch Inch Inch Inch Inch Inch Catalog Description Size (mm) (mm) (mm) (mm) (mm) (mm) Capacity Numbers 3 Back box 20 /4 5 1/8 4 4 3/16 3 3/4 3 4 30 BB201W and 30A devices (19.1) (130.2)(101.6) (106.4) (95.3) (76.2) (101.6) Back box 20 1 5 1/8 4 4 3/16 3 3/4 3 4 30 BB301W and 30A devices (25.4) (130.2)(101.6) (106.4) (95.3) (76.2) (101.6) 3 Feed thru for /4 8 1/4 3 1/16 7 9/64 4 1/2 3 3/4 – 48 FT202W 20 & 30A devices(19.1) (209.6)(77.8) (181.4) (114.3) (95.3) – Feed thru for 1 8 1/4 3 1/16 7 9/64 4 1/2 3 3/4 – 48 FT302W 20 & 30A devices(25.4) (209.6)(77.8) (181.4)(114.3)(95.3) – Notes: These boxes are cast aluminum, suitable for IP54 requirements and are finished with enamel paint. These boxes withstand a 500-hour salt spray test as well as UL raintight and external icing tests. 3.13" C (79.5) Catalog Number HBL2030AP Angle Wall Box Adapter Description Adapts 20A and 30A Watertight Safety-Shroud Twist-Lock receptacles to single or two gang standard wall boxes (4” or 411/16” square). Catalog Number AA2030PS Feed-Thru Box Accessories HBL2030AP AA2030PS B-72 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices Safety-Shroud TWIST-LOCK® Devices ADD-A-SHROUD™: The Innovation That Lets You Convert Existing INSULGRIP® TWIST-LOCK® Plugs to Safety-Shroud TWIST-LOCK Devices The Add-A-Shroud devices allow conversion of existing 20A and 30A 3 to 5 Wire Hubbell Insulgrip® Twist-Lock devices to a Safety-Shroud Twist-Lock plug. These devices provide a convenient and costeffective way to convert existing Hubbell Insulgrip Twist-Lock plugs to Safety-Shroud Twist-Lock plugs. The Safety-Shroud Twist-Lock plug permits engagement with the Hubbell Mechanical Interlock Enclosure which virtually prevents make and break under load. Safety-Shroud Twist-Lock – 20 & 30 Ampere Add-A-Shroud Catalog Number HBLSS3 For conversion of all 3 wire Hubbell Insulgrip Twist-Lock Devices. 20A, 2 Pole 3 Wire Grounding 30A, 2 Pole 3 Wire Grounding Voltage Rating 125 250 277V AC 480V AC 600V AC 125 250 277V AC 480V AC 600V AC NEMA Number L5-20 L6-20 L7-20 L8-20 L9-20 L5-30 L6-30 L7-30 L8-30 L9-30 Hubbell Catalog Numbers Plug Add-A-Shroud HBL2311 HBLSS3 HBL2321 HBLSS3 HBL2331 HBLSS3 HBL2341 HBLSS3 HBL2351 HBLSS3 HBL2611 HBLSS3 HBL2621 HBLSS3 HBL2631 HBLSS3 HBL2641 HBLSS3 HBL2651 HBLSS3 Add-A-Shroud Catalog Number HBLSS45 For conversion of all 4 & 5 wire Hubbell Insulgrip Twist-Lock Devices. 20A, 3 Pole 4 Wire Grounding 30A, 3 Pole 4 Wire Grounding 20A, 4 Pole 5 Wire Grounding Dimensions in Inches (mm) NEMA Number L14-20 L15-20 L16-20 L14-30 L15-30 L16-30 L17-30 L21-20 Hubbell Catalog Numbers Plug Add-A-Shroud HBL2411 HBLSS45 HBL2421 HBLSS45 HBL2431 HBLSS45 HBL2711 HBLSS45 HBL2721 HBLSS45 HBL2731 HBLSS45 HBL2741 HBLSS45 HBL2511 HBLSS45 L22-20 HBL2521 HBLSS45 L23-20 HBL2531 HBLSS45 L21-30 HBL2811 HBLSS45 L22-30 HBL2821 HBLSS45 L23-30 HBL2831 HBLSS45 www.hubbell-wiring.com 1.57" (39.9) HBLSS3 2.21" (56.1) 1.65" (41.9) HBLSS45 ADD-A-SHROUD™ Devices 30A, 4 Pole 5 Wire Grounding Voltage Rating 125/250 3Ø250V AC 3Ø480V AC 125/250 3Ø250V AC 3Ø480V AC 3Ø600V AC 3ØY 120/ 208V AC 3ØY 277/ 480V AC 3ØY 347/ 600V AC 3ØY 120/ 208V AC 3ØY 277/ 480V AC 3ØY 347/ 600V AC 2.04" (51.8) B-73 Locking Devices TWIST-LOCK® Devices Accessories For 50 Ampere TWIST-LOCK Devices Weatherproof Receptacle Lift Cover Plates for FS/FD Box Mounting IP44 SUITABILITY HBL7774WO Description Corrosion resistant, gray thermoplastic. Same as above except yellow. Cast aluminum. Note: See Section K for more information on weatherproof plates. Catalog Numbers HBL7774WO HBL77CM74WO HBL7770 Receptacle Plates for FS/FD Box Mounting Description Cast aluminum with lift cover. Same as above less lift cover. HBL7770 Note: The two plates Listed above will only fit non-“CS” type 50A Twist-Lock receptacles. *Not UL Listed “WDL Closed.” Weatherproof Boots HBL7382 Catalog Numbers HBL7382* HBL7383 IP55** SUITABILITY Description Catalog Numbers Seal-Tite® triple seal black elastomeric cover for plugs when used HBL7716C* in a cord set and connector bodies when used with flanged inlets. Seal-Tite triple seal black elastomeric cover for connector bodies HBL7717C* when used with cord sets. **When installed and used properly with plug and connector body combinations. * Not UL Listed Closure Cover HBL7716C Description Black closure plug. * Not UL Listed Catalog Number HBL4892* Box Cover Description Galvanized Steel fits 4” square, 4 11/16” or 2 gang box Catalog Number HBL50SC Accessories HBL7717C HBL4892 B-74 HBL50SC www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices HUBBELLOCK® Plugs and Connector Bodies Features and Benefits Three-piece thermoplastic clamp assembly with fast-lead stainless screws provides a more consistent durable grip. Grommets provide a sealed cable entry that protects against the entry of moisture and dust. Superior wire terminations are assured with box terminals and screws with pressure pads. This design captures stray wire strands and permits more clamping pressure on the wire without damaging it. Loosening of terminations and resulting heat build-up are greatly reduced. Impact resistance in the interior of the female device comes from a strong thermoplastic material. No “lazy” connections because a spring-loaded safety shutter automatically ejects the plug if it hasn’t been properly locked into the female device. This eliminates teasing of the contacts, a major cause of contact burn-up. Arcs are snuffed out, when devices are mated or unmated under load, by spring-loaded safety shutter. Longer contact life is assured by supplementary springs. Other devices rely just on contacts themselves to provide proper contact pressure. Enhanced safety because access to live female contacts is restricted by the spring-loaded safety shutter. Positive locking is ensured by the nose of the plug being keyed into a detent in female device. This lock is independent of the contacts or a separate mechanical lock. Insulated non-metallic housing enhances safety and abuse resistance. Features and Benefits Note: Above cut-away view and call-outs are construction elements pertaining specifically to the 30A Hubbellock series. While the Hubbellock contact interface design applies to all, there are construction elements that are different, depending on the amperage. Dimensions in Inches (mm) www.hubbell-wiring.com B-75 Locking Devices HUBBELLOCK® Devices 2 Pole, 3 Wire Grounding 20 Ampere, 125 Volts Receptacle, Plug and Connector IP30 GR GR SUITABILITY #6-32 TAP W W 20A 125V 20A 125V Receptacle 1.38" 2.38" 3.28" (35.1) (60.5) (83.3) 2.50" (63.5) Description Black phenolic, back wired. Catalog Number HBL23030 – Plug 1.66" (42.2) Description Nylon housing, thermoset interior. HBL23030 Connector Body Description Nylon housing, thermoset interior. 3.22" (81.8) Catalog Number HBL23032B – Notes: Cord clamp range for plug and connector .32”-.66” (8.12-16.5). Devices listed above are not interchangeable with any other Hubbellock device listed in this catalog. 1.72" (43.7) 2.31" (58.7) Accessories Weatherproof Covers HBL23035B Description Gray polycarbonate for FS/FD box mounting, corrosion resistant. IP44 SUITABILITY. Same as above except yellow. Cast aluminum, lift cover for indoor use only (not shown). 3.56" (90.4) 1.72" (43.7) Catalog Number – HBL23035B Catalog Numbers HBL7423WO HBL74CM23WO HBL23007 1.63" (41.4) HBL23032B 2P 3W, 20A, 125V HBL7423WO B-76 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices HUBBELLOCK® Devices 3 Pole, 4 Wire Grounding 30 Ampere, 600 Volts AC, 20 Ampere, 250 Volts DC Receptacles, Plugs, Connector Bodies and Inlets Z IP30 SUITABILITY Z 1.75" (44.5) GR Y GR X X Receptacles 30A 600V AC 20A 250V DC 30A 600V AC 20A 250V DC Description Black phenolic. Weathertight, corrosion resistant, nickel plated brass plate, for FS/FD box mounting. IP44 SUITABILITY Aluminum angle housing, with 3/4” topped hub for surface mounting. IP44 SUITABILITY Catalog Numbers HBL20403 – HBL22CM427 – HBL21420 1.22" (31.0) Y 3.28" 2.69" (83.3) (68.3) 1.94" (49.3) – 1.94" (49.3) Connector Bodies Description Black nylon housing, thermoplastic interior. Same as above except corrosion resistant. Note: Cord clamp range .70”-1.20 ” (17.78-30.5). 4.56" (115.8) Catalog Numbers HBL21414B – HBL21CM414B – 3.25" (82.6) 5.31" (134.9) Plugs Description Black nylon housing, thermoplastic interior. Same as above except corrosion resistant. Note: Cord clamp range .70”-1.20 ” (17.78-30.5). Catalog Numbers – HBL21415B – HBL21CM415B Flanged Inlets Description Weathertight, corrosion resistant, nickel plated brass plate, for FS/FD box mounting. Black phenolic interior, aluminum housing, for FS/FD box mounting (not shown). Aluminum angle housing, with 3/4” NPT topped hub for surface mounting. 2.69" (68.3) HBL21420 .88" (22.4) Catalog Numbers – HBL22CM428 – HBL20418 – HBL21447 5.08" (129.0) 2.44" (62.0) HBL21414B Description Catalog Number Switched enclosure for use with 3 pole 4 wire 30A SEHBL3 Hubbellock receptacle. Receptacle not included. Note: For more information on switched enclosures see page B-63. 2.33" (59.2) Accessories Receptacle Plates HBL21415B Description Catalog Numbers Cast aluminum weatherproof, lift cover plate (not shown). HBL20405 302/304 stainless, single gang, smooth (not shown). S737 Liquidtight Metallic Conduit Adapters Description Adapter for use with 1/2” NPT conduit fittings. Adapter for use with 3/4” NPT conduit fittings. 4.75" (120.7) .88" (22.4) Catalog Numbers SAB12 SAB34 4.56" (115.8) 3.25" (82.6) 5.31" (134.9) Boots Description “Mini” boot for Hubbellock connector body.* “Mini” boot for Hubbellock plug.* * Not UL Listed or CSA Certified. Dimensions in Inches (mm) Catalog Numbers HBL20424B HBL20425B www.hubbell-wiring.com 2.69" (68.3) B-77 3P 4W, 30A, 600V AC, 20A, 250V DC Switched Enclosure IP54 SUITABILITY Locking Devices HUBBELLOCK® Devices 3 Pole, 4 Wire Grounding 30 Ampere, 480 Volts AC Receptacle, Plug and Connector Body 1.94" (49.3) SUITABILITY 3.28" 2.69" (83.3) (68.3) 1.94" (49.3) GR Y GR Y X X Receptacle 30A 480V AC 30A 480V AC Description Black phenolic, red center insert. Catalog Number HBL20443 – Connector Body HBL20443 .88" (22.4) Z Z IP20 1.22" (31.0) Description Red nylon housing, thermoset interior. Note: Cord clamp range .70”-1.20 ” (17.78-30.5). 5.08" (129.0) Catalog Number HBL20444B – Plug 2.44" (62.0) HBL20444B .88" (22.4) Description Red nylon housing, thermoset interior. Note: Cord clamp range .70”-1.20 ” (17.78-30.5). Switched Enclosure Catalog Number – HBL20445B+ IP54 SUITABILITY Description Catalog Numbers Switched enclosure for use with 3 pole 4 wire 30A SEHBL3 – Hubbellock receptacle. Receptacle not included. Note: For more information on switched enclosures see pages B-62 and B-63. 4.75" (120.7) 2.33" (59.2) HBL20445B Accessories Receptacle Plates Description Cast aluminum, weatherproof, red finish (not shown). 302/304 stainless, single gang, smooth (not shown). Catalog Numbers HBL20446 S737 Liquidtight Metallic Conduit Adapters HBL20424B Description Adapter for use with 1/2” NPT conduit fittings. Adapter for use with 3/4” NPT conduit fittings. Catalog Numbers SAB12 SAB34 Boots 3P 4W, 30A, 480V AC HBL20425B Description “Mini” boot for Hubbellock connector body. “Mini” boot for Hubbellock plug. * Not UL Listed or CSA Certified. + Not CSA Certified. Catalog Numbers HBL20424B* HBL20425B* SEHBL3 B-78 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices HUBBELLOCK® Devices 3 Pole, 4 Wire Grounding 60 Ampere, 600 Volts AC Receptacles, Plug, Connector Body and Flanged Devices IP30 SUITABILITY X X GR 1.75" (44.5) GR Y Y Z Z 60A 600V 60A 600V 1.84" (46.7) 3.63" (92.2) Receptacles IP44 SUITABILITY Description Black phenolic interior with short aluminum housing and lift cover. Black phenolic interior with long aluminum housing and lift cover. Catalog Numbers HBL26410 – HBL26420 3.50" sq. 2.88" (88.9) (73.2) – .25 DIA. HBL26410 Connector Body Description Black phenolic interior with yellow thermoplastic sleeve over steel cover. Note: Cord clamp range .92”-1.45” (23.36-36.83). Flanged Receptacle 4.88" (124.0) Catalog Number HBL26418 – 3.50" sq. 2.88" (88.9) (73.2) IP44 SUITABILITY Description Black phenolic interior with steel housing and flange. Catalog Number HBL26421 – HBL26420 Plug 4.88" (124.0) 1.09" (27.7) Description Black phenolic interior with yellow thermoplastic sleeve over steel housing. Note: Cord clamp range .92”-1.45” (23.36-36.83). Catalog Number – HBL26419 3.19" (81.0) Flanged Inlet HBL26418 Description Black phenolic interior with steel housing and flange. Catalog Number – HBL26422 3.31" (84.1) 4.52" (114.8) Box and Adapter Plates 2.86" (72.6) Note: Straight or angle adapter plate must be used when mounting a 60A receptacle to HBL26401 box. HBL26421 4.81" (122.2) Kellems® Cable Grip Catalog Number H660A 4.50" (114.3) 3.88" (98.6) 3.03" (77.0) 4.50" (114.3) 3.88" (98.6) 2.88" 3.88" (73.2) (98.6) 4.50" (114.3) HBL26419 3.88" 4.50" (98.6) (114.3) 2.18" (55.4) Dimensions in Inches (mm) 2.73" (69.3) 3.94" (100.1) 4.13" (104.9) 3.50" (88.9) 2.69" (68.3) 4.50" 3.88" (114.3) (98.6) .22" (5.6) .41" (10.4) 2.88" (73.2) 3.53" (89.7) HBL26402 1.09" (27.7) 1.50" NPT HBL26401 www.hubbell-wiring.com HBL26422 B-79 3P 4W, 60A, 600V AC Cord Dia. .83”-1.00” (21.1-25.4) 4.50" (114.3) 3.88" (98.6) HBL26404 4.13" (104.9) 3.50" (88.9) 2.69" (68.3) Description Catalog Numbers Box, cast aluminum, only for 60A Hubbellock® receptacles.HBL26401 Straight adapter plate. HBL26402 45° adapter plate. HBL26404 Description Cable grip (not shown). 3.63" (92.2) Locking Devices HUBBELLOCK® Devices 4 Pole, 5 Wire Grounding 30 Ampere, 600 Volts AC, 20 Ampere, 250 Volts DC Receptacles, Plug and Connector Body 4- #6-32 SCREWS SUITABILITY Receptacles Description Black phenolic interior, aluminum housing, blue finish, for FS/FD box mounting. Black phenolic interior, aluminum weatherproof housing, blue finish, for FS/FD box mounting. IP44 SUITABILITY 4.56" 3.25" (115.8) (82.6) 1.66" (42.2) 2.48" (49.3) Z W Y GR W GR Y X X 30A 600V AC 20A 250V DC 30A 600V AC 20A 250V DC Catalog Numbers HBL25403 – HBL25250 – Connector Body HBL25403 4- #6-32 SCREWS Z IP30 2.84" (72.1) 1.88" (47.8 ) Description Black nylon housing, thermoplastic interior. Note: Cord clamp range .76”-1.20 ” (19.30-30.4). 3.00" (76.2) Catalog Number HBL25414B – Plug Description Black nylon housing, thermoset interior, steel shroud. Note: Cord clamp range .76”-1.20 ” (19.30-30.4). 4.56" 3.25" (115.8) (82.6) Catalog Number – HBL25415B Liquidtight Metallic Conduit Adapters Description Adapter for use with 1/2” NPT conduit fittings. Adapter for use with 3/4” NPT conduit fittings. 1.88" (47.8 ) 2.84" (72.1) HBL25250 .88" (22.4) 5.91" (150.1) 2.5" (63.5) 4P 5W, 30A, 600V AC, 20A, 250V DC Catalog Numbers SAB12 SAB34 2.69" (68.3) HBL25414B .88" (22.4) 4.75" (120.7) 2.50" (63.5) 2.33" (59.2) HBL25415B SAB12, SAB34 B-80 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices HUBBELLOCK® Devices 4 Pole, 5 Wire Grounding 60 Ampere, 600 Volts AC Receptacle, Plug, Connector Body and Flanged Devices IP30 X GR SUITABILITY X W W Y Z Description Black phenolic interior with long aluminum housing with lift cover and blue finish. IP44 SUITABILITY 3.63" (92.2) Z 60A 600V AC 60A 600V AC Receptacle 4.88" (123.9) GR Y Catalog Number HBL26520 – 3.50" (88.9) sq. 2.88" (73.2) HBL26520 Connector Body Description Black phenolic interior with blue thermoplastic sleeve over steel cover. Note: Cord clamp range 1.00”-1.50 ” (25.40-38.10). Catalog Number HBL26516 – 5.44" (138.2) 1.09" (27.7) 3.19" (81.0) Flanged Receptacle Description Black phenolic interior with steel housing and flange with blue finish. HBL26516 Catalog Number HBL26521 – 4.53" (102.13) Plug Description Black phenolic interior with blue thermoplastic sleeve and steel housing. Note: Cord clamp range 1.00”-1.50 ” (25.40-38.10). Catalog Number – HBL26519 2.86" 4.12" (72.6) (104.6) 2.69" (68.3) 3.31" (84.1) HBL26521 Flanged Inlet Description Black phenolic interior with steel housing and flange with blue finish. Catalog Number – HBL26522 Box and Adapter Plates Catalog Numbers HBL26401 HBL26402 HBL26404 Note: Straight or angle adapter plate must be used when mounting a 60A receptacle to HBL26401 box. 1.50" NPT Dimensions in Inches (mm) 3.94" (100.1) 3.50" (88.9) 4.13" (104.9) Catalog Number H660A HBL26522 4.50" (114.3) 3.88" (98.6) 3.88" 4.50" (98.6) (114.3) HBL26401 2.73" (69.3) 4P 5W, 60A, 600V AC Cable Range .83”-1.00” (21.1-25.4) 4.50" (114.3) 3.88" (98.6) 2.18" (55.4) HBL26519 2.69" (68.3) Cable Grip Description Cable grip (not shown). 1.09" (27.7) 3.03" (77.0) Description Box, cast aluminum, only for 60A Hubbellock® receptacles. Straight adapter plate. 45° adapter plate. Kellems® 4.81" (122.2) 4.50" (114.3) 3.88" (98.6) 2.88" 3.88" (73.2) (98.6) 4.50" (114.3) 4.50" 3.88" (114.3) (98.6) .22" (5.6) .41" (10.4) 2.88" (73.2) 3.53" (89.7) HBL26404 HBL26402 www.hubbell-wiring.com B-81 Locking Devices Not UL Listed, HUBBELLOCK® Devices 2 Pole, 3 Wire Grounding 20 Ampere, 125 Volts AC or DC, 10 Ampere, 250 Volts DC, 480 Volts AC Receptacle, Plug and Connector Body IP30 1.66" (42.2) Y Y GR GR SUITABILITY X X 20A 125V 20A 125V Receptacle 2.50" (63.5) 1.38" 2.38" (35.1) (60.5) 3.28" (83.3) Description Black phenolic, back wired. Catalog Number HBL23000G – Plug Description Nylon housing, thermoset interior. #6-32 TAP HBL23000G Connector Body Not UL Listed 2P 3W, 20A, 125V AC or DC, 10A, 250V DC, 480V AC 2.31" (58.7) 1.72" (43.7) 3.22" (81.8) Description Catalog Number Nylon housing, thermoset interior. HBL23002GB Note: Cord clamp range for plug and connector .32”-.66” (8.12-16.5). – Accessories Weatherproof Covers HBL23005GB 3.56" (90.4) 1.72" (43.7) Catalog Number – HBL23005GB 1.63" (41.4) Description Gray polycarbonate for FS/FD box mounting, corrosion resistant. IP44 SUITABILITY. Same as above except yellow. Cast aluminum, lift cover for indoor use only (not shown). Catalog Numbers HBL7423WO HBL74CM23WO HBL23007 HBL23002GB B-82 www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices and Watertight Safety Shroud Devices Technical Information 15-30 Ampere Twist-Lock, 20-30 Ampere Safety-Shroud Twist-Lock Specifications Listings Listed to UL Standard 498 (Attachment Plugs and Receptacles). Fed. Spec W-C-596 (Insulgrip and Safety-Shroud). Certified to CSA Standard C22.2 No.42 (General Use Receptacles, Attachment Plugs and Similar Wiring Devices). Materials Part Plugs and Connector Bodies (Insulgrip®) Blade/Contact Carrier Terminal Retainer Cover (Housing) Cord Clamp Dust Shield Blades/Contacts Terminal Clamp Terminal Screws Grounding Screw Cord Clamp Screws Body Holding Screws Materials Part Materials 20-30A 15-30A Safety-Shroud Receptacles Angle, Surface Semi-Flush Housing and Mounting Flange Mounting Plate (Angle Housing Only) Body Contact Carrier Terminal Retainer Body Holding Screws Contact Springs Spring Binding Plate Terminal Clamp Gray Valox® Galvanized steel Natural (white) nylon Clear polycarbonate Black nylon (yellow in “CM” devices) Natural (white) nylon EPDM Brass Cold rolled steal – nickel plated 15A (8-32), 20-30A (10-32) Brass (white finish on neutral screw when used) Brass (green finish) Steel – zinc plated Steel – zinc plated Flanged Inlet/Receptacles 15-30A Flanged Casing Blade/Contact Carrier Terminal Retainer Blades/Contacts Drive Screws Terminal Clamp Terminal Screws Natural (white) nylon Natural (white) nylon Clear polycarbonate Brass Steel – zinc plated Cold rolled steel – nickel plated 15A (8-32), 20-30A (10-32) Brass (white finish on neutral screw when used) Brass (green finish) Nickel plated brass Round head screws 15A: 6-32, 3/8” long 20A & 30A: 8-32, 7/16” long Grounding Screw Mounting Screws Screw Sizes 15A Cover(Top) Base Contact Springs Clamp Ground Contact Ground Shunt Bridge (Mounting Strap) Nylon (Black) Nylon (Black) RTP (Black) RTP (Natural) .031” Brass .040” Brass .031” Brass .040” Brass .031” Brass .040” Brass – .015” Brass .050” Steel-zinc – plated – .050” Brass – .040” Brass Brass (8-32) Brass (10-32) (white finish on neutral screw when used) Brass (Green) Bronze (Green) Steel-zinc plated Steel-zinc plated Stainless steel Stainless steel (Used only on IG receptacle) End Plates (Mounting) Back Plate Terminal Screws Grounding Screw Flat Head Mounting Screws Auto Ground Clip 20A & 30A Grounding Screw Mounting Plate Screws Wall Plate Mounting Screws Safety-Shroud Twist-Lock Plug 20-30A Insulgrip Plug with Safety-Shroud installed Safety-shroud White Valox Cord Clamp White nylon Performance Electrical Dielectric Voltage Max. Working Voltage Current Interrupting Temperature Rise Fed. Spec. Mechanical Cord Accommodation (Plugs and connectors only) Cord Grip Accommodation (Insulgrip) Terminal Identification Terminal Accommodation Product Identification Round portable service cords of diameters commensurate with the device rating as defined in UL Standard 62, CSA C22.2 No. 49. 15A: .230”-.720” (5.8-18.3); 20A & 30A 3W: .360”-.930” (9-24); 20A & 30A 4W-5W: .350”-1.150” (9-29). Terminals identified in accordance with UL 498 (X, Y, Z, White, Green). 20A & 30A,#16- #8 AWG. 15A, #18-#10 AWG Ratings are a permanent part of the device housing. Environmental Flammability (Enclosure) Plugs, Connectors, Flanged Receptacles & Flanged Inlets Receptacles (Box Mount) Operating Temperatures ®Valox Dimensions in Inches (mm) Withstands 2,000V minimum. 600 Volts RMS. Certified for current interrupting at full rated current. Max 30°C temperature rise at full rated current after 250 cycles of overload at 200% of rated current at a power factor of 75%.(WC 596) HB or better per UL94/CSA 22.2 No. 0.17. Specifications Receptacle, Single Terminal Screws Natural (white) nylon Clear polycarbonate Steel, zinc plated Brass Brass Steel, nickel plated .080” curved, scalloped 10-32 Brass (white finish on neutral screw when used) Brass (green finish) Steel, zinc plated Steel, zinc plated V2 or better. Maximum Continuous 75° C Minimum -40° C (w/o impact). is a registered trademark of General Electric Company. www.hubbell-wiring.com B-83 Locking Devices Watertight Safety-Shroud TWIST-LOCK® Devices Specifications 20 & 30 Ampere Specifications Listings Listed to UL Standard 498 (Attachment Plugs and Receptacles). Certified to CSA Standard No.42 (General Use Receptacles, Attachment Plugs and Similar Wiring Devices). Fed. Spec. WC-596. UL Listed, CSA Certified to Type 4, 4X and Type 12. Part Watertight Safety-Shroud™ Plug (Insulgrip®) Materials 20 and 30A Blade Holder Terminal Retainer Cover (Housing) Cord Clamp Blades Terminal Clamp Terminal Screws Grounding Screw Cord Clamp Screws Body Holding Screws Closure Cap and Strap Natural (white) nylon Clear polycarbonate Black Valox® White Valox Brass Steel, nickel plated .080” curved scalloped 10-32 brass (white finish on neutral screw when used) multiple drive head Brass (green finish) combination head Stainless steel 302/304, combination head Stainless steel 302/304, combination head Neoprene EPDM Blend Watertight Safety-Shroud Connector (Insulgrip) 20 and 30A Body Contact Carrier Terminal Retainer Contact Spring Spring Binding Plate Cover (Housing) Cord Clamp Terminal Clamp Terminal Screws Grounding Screw Cord Grip Screws Body Holding Screws Closure Cap and Strap Natural (white) nylon Clear polycarbonate Brass Brass Black Valox White Valox Steel, nickel plated .080” curved scalloped 10-32 brass (white finish on neutral screws when used) multiple drive head Brass (green finish) combination head Stainless steel 302/304, combination head Stainless steel 302/304, combination head Polypropylene with Neoprene gasket *Watertight Safety-Shroud Receptacle, Single 20 and 30A Housing and Flange Body Contact Carrier Terminal Retainer Drive Screws Contact Spring Spring Binding Plate Terminal Clamp Flange Gasket Lid Gasket Cover Hinge Pin Cover Spring Terminal Screws Grounding Screw Mounting Screws Gray Valox Natural (white) nylon Clear polycarbonate Steel, zinc plated Brass Brass Steel, nickel plated .080” curved, scalloped Closed-cell neoprene foam Closed-cell neoprene foam Stainless steel 302/304 Stainless steel 302/304 10-32 brass (white finish on neutral screw when used) multiple drive head Brass (green finish) combination head Stainless steel 302/304 combination head Watertight Safety-Shroud Flanged Inlet 20 and 30A Housing and Flange Blade Holder Terminal Retainer Blades Drive Screws Terminal Clamp Terminal Screws Grounding Screw Closure Cap Mounting Screws Gray Valox Natural (white) nylon Clear polycarbonate Brass Steel, zinc plated Steel, nickel plated .080” curved scalloped 10-32 brass (white finish on neutral screw - when used) multiple drive head Brass (green finish) combination head Neoprene EPDM blend Stainless steel 302/304 combination head Performance Electrical Dielectric Voltage Max. Working Voltage Current Interrupting Temperature Rise Withstands 2,000V minimum. 600 Volts RMS. Certified for current interrupting at full rated current. Max 30 deg. temperature rise at full rated current after 250 cycles of overload at 200% of rated current at a power factor of 75%.(WC 596) Mechanical Specifications Cord Accommodation (Plugs and connectors only) Cord Grip Accommodation Terminal Identification Terminal Accommodation Product Identification Round portable service cords of diameters commensurate with the device rating as defined in UL Standard 62, CSA C22.2 No. 49. 20 and 30A, 3W: .32”-.93” (8.0-24.0mm) #16-3 Type SJ-#8-3 Type S,SO; 20 and 30A, 4W: .35”-1.15” (9.0-29.0mm) #16-4 Type SJ-#8-4 Type S, SO; 20 and 30A, 5W: .35”-1.15” (9.0-29.0mm) #16-5 Type S,SO - #8-5 Type S,SO. Terminals identified in accordance with UL 498 (X, Y, Z, White, Green). #16- #8 AWG solid or stranded wire. Ratings are a permanent part of the device blade holder, and are also labeled on device color coded by voltage, visible in use. Catalog No. I.D. is on device visible in use. Environmental Moisture Resistance Flammability (Enclosure) Operating Temperatures Type 4, 4X, 12, IP66 suitability. V0 per UL94 or CSA 22.2 No. 0.17 Maximum Continuous 75°C; Minimum -40°C (w/o impact). *Suitable for use as a flanged receptacle. ®Valox B-84 is a registered trademark of General Electric Company. www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices TWIST-LOCK® Devices Technical Information 50 Ampere TWIST-LOCK Listing and Specifications Specifications Listings Listed to UL Standard 498 (Attachment Plugs and Receptacles). Certified to CSA Standard No. 42 (General Use Receptacles, Attachment Plugs and Similar Wiring Devices). Materials Part Materials Part Materials Plug (Twist-Lock) Blade Holder Power Blades Terminal Set Screw Terminal Retainer Front & Rear (housing) Cord Clamp 50A Rynite® (black) Brass Stainless steel Rynite Supertough nylon Rynite (white) Ground Contact Seal Cup Cord Grip crews Seal Flanged Inlet Flanged Casing Blade Holder One piece copper/nickel Nylon 302/304 Stainless steel Neoprene 50A .062” Steel, zinc plate Phenolic Seal Seal Cup Box Terminal Latches Ground Contact Spring Cord Clamp Screws Shroud Connector (Twist-Lock) Contact Nose Terminal Retainer Terminal Set Screw Contact Spring Assembly Ring Front & Rear (housing) Latches Cord Clamp Box Terminal Contact Holder Neoprene Nylon Copper Supertough nylon One piece copper/nickel 302/304 Stainless steel 302/304 Stainless steel 50A Nylon (black) Rynite (black) 302/304 Stainless steel Brass 302/304 Stainless steel Supertough nylon (black) Supertough nylon (white) Rynite (white) Copper Rynite (black) Pressure Screws Blades Ground Spring Terminals Grounding Terminal Round Head Screws Receptacle Body Face Contact Springs Contact Binding Plates Ground Contact Insulator Bridge (Mounting Strap) Pressure Screws Terminals Casing Center Pin (CS Devices) Steel, zinc plate .100” Brass .025” Bronze .050” Steel, brass finish .062” Copper, green finish Steel, zinc plate 50A Phenolic Phenolic .100” Brass alloy .100” Brass .031” Brass .093” Laminated phenolic .062” Steel, zinc plate Steel, zinc plate .050” Steel .062” Steel, zinc plate Steel, zinc plate Product Identification Ratings Catalog No. Molded into face for all devices and stamped into stainless steel shroud on plug devices. Molded into face for plug and connector bodies and stamped into stainless steel shroud on plug devices. Performance Electrical Dielectric Voltage Max. Working Voltage Current Interrupting Temperature Rise #10 AWG min. -#6 AWG max. .750”-1.150” (19.1-29.2). Environmental Flammability UL 94 V0 for Receptacles and Inlets. HB or better for Plugs and Connectors. Operating Temperatures Maximum continuous 75°C; minimum – 40°C (w/o impact). Please consult the factory for product dimensions and specifications for other products listed in this catalog. Rynite is a registered trademark of E. I. Dupont. Dimensions in Inches (mm) www.hubbell-wiring.com B-85 Specifications Mechanical Terminal Accommodation Cord Grip Accommodation Withstands 2,000V minimum. 600 Volts RMS. Certified for current interrupting at full rated current. Max. 30°C temperature rise at full rated current after 50 cycles of overload at 150% rated DC current (UL 498) Locking Devices Switched Safety Enclosures Technical Information Switched TWIST-LOCK® and HUBBELLOCK® Enclosures Specifications Typical Specifications Manufacturer’s Identification Description Electrical Type Rating Configuration Enclosure Type Enclosure Material Materials Part Base Top Handle Conduit Hub Enclosure Gasket Shaft Shaft Seal Frame Lift Cover Enclosure Screws Hinge Spring and Pin Hubbell SETL3/SEHBL3-SE2730A. Lockable Switched Enclosure.This unit is a complete enclosure ready to accept any 20 or 30A Twist-Lock or 30A Hubbellock receptacle. 2 Pole + Earth through 4 Pole & Earth. 20 or 30A, 125V through 3ØY 347/600V AC. NEMA Locking L5-20R through L23-30R. Outdoor – Type 3R (Rainproof, Sleet, External Ice), IP54 suitability. Indoor – Type 12K (Dust-tight, Falling Dirt, Noncorrosive Liquids, with Knockout). Non-metallic enclosure suitable for metallic conduit. Materials Valox®/Makroblend® Valox/Makroblend Valox/Makroblend Zinc 3 /4” watertight Neoprene Valox/Makroblend Molded neoprene Galvanized steel Valox/Makroblend Stainless steel 300 series Stainless steel 300 series Performance Electrical Dielectric Voltage Max. Working Voltage Current Interrupting Short Circuit Withstand Operations Mechanical Impact Resistance Terminal Identification Product Identification Weight Mounting Environmental Moisture Resistance Specifications Flammability Operating Temperature UV Resistance Withstands 3,000V minimum. 600V RMS. Certified for current interrupting at full rated current and voltage. Suitable for use on a circuit capable of delivering not more than 10,000 RMS symmetrical amperes at the voltage rating of the receptacle. Mechanical 10,000 cycles; electrical 6,000 cycles. In accordance with UL 746C. In accordance with UL, CSA and international conventions. Identification and ratings are part of external label and receptacle face. 3.5 pounds. External fully adjustable feet. Outdoor – Type 3R (Rainproof, Sleet, External Ice), IP54 suitability. Indoor – Type 12K (Dust-tight, Falling Dirt, Noncorrosive Liquids, with Knockout). UL94 – 5 VA and V0 classification. Maximum continuous +75°C. Minimum continuous -40°C. All materials are UV stabilized. This device provdes on/off switched control of a plug connected load and includes lockout provision: ON-OFF control knob (in the OFF position) accepts up to a 5 /16 inch (8.0) diameter shackle of suitable padlock lockout device to isolate energy from the receptacle and cord connected equipment as a method of compliance to OSHA Lockout/Tagout Regulation 29CRF Part 1910.147. ®Makroblend ®Valox B-86 is a registered trademark of Miles. is a registered trademark of General Electric Company. www.hubbell-wiring.com Dimensions in Inches (mm) Locking Devices Switched Safety Enclosures Technical Information CIRCUIT-LOCK® Unfused Safety-Shroud TWIST-LOCK Mechancial Interlock Specifications Typical Specifications Manufacturer’s Identification Description Electrical Type Rating Enclosure Type Enclosure Material Materials Part Base Top Handle Conduit Hub Enclosure Gasket Shaft Shaft Seal Frame Enclosure Screws Hubbell HBLMITL. CIRCUIT-LOCK Mechanical Interlock. 2 Pole + Earth through 4 Pole & Earth. Up to 30A, 600V AC 3Ø. Outdoor-4X (Watertight, Washdown); Indoor-12K (Dust-tight, Falling Dirt and noncorrosive liquids with knockout. IP66 suitability. Non-metallic enclosure suitable for metallic conduit. Material Valox® Valox Valox Zinc 3 /4” watertight Neoprene Valox Neoprene Galvanized steel Stainless steel 300 series Performance Electrical Dielectric Voltage Max. Working Voltage Current Interrupting Short Circuit Withstand Rating Operations Mechanical Impact Resistance Terminal Identification Product Identification Weight Mounting Environmental Moisture Resistance Flammability Operating Temperature UV Resistance In accordance with UL 746C. In accordance with UL, CSA. Identification & ratings are part of the external label & receptacle face. 3.5 pounds. External full adjustable feet. Outdoor – 4X (Hose-Directed Water, Corrosion Resistance), IP66 suitability. Meets UL 94V0 material classification. Maximum continuous +75°C; Minimum continuous -40°C. All exposed materials are UV stabilized. Specifications ®Valox Withstands 3,000V Min. 600V RMS. Certified for current interrupting at full rated current voltage. Suitable for use on a circuit capable of delivering not more than 10,000 RMS symmetrical amperes at the voltage rating of the receptacle. Mechanical 10,000 cycles; Electrical 6,000 cycles. is a registered trademark of General Electric Company. Dimensions in Inches (mm) www.hubbell-wiring.com B-87 Locking Devices TWIST-LOCK® Devices Technical Information VALISE® Plugs and Connectors Specifications Plugs Typical Specification- Catalog No. HBL4723VY. Manufacturer’s Identification - Hubbell HBL4723VY. Description - Straight Body Plug Type – 2 Pole, 3 Wire, Grounding Rating – 15 and 20A 125V, 250V, & 277V AC, 30A 125 & 250V Certification – UL Listed File E1706, CSA Certified File LR280C IP Suitability – IP20 Part Plug Housing Blades Ground Blade Terminal Screws Cable Inserts Terminal Clamps Body Holding Screws Description 15, 20 & 30A Nylon Brass Brass Steel multiple drive Polyphenylene Oxide CR Steel Steel multiple drive Connector Bodies Part Connector Typical Specification- Catalog No. HBL4729VY Manufacturer’s Identification - HBL4729VY Connector Housing Contact and Ground Springs Terminal Screws Cable Inserts Terminal Clamps Body Holding Screws 15, 20 & 30A Nylon Brass Steel multiple drive Polyphenylene Oxide CR Steel Steel multiple drive Description – Straight Body Connector Type – 2 Pole, 3 Wire, Grounding Rating – 15 and 20A 125V, 250V, & 277V AC, 30A 125 & 250V Certification – UL Listed File E1706, CSA Certified File LR280C IP Suitability – IP20 Performance Electrical Dielectric Voltage Max. Working Voltage Current Interrupting Temperature Rise Specifications Mechanical Terminal Identification Terminal Accommodation Withstands 2,000V minimum. 125V, 250V or 277V AC as rated. Certified for full rated current. Max. 30°C temperature rise at full rated current after 50 cycles of overload at 150% rated DC current. Product Identification Torque Screw Color per UL 498 (Brass, White & Green). 15A-18 to 12AWG. 20A-18 to 10AWG. 30A-14 to 8AWG. Molded rating on device face. 12 in-lb terminal screws, 7 in-lb assembly screws. Cord Range 15A 20A 30A .220” to .660” (5.6mm to 16.8mm). .325” to .720” (8.26mm to 18.3mm). .590” to .930” (15.0mm to 23.6mm). Environmental Flammability Operating Temperature UL 94HB. Maximum continuous 75°C, minimum -40°C (w/o impact). Standards NEMA WD1 NEMA WD6 Listed to UL Standard UL498 Certified to CSA Standard C22.2 No. 42 B-88 www.hubbell-wiring.com Dimensions in Inches (mm)
HBL2320 价格&库存
很抱歉,暂时无法提供与“HBL2320”相匹配的价格&库存,您可以联系我们找货
