HBL2325SW
HBL2325SW
    HUBBELL(哈伯尔公司)
HBL2325SW 数据手册
Section F Switched Disconnects and Enclosures Index Product Page Circuit-Lock® Unfused Disconnect Switches Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . F-2 Ratings Quick Reference Guide . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . F-3 Labelless Circuit-Lock® Unfused Disconnect Switches 30, 60 and 100 Amp Units . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . F-5 Accessories and Replacement Parts . . . . . . . . . . . . . . . . . . . . . . . . . . . . F-6 Dimensions and Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . F-7 MotorQuick® Disconnect Switches Cost of Ownership Analysis . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . F-8 Labelless Disconnect Switches and Accessories . . . . . . . . . . . . . . . . . . F-9 Dimensions and Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . F-10 Fused Disconnects, MotorQuick® and VFDs Circuit-Lock® Fused Disconnect Switches 30 and 60 Amp Units. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . F-12 Horsepower Ratings and Specifications. . . . . . . . . . . . . . . . . . . . . . . . . F-13 Hazardous Locations Unfused Disconnect Switches . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . F-15 AC Manual Toggle Controllers/Disconnects 600V AC Manual Motor Controllers/Disconnects. . . . . . . . . . . . . . . . . . F-17 NEMA 1 Disconnect Switches . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . F-18 NEMA 3/3R and 3R Disconnect Switches . . . . . . . . . . . . . . . . . . . . . . . . . F-19 Hazardous Locations 30 Ampere, 600 Volts AC Manual Motor Controllers . . . . . . . . . . . . . . . . F-20 40, 50, 60 and 85 Ampere, 600 Volts AC Manual Motor Controllers . . . . F-21 NEMA 4X Disconnect Switches . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . F-22 Pendant Pushbutton Stations CPB2 and PBS Series . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . F-23 Accessories and Replacement Parts . . . . . . . . . . . . . . . . . . . . . . . . . . . F-24 NEMA 1, 3/3R and 4X Disconnect Switches www.hubbell-wiring.com ® Wiring Device-Kellems F-1 Hubbell’s Circuit-Lock® Manual Motor Controllers "Suitable as Motor Disconnects" Hubbell manufactures one of the most complete lines of motor disconnects on the market. Designed to ensure maximum reliability and performance, Hubbell Circuit-Lock® motor controllers meet or exceed all industry requirements. Because our Circuit-Lock® motor controllers are also disconnects, they ensure safety, compliance, flexibility and productivity for today’s industrial and commercial environments. Whether controlling motor loads, safely terminating power or isolating equipment, Hubbell has the solution for you—no matter what the environment or application. Hubbell Safety Safety of personnel and equipment is paramount in any manufacturing environment. Hubbell Circuit-Lock® motor controllers withstand short circuits and provide a high degree of safety across the factory floor. Disconnect Switches for Variable Frequency Drives (VFDs) safely terminate power to prevent risk of injury and damage to highperformance output devices used for controlling today’s conveyor systems. Hubbell Flexibility Hubbell Productivity With Hubbell’s wide range of Circuit-Lock® motor controllers and disconnects that offer several mounting options, NEC® line of sight requirements are easily achieved at the equipment or on the wall in virtually any industrial environment. Switches with a compact footprint, a variety of NEMA® type enclosures and plug-and-play LINKOSITY® make switch placement easier and more flexible than ever. Circuit-Lock® keeps assembly lines, goods and services moving. By offering a dual motor controller-disconnect rating, power can be safely terminated at any point in the circuit to perform maintenance on a single motor without shutting down the entire line. With the plug-and-play LINKOSITY® power system, MotorQuick® reduces motor change-out time by more than 65% to get equipment up and running faster. Variable Frequency Disconnects Hubbell Compliance Compliance with codes and regulations is a must in any industrial environment. Hubbell motor controllers meet a variety of requirements, including OSHA lockout/tagout, NSF certification for hygiene and hazardous location ratings. Each Circuit-Lock® motor controller is UL listed as “Suitable as Motor Disconnect”. The NEC® allows for the disconnect and controller to be in one unit. Each Controller is Also a Disconnect NEC® is a registered trademark of the National Fire Protection Association (NFPA). NEMA® is a registered trademark of the National Electrical Manufacturers Association. F-2 ® Wiring Device-Kellems www.hubbell-wiring.com Switched Disconnects and Enclosures Hubbell Manual Motor Controllers and Disconnects "Suitable as Motor Disconnects" Ratings Quick Reference Guide Circuit-Lock® Switched Enclosures Amp Description 30 TYPE 1 Non-Metallic TYPE 1 Non-Metallic TYPE 1 Non-Metallic NEMA 1 Aluminum NEMA 1 Aluminum NEMA 1 Non-Metallic NEMA 1 Non-Metallic NEMA 3/3R Non-Metallic NEMA 3/3R Non-Metallic NEMA 3R Die Cast Aluminum NEMA 3R Die Cast Aluminum NEMA 3R Aluminum NEMA 3R Aluminum IP69k TYPE 4X Labelless Non-Metallic IP69k TYPE 4X Labelless Non-Metallic IP69k TYPE 4X Labelless Non-Metallic IP69k TYPE 4X Labelless Non-Metallic IP69k TYPE 4X Labelless Non-Metallic IP69k TYPE 4X Labelless Non-Metallic TYPE 4X Labelless Non-Metallic TYPE 4X Labelless Non-Metallic TYPE 4X Labelless Non-Metallic IP69k TYPE 4X Stainless Steel IP69k TYPE 4X Stainless Steel IP69k TYPE 4X Stainless Steel TYPE 4X Stainless Steel TYPE 4X Stainless Steel TYPE 4X Non-Metallic Fused Disconnect NEMA 4X Stainless Steel NEMA 4X Non-Metallic 60 NEMA 3R Aluminum NEMA 3R Aluminum IP69k TYPE 4X Non-Metallic IP69k TYPE 4X Non-Metallic IP69k TYPE 4X Stainless Steel IP69k TYPE 4X Stainless Steel TYPE 4X Non-Metallic Fused Disconnect NEMA 4X Stainless Steel NEMA 4X Non-Metallic 100 IP69k TYPE 4X Non-Metallic IP69k TYPE 4X Non-Metallic IP69k TYPE 4X Stainless Steel IP69k TYPE 4X Stainless Steel Phase Poles 3 3 3 1 3 1 3 1 3 1 3 1 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 1 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 2 3 2 3 2 3 2 3 2 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 2 3 3 3 3 3 3 3 3 3 3 3 3 120 240 HP 480 600 Catalog Number 3 3 3 2 3 2 3 2 3 2 3 2 3 1 1 1 1 1 1 1 1 1 1 1 1 2 1 1 3 3 — — 7.5 7.5 7.5 7.5 3 — — 7.5 7.5 7.5 7.5 7.5 7.5 7.5 5 7.5 5 7.5 5 7.5 5 7.5 5 7.5 7.5 7.5 7.5 7.5 7.5 5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 10 10 30 30 30 30 15 10 10 30 30 30 30 15 15 15 10 15 10 15 10 15 10 15 10 15 15 15 15 15 15 10 15 15 15 15 15 15 15 15 15 15 15 15 25 50 50 50 50 30 25 25 50 50 50 50 20 20 20 15 20 15 20 15 20 15 20 15 20 15 15 15 15 15 10 15 15 15 15 15 15 15 15 20 20 20 20 30 50 50 50 50 40 30 30 50 50 50 50 HBL1389MQR HBL1389MQ5 HBL1389MQR2 HBL1372D HBL1379D HBL1392D HBL1389D HBL13R22D HBL13R23D HBL13R12D HBL13R13D HBL13R92D HBL13R89D HBLDS3 HBLDS3AC HBLDS3AC2 HBLDS3NK HBLDS3ACNK HBLDS33ACNK HBLDS3MQR HBLDS3MQ5 HBLDS3MQR2 HBLDS3SS HBLDS3SSAC HBLDS3SSVFD HBLDS3SSMQR HBLDS3SSMQ5 FDS30 HBL13S33D HBL13X33D HBL16R92D HBL16R93D HBLDS6 HBLDS6AC HBLDS6SS HBLDS6SSAC FDS60 HBL16S63D HBL16X63D HBLDS10 HBLDS10AC HBLDS10SS HBLDS10SSAC 120 240 HP 480 600 Catalog Number 2 2 2 3 3 2 3 2 3 — — — — — — — 5 5 5 7.5 7.5 5 7.5 5 7.5 — 10 10 10 10 10 10 10 10 10 15 15 10 15 10 15 — 15 25 15 25 15 25 15 15 15 20 20 15 20 15 25 — 20 30 20 30 20 40 HBL7832D HBL7832DS HBL7832DX HBL7810D HBL7810DS HBL7842D HBL7843D HBL7852D HBL7853D HBLFG30 HBL7862D HBL7863D HBL7862FWD HBL7863FWD HBL7882D HBL7883D HBL1379D HBL13R89D HBLDS3 HBL16R93D HBL13S33D FDS30 HBLDS3SS HBLDS3SSR HBLDS3MQR HBLDS3MQ5 Circuit-Lock® Switches Amp 30 40 50 — 60 85 Description Toggle Switch Short Toggle Switch Toggle Switch, Bulk Pack Toggle Switch Short Toggle Switch Toggle Switch Toggle Switch Toggle Switch Toggle Switch Finger guard (30–50A Switches) Toggle Switch Toggle Switch Toggle Switch – Front Wire Toggle Switch – Front Wire Toggle Switch Toggle Switch www.hubbell-wiring.com Phase Poles 1 1 1 3 3 1 3 1 3 — 1 3 1 3 1 3 2 2 2 3 3 2 3 2 3 — 2 3 2 3 2 3 ® Wiring Device-Kellems HBL7810D HBL7853D HBL7862D HBL7863D F-3 Switched Disconnects and Enclosures IP69k Circuit-Lock® Unfused Disconnect Switches Features and Benefits Labelless Circuit-Lock® 30, 60, and 100 Ampere Unfused Disconnect Switches NEC section 430.102(B) requires each motor controller to have a disconnect within line of sight from the motor and driven equipment. NEC section 430.109(A)(6) recognizes that a manual motor controller and disconnect can be the same unit, provided it has been tested for this purpose. Hubbell’s Circuit-Lock® Unfused Disconnect Switches are UL listed as a manual motor controller and also “suitable as a motor disconnect” and meet these code requirements. In addition, the enclosure offers the ability to lock directly wired motor loads in the OFF position to comply with OSHA Lockout/Tagout regulations. This safety enclosure is Type 4X (Wash down, Corrosion resistant) IP69k and is also suitable for use with metallic conduit. The switch is mounted on an internal frame that is integral with the enclosure and bonds all grounds, and it accepts auxiliary contacts that can be used to signal PLC controllers. Product ratings are laser-marked into the device and will not wash off for permanent identification Stainless steel hardware for corrosion resistance Molded-in conduit opening and field installed hub High visibility red handle can be locked in the OFF position as a method of compliance with OSHA Lockout/ Tagout requirements Internal frame automatically bonds all grounds Reversible interior accommodates top or bottom conduit opening Captured neoprene gasket provides a watertight seal between cover and base Type 4X, 12 and IP69k enclosure is molded of rugged Valox® to resist abuse, corrosion and enhance safety HBLDS3 Three molded-in conduit drill points are located on the top, bottom, and back surface of enclosure IP69k Labelless Circuit-Lock® Unfused Disconnect Switches are available in 30, 60 and 100 Amp, 600V AC ratings. Auxiliary contacts are available for control circuit applications including the ON/OFF control of pilot lights or signal for programmable controllers. Conduit hub and adjustable mounting feet are supplied for ease of installation. Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. F-4 ® Wiring Device-Kellems www.hubbell-wiring.com Switched Disconnects and Enclosures IP69k Circuit-Lock® Unfused Disconnect Switches UL Listed, CSA Certified TYPE 4, 4X and 12 Enclosure Rating “Suitable as Motor Disconnects” Labelless Circuit-Lock® Unfused Disconnect Switches in Non-Metallic Enclosures* Description 30 Amp 60 Amp 100 Amp Labelless disconnect switch. Labelless disconnect switch for use with variable frequency drives. Labelless disconnect switch with HBLAC1 auxuliary contact. Labelless disconnect switch with HBLAC2 auxuliary contact. Labelless disconnect switch without conduit knockout or conduit fitting. Labelless disconnect switch with HBLAC1 auxuliary contact without conduit knockout or conduit fitting. Labelless disconnect switch with 3 auxuliary contacts, without conduit knockouts. Break before main break – 1 set “normally open”, 1 set “normally closed”. Break after main break – 2 sets “normally open”, 1 set “normally closed”. HBLDS3 HBLDS3VFD HBLDS6 HBLDS6VFD HBLDS10 HBLDS10VFD HBLDS3AC HBLDS6AC HBLDS10AC HBLDS3AC2 — — HBLDS3NK — — HBLDS3ACNK — — HBLDS33ACNK — — HBLDS3AC Circuit-Lock® Unfused Disconnect Switches in Stainless Steel Enclosures* Description 30 Amp 60 Amp 100 Amp Square Top disconnect switch. Square Top disconnect switch for use with variable frequency drives. Square Top disconnect switch with HBLAC1 auxuliary contact. Sloped Top disconnect switch. Sloped Top disconnect switch for use with variable frequency drives. Sloped Top disconnect switch with HBLAC1 auxuliary contact. HBLDS3SS HBLDS3SSVFD HBLDS6SS HBLDS6SSVFD HBLDS10SS HBLDS10SSVFD HBLDS3SSAC HBLDS6SSAC HBLDS10SSAC HBLDS3SS HBLDS3SSR HBLDS6SSR HBLDS10SSR HBLDS3SSRVFD HBLDS6SSRVFD HBLDS10SSRVFD HBLDS3SSRAC HBLDS6SSRAC HBLDS10SSRAC Auxiliary Contacts for 30, 60 and 100 Amp Switch, NEMA A600 Pilot Duty Description Catalog Number “Break After Main Break”, 1 set of n/o contacts, 1 set of n/c contacts. “Break Before Main Break”, 1 set of n/o contacts. HBLAC1** HBLDS3SSR HBLAC2** Note: *Certified by NSF, International. **Up to two auxiliary contacts per enclosure. Not for use with HBLDS33ACNK. 30A Units are supplied with one ¾ in. NPT Raintight conduit fitting. 60A and 100A Units are supplied with two 1¼ in. NPT Raintight conduit fittings. HBLAC1 Variable Frequency Drive Diagram HBLAC2 www.hubbell-wiring.com ® Wiring Device-Kellems F-5 Switched Disconnects and Enclosures Circuit-Lock® Unfused Disconnect Switches “Suitable as Motor Disconnects” IP66 SUITABILITY Labelless Replacement Covers HBLDS3RC Description 30 Amp 60 Amp 100 Amp For non-metallic switches. HBLDS3RC HBLDS6RC HBLDS10RC For square top stainless steel switches. HBLDS3SSRC HBLDS6SSRC HBLDS10SSRC For sloped top stainless steel switches. HBLD3SSRRC HBLD60100SSRRC HBLD60100SSRRC Replacement Ground Block Description Catalog Number For 30A switches. HBL30RGB For 60A and 100A switches. HBL60100RGB Replacement Neutral Block HBLDS3SSRC Description Catalog Number For 30A switches. HBL30RNB For 60A switches. HBL60RNB For 100A switches. HBL100RNB Replacement Switches HBLD3SSRRC Description Catalog Number For 30A switches. HBLDS3RS For 60A and 100A switches. HBLDS60100RS For HBLDS33ACNK. HBLDS33ACRS Replacement Mounting Feet Description Catalog Number For 30A non-metallic switches. HBLRFT1∆ For 60A and 100A non-metallic switches. HBLRFT2 ∆ Note: ∆ Package of 10 feet and 10 screws. HBL30RGB HBL30RNB HBLDS3RS HBLRFT1 F-6 ® Wiring Device-Kellems www.hubbell-wiring.com Switched Disconnects and Enclosures Circuit-Lock® Unfused Disconnect Switches Dimensions and Specifications Dimensions Horsepower Ratings Labelless Non-Metallic 30A Key inch (mm) 60A/100A inch (mm) Stainless Steel, Square Top 30A inch (mm) 60A/100A inch (mm) Stainless Steel, Sloped Top 30A inch (mm) 60A/100A inch (mm) — — A 6.00 (152) 7.75 (197) B 5.12 (130) 6.87 (175) 4.87 (124) 7.30 (185) 5.41 (137) 7.66 (195) C 4.12 (105) 4.75 (121) 3.30 (84) 5.50 (140) 4.50 (114) 6.45 (164) D 6.62 (168) 8.00 (203) — — — E 7.62 (194) 9.95 (253) 7.05 (179) 10.30 (262) 8.60 (218) 11.41 (290) F 8.50 (216) 11.00 (279) 8.38 (213) 11.63 (296) 8.22 (209) 11.17 (284) G 4.12 (105) 5.94 (151) 5.39 (137) 5.93 (151) 4.92 (125) 6.10 (155) — Non-Metallic — — Stainless Steel, Square Top Voltage 30A 30A* 60A 100A 1Ø 120V AC 1 1 7.5 7.5 1Ø 200–240V AC 3 2.5 15 15 1Ø 480V AC 5 5 30 30 3Ø 200–240V AC 7.5 5 30 30 3Ø 480V AC 15 10 50 50 3Ø 600V AC 15 10 50 50 Note: *HBLDS33ACNK. Stainless Steel, Sloped Top Circuit-Lock® Unfused Disconnect Switches Specifications Moisture Resistance Flammability Operating Temperature UV Resistance Dielectric Voltage Max. Working Voltage Current Interrupting Short Circuit Current Ratings (SCCR): (Motor Disconnect) Terminal Identification Product Identification Mounting Impact Resistance Materials Part Base Top Handle Conduit Hub Enclosure Gasket Shaft (Unfused) Shaft Seal Frame Enclosure Screws Indoor and Outdoor – Type 4X (Wash down, Corrosion resistant); Indoor – 30, 60A and 100A Type 12 (Dust-tight, Falling Dirt, Noncorrosive Liquids). UL94-5VA and V0 Classification. Maximum Continuous 75°C; Minimum Continuous -40°C without impact. All materials are UV stabilized. Withstands 3000V AC minimum. 600V AC RMS. Certified for current interrupting at full rated current and voltage. • 30/60/100A: Suitable for use on a circuit capable of delivering not more than 10kA RMS symmetrical, 600V AC max. • 30A: Suitable for use on a circuit capable of delivering not more than 65kA RMS symmetrical, 600V AC max. when protected by Class J fuses rated 30A max. • 60/100A: Suitable for use on a circuit capable of delivering not more than 65kA RMS symmetrical, 600V AC max. when protected by Class J fuses rated 100A max. In accordance with UL, CSA and international conventions. Identification and ratings are part of external label. Non-Metallic - External fully adjustable feet. Stainless Steel - Feet are fixed. In accordance with UL 746C. Non-Metallic Stainless Steel Valox® Valox® Valox® Zinc 30A Unfused - ¾ in. Zinc 60/100A Unfused - 1¼ in. Neoprene Valox® Molded Neoprene Galvanized Steel Stainless Steel 300 Series #14 Gauge Type 304 Stainless Steel #14 Gauge Type 304 Stainless Steel Valox® Zinc 30A - ¾ in. Zinc 60/100A - 1¼ in. Neoprene Valox® Molded Neoprene N/A Stainless Steel Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. www.hubbell-wiring.com Dimensions in Inches (mm) ® Wiring Device-Kellems F-7 Switched Disconnects and Enclosures Hubbell’s MotorQuick® Plug and Play Technology MotorQuick® significantly reduces the time it takes to replace motors by combining the plug-and-play technology of the LINKOSITY® power system with the versatility of Circuit-Lock® motor disconnect switches. Quick disconnect terminations will reduce motor changeout time by aproximately 65%. Keeping spare motors already pre-wired with a LINKOSITY® inlet enables wiring to be done off-line when it is convenient, not critical. Motor rotation can be pre-checked in a maintenance shop to further speed the installation. The net result is that equipment is up and running in a fraction of the time, helping improve the bottom line. MotorQuick® Cost of Ownership Analysis Traditional Motor Changeout Catalog Number Total Material Cost Labor Cost/ Hr HBL1389D HBLDS3 $106.00 $185.00 $53.00 $53.00 Downtime Total Labor Cost Downtime Cost/hr Total Downtime Cost Total Cost 1 hour 1 hour $53.00 $53.00 $750.00 $750.00 $750.00 $750.00 $909.00 $988.00 Downtime Cost/hr Total Downtime Cost Total Cost Total Savings $750.00 $750.00 $250.00 $250.00 $566.67 $678.67 $342.33 $309.33 MotorQuick® Motor Changeout Catalog Number Total Material Cost Labor Cost/ Hr Downtime Total Labor Cost HBL1389MQ* HBLDS3MQ* $299.00 $411.00 $53.00 $53.00 20 minutes 20 minutes $17.67 $17.67 Note: *MotorQuick catalog numbers are based on the average cost of the various designs. F-8 ® Wiring Device-Kellems www.hubbell-wiring.com 30 Ampere, 600 Volts AC IP67 SUITABILITY Type 4X Enclosure Thermoplastic Cover on Plated Steel Base Permanent Labelless Marking NEMA 1 Enclosure Lockable Handle to Meet OSHA Lockout/ Tagout Regulations Pre-wired with LINKOSITY® Components High Impact Valox® Enclosure HBLDS3MQ5 Crush and Impact Resistance of MC Cable HBL1389MQ5 Cable Ratings: TC-ER, MTW, STOOW MotorQuick® Disconnect Switches Type 1 Non-Metallic Enclosure 30A 3 Pole 600V AC Catalog Number HBL1389D with one pre-wired LINKOSITY® female receptacle (load side). HBL1389D with 5 foot pre-wired LINKOSITY® female cable (load side). HBL1389D with one pre-wired LINKOSITY® male receptacle (line side) and one pre-wired LINKOSITY® female receptacle (load side). HBL1389MQR HBL1389MQ5 HBL1389MQR2 HBL1389MQR2 Type 4X Non-Metallic Labelless Enclosure 30A 3 Pole 600V AC HBLDS3 with one pre-wired LINKOSITY® female receptacle (load side). HBLDS3 with 5 foot pre-wired LINKOSITY® female cable (load side). HBLDS3 with one pre-wired LINKOSITY® male receptacle (line side) and one pre-wired LINKOSITY® female receptacle (load side). HBLDS3MQR HBLDS3MQ5 HBLDS3MQR2 Type 4X Stainless Steel Enclosure 30A 3 Pole 600V AC Sloped Top HBLDS3SS with one pre-wired LINKOSITY® female receptacle (load side). HBLDS3SS with 5 foot pre-wired LINKOSITY® female cable (load side). HBLDS3SS with one pre-wired LINKOSITY® male receptacle (line side) and one pre-wired LINKOSITY® female receptacle (load side). HBLDS3SSRMQR HBLDS3SSMQR HBLDS3SSRMQ5 HBLDS3SSMQ5 HBLDS3SSRMQR2 HBLDS3SSMQR2 Square Top HBLDS3MQR Accessories Description Catalog Number 3P 4W LINKOSITY® male receptacle for installation on motor. 3P 4W LINKOSITY® female receptacle for installation in switch. 3P 4W LINKOSITY® double ended (male/female) 5-50 foot cable. 3P 4W LINKOSITY® single ended (female) 5-50 foot cable. Cord connector, ¾ in. NPT .63–.75 in. (16.0–19.1) diameter. Lock-on cover for LINKOSITY® connections. RM3004PA001 RF3004PA001 PH3004PAxxx* PF3004PAxxx* SHC1037CR PH2030C HBLDS3SSRMQR Note: *Cables available from 5-50 feet in 5 foot increments. To purchase larger cable, replace the XXX with the required length in feet. (Examples: PH3004PA005 = 5 foot cable, PH3004PA050 = 50 foot cable.) Sample Set Up (1) HBLDS3MQR + (1) PH3004PAxxx + + (1) RM3004PA001 = + = HBLDS3SSMQR Total Set Up** PH2030C Note: ** Retrofit parts available for pre-existing disconnect switch installations. Please consult factory for availability. Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. www.hubbell-wiring.com ® Wiring Device-Kellems F-9 30 Ampere, 600 Volts AC Dimensions Type 1 Male LINKOSITY Receptacle (MQR2 Option) Type 4X 6.00" (152) 5.12" (130) 4.12" (105) 3.97" (100.84) ON 3.40" (86.36) 4.52" (114.81) .88" (22.35) Female LINKOSITY Cord (MQ5 Option) Female LINKOSITY Receptacle HP Rating 120V AC 240V AC 480V AC 600V AC OFF Male LINKOSITY Receptacle (MQR2 Option) Female LINKOSITY Cord (MQ5 Option) 3 7.5 15 20 Specifications 4.12" (105) 6.62" (168) 7.62" (194) 8.50" (216) Female LINKOSITY Receptacle HP Rating 120V AC 240V AC 480V AC 600V AC 1 7.5 15 15 Type 1 Type 4X 2,200V AC minimum for 1 minute. 6,000 cycles with load. 600V AC RMS. 10,000 RMS symmetrical amps when tested with 60A max J fuses. 10,000 RMS symmetrical amps when tested with 125A RK5 fuses. 2,200V AC minimum for 1 minute. 6,000 cycles with load. 600V AC RMS. • 30: Suitable for use on a circuit capable of delivering not more than 10kA RMS symmetrical, 600V AC max. • 30A: Suitable for use on a circuit capable of delivering not more than 65kA RMS symmetrical, 600V AC max. when protected by Class J fuses rated 30A max. 10,000 minimum cycles. Amps AWG Min. AWG Max. 30 #14 #10 20 inch pounds 30 — — — 10,000 minimum cycles. Amps AWG Min. AWG Max. 30 #14 #10 30 20 inch pounds UL746C UL94HB/V-0. Max. continuous Min. continuous w/o impact UL94-5VA and V0 Classification. Max. continuous 75°C Min. continuous -40°C Electrical Performance Dielectric Voltage Electrical Life Max. Working Voltage Short Circuit Current Ratings (SCCR): (Motor Disconnect) Short Circuit Current Ratings (SCCR): (Motor Controller) Mechanical Mechanical Life Terminal Accommodations Terminal Torque Impact Resistance Environmental Flammability Operating Temp. 60°C -40°C Listings UL 508 Industrial Control Equipment File #E36355 Industrial Control Equipment File #E36355 LINKOSITY® Connection Certifications Connecting Components Materials Listed to UL 2238 and UL 50E. Electrical Performance Voltage Amperage Up to 600V AC. Up to 30A. Environmental Connectivity System Components Moisture Resistance Ingress Protection Flammability UL Type 4, 4X, 12 and 13. IP67 Suitability. UL94HB cables / UL94V-0 receptacles. Connectivity System Components Contact Carrier Nylon 6/6, white. Contact Materials Pins - brass. Sockets - leaded nickel copper w/ stainless steel sleeve. Contact Plating Hard gold over palladium/nickel. Overmold Material Glass filled polyurethane, gray. Coupling Hardware Nickel plated brass. Cable (16 AWG and Up) UL 600V Type TC-ER, MTW 90°C or STOOW 600V 105°C. Dimensions in Inches (mm) F-10 ® Wiring Device-Kellems www.hubbell-wiring.com Switched Disconnects and Enclosures Circuit-Lock® Fused Disconnect Switches “Suitable as Motor Disconnects” Features and Benefits Circuit-Lock® 30 and 60 Ampere Fused Disconnect Switches The Circuit-Lock Fused Disconnect Switch provides fused switched control of a directly wired load. The switch cannot be turned ON unless the enclosure cover is closed. The fuses cannot be accessed until the switch is turned OFF. The fuse holder accepts Class “J” fuses. This enclosure is non-metallic and is listed for Outdoor/Indoor (Type 4X Wash down, Corrosion resistant). The handle can be locked in the OFF position to comply with OSHA Lockout/Tagout regulations. Three molded-in conduit drill points are located on the top, bottom, and back surface of enclosure. Conduit hub provided: 30A 1 inch NPT, 60A 1¼ inch NPT Adjustable mounting feet (4) can be mounted in any of three positions for ease of installation Stainless steel hardware for corrosion resistance Fused disconnect switches accept Class “J” fuses Safety interlocked fuse access door Non-metallic enclosure meets UL 50E Type 4X (watertight) 12 (dust-tight) and IP66 suitability requirements. Enclosure is molded of rugged Valox® to resist abuse, corrosion and enhance safety. All external hardware is stainless steel Conduit hub and adjustable mounting feet are supplied with each Circuit-Lock® Fused Disconnect Switch. Stainless steel ¼ inch turn door fasteners for quick, easy access to fuses. Lockable high visibility red handle to meet OSHA Lockout/Tagout FDS30 Removable door for ease of wiring and installation Enclosure door can be locked to prevent unauthorized access. Additionally, if the switch is ON, the door cannot be opened. Compact Fused Disconnect Switch accepts Class “J” fuses. Fuse holders are top mounted for easy access. The switch accepts auxiliary contacts for control circuit applications including the ON/OFF control of remote pilot lights or signal for programmable controllers. Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. www.hubbell-wiring.com ® Wiring Device-Kellems F-11 Switched Disconnects and Enclosures Circuit-Lock® Fused Disconnect Switches “Suitable as Motor Disconnects” Dimensions UL Listed, CSA Certified TYPE 4, 4X and 12 Enclosure Rating IP66 SUITABILITY 30 and 60 Amp Fused Disconnect Switches Description Catalog Number 30A Circuit-Lock fused disconnect switch. FDS30* 60A Circuit-Lock fused disconnect switch. FDS60* Note: *Class “J” fuses not included. Auxiliary Contacts FDS30 Description Black Style Switch Catalog Number Gray Style Switch Catalog Number Auxiliary contact, normally open, A600 pilot duty, break before break. ACFSNO HBLACFSNO Auxiliary contact, normally closed, A600 pilot duty, break before break. ACFSNC HBLACFSNC Note: Auxiliary contacts are specific to the style switch noted and are NOT interchangeble. Gray Style Switch Replacement Switches Description Black Style Switch Catalog Number Gray Style Switch Catalog Number For 30A fused switches. 30MIFRS HBL30MIFRS — HBL60MIFRS For 60A fused switches. Gray Style switch will retro fit Black Style switch. Note: If replacing a Black Style switch, you must use the 30MIFRS. All other applications can use the Gray Style switch. HBLACFSNO HBL30MIFRS Black Style Switch Watertight Closure Plug Kits Description Catalog Number For 30A Circuit-Lock® unfused and fused Pin and Sleeve mechanical interlocks. MICPK30 For 60 and 100A Circuit-Lock® unfused and fused Pin and Sleeve mechanical interlocks. MICPK60 Replacement Mounting Feet ACFSNO 30MIFRS MICPK30 Description Catalog Number Replacement mounting feet and screws for 30 and 60A fused mechanical interlocks. HBLRFT2 ∆ Note: 30A Units supplied with two 1 in. NPT raintight conduit fittings. 60A Units supplied with two 1¼ in. NPT raintight conduit fittings. ∆ Package of 10 feet and 10 screws. HBLRFT2 Dimensions 7.27" (184.7) 9.31" (236.5) 3.60" (91.4) 10.18" (258.6) 7.19" (182.6) 11.46" (291.6) 12.37" (314.2) 15.03" (381.8) 14.48" (367.8) 15.36" (390.1) Dimensions in Inches (mm) F-12 8.43" (214.1) ® Wiring Device-Kellems www.hubbell-wiring.com Switched Disconnects and Enclosures Circuit-Lock® Fused Disconnect Switches Horsepower Ratings and Specifications Horsepower Ratings Ratings Volts Standard HP Maximum HP* 30A 600V AC Max. 120V AC 208-240V AC 3Ø 240V AC 3Ø 480V AC 3Ø 600V AC 3Ø Y 120/208V AC 3Ø Y 277/480V AC 3Ø Y 347/600V AC 0.5 1.5 3 5 7.5 3 5 7.5 2 3 7.5 15 20 5 15 20 Catalog Number FDS30 60A 600V AC Max. 120V AC 208-240V AC 3Ø 240V AC 3Ø 480V AC 3Ø 600V AC 3Ø Y 120/208V AC 3Ø Y 277/480V AC 3Ø Y 347/600V AC 1.5 3 7.5 15 15 7.5 15 15 3 7.5 15 30 50 15 30 40 FDS60 Note: *Requires time delay fuses. Fuse and Short Circuit Information Horsepower Ratings Short Circuit Withstand Rating The starting current of motors of more than the standard horsepower rating may require the use of fuses with appropriate time-delay characteristics. Suitable for use on a circuit capable of delivering not more than 200,000 RMS symmetrical amperes at the voltage rating of receptacle when protected by Class “J” fuses. Note: Replacement fused switch must be the same type Hubbell switch as original and have equal or greater short circuit current withstand rating. Circuit-Lock® Fused Disconnect Switch Specifications Moisture Resistance UV Resistance Dielectric Voltage Max. Working Voltage Impact Resistance Terminal Identification Product Identification Mounting Fuse Types Indoor and Outdoor – Type 4X (Wash down, Corrosion resistant); Indoor – Type 12 (Dust-tight, Falling Dirt, Noncorrosive Liquids). UL94-5VA and V0 Classification. Maximum Continuous 75°C; Minimum Continuous -40°C without impact. All materials are UV stabilized. Withstands 3000V AC minimum. 600V AC RMS. In accordance with UL 746C. In accordance with UL, CSA and international conventions. Identification and ratings are part of external label. External fully adjustable feet. UL Listed, Class “J”; CSA Certified, HRCI-J. Materials Part Material Base Door Handle Conduit Hub Enclosure Gasket Shaft Shaft Seal Frame Ground Plate Enclosure Screws Valox® Valox® Valox® Zinc, 30A Fused – 1 in., 60A Fused – 1¼ in. Neoprene Brass Neoprene Galvanized Steel Galvanized Steel Stainless Steel 300 Series Flammability Operating Temperature Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. www.hubbell-wiring.com ® Wiring Device-Kellems F-13 Switched Disconnects and Enclosures Wiring Devices for Hazardous Locations Features and Applications Hazardous Location Non-Fused Disconnect Switches Hubbell’s hazardous location line of non-fused disconnect switches are typically used for applications with the presence of flammable gasses or vapors, ignitable dusts and fibers. They are also suitable for use in outdoor or indoor damp, wet and dirty locations or in areas where frequent wash downs, heavy rain, or water spray routinely occurs. These switches are compact in size to reduce cost and make it easier to position on the wall or piece of equipment. The enclosures are made of copper-free aluminum and have a polyester/epoxy finish to prevent corrosion. The high visibility handles can be locked out to comply with OSHA lock out/tag out regulations. Copper-free aluminum construction with electrostatically applied polyester/ epoxy finish to prevent corrosion Compact NEMA 4X enclosure and footfrint allows easy installation in tight locations • 316 Stainless steel bolts • Top and bottom drilled and tapped conduit entrances • For use as motor disconnects Class I, Div. 1 & 2, Groups B,C,D Class l, Zones 1 & 2, Groups llB+ H2, llA Class II, Div. 1 & 2, Groups E,F,G Class III, NEMA 3, 4, 4X, 7(B,C,D), 9(E,F,G) Lockable handle to meet OSHA Lockout/Tagout regulations HBLB7NFD13A Lockable handle to meet OSHA Lockout/Tagout regulations Large visible rotary handle with “On-Off” indicator allows a quick means of disconnecting power HBLB7NFD26A Features Applications • Compact size enclosures provide application flexibility with cost savings over industry standard sizes. • Fewer cover bolts reduces installation and maintenance time. • Gasketed flange with O-ring located inside bolt circle to seal out moisture. • Rotary handle style operating mechanism with lockout provision as standard. • Removable ductile mounting lugs adjust to irregular mounting surfaces. • Bodies have top and bottom drilled and tapped conduit entrances for power connection. • UL98 certified switch. • • • • • • • F-14 ® Wiring Device-Kellems Grain manufacturing and storage Industrial chemical and gas manufacturing Petroleum refining Fertilizer manufacturing Vehicle repair/paint shops Coal mining Cotton and fabric mills www.hubbell-wiring.com Switched Disconnects and Enclosures Wiring Devices for Hazardous Locations 30, 60 and 100 Ampere Standard Materials/Finish • • • • • Enclosures: Copper-free aluminum (less than 4/10 of 1% copper content) Cover Bolts: 316 Stainless Steel O-Ring Gasket: Silicone Finish: Grey Powder Polyester painted exterior, electrostatically applied Ratings: 600V AC, 230V DC 30–100 Amp 30, 60 and 100 Amp Unfused Hazardous Location Disconnect Switches HBLB7NFD13A Description Catalog Number 30A 3 Pole disconnect switch. HBLB7NFD13A 30A 3 Pole disconnect switch with auxuliary contact. HBLB7NFD13AA 60A 3 Pole disconnect switch. HBLB7NFD26A 60A 3 Pole disconnect switch with auxuliary contact. HBLB7NFD26AA 100A 3 Pole disconnect switch. HBLB7NFD21A 100A 3 Pole disconnect switch with auxuliary contact. HBLB7NFD21AA HBLB7NFD26A Unfused Mechanical Interlocks and Plugs Amp 30 60 Poles/Wires Voltage AC Receptacle Plug 3 Pole, 2 Wire 600V AC HBLVSQ3023 HBLVP3385 4 Pole, 3 Wire 600V AC HBLVSQ3034 HBLVP3485 3 Pole, 2 Wire 600V AC HBLVSQ6023 HBLVP6385 4 Pole, 3 Wire 600V AC HBLVSQ6034 HBLVP6485 HBLVSQ3034 Note: HBLVSQ 30 amp models come standard with 1" drilled and tapped conduit openings top and bottom plus two 1" x ¾" reducers and one ¾" close-up plug for maximum flexibility. 60 amp models come with one 1½" opening on top and bottom and one 1½" close-up plug. HBLVP3485 Horsepower Ratings Single Phase HP Three Phase HP DC HP Switch Amps/Phase 120V AC 230V AC 208V AC 230V AC 480V AC 600V AC 230V DC Terminal Wire Size Conduit Sizes Catalog Number 30A / 3P 2 5 10 10 20 30 1 #14-10 1 NPT HBLB7NFD13A 60A / 3P 3 7.5 20 20 40 40 10 #14-4 1½ NPT HBLB7NFD26A 100A / 3P 5 15 25 30 50 50 20 #8-1 1½ NPT HBLB7NFD21A Dimensions Outside Box A B Inside Box C D E Mounting Dimensions F G H I J K 30 Amp 5³⁄₄ 8¹⁄₁₆ 6⁵⁄₁₆ 3⁵⁄₈ 5¹³⁄₁₆ 5¹⁄₁₆ 3¹⁄₈ 8¹⁄₈ – – 1¹⁄₄ 60 & 100 Amp 8¹⁄₈ 13¹⁄₁₆ 7¹³⁄₁₆ 4¹⁄₄ 9³⁄₁₆ 6⁵⁄₁₆ 2¹⁄₂ 11³⁄₈ 6³⁄₈ 7¹⁄₂ 1¹³⁄₁₆ Fixed Lug Position for HBLB7NFD13A Optional Position for HBLB7NFD2 A-Series Standard Lug Position for HBLB7NFD2 A-Series F C I G J A D H E B K Dimensions in Inches (mm) www.hubbell-wiring.com ® Wiring Device-Kellems F-15 Switched Disconnects and Enclosures AC Manual Toggle Controllers/Disconnects 30, 40, 50, 60 and 85A 600V AC Circuit-Lock® controllers rated “Suitable as Motor Disconnect” The most complete offering of controllers with top horsepower and high amperage ratings in such a compact device. #10 Brass Terminal Screw Clamping plate for secure back or side wiring (30A only) Optional Side Guard For close wall applications and finger safe environments 30A, 40A and 50A Shared Features Front and Back Wiring Steel Screws and Copper Terminals Strong on/off action with quick-make, slow break operation • Provides long-life reliability • 10,000 Amp High Fault Short Circuit Withstand Rating Recessed Wiring Wells Finger safe environments Thermoset Body • Provides high resistance to electrical arc tracking • Withstands high temperatures • Excellent dimensional stability • Superior dielectric strength Optional Side Finger Guards For close wall applications and finger safe environments. For 30A, 40A and 50A controllers. F-16 60A and 85A Four Large Silver Alloy Contacts per Pole • Excellent conductivity • Maximum longevity ® 100% Copper Contact Arm Lubrication-Free Controller • High heat management • Reliability • Continued on/off cycling even in harsh, dust and high heat environments Wiring Device-Kellems www.hubbell-wiring.com Switched Disconnects and Enclosures AC Manual Toggle Controllers/Disconnects 30, 40, 50, 60 and 85A 600V AC 600V AC Manual Motor Controllers/Disconnects For use in almost any industrial environment. Ideal component switch for motor control and as a disconnect. Toggle controllers can be built into equipment and enclosures for either box or panel-mount installation. HP Rating Amp 120V AC 1Ø 240V AC 3Ø 480V AC 3Ø 600V AC 3Ø Catalog Number Poles ToggleType Wire 30 2 2 2 3 3 Standard Short Standard Standard Short Back/Side Back/Side Back/Side Back/Side Back/Side 2 2 2 3 3 5 5 5 7.5 7.5 10 10 10 15 15 15 15 15 20 20 HBL7832D HBL7832DS HBL7832DX HBL7810D HBL7810DS 40 2 3 Standard Standard Side Side 2 3 5 7.5 10 15 15 20 HBL7842D HBL7843D 50 2 3 Standard Standard Side Side 2 3 5 7.5 10 15 15 25 HBL7852D HBL7853D 60 2 3 2 3 Standard Standard Standard Standard Back Back Front Front — — — — 10 10 10 10 15 25 15 25 20 30 20 30 HBL7862D HBL7863D HBL7862FWD HBL7863FWD 85 2 3 Standard Standard Back Back — — 10 10 15 25 20 40 HBL7882D HBL7883D HBL7810D HBLFG30 HBL7863D HBLFG30* Optional Side Guard, for close wall applications and finger safe environments. HBL7853D Note: *For 30A, 40A and 50A controllers. Specifications Dimensions Electrical Performance 30, 40 and 50 Amp Standard Toggles Dielectric Voltage Min. 2,200V AC minimum for 1 minute Electrical Life Min. 6,000 Cycles at rated switch load Max. Working Voltage 600V AC RMS Switches 10,000 RMS Short Circuit 30A & 40A 60A max. when protected by J fuses Withstand Rating 50A 50A max. when protected by J fuses as Motor Disconnect 60A & 85A 80A max. when protected by J fuses Short Circuit Withstand Rating All Switches 125A max. RK5 fuses as Motor Controller 2.25" (57.2) 3.28" (83.3) 3.78" (96.0) ON 2.44" (62.0) 2.38" (60.4) 1.53" (38.9) Side Front Mechanical Mechanical Life Terminal Accommodations Wire Type Terminal Torque Switch Rating Min. 10,000 minimum cycles Switch Rating AWG Max. 30A #10 40A & 50A #8** 60A & 85A #4 Solid and stranded copper wire only. 30A – 50A 20 inch pounds 60A – 85A 25 inch pounds 3.56" (90.4) 3.78" (96.0) 3.28" (83.3) Environmental Flammability Operating Temp. 60 and 85 Amp Standard Toggles UL94HB/VO Max. 75°C Min. -40°C continuous without impact Listings UL 508 CSA-C22.2 No.14 ON 1.92" (48.8) 2.38" (60.4) Front Industrial Control File #E70402 LR-46186 2.83" (71.9) Side Note: **Use listed certified ring terminal. Dimensions in Inches (mm) www.hubbell-wiring.com ® Wiring Device-Kellems F-17 Switched Disconnects and Enclosures NEMA 1 Disconnect Switches “Suitable as Motor Disconnects” Thermoplastic Cover on a Plated Steel Base Durable, non-conductive cover HBL1389D Shared Features Wiring conduit knockouts • ½" and ¾" NPT All Aluminum Cover and Base Base is pre-drilled for rear surface mounting • Top, bottom or back wire entry points Surface mount control HBL1379D Switch can be locked in the off position as a method of compliance with OSHA lockout/tagout Circuit-Lock® NEMA 1 Enclosures with Switch Ideal for use in industrial environments, i.e. conveyer systems, industrial fans, etc. HP Rating Amp Poles 30 HBL1389D HBL1379D 2 Enclosure Material 120V AC 1Ø 240V AC 3Ø 480V AC 3Ø 2 5 10 15 Thermoplastic 600V AC 3Ø Catalog Number HBL1392D 30 3 Thermoplastic 3 7.5 15 20 HBL1389D 30 2 Aluminum 2 5 10 15 HBL1372D 30 3 Aluminum 3 7.5 15 20 HBL1379D Note: See page F-17 for technical information. Circuit-Lock® NEMA 1 Enclosures without Switch For use with switches shown on page F-17. Description HBL1390 HBL1370 Cover Material Base Material No. Equipment Grounds Catalog Number For use with 30A switch. Thermoplastic Steel 1 HBL1390 For use with 30A switch. Aluminum Aluminum 2 HBL1370 Dimensions HBL1370, HBL1372D and HBL1379D HBL1390, HBL1389D and HBL1392D 3.97" (100.8) 2.76" (70.1) 3.20" (81.2) 1/2" x 3/4" Knockout Each End 3.15" (80.0) 2.41" (61.3) 0.92" (23.2) 2 - 1/2" Knockouts 2.75" (69.8) 4.72" (120.0) F-18 3.43" (87.1) 2.65" (67.3) 2.44" (61.9) 2 - 0.265" (6.7) Mounting Holes Bottom Dimensions in Inches (mm) 1/2" x 3/4" Knockout Each End 0.88" (22.42) 2.38" (60.5) 4.52" (114.8) 2 - 0.265" (6.7) Mounting Holes Bottom 1.50" (38.1) 2.00" (50.8) Back Back ® Wiring Device-Kellems 2 - 1/2" x 3/4" Knockouts www.hubbell-wiring.com Switched Disconnects and Enclosures NEMA 3/3R and 3R Disconnect Switches “Suitable as Motor Disconnects” Circuit-Lock® NEMA 3/3R Enclosures with Switch Ideal for use on outdoor equipment. HP Rating Amp Poles 30 Enclosure Material 2 120V AC 1Ø 240V AC 3Ø 480V AC 3Ø 2 5 10 15 Thermoplastic 600V AC 3Ø Catalog Number HBL13R22D 30 3 Thermoplastic 3 7.5 15 20 HBL13R23D 30 2 Aluminum 2 5 10 15 HBL13R12D† 30 3 Aluminum 3 7.5 15 20 HBL13R13D† HBL13R23D Note: See page F-17 for technical information. *Drill weephole to alter from NEMA 3 to NEMA 3R. †Equipped with HBLFG30 sidewall insulation barriers. HBL13R13D Dimensions HBL13R22D and HBL13R23D 2.99" (75.9) 4.76" (120.9) HBL13R12D and HBL13R13D 2.25" (57.2) 0.30" (7.6) Padlock Hole ON 5.42" (137.7) 2.93" (74.4) 1.84" (46.7) 4.55" (115.6) 3.24" (82.3) OFF 2.22" (56.4) 3 - 1/2" Hubs 3.94" (100.1) 4.51" (114.6) 0.34" (8.6) Padlock Hole 2.99" (75.9) Front Side Back Front Side Circuit-Lock® NEMA 3R Enclosures with Switch Ideal for use in outdoor environments. HP Rating Amp Poles 30 2 Enclosure Material Aluminum 120V AC 1Ø 240V AC 3Ø 480V AC 3Ø 2 5 10 600V AC 3Ø Catalog Number HBL13R92D 15 30 3 Aluminum 3 7.5 15 20 HBL13R89D 60 2 Aluminum — 10 15 20 HBL16R92D 60 3 Aluminum — 10 25 30 HBL16R93D Note: For switch specifications refer to page F-17. Circuit-Lock® NEMA 3R Enclosures without Switch For use with switches shown on page F-17. Description Enclosure Material Catalog Number For use with 30A switch. Aluminum HBL13R90 For use with 60A switch. Aluminum HBL16R90 HBL13R89D HBL16R93D Dimensions HBL13R90, HBL13R89D and HBL13R92D HBL16R90, HBL16R92D and HBL16R93D 4.40" (111.8) 4.40" (111.8) 5.52" (140.2) 0.31" (7.9) Padlock Hole 2 - 3/4" Knockouts 3.30" (83.3) 2.75" (69.9) 1.06" (26.9) 4.28" (108.7) 1.99" (50.5) Front Bottom 2 - 3/4" x 1" Knockouts 10.11" (256.8) 3.30" 2.75" (83.8) (69.9) 1.52" (38.6) 0.31" (7.9) Padlock Hole 2.00" (50.8) Front Bottom 4.28" (108.7) www.hubbell-wiring.com ® Wiring Device-Kellems Dimensions in Inches (mm) F-19 Switches 30 Ampere, 600 Volts AC Manual Motor Controllers “Suitable as Motor Disconnect” 30A 600V AC Manual Motor Controllers, Double Pole 2.25" (57.1) (4) #10-32 TAP 3.28" (83.3) 2.38" (60.5) 3.78" (96.0) (2) .20 Dia. Mtg. Holes HBL7810D 3.97" (100.8) Description Catalog Number 30A, double pole, single throw, AC manual motor controller, black nylon handle, side and back wired. HBL7832D 30A, double pole, single throw, AC manual motor controller, black nylon handle, short toggle. HBL7832DS 30A, double pole, single throw, AC manual motor controller. 50 piece bulk pack. HBL7832DX HBL7832D in HBL1390 Type 1 enclosure with non-metallic cover, ½ in. and ¾ in. knockouts on top, bottom and back of steel frame. HBL1392D HBL7832D in HBL1370 metal Type 1 enclosure. HBL1372D HBL7832D in NEMA 3R non-metallic enclosure. HBL13R22D HBL7832D in HBL13R90 metal Type 3R enclosure. HBL13R92D HBL7832D in NEMA 3R flip-lid enclosure. HBL13R12D Note: See page F-17 for technical information. 30A 600V AC Manual Motor Controllers, Three Pole 4.52" (114.8) 2.62" (66.5) HBL1389D 2.25" (57.2) 4.51" (114.6) 3.94" (100.1) HBL13R13D Description Catalog Number 30A, three pole, single throw, AC manual motor controller, black nylon handle, side and back wired. HBL7810D 30A, three pole, single throw, AC manual motor controller, black nylon handle, short toggle. HBL7810DS HBL7810D in HBL1390 Type 1 enclosure with non-metallic cover, ½ in. and ¾ in. knockouts on top, bottom and back of steel frame. HBL1389D HBL7810D in HBL1370 metal Type 1 enclosure. HBL1379D HBL7810D in NEMA 3R non-metallic enclosure. HBL13R23D HBL7810D in HBL13R90 metal Type 3R enclosure. HBL13R89D HBL7810D in NEMA 3R flip-lid enclosure. HBL13R13D 30A, 600V, three pole, rotary controller in NEMA 4X stainless steel enclosure. HBL13S33D 30A, 600V, three pole, rotary controller in NEMA 4X non-metallic enclosure. HBL13X33D Note: See page F-17 for technical information. Motor Rating Product 3.20" (81.3) 4.72" (119.9) 2.41" (61.2) HBL1379D 120V AC 240V AC 480V AC 600V AC Phase 30A Double Pole 2HP 5HP 10HP 15HP 1 30A Three Pole 3HP 7½HP 15HP 20HP 3 40A Double Pole 2HP 5HP 10HP 15HP 1 40A Three Pole 3HP 7½HP 15HP 20HP 3 50A Double Pole 2HP 5HP 10HP 15HP 1 50A Three Pole 3HP 7½HP 15HP 25HP 3 60A Double Pole - 10HP 15HP 20HP 1 60A Three Pole - 10HP 25HP 30HP 3 85A Double Pole - 10HP 15HP 20HP 1 85A Three Pole - 10HP 25HP 40HP 3 2.99" (75.9) 4.40" (111.8) 4.76" (120.9) 0.30" (7.6) Padlock Hole 6.96" (176.8) 5.52" (140.2) 6.75" (171.5) 2.99" (75.9) 4.55" (115.6) 4.00" (101.6) 3.00" (76.2) HBL13R23D HBL13R89D HBL13S33D Dimensions in Inches (mm) F-20 ® Wiring Device-Kellems www.hubbell-wiring.com AC Switches 40, 50, 60 and 85 Ampere, 600 Volts AC Manual Motor Controllers “Suitable as Motor Disconnect” IP44* SUITABILITY 40A 600V AC Manual Motor Controllers Description Catalog Number 40A, double pole, single throw, AC manual motor controller, black nylon handle, side wired. HBL7842D 40A, three pole, single throw, AC manual motor controller, black nylon handle, side wired. HBL7843D 3.38" (85.9) .40" (10.2) 3.28" (83.3) 3.78" (96.0) Note: See page F-17 for technical information. 50A 600V AC Manual Motor Controllers Description Catalog Number 50A, double pole, single throw, AC manual motor controller, black nylon handle, side wired. HBL7852D 50A, three pole, single throw, AC manual motor controller, black nylon handle, side wired. HBL7853D #10-32 TAP 2.82" (71.6) 2.38" (60.5) .20" DIA (5.1) 2.31" (58.7) 1.5" (38.1) 1.75" (44.5) HBL7862D 3.38" (85.9) Note: See page F-17 for technical information. #10-32 TAP .40" (10.2) 3.28" (83.3) 60A 600V AC Manual Motor Controllers Description Catalog Number 60A, double pole, single throw, AC manual motor controller, black nylon handle, back wired. HBL7862D Same as HBL7862D except front wired. HBL7862FWD HBL7862FWD in Type 3R enclosure. HBL16R92D 60A, three pole, single throw, AC manual motor controller, black nylon handle, back wired. HBL7863D Same as HBL7863D except front wired. HBL7863FWD HBL7863FWD in a Type 3R enclosure. HBL16R93D 60A, 600V, three pole, rotary controller in NEMA 4X stainless steel enclosure. HBL16S63D 60A, 600V, three pole, rotary controller in NEMA 4X non-metallic enclosure. HBL16X63D 3.78" (96.0) 2.82" (71.6) 2.31" (58.7) 2.38" (60.5) .20" DIA (5.1) 1.5" (38.1) 1.75" (44.5) HBL7862FWD 4.40" (111.8) Note: See page F-17 for technical information. 10.11" (256.8) 85A 600V AC Manual Motor Controllers Description Catalog Number 85A, double pole, single throw, AC manual motor controller, black nylon handle, back wired. HBL7882D 85A, three pole, single throw, AC manual motor controller, black nylon handle, back wired. HBL7883D 3.00" (76.2) Note: See page F-17 for technical information. HBL16R93D Motor Controller Accessories Description Catalog Number Finger Guards, fit 30A, 40A and 50A controllers. HBLFG30 Auxiliary Contacts, NO/Common/NC, for use in rotary switches only. HBLAUX 6.95" (176.5) 8.00" (203.2) 4.00" (101.6) HBL16S63D Dimensions in Inches (mm) www.hubbell-wiring.com ® Wiring Device-Kellems F-21 Switched Disconnects and Enclosures NEMA 4X Disconnect Switches “Suitable as Motor Disconnects” Hinged Cover with Removable Continuous Pin Shared Features Un-drilled case allows custom placement of wire entry 304 Stainless Steel Enclosure Chemical and corrosion resistant Switch can be locked in the off position as a method of compliance with OSHA lockout/tagout Valox® Handle and Collar Chemical and impact resistant Thermoplastic 4X Non-Metallic Enclosures HBL13S33D Poured in Closed Cell Neoprene Gasket Interlocking Shaft and Handle Prevents cover removal when switch is on Up to 2 Optional Auxiliary Contacts For PLCs and external indicators HBL13X33D Circuit-Lock® NEMA 4X Enclosures with Switch and Accessories Ideal for use in environments where wash-down is necessary, i.e. food processing, laboratories, etc. HP Rating Amp HBL16S63D HBL13X33D Poles Enclosure Material 120V AC 1Ø 240V AC 3Ø 480V AC 3Ø 600V AC 3Ø Catalog Number HBL13S33D 30 2 Stainless Steel 3 7.5 15 20 30 3 Valox 3 7.5 15 20 HBL13X33D 60 3 Stainless Steel — 10 25 30 HBL16S63D 60 3 Valox — 10 25 30 HBL16X63D Finger Guard option for 30A switch. HBLFG30 NO/Comon/NC auxiliary contact, 10A 120/250V AC for 30 and 60 Amp switches. HBLAUX Note: See page F-17 for technical information. Dimensions HBL13S33D HBL16S63D 6.10" (154.9) 6.95" (176.5) 6.96" (176.8) 4.00" (101.6) 6.10" (154.9) 8.00" (203.2) 8.75" (222.3) 6.00" (152.4) 7.44" (189.0) 9.44" (239.8) 6.75" (171.5) 4.25" (108.0) Front Side 4.25" (108.0) Front Side Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. Dimensions in Inches (mm) F-22 4.00" (101.6) ® Wiring Device-Kellems www.hubbell-wiring.com Switched Disconnects and Enclosures Pendant Pushbutton Stations CPB and PBS Series IP55 SUITABILITY CPB Series Compact Pendant Stations, Two Button, NEMA 4X 1.06" (26.9) Description Catalog Number Single-speed normally open-normally closed without mechanical interlock. CPB20 Single-speed with mechanical interlock between pushbuttons. CPB21 Two-speed with mechanical interlock between pushbuttons. CPB22 Note: Included with product: nylon cord grip and sealing washer (must be installed to achieve NEMA 4X rating). Indication label pack. Cord dia. range .375–.625 in. (9.5–15.9) Ambient temperatures: 25°F to 140°F (32°C to 60°C). Typical applications: Package electric motor hoists. Remote control of machinery. 9.13" (231.9) Contact Ratings, CPB Series Single-Speed Voltage Current AC 120V 6A 35% PF 240V 3A DC 125V 1.1A IND 250V .55A Two-Speed Voltage Current AC 120V 3A 35% PF 240V 1.5A 2.38" (60.5) CPB21 Com.1 Ctr. Top N.O.1 Com.1 SUITABILITY PBS Series Heavy Duty Pendant Pushbutton Stations, NEMA 3R Description Catalog Number 2 button, single speed. 2 button, two speed. PBS2 PBS22 4 button, single speed. 4 button, two speed. PBS4 PBS42 6 button, single speed. 6 button, two speed. PBS6 PBS62 8 button, single speed. 8 button, two speed. PBS8 PBS82 N.O.2 TAB Top Two Speed* CPB22 IP44 N.C.1 N.O.1 N.O.2 Bott. N.O.1 Single Speed* CPB21 Bott. Ctr. Top Momentary (On / Off) CPB20 Bott. Wiring Diagram CPB2 Series Ctr. *Mechanical “floating ball” interlock prevents activating both Pushbuttons simultaneously. Product Dimensions, PBS Series Style A Approx. Wt. Assembled Catalog Number 2 button 7.88" (200.0) 2.5 lbs PBS2 4 button 13.69" (347.6) 4.5 lbs PBS4 6 button 18.0" (457.2) 5.5 lbs PBS6 8 button 22.31" (566.7) 7.5 lbs PBS8 PBS6 Cable Entrance Threaded 1" (25.4) NPT I.D. 1.125" (28.6) O.D. Note: Housing: Yellow vinyl rubber. Contact Interrupting Ratings, PBS Series Two-Speed Single Break Voltage Current AC 120V 6A 35% PF 240V 3A DC 125V .4A IND 250V .2A Single-Speed Double Break Voltage Current AC 120V 6A 35% PF 240V 3A DC 125V 1.1A IND 250V .55A 30mm K.O. A 3.25" (82.6) 0.88" (22.4) 3.50" (88.9) Dimensions in Inches (mm) www.hubbell-wiring.com ® Wiring Device-Kellems F-23 Switched Disconnects and Enclosures Pendant Pushbutton Stations Accessories and Replacement Parts Replacement Inserts PG2 PG6 MS2 When the insert switches are in need of replacement, simply unplug the old insert and plug in a new one. Description Catalog Number Single speed insert momentary N.O. and N.C. PG2 On-Off insert (no mechanical interlock). Momentary, start-stop, reset-stop. PG6 2 or 3 speed insert, momentary. Used to a maximum of 3 speed points. MS2 5 speed insert, momentary. Used to a maximum of 5 speed points. For five speed applications replace an existing terminal board with the TB5 terminal board and replace an existing insert with the five speed (MS5) insert. MS5 MS5 Conversion Inserts In addition to single speed and two speed applications, pre-assembled units can be adapted to handle other applications. TB2 Description Catalog Number Terminal board, required for each insert switch PG2, PG6 and MS2. TB2 Terminal board, required for insert switch MS5. TB5 Accessories TB5 Description Catalog Number Indicator labels for replacement package contains 1 each: hoist, trolley, bridge, forward-reverse, raise-lower, in-out, right left, east-west, north-south, reset-stop, start-stop, power, main hoist, auxuliary hoist, on-off, up-down. PBSLP Rubber button cover for replacement purposes. PBSBC 120V red pilot light for 4, 6, and 8 button units only. PBSPL1* Note: *Each pendant station can accommodate one of the pilot light in the 1.20 in. (30.6) diameter mounting hole. PBSLP PBSBC Kellems® Deluxe Aluminum Cord Fitting Outdoor or indoors where subject to moisture, splash or submersion. Kellems grips provide strain relief for multi-conductor cable. PBSPL1 Description Cord Range Catalog Number Kellems grip. .750"-.875" (19-22.2) 07401023 Kellems grip. .875"-1.00" (22.2-25.4) 07401025 07401023 F-24 ® Wiring Device-Kellems www.hubbell-wiring.com
HBL2325SW 价格&库存
很抱歉,暂时无法提供与“HBL2325SW”相匹配的价格&库存,您可以联系我们找货
