HBL2420ST
HBL2420ST
    HUBBELL(哈伯尔公司)
    HUBBELL WIRING DEVICES - HBL2420ST - CONN, POWER ENTRY, NEMA L15-20R, 250V
HBL2420ST 数据手册
Twist-Lock® Devices 20A, 3 Phase 250V AC, 3 Pole, 4 Wire Grounding Spring Termination Single Flush Receptacle Features Faster termination time No need for screwdriver and torque wrench Spring Termination eliminates strand relaxation High-impact, abuse-resistant nylon face Face color coding by voltage facilitates locating and mating of proper devices Ordering Information Description Device Color UPC Catalog Number Nylon face, back wire Black 783585788586 HBL2420ST Listings Listed to UL 498 Certified to CSA C22.2 No.42 Specifications Face Base Contacts Spring Mounting Strap Nylon Nylon Brass Steel Brass Performance Electrical Current Interrupting Dielectric Voltage Certified for current interrupting at full rated current Withstands 2,000V minimum Mechanical Terminal Accommodation Solid/Stranded #14 AWG to #12 AWG Terminal Identification Terminals identified in accordance with UL 498 Environmental Flammability Moisture Resistance Operating Temperatures V2 or better per UL94/CSA 22.2 No.0.17 IP20 Suitability Maximum Continuous 75°C; Minimum -40°C (w/o impact) Accessories Plug Wallplate or Weatherproof Cover Switched Enclosure Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. HBL2421 1.60" Opening SETL3
HBL2420ST 价格&库存
很抱歉,暂时无法提供与“HBL2420ST”相匹配的价格&库存,您可以联系我们找货
