HBL25W47A
HBL25W47A
    HUBBELL(哈伯尔公司)
    HUBBELL WIRING DEVICES - HBL25W47A - STR BLADE RCPT, NEMA L5-15R, 15A, 125V
HBL25W47A 数据手册
Watertight Devices 15A, 125V, 2 Pole, 3 Wire Twist-Lock® Connector Features Smooth body design minimizes collection points simplifying the wash down process Strain relief nut always seals on the body, minimizing debris collection Stainless steel hardware and corrosion-resistant connection points Ordering Information Description Thermoplastic elastomer yellow connector Cord Diameter 0.375"-0.625" (9.5-15.9) UPC 783585131320 Catalog Number HBL25W47A Listings Listed to UL498 Certified to CSA C22.2 No. 42 Meets NEMA WD-1, WD-6 and ANSI standards UL Listed, CSA Certified to Type 4, 4X, 12, 6, 6P Specifications Body Contact Carrier Terminal Retainer Contacts Core Bushing & Cone Seal Gotcha Ring Strain Relief Nut Terminal Screws Thermoplastic Elastomer White Nylon Clear polycarbonate Nickel plated brass White Nylon Black Elastomer Nylon PBT Nickel Plated Brass Performance Electrical Current Interrupting Dielectric Voltage Max Working Voltage Temperature Rise Rated for current interruption per UL498 2500V AC As marked 30°C max per UL498 at rated current Mechanical Cord Accomodation 0.375"-0.625" (9.5-15.9) Environmental Moisture Resistance Operating temperatures UV resistance UL Listed 4, 4X, 12, 6, 6P -40°C (without impact) to +60°C continuous All exposed materials are UV stabilized Complementary Products Watertight Plug Online Resources eCatalog Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. HBL24W47A
HBL25W47A 价格&库存
很抱歉,暂时无法提供与“HBL25W47A”相匹配的价格&库存,您可以联系我们找货
