HBL2710SW
HBL2710SW
    HUBBELL(哈伯尔公司)
HBL2710SW 数据手册
Twist-Lock® Devices 30 Ampere, 125/250 and 3Ø 250 Volts AC 3 Pole, 4 Wire Grounding X G 30A 125/250V AC NEMA L10-30R UL/CSA Connector Bodies Watertight Safety-Shroud® W Cord Dia. Black Valox® housing, white Valox® clamps. Reverse service, black Valox® housing, white Valox® clamps (use with HBL2715SWR), (Not shown). .350"-1.150" (9-29) .350"-1.150" (9-29) Z 30A 125/250V AC NEMA L14-30R UL/CSA 2 (2) HP 30A 3Ø 250V AC NEMA L15-30R UL/CSA 3 HP UL Type 4x, 12 Catalog Number – HBL2713SW – HBL2713SR IP20 Description Cord Dia. Black and white nylon. .350"-1.150" (9-29) .300"-.950" (7.6-24.1) .350"-1.150" (9-29) .350"-1.150" (9-29) HBL2723SW 2.75" (69.9) – 4.38" (111.1) HBL2713SW Insulgrip® All black nylon. Y G Y IP66 SUITABILITY Description Black and white nylon, (Not shown). Corrosion resistant, yellow nylon. X SUITABILITY Catalog Number – HBL2713 HBL2663 HBL2723 – 2.33" (59.2) – – HBL27CM13 – HBL2713BK 2.21" (56.1) HBL27CM23 3.86" (98.0) HBL2713 – Note: See page B-53 for accessories. 2.91" (73.9) Receptacles Watertight Safety-Shroud® IP66 SUITABILITY Description UL Type 4x, 12 Catalog Number Gray Valox® housing and flange, back wired. – HBL2710SW HBL2720SW 3.75" (95.3) Note: See page B-54 for accessories. Safety-Shroud® Twist-Lock® IP20 Description SUITABILITY Catalog Number Valox® – – – Gray angle housing, one gang, back wired. Gray Valox® surface mounting, one gang, back wired. Gray Valox® semi-flush, two gang, back wired. HBL2710AR HBL2710SR HBL2710SR2 HBL2720AR HBL2720SR HBL2720SR2 HBL2710SW Note: See page B-54 for accessories. Single Flush Receptacles IP20 Description Catalog Number Black nylon face, back and side wired. Black nylon face, back and side wired, (Not shown). Isolated ground, orange nylon face, back and side wired. Ring terminal connection. – HBL2660 – – 1.75" (44.5) 3.75" (95.3) 3.14" (79.8) SUITABILITY HBL2710 – IG2710 HBL2720 – IG2720 HBL2710RT HBL2720RT 4.57" (116.1) Note: See page B-52 for accessories. 2.88" (73.2) Insulgrip® Flanged Receptacles Description HBL2710AR Catalog Number – Nylon casing, back wired. HBL2716 HBL2726 Note: See page B-52 for accessories. 3.06" (77.7) 1.70" (43.2) 120° 1.23" (31.2) 1.34" R. (34.0) .19" (4.8) 120° DIA. 2.67" (67.8) 1.56" 2.38" 3.28" (39.6) (60.5) (83.3) 1.71" (43.4) .77" (19.6) 4.56" (115.8) 5.12" (130.0) 2.27" (57.7) 2.23" (56.6) HBL2716 5.12" (130.0) .98" (24.9) #6-32 TAP HBL2710SR2 HBL2710 Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. www.hubbell-wiring.com 2.84" (72.1) HBL2710SR Dimensions in Inches (mm) ® Wiring Device-Kellems B-29
HBL2710SW 价格&库存
很抱歉,暂时无法提供与“HBL2710SW”相匹配的价格&库存,您可以联系我们找货
