HBL5366CA
HBL5366CA
    HUBBELL(哈伯尔公司)
HBL5366CA 数据手册
Straight Blade Devices 15 and 20 Ampere, 125 Volts 2 Pole, 3 Wire Grounding G G W IP20 SUITABILITY 1.97" (50.0) Plugs 1.53" (38.9) HBL5266C 1.22" (30.9) 2.11" (53.6) 1.53" (38.9) HBL5266CA 2.19" (55.6) 1.56" (39.6) W 15A 125V NEMA 5-15P UL CSA 20A 125V NEMA 5-20P UL CSA Insulgrip® Description Cord Diameter Catalog Number Black and white nylon. .230"-.720" (5.8-18.3) HBL5266C Blue and white nylon. .230"-.720" (5.8-18.3) HBL5266CBL Black nylon extra large cord clamp. .360"-.720" (9.1-18.3) HBL5266EBK HBL5366EBK Corrosion resistant yellow nylon. .230"-.720" (5.8-18.3) HBL52CM66C HBL53CM66C 8-position angle plug, black and white nylon. .325"-.655" (8.3-16.6) HBL5266CA HBL5366CA 8-position angle plug, transparent enclosure. .325"-.655" (8.3-16.6) HBL5266CAT – Anchor lock, black and white nylon. .230"-.720" (5.8-18.3) HBL5280C* – Anchor lock, corrosion resistant yellow nylon. .230"-.720" (5.8-18.3) HBL52CM80C* – Finger grip, black neoprene, combination screws. CSA only. .312"-.468" (7.9-11.9) HBL5921 – Fusible, black vinyl housing, slotted screws. CSA only. .296"-.625" (7.5-15.9) HBL5299 – HBL1447 HBL5366C – IP20 and IP55 Elastogrip 2.63" (66.8) 1.56" (39.6) SUITABILITY ® Description Cord Diameter Catalog Number Yellow elastomer, dust tight. .300"-.655" (7.6-16.6) HBL1447 HBL1433 Yellow elastomer, watertight. .300"-.655" (7.6-16.6) HBL14W47** HBL14W33** HBL14W47 IP20 1.88" (47.8) Description Cord Diameter Catalog Number 1.25" (31.8) Yellow nylon. .220"-.660" (5.6-16.8) HBL5965VY HBL5364VY 1.13" (28.7) Black nylon. .220"-.660" (5.6-16.8) HBL5965VBLK HBL5364VBK Gray nylon. .220"-.660" (5.6-16.8) HBL5965VGY – Orange nylon, sold in bulk pack of 50. .220"-.660" (5.6-16.8) HBL515PVO – Insulation displacement terminals, black nylon. .230"-.360" (5.8-9.1) HBL5966VBLK – Insulation displacement terminals, yellow nylon. .230"-.360" (5.8-9.1) HBL5966VY – HBL5965VY 1.17" (29.7) 1.60" (40.6) HBL5966VBLK SUITABILITY Valise® 1.24" (31.5) Note: *UL Component Listed only. Not for general use applications. **Watertight plugs IP55 suitability when installed and used properly with mating Elastogrip watertight connector bodies. Horsepower ratings listed are AC only. See page A-47 for accessories. Dimensions in Inches (mm) A-30 ® Wiring Device-Kellems www.hubbell-wiring.com
HBL5366CA
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种通用的晶体管输出型光耦器件,具有较高的输入输出隔离电压。
3. 引脚分配:共有6个引脚,分别为1脚为阳极,2脚为阴极,3脚为集电极,4脚为发射极,5脚为输出晶体管的集电极,6脚为输出晶体管的发射极。
4. 参数特性:输入电流范围为5-50mA,输出晶体管的低电平输出电流为10mA,高电平输出电流为15mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,常用于开关电源、信号隔离等应用。
6. 应用信息:适用于需要电气隔离的场合,如开关电源、信号隔离、工业控制等。
7. 封装信息:采用DIP6封装形式,尺寸为9.1x9.1mm。
HBL5366CA 价格&库存
很抱歉,暂时无法提供与“HBL5366CA”相匹配的价格&库存,您可以联系我们找货
