HBL5369C
HBL5369C
    HUBBELL(哈伯尔公司)
HBL5369C 数据手册
Straight Blade Devices Straight Blade Devices 2 Pole, 3 Wire Grounding 15 and 20 Ampere, 125 Volts INSULGRIP® Connector Bodies F S IP20 G G SUITABILITY W W Fed.Spec. Insulgrip Connector Bodies Description Black and white nylon. Corrosion resistant yellow nylon. Cord Dia. .230”-.720” (5.8-18.3) .230”-.720” (5.8-18.3) Catalog Numbers HBL5269C™ HBL5369C™ HBL52CM69C HBL53CM69C Insulgrip Hospital Grade Connector Bodies 2.78" (70.6) 1.41" (35.8) 1.53" (38.9) NEMA 5-20R 20A 125V UL CSA NEMA 5-15R 15A 125V UL CSA Description Black and white nylon. Transparent housing. HBL8219C Cord Dia. .230”-.720” (5.8-18.3) .230”-.720” (5.8-18.3) Catalog Numbers HBL8219C™ HBL8319C HBL8219CT HBL8319CT Accessories 2P 3W, 15A & 20A, 125V INSULGRIP® Connector Bodies Seat-Tite® triple seal black elastomer cover for Insulgrip® connector bodies when used in a cord set. Same as above except yellow. Closure plug, black. Closure plug, yellow. PLUGOUT® lockout device for Hubbell plugs and others. HBL6018* HBL60CM18* HBL6019 HBL60CM19 HLD Notes: *IP55 suitability if closure plug inserted or when installed and used properly with HBL6017 or HBL60CM17. A-16 www.hubbell-wiring.com Dimensions in Inches (mm) 2 Pole, 3 Wire Grounding 15 and 20 Ampere, 250 Volts Connector Bodies and Flanged Receptacles F IP20 S 2.78" (70.6) SUITABILITY Fed.Spec. NEMA 6-15R 15A 250V UL CSA Connector Bodies Description Insulgrip® connector body, black and white nylon, multiple drive screws. ERGO™ Grip connector body, overmolded yellow nylon. Valise® connector body, yellow nylon. G G NEMA 6-20R 20A 250V UL Listed 1.53" (38.9) 1.41" (35.8) Cord Dia. .230”-.720” (5.8-18.3) Catalog Numbers HBL5669C HBL5469C HBL5669C .220”-.600” (5.6-15.25) .220”-.660” (5.6-16.8) HBL5567EY HBL5579EY 2.65" (67.3) HBL5669VY HBL5469VY 1.40" (35.6) ERGO™ Grip Hospital Grade Connector Bodies Description Overmolded white nylon. Cord Dia. .300”-.600” (7.6-15.25) Catalog Numbers HBL8567E HBL8579E HBL5567EY 2.63" (66.88) Valise® Hospital Grade Connector Body Cord Dia. .300”-.660” (7.6-16.8) Catalog Number – HBL8469V 1.50" (38.1) 1.13" (28.7) HBL5669VY 2.56" (65.0) G G NEMA 6-20R 20A 250V UL Listed Flanged Receptacles NEMA 6-15R 15A 250V UL CSA Description Catalog Numbers Nylon casing, multiple drive screws. Stainless steel flange, brown phenolic housing (mounting screws packaged separately). HBL5679C HBL5656 2.19" (55.63) .16" (4.1) Dia. 1.72" (43.7) 1.72" (43.7) HBL5679C HBL5479C – .20" Dia. (5.1) 1.47" (37.3) 2.06" (52.3) 1.09" (27.7) HBL5656 Dimensions in Inches (mm) www.hubbell-wiring.com A-27 2P 3W, 15A & 20A, 250V Connectors and Flanged Receptacles Description White nylon. Straight Blade Devices Straight Blade Devices
HBL5369C 价格&库存
很抱歉,暂时无法提供与“HBL5369C”相匹配的价格&库存,您可以联系我们找货
