HBL7468
HBL7468
    HUBBELL(哈伯尔公司)
    HBL7468
HBL7468 数据手册
Product Datasheet HBL7468 -- Twist-Lock Receptacle 2P2W, 15A 125V, ML-1R, Stainless Flange Product Specifications Product Type Product Item Flanged Receptacle Wiring Scheme 2-Pole, 2-Wire Non-Grounding Amperage 15A Voltage 125V AC NEMA Configuration ML-1R Item Style Standard Device Color Black Terminal Screw Material Brass Body Contact Carrier Material Black Thermoset Contact Spring Material .032" (.8) Bronze Flanged Casing Material .025" Stainless Steel Mounting Screw Material Brass, Nickel plated Ground Contact Material .032" Bronze Ratings Molded In or Stamped On Catalog No Permanently ink marked on product Dielectric Voltage Withstand 2,000V minimum Current Interrupting Certified for current interrupting at full rated current Temperature Rise Max 30C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of .75. Terminal Accommodation 15A #14 AWG Terminal Identification Terminals identified in accordance with UL 498 (X, Y, Z, White, Green) Flammability UL 94 VO for Receptacles and Inlets. HB or better for Plugs and Connectors. Operating Temperatures Maximum Continuous 75 C Minimum -40 C (w/o impact) UPC Number 783585237336 Weight in LBs 0.05 Link to Drawing Library Click here for Library Link to PDF Catalog Click here for Catalog NEMA Configuration
HBL7468
- 物料型号: HBL7468 - 器件简介: 2P2W, 15A 125V, ML-1R, Stainless Flange,代表这是一个具有两个极点和两个线圈的15安培125伏交流电的带法兰的插孔。 - 引脚分配: 2-Pole, 2-Wire Non-Grounding,意味着它是一个两极两线无接地的接线方案。 - 参数特性: - 额定电流: 15A - 额定电压: 125V AC - NEMA配置: ML-1R - 绝缘电压耐受: 至少2000V - 电流中断能力: 在额定电流下通过认证 - 温升: 在额定电流下,经过150%的过载50个周期后,最大温升为30°C - 端子容纳: 15A #14 AWG - 端子标识: 符合UL 498标准的标识 - 耐燃性: 插孔和插座为UL 94 VO级,插头和连接器为HB级或更高 - 功能详解: 该产品为标准款式,设备颜色为黑色,端子螺丝材料为黄铜,接触材料为黑色热固性材料,接触弹簧材料为0.032英寸青铜,法兰材料为0.025英寸不锈钢,安装螺丝材料为镀镍黄铜,接地接触材料为0.032英寸青铜。 - 应用信息: 操作温度范围为-40°C至75°C(无影响),UPC编号为783585237336,产品重量为0.05磅。 - 封装信息: 产品类型为Twist-Lock,产品项目为带法兰的插孔。
HBL7468 价格&库存
很抱歉,暂时无法提供与“HBL7468”相匹配的价格&库存,您可以联系我们找货
