HBL7484
HBL7484
    HUBBELL(哈伯尔公司)
    HBL7484
HBL7484 数据手册
Product Datasheet HBL7484 -- Twist-Lock Connector Body 3P3W, 15A 125/250V, ML-3R, Nylon Body, Phenolic Base, Black Product Specifications Product Type Product Item Connector Body Wiring Scheme 3-Pole, 3-Wire Non-Grounding Amperage 15A Voltage 125/250V AC NEMA Configuration ML-3R Item Style Standard Device Color Black Cord Dia. .281-.421" (7.1-10.7) Housing Material Phenolic Cord Clamp Material Metallic Cord Clamp Screw Material Steel - black oxide Body Holding Screw Material Steel, zinc plated Body Contact Carrier Material Black Thermoset Contact Spring Material .031" Brass Ground Contact Material .031" (.8) Brass Ratings Molded In or Stamped On Catalog No Permanently ink marked on product Dielectric Voltage Withstand 2,000V minimum Current Interrupting Certified for current interrupting at full rated current Temperature Rise Max 30C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of .75. Cord Accommodation Round portable service cords of diameters commensurate with the device rating as defined in UL Standard 62, CSA C22.2 No. 49. Terminal Accommodation 15A #14 AWG Terminal Identification Terminals identified in accordance with UL 498 (X, Y, Z, White, Green) Flammability UL 94 VO for Receptacles and Inlets. HB or better for Plugs and Connectors. Operating Temperatures Maximum Continuous 75 C Minimum -40 C (w/o impact) Moisture Resistance IP20 Listings UL UPC Number 783585237381 Weight in LBs 0.05 Link to Drawing Library Click here for Library Link to PDF Catalog Click here for Catalog NEMA Configuration
HBL7484 价格&库存
很抱歉,暂时无法提供与“HBL7484”相匹配的价格&库存,您可以联系我们找货
