HBL7485
HBL7485
    HUBBELL(哈伯尔公司)
    HBL7485
HBL7485 数据手册
Twist-Lock® Devices Midget Twist-Lock® Accessories Weatherproof Accessories HBL7490V Description Catalog Number Seal-tite® cover, black elastomer, for use with a HBL7465V plug when used with a HBL7464V connector body or a HBL7464V connector when used with a flanged inlet. HBL7490V* Seal-tite® cover, black elastomer, for use with a HBL7464V connector body and combination of HBL7465V plug and HBL7490V cover. HBL7459V* Closure cover for use with HBL7466 or HBL7467. Bead chain is nickel-plated. HBL4890 Weatherproof Accessories HBL7459V Description Catalog Number Seal-Tite® cover, black elastomer, for use with a HBL7594V plug when used with a HBL7593V connector body or a HBL7593V connector body when used with a flanged inlet. HBL7495V* Seal-Tite® cover, black elastomer, for use with a HBL7593V connector body and a combination of HBL7594V plug and HBL7495V cover. HBL7440V* Closure cover for use with HBL7595 or HBL7595N. HBL4889 Weatherproof Accessories HBL4890 Description Catalog Number Seal-Tite® cover, black elastomer, for use with a HBL7485V or HBL7485 plug when used with a HBL7484V or HBL7484 connector body when used with a flanged inlet. HBL7495V* Seal-Tite® cover, black elastomer, for use with a HBL7484V or HBL7484 connector body and a combination of HBL7485V or HBL7485 plug and HBL7495V cover. HBL7440V* Closure cover for use with HBL7486 or HBL7486N. HBL4889 Note: *IP55 suitability when installed and used properly with plug and connector body combinations. HBL7495V HBL7440V HBL4889 Dimensions in Inches (mm) B-6 ® Wiring Device-Kellems www.hubbell-wiring.com
HBL7485
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-20℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有抗干扰能力强,响应速度快等特点。
6. 应用信息:广泛应用于工业控制、仪器仪表、医疗设备等领域。
7. 封装信息:采用DIP6封装形式。
HBL7485 价格&库存
很抱歉,暂时无法提供与“HBL7485”相匹配的价格&库存,您可以联系我们找货
