HBL61CM64
HBL61CM64
    HUBBELL(哈伯尔公司)
    HBL61CM64
HBL61CM64 数据手册
Marine Products 15 Ampere, 125 Volt AC Straight Blade Devices 2 Pole, 3 Wire 15A 125V NEMA 5-15R UL/CSA 15A 125V AC Straight Blade Devices Description Catalog Number Yellow corrosion resistant/weather resistant duplex receptacle. Use outdoors or where salt and other corrosive materials are a problem. Accepts 15A 125V, 2 pole 3 wire straight blade plugs. IP20 SUITABILITY. HBL52CM62 Same as HBL52CM62 except ivory. HBL52CM62I Single version of HBL52CM62 duplex yellow receptacle. IP20 SUITABILITY. HBL52CM61 Yellow Insulgrip® plug has rugged nylon housing and detachable cord grip with range of .23–.72 in. (5.8–18.3) that utilizes a unique offset jaws arrangement for secure strain relief. IP20 suitability. HBL52CM66C Yellow Seal-Tite® cover for weatherproofing straight blade Insulgrip plugs, HBL52CM66C and HBL53CM66C, when used with receptacles and connector bodies. Can also be used to weatherproof Insulgrip connector bodies when mating with flanged inlets. IP44 SUITABILITY. Not UL or CSA. Note: For Insulgrip® devices only. HBL60CM17+ Yellow Insulgrip connector body has rugged nylon housing and detachable cord grip with range of .23–.72 in. (5.8–18.3) that utilizes a unique offset jaws arrangement for secure strain relief. IP20 suitability. HBL52CM69C Yellow Seal-Tite® cover for weatherproofing straight blade Insulgrip connector bodies, HBL52CM69C and HBL53CM69C, on extension cords and adapters. IP55 SUITABILITY. Not UL or CSA. Note: For Insulgrip devices only. HBL60CM18+ Yellow Valise® plug has one-piece nylon housing that assembles easily with two screws. Built-in cord grip has range of .22–.66 in. (5.6–16.8). IP20 suitability. HBL52CM66V Yellow Valise® connector body has one-piece nylon housing that assembles easily with two screws. Built-in cord grip has range of .22–.66 in. (5.6–16.8). IP20 suitability. HBL52CM69V Yellow Insulgrip® plug with anchor locking screw to prevent accidental pull-out. The plug is “locked” into the receptacle when the screw is turned down so the head is flush with the plug surface. The cord grip range is .30–.69 in. (7.5–17.4). UL Recognized Component. IP20 suitability. HBL52CM80C Compact gray nylon panel mount inlet ideal for bass boat battery charging connection. Has gasketed spring-loaded lift cover for weatherproofing front and neoprene boot for weatherproofing rear. Will accept both 15A 125V and 20A 125V, 2 pole 3 wire straight blade connector bodies. IP44 suitability. HBL61CM64 Same as HBL61CM64 except black in color. HBL61CM64BK Yellow Valox® spring-loaded lift cover for weatherproofing duplex receptacles. Stainless steel screws and neoprene gasket included for mounting to FS/FD type weatherproof boxes. IP20 suitability. HBL52CM21 Same as HBL52CM21 except gray in color. HBL5221 Same as HBL52CM21 except for mounting to standard boxes. HBL52CM22 Same as HBL52CM22 except gray in color. HBL5222 Yellow Valox spring-loaded lift cover for weatherproofing single straight blade receptacles. Stainless steel screws and neoprene gasket included. For mounting to FS/FD type weatherproof boxes. IP44 SUITABILITY. HBL74CM23WO Same as HBL74CM23WO except gray in color. HBL7423WO HBL52CM62 HBL52CM66C Note: +Boots are not UL Listed. See page Tech-10 for Weather Resistant descriptions. HBL74CM23WO Rynite® is a registered trademark of E. I. DuPont. Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. www.hubbell-wiring.com HBL52CM61 ® Wiring Device-Kellems HBL52CM69C HBL52CM80C HBL52CM66V HBL52CM69V HBL61CM64 Y-35
HBL61CM64 价格&库存
很抱歉,暂时无法提供与“HBL61CM64”相匹配的价格&库存,您可以联系我们找货
