HBL7595N
HBL7595N
    HUBBELL(哈伯尔公司)
HBL7595N 数据手册
Midget Twist-Lock® Devices 15A, 125V AC, 2 Pole, 3 Wire Grounding Flanged Inlet Features Fully Insulated nylon casing with integral flange Black color blends in with equipment Ordering Information Description Black nylon flanged inlet. Terminals Exposed UPC 783585237800 Catalog Number HBL7595N Listings Listed to UL 498 Certified to CSA C22.2 No.42 Specifications Flange Base Blades Terminal Screws Nylon Nylon Bronze #5-40 Brass Performance Electrical Current Interrupting Dielectric Voltage Certified for current interrupting at full rated current Withstands 2,000V minimum Mechanical Terminal Accommodation #18 AWG - #14 AWG solid or stranded copper wire only. Terminal Identification Terminals identified in accordance with UL 498 Environmental Flammability Moisture Resistance Operating Temperatures HB or better per UL94/CSA 22.2 No.0.17 IP20 Suitability Maximum Continuous 75°C; Minimum -40°C (w/o impact) Accessories Valise® Connector Connector Angled Connector Resources Customer Use Drawing eCatalog Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. HBL7593V HBL77593 HBL7571
HBL7595N 价格&库存
很抱歉,暂时无法提供与“HBL7595N”相匹配的价格&库存,您可以联系我们找货
