HBL9462C
HBL9462C
    HUBBELL(哈伯尔公司)
HBL9462C 数据手册
Straight Blade Devices Straight Blade Devices 60 Ampere, 125/250 Volts, 3Ø 250 and 120/208 Volts AC 3 Pole, 4 Wire Grounding and 4 Pole, 4 Wire Non-Grounding Single Receptacles and Plugs G G 60A, 125/250V 3 Pole, 4 Wire Grounding Receptacles and Plugs Z IP20 X X W 60A 125/250V NEMA 14-60R UL CSA 3(2) HP 60A 125/250V NEMA 14-60P UL CSA 3(2) HP SUITABILITY Description Cord Diameter Catalog Numbers Receptacle, black RTP. Plug, nylon. – .625"-1.310" (15.9-33.3) .625"-1.310" (15.9-33.3) HBL9460A – Plug, nylon, angle, 4-position. Z W – – HBL9461C Description Receptacle, black RTP. Plug, nylon. HBL9461C IP20 X Y 60A 3Ø 250V AC NEMA 15-60P UL CSA 10 HP Catalog Numbers HBL8460A – – HBL8461C – Receptacle, black RTP. Plug, nylon. Plug, nylon, angle, 4-position. – .625"-1.310" (15.9-33.3) .625"-1.310" (15.9-33.3) 2.38" (60.5) W Z X X 2.75" (69.9) Z Y Y 60A 3ØY 120/208V AC NEMA 18-60R UL Listed 7.5 HP 60A 3ØY 120/208V AC NEMA 18-60P UL Listed 7.5 HP SUITABILITY Cord Diameter 4.5" (114.3) HBL8462C W Description 3.38" (85.8) HBL9462C IP20 60A, 3ØY 120/208V AC 4 Pole, 4 Wire Non-Grounding Receptacles and Plugs Z Y 60A 3Ø 250V AC NEMA 15-60R UL CSA 10 HP SUITABILITY Cord Diameter – .625"-1.310" (15.9-33.3) .625"-1.310" (15.9-33.3) G X Z #6-32 TAP 3.28" (83.3) 2.37" (60.3) Catalog Numbers HBL7301A – – – HBL7303C 1.81" (46.0) 1.81" (46.0) 2.44" (61.9) HBL7302C HBL7301A Note: See page A-47 for accessories. RTP is an abbreviation for reinforced thermoplastic polyester. Dimensions in Inches (mm) www.hubbell-wiring.com A-41 60 Ampere, 125/250 Volts, 3Ø 250 and 120/208 Volts AC Plug, nylon, angle, 4-position. 4.13" (104.9) HBL9462C G 60A, 3Ø 250V AC 3 Pole, 4 Wire Grounding Receptacles and Plugs 2.88" (73.2)
HBL9462C 价格&库存
很抱歉,暂时无法提供与“HBL9462C”相匹配的价格&库存,您可以联系我们找货
