CS6365C
CS6365C
    HUBBELL(哈伯尔公司)
CS6365C 数据手册
Twist-Lock® Devices 50A, 125/250V AC, 3 Pole, 4 Wire Grounding Insulgrip® Plug Features Tough nylon housing offers better impact qualities Stainless steel shroud restricts mismating with the wrong device Heavy duty two-piece external cord clamp provides maximum strain relief Box terminal with hex socket threaded slug, permits high clamping pressure on conductors without damaging strands Thermoplastic polyester interior provides heat resistance and impact strength Ordering Information Description Nylon cover, thermoplastic polyester interior Cord Diameter .830"-1.250" (21.08-31.75) UPC 783585827995 Catalog Number CS6365C Listings Listed to UL 498 Certified to CSA C22.2 No.42 Specifications Housing Blade Holder Blades Shell Terminal Screws Cord Grip Nylon Polyester Brass Stainless Steel Stainless steel Polyester Performance Electrical Current Interrupting Dielectric Voltage Certified for current interrupting at full rated current Withstands 2,000V minimum Mechanical Terminal Accommodation #10 AWG - #6 AWG stranded copper wire only Environmental Flammability Operating Temperatures HB or better Maximum continuous 75°C; minimum –40°C (w/o impact) Accessories Connector Single Receptacle Weatherproof Boot Resources Customer Use Drawing eCatalog Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. CS6364C CS6369 HBL7716C
CS6365C 价格&库存
很抱歉,暂时无法提供与“CS6365C”相匹配的价格&库存,您可以联系我们找货
