H320P
H320P
    HUBBELL(哈伯尔公司)
H320P 数据手册
Straight Blade Devices 16 Ampere, 250 Volts AC International 2 Pole, 3 Wire Grounding 1.55" (39.4) 1.41" (35.8) 1.52" (38.6) 1.89" (48.0) Receptacle IEC 320 Compatible Description Catalog Number 20/16A 250V AC IEC straight blade. H320R For Ring Terminal connection. H320RRT* Note: *Not UL Listed. H320R 1.42" (36.1) 1.95" (49.5) 1.36" (34.5) .787" min. (20) min. IP20 SUITABILITY Connector Description Catalog Number 20/16A 250V AC IEC straight blade. H320C H320C 1.52" (38.6) 1.95" (49.5) IP20 1.36" (34.5) .797" (20) Plug IEC 320 Compatible SUITABILITY Description Catalog Number 20/16A 250V AC IEC straight blade. H320P H320P .22" (5.6) 1.47" (37.3) 1.19" (30.2) 1.28" (32.5) 1.64" (41.7) Inlets Description Catalog Number 20/16A 250V AC IEC straight blade. H320B 20/16A 250V AC IEC straight blade with retention clamp. H320BL Note: See page A-63 for technical information. H320B 1.28" (32.5) 1.47" 1.19" (37.3) (30.2) .22" (5.6) 1.64" (41.7) H320BL Dimensions in Inches (mm) A-36 ® Wiring Device-Kellems www.hubbell-wiring.com
H320P 价格&库存
很抱歉,暂时无法提供与“H320P”相匹配的价格&库存,您可以联系我们找货
