HBL2513
HBL2513
    HUBBELL(哈伯尔公司)
    HBL2513
HBL2513 数据手册
HUBBELL WIRING SYSTEMS Entertainment Industry Products Insulgrip® Straight Blade and Twist-Lock® Devices  From the Company that Invented Twist-Lock® Devices  All Black Devices Exclusively for the Entertainment Industry  Industry Best Strain Relief  Encased in Tough Nylon, Insulgrip® Devices Ensure High Impact, Heat and Chemical Resistance FEATURES      Dual, maximum strength cord grip Super tough nylon construction Integral dust shield Funneled entry terminations Visible product identification on device SPECIFICATIONS     Certified for current interrupting at full rated current Cord Range: – 15A: .220" to .660" (5.6mm to 16.8mm) – 20A: .325" to .720" (8.26mm to 18.3mm) – 30A: .590" to .930" (15.0mm to 23.6mm) Environmental Rating: V2 or better Operating Temperature: -40°C to 75°C STANDARDS/LISTINGS/VERIFICATIONS   UL Listed CSA Certified APPLICATIONS       Stage/studio power Portable power distribution Lighting "On-location" filming Carnivals Theme parks The unparalleled acceptance and success of the Twist‑Lock® line is a tribute to the quality of this long lasting design. When selecting premium plugs and connectors for the Entertainment Industry, the decision is Hubbell. Hubbell Insulgrip® plugs and connectors continue our long-standing tradition of leadership as well as innovative design. The tough nylon body provides impact and chemical resistance commonly needed in the Entertainment Industry. The durable and powerful offsetting cord grip clamps on individual conductors and outer cord jackets prevent strain on the terminals. It’s these and many other features that set Hubbell performance above all others. Since 1929, when Harvey Hubbell obtained the first patents on Twist-Lock devices and introduced them to the market, they have been the standard for the Entertainment Industry. Today, Hubbell Insulgrip Twist‑Lock Devices continue to set the standard against which all quality industrial wiring devices are measured. The Insulgrip line includes plugs, connectors, flanged inlets and outlets and flush mounting receptacles. With a single piece dust shield, tough nylon housing, visible identification and a roomy wiring chamber, these devices offer the most powerful cord grip in the industry. www.hubbell-wiring.com HUBBELL WIRING SYSTEMS Entertainment Industry Products Straight Blade Devices Heavy Duty Plug Insulgrip Poles Wires Amps 15 2 NEMA AC HP Code# Rating† L5-15 0.5 HBL5266C L5-15 0.5 L5-20 1 HBL5366C* L5-20 1 Volts 125 125 125 125 3 20 HBL5266CM2 HBL5266EBK HBL5366CM2 HBL5366EBK 8-Position Angle Plug Insulgrip Connector Body Insulgrip HBL5269C HBL5369C HBL5269CM2 HBL5269EBK HBL5369CM2 HBL5369EBK Inlet Flange Outlet Flange HBL5266CA HBL5278C HBL5279C HBL5366CA HBL5378C HBL5379C Twist-Lock Devices Plug Insulgrip Poles Wires Amps 15 20 2 3 30 20 3 4 30 20 4 5 30 NEMA AC HP Code# Rating† L5-15 0.5 L6-15 1.5 L7-15 2 L5-20 1 L5-20 1 L6-20 2 L6-20 2 L7-20 2 L8-20 3 L9-20 L5-30 2 L6-30 2 L7-30 3 L8-30 5 L9-30 L14-20 2 (1) L15-20 3 L16-20 5 L14-30 2 L15-30 3 L16-30 10 L17-30 L21-20 2 L22-20 5 L23-20 L21-30 3 L22-30 10 L23-30 Volts 125 250 277AC 125 125 250 250 277AC 480AC 600AC 125 250 277AC 480AC 600AC 125/250 3Ø250AC 3Ø480AC 125/250 3Ø250AC 3Ø480AC 3Ø600AC 3ØY120/208AC 3ØY277/480AC 3ØY347/600AC 3ØY120/208AC 3ØY277/480AC 3ØY347/600AC Connector Body Insulgrip HBL4720C HBL4720CBK HBL4729C HBL4570C HBL4579C HBL4770C HBL4779C HBL2311 HBL2311BK HBL2313 HBL2311EBK HBL2321 HBL2321BK HBL2323 HBL2321EBK HBL2331 HBL2333 HBL2341 HBL2343 HBL2351 HBL2353 HBL2611 HBL2611BK HBL2613 HBL2621 HBL2621BK HBL2623 HBL2631 HBL2633 HBL2641 HBL2643 HBL2651 HBL2653 HBL2411 HBL2411BK HBL2413 HBL2421 HBL2423 HBL2431 HBL2433 HBL2711 HBL2711BK HBL2713 HBL2721 HBL2723 HBL2731 HBL2733 HBL2741 HBL2743 HBL2511 HBL2511BK HBL2513 HBL2521 HBL2523 HBL2531 HBL2533 HBL2811 HBL2811BK HBL2813 HBL2821 HBL2823 HBL2831 HBL2833 Inlet Flange HBL4729CBK HBL4716C HBL4586C HBL4786C HBL2313BK HBL2315 HBL2313EBK HBL2323BK HBL2325 HBL2323EBK HBL2335 HBL2345 HBL2355 HBL2613BK HBL2615 HBL2623BK HBL2625 HBL2635 HBL2645 HBL2655 HBL2413BK HBL2415 HBL2425 HBL2435 HBL2713BK HBL2715 HBL2725 HBL2735 HBL2745 HBL2513BK HBL2515 HBL2525 HBL2535 HBL2813BK HBL2815 HBL2825 HBL2835 Outlet Flange Receptacle Single HBL4715C HBL4585C HBL4785C HBL2316 HBL4710 HBL4560 HBL4760 HBL2310 HBL2326 HBL2320 HBL2336 HBL2346 HBL2356 HBL2616 HBL2626 HBL2636 HBL2646 HBL2656 HBL2416 HBL2426 HBL2436 HBL2716 HBL2726 HBL2736 HBL2746 HBL2516 HBL2526 HBL2536 HBL2816 HBL2826 HBL2836 HBL2330 HBL2340 HBL2350 HBL2610 HBL2620 HBL2630 HBL2640 HBL2650 HBL2410 HBL2420 HBL2430 HBL2710 HBL2720 HBL2730 HBL2740 HBL2510 HBL2511FC HBL2513FC HBL2520 HBL2530 HBL2810 HBL2811FC HBL2813FC HBL2820 HBL2830 Flat Cable Cord Clamp Plug Connector Midget Twist Lock Plug Poles Wires Amps Volts Plug Insulation Displacement Connector Connector Insulation Displacement Nylon Inlet Stainless Steel Inlet Stainless Steel Nylon Outlet Outlet NEMA Code# 2 2 15 125 ML-1 HBL7465V 2 3 15 125 ML-2 HBL7494 HBL7494V HBL7464V HBL7593 HBL7593V HBL7595N HBL7467 HBL7595 HBL7596N HBL7468 HBL7596 3 3 15 125/250 ML-3 HBL7485 HBL7485V HBL7484 HBL7484V HBL7486N HBL7486 HBL7487N HBL7487 †The horsepower ratings are the phase values. The values in parentheses are phase to neutral. Horsepower ratings are applicable to plugs and receptacles only and do not apply to connectors, flanged inlets and outlets. Component. * ® Wiring Systems www.hubbell-wiring.com Hubbell Wiring Systems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 • Phone (800) 288-6000 • FAX (800) 255-1031 Printed in U.S.A. Specifications subject to change without notice. SNAPConnect® is a registered trademarks of Hubbell Incorporated. Hubbell-PRO™ is a trademark of Hubbell. WLDSBL001E 8/12
HBL2513 价格&库存
很抱歉,暂时无法提供与“HBL2513”相匹配的价格&库存,您可以联系我们找货
